SD Card with NRF54L15DK and 3.1.0 SDK and toolchain
I send a ticket because I have an issue to access and write files to a SD Card with NRF54L15DK and 3.1.0 SDK and toolchain.
Can you help me please ?
Here is my configuration files :
main.c
 * Copyright (c) 2019 Tavish Naruka <[email protected]>
 * Copyright (c) 2023 Nordic Semiconductor ASA
 * Copyright (c) 2023 Antmicro <www.antmicro.com>
/* Sample which uses the filesystem API and SDHC driver */
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/storage/disk_access.h>
#include <zephyr/fs/fs.h>
#if defined(CONFIG_FAT_FILESYSTEM_ELM)
#include <ff.h>
PARTITION VolToPart[] = {
    {0, 1},  /* SD1 -> partition 1 */
    {0, 2},  /* SD2 -> partition 2 */
 *  Note the fatfs library is able to mount only strings inside _VOLUME_STRS
 *  in ffconf.h
#if defined(CONFIG_DISK_DRIVER_MMC)
#define DISK_DRIVE_NAME "SDHC0"
#else
#define DISK_MOUNT_PT "/"DISK_DRIVE_NAME":"
#define DISK_MOUNT_PTSD1 "/SD"
#define DISK_MOUNT_PTSD2 "/SD1"
#define MAX_PARTS  2  /* jusqu’à 4 partitions possibles */
/* Un FATFS par partition */
static FATFS fat_fs[MAX_PARTS];
static struct fs_mount_t mp[MAX_PARTS];
static const char *disk_names[MAX_PARTS] = {
    "SD", "SD1"
static const char *mount_points[MAX_PARTS] = {
    "/SD", "/SD1"
// static FATFS fat_fs;
// /* mounting info */
// static struct fs_mount_t mp = {
//  .type = FS_FATFS,
//  .fs_data = &fat_fs,
#elif defined(CONFIG_FILE_SYSTEM_EXT2)
#include <zephyr/fs/ext2.h>
#define DISK_MOUNT_PT "/ext"
    .type = FS_EXT2,
    .flags = FS_MOUNT_FLAG_NO_FORMAT,
    .storage_dev = (void *)DISK_DRIVE_NAME,
    .mnt_point = "/ext",
#define FS_RET_OK FR_OK
#else
#define FS_RET_OK 0
LOG_MODULE_REGISTER(main);
// #define MAX_PATH 128
// #define SOME_FILE_NAME "some.dat"
// #define SOME_DIR_NAME "some"
// #define SOME_REQUIRED_LEN MAX(sizeof(SOME_FILE_NAME), sizeof(SOME_DIR_NAME))
static int lsdir(const char *path);
// #ifdef CONFIG_FS_SAMPLE_CREATE_SOME_ENTRIES
// static bool create_some_entries(const char *base_path)
//  char path[MAX_PATH];
//  struct fs_file_t file;
//  int base = strlen(base_path);
//  fs_file_t_init(&file);
//  if (base >= (sizeof(path) - SOME_REQUIRED_LEN)) {
//      LOG_ERR("Not enough concatenation buffer to create file paths");
//      return false;
//  LOG_INF("Creating some dir entries in %s", base_path);
//  strncpy(path, base_path, sizeof(path));
//  path[base++] = '/';
//  path[base] = 0;
//  strcat(&path[base], SOME_FILE_NAME);
//  if (fs_open(&file, path, FS_O_CREATE) != 0) {
//      LOG_ERR("Failed to create file %s", path);
//      return false;
//  fs_close(&file);
//  path[base] = 0;
//  strcat(&path[base], SOME_DIR_NAME);
//  if (fs_mkdir(path) != 0) {
//      LOG_ERR("Failed to create dir %s", path);
//      /* If code gets here, it has at least successes to create the
//       * file so allow function to return true.
//  return true;
// #endif
static const char *disk_mount_pt = DISK_MOUNT_PT;
static const char *disk_mount_ptSD1 = DISK_MOUNT_PTSD1;
static const char *disk_mount_ptSD2 = DISK_MOUNT_PTSD2;
void mount_all_partitions(void)
    for (int i = 0; i < MAX_PARTS; i++) {
        mp[i].type = FS_FATFS;
        mp[i].fs_data = &fat_fs[i];
        if (i == 0) {
            mp[i].mnt_point = disk_mount_ptSD1;
        if (i == 1) {
            mp[i].mnt_point = disk_mount_ptSD2;
        if (i == 0) {
            mp[i].storage_dev = (void *)"SD";
        if (i == 1) {
            mp[i].storage_dev = (void *)"SD1";
        int res = fs_mount(&mp[i]);
        if (res == FR_OK) {
            printk("Partition %s montée sur %s\n", disk_names[i], mount_points[i]);
        } else {
            printk("Partition %s non montée (code %d)\n", disk_names[i], res);
void UNmount_all_partitions(void)
        mp[i].mnt_point = mount_points[i];
        mp[i].storage_dev = (void *)disk_names[i];
        int res = fs_unmount(&mp[i]);
        if (res == FR_OK) {
            printk("Partition %s demontée sur %s\n", disk_names[i], mount_points[i]);
        } else {
            printk("Partition %s non demontée (code %d)\n", disk_names[i], res);
static void write_to_sd()
    char file_path[64];
    int ret;
    /* Construire le chemin du fichier */
strcpy(file_path, "/SD/test.txt");
    /* Ouvrir (ou créer) le fichier en écriture */
    ret = fs_open(&file, file_path, FS_O_CREATE | FS_O_WRITE);
    if (ret) {
        LOG_ERR("Erreur d'ouverture du fichier (%d)", ret);
        return;
    /* Données à écrire */
    const char msg[] = "Hello SD card from nRF54L15!\n";
    /* Écriture */
    ret = fs_write(&file, msg, sizeof(msg) - 1);
    if (ret < 0) {
        LOG_ERR("Erreur d'écriture (%d)", ret);
        fs_close(&file);
        return;
    LOG_INF("Écrit %d octets dans %s", ret, file_path);
    /* Fermer le fichier */
    fs_close(&file);
    /* Lire pour vérifier */
    ret = fs_open(&file, file_path, FS_O_READ);
    if (ret) {
        LOG_ERR("Erreur de réouverture du fichier (%d)", ret);
        return;
    char buf[64];
    int n = fs_read(&file, buf, sizeof(buf) - 1);
    if (n >= 0) {
        buf[n] = '\0';
        LOG_INF("Contenu lu : %s", buf);
    } else {
        LOG_ERR("Erreur de lecture (%d)", n);
    fs_close(&file);
strcpy(file_path, "/SD1/test.txt");
    if (ret) {
        return;
    const char msg2[] = "Hello SD card from nRF54L15!\n";
    /* Écriture */
    ret = fs_write(&file, msg2, sizeof(msg2) - 1);
    if (ret < 0) {
        fs_close(&file);
        return;
    fs_close(&file);
    if (ret) {
        return;
    if (n >= 0) {
        buf[n] = '\0';
    } else {
    fs_close(&file);
/* Petit utilitaire pour inspecter le MBR et afficher les partitions trouvées */
static void print_mbr_info(void)
    uint8_t mbr[512];
    if (disk_access_read("SD", mbr, 0, 1) != 0) {
        printk("Impossible de lire le MBR (disk_access_read)\n");
        return;
    printk("MBR signature: 0x%02x%02x\n", mbr[510], mbr[511]);
    for (int i = 0; i < 4; i++) {
        uint8_t part_type = mbr[446 + i*16 + 4];
        uint32_t start_lba = mbr[446 + i*16 + 8] |
                             (mbr[446 + i*16 + 9] << 8) |
                             (mbr[446 + i*16 + 10] << 16) |
                             (mbr[446 + i*16 + 11] << 24);
        uint32_t num_sectors = mbr[446 + i*16 + 12] |
                               (mbr[446 + i*16 + 13] << 8) |
                               (mbr[446 + i*16 + 14] << 16) |
                               (mbr[446 + i*16 + 15] << 24);
        if (part_type != 0) {
            printk("Partition %d: type=0x%02x start=%u sectors=%u\n",
                   i+1, part_type, start_lba, num_sectors);
void init_sd_card(void)
    const char *disk_pdrv = "SD";
    int ret;
    ret = disk_access_init(disk_pdrv);
    if (ret != 0) {
        printk("Erreur init SD card (%d)\n", ret);
    } else {
        printk("SD card initialisée\n");
    // /* raw disk i/o */
    // do {
    //  static const char *disk_pdrv = "SD";
    //  uint64_t memory_size_mb;
    //  uint32_t block_count;
    //  uint32_t block_size;
    //  if (disk_access_ioctl(disk_pdrv,
    //          DISK_IOCTL_CTRL_INIT, NULL) != 0) {
    //      LOG_ERR("Storage init ERROR!");
    //      break;
    //          DISK_IOCTL_GET_SECTOR_COUNT, &block_count)) {
    //      LOG_ERR("Unable to get sector count");
    //      break;
    //  LOG_INF("Block count %u", block_count);
    //          DISK_IOCTL_GET_SECTOR_SIZE, &block_size)) {
    //      LOG_ERR("Unable to get sector size");
    //      break;
    //  printk("Sector size %u\n", block_size);
    //  memory_size_mb = (uint64_t)block_count * block_size;
    //  printk("Memory Size(MB) %u\n", (uint32_t)(memory_size_mb >> 20));
    //          DISK_IOCTL_CTRL_DEINIT, NULL) != 0) {
    //      LOG_ERR("Storage deinit ERROR!");
    //      break;
    // } while (0);
    // mp.mnt_point = disk_mount_pt;
    // int res = fs_mount(&mp);
    init_sd_card();
    print_mbr_info();
    mount_all_partitions();
//  if (res == FS_RET_OK) {
//      printk("Disk mounted.\n");
//      /* Try to unmount and remount the disk */
//      res = fs_unmount(&mp);
//      if (res != FS_RET_OK) {
//          printk("Error unmounting disk\n");
//          return res;
//      res = fs_mount(&mp);
//          printk("Error remounting disk\n");
//          return res;
//      if (lsdir(disk_mount_pt) == 0) {
//          if (create_some_entries(disk_mount_pt)) {
//              lsdir(disk_mount_pt);
// #endif
//  } else {
//      printk("Error mounting disk.\n");
    write_to_sd();
    // fs_unmount(&mp);
    UNmount_all_partitions();
    while (1) {
        k_sleep(K_MSEC(1000));
    return 0;
/* List dir entry by path
 * @param path Absolute path to list
 * @return Negative errno code on error, number of listed entries on
 *         success.
    int res;
    struct fs_dir_t dirp;
    static struct fs_dirent entry;
    int count = 0;
    fs_dir_t_init(&dirp);
    /* Verify fs_opendir() */
    res = fs_opendir(&dirp, path);
    if (res) {
        printk("Error opening dir %s [%d]\n", path, res);
        return res;
    printk("\nListing dir %s ...\n", path);
    for (;;) {
        /* Verify fs_readdir() */
        res = fs_readdir(&dirp, &entry);
        /* entry.name[0] == 0 means end-of-dir */
        if (res || entry.name[0] == 0) {
        if (entry.type == FS_DIR_ENTRY_DIR) {
            printk("[DIR ] %s\n", entry.name);
        } else {
            printk("[FILE] %s (size = %zu)\n",
                entry.name, entry.size);
        count++;
    /* Verify fs_closedir() */
    fs_closedir(&dirp);
    if (res == 0) {
        res = count;
    return res;
prj.conf
CONFIG_DISK_ACCESS=y
CONFIG_LOG=y
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_PRINTK=y
CONFIG_MAIN_STACK_SIZE=2048
nrf54l15dk_nrf54l15_cpuapp.conf
# Copyright (c) 2024 Nordic Semiconductor ASA
CONFIG_DISK_DRIVER_SDMMC=y
CONFIG_SPI=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_SERIAL=n
CONFIG_CONSOLE=n
CONFIG_UART_CONSOLE=n
nrf54l15dk_nrf54l15_cpuapp.overlay
&spi20 {
    status = "okay";
    pinctrl-0 = <&spi20_default>;
    pinctrl-1 = <&spi20_sleep>;
    cs-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>; // P1.06 - SD_nCS
    sdhc0: sdhc@0 {
        compatible = "zephyr,sdhc-spi-slot";
        reg = <0>;
        status = "okay";
        mmc {
            compatible = "zephyr,sdmmc-disk";
            disk-name = "SD";
            status = "okay";
        spi-max-frequency = <24000000>;
&uart20 {
    status = "disabled";
&pinctrl {
    spi20_default: spi20_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK,  1, 4)>,
                    <NRF_PSEL(SPIM_MOSI, 1, 7)>,
                    <NRF_PSEL(SPIM_MISO, 1, 5)>;
    spi20_sleep: spi20_sleep {
        group1 {
            low-power-enable;
ff_conf.h
/  Configurations of FatFs Module
#define FFCONF_DEF  5380    /* Revision ID */
/ Function Configurations
#define FF_FS_READONLY  0
/* This option switches read-only configuration. (0:Read/Write or 1:Read-only)
/  Read-only configuration removes writing API functions, f_write(), f_sync(),
/  f_unlink(), f_mkdir(), f_chmod(), f_rename(), f_truncate(), f_getfree()
/  and optional writing functions as well. */
#define FF_FS_MINIMIZE  0
/* This option defines minimization level to remove some basic API functions.
/   0: Basic functions are fully enabled.
/   1: f_stat(), f_getfree(), f_unlink(), f_mkdir(), f_truncate() and f_rename()
/      are removed.
/   2: f_opendir(), f_readdir() and f_closedir() are removed in addition to 1.
/   3: f_lseek() function is removed in addition to 2. */
#define FF_USE_FIND     0
/* This option switches filtered directory read functions, f_findfirst() and
/  f_findnext(). (0:Disable, 1:Enable 2:Enable with matching altname[] too) */
#define FF_USE_MKFS     0
/* This option switches f_mkfs(). (0:Disable or 1:Enable) */
#define FF_USE_FASTSEEK 0
/* This option switches fast seek feature. (0:Disable or 1:Enable) */
#define FF_USE_EXPAND   0
/* This option switches f_expand(). (0:Disable or 1:Enable) */
#define FF_USE_CHMOD    0
/* This option switches attribute control API functions, f_chmod() and f_utime().
/  (0:Disable or 1:Enable) Also FF_FS_READONLY needs to be 0 to enable this option. */
#define FF_USE_LABEL    0
/* This option switches volume label API functions, f_getlabel() and f_setlabel().
/  (0:Disable or 1:Enable) */
#define FF_USE_FORWARD  0
/* This option switches f_forward(). (0:Disable or 1:Enable) */
#define FF_USE_STRFUNC  0
#define FF_PRINT_LLI    0
#define FF_PRINT_FLOAT  0
#define FF_STRF_ENCODE  3
/* FF_USE_STRFUNC switches the string API functions, f_gets(), f_putc(), f_puts()
/  and f_printf().
/   0: Disable. FF_PRINT_LLI, FF_PRINT_FLOAT and FF_STRF_ENCODE have no effect.
/   1: Enable without LF - CRLF conversion.
/   2: Enable with LF - CRLF conversion.
/  FF_PRINT_LLI = 1 makes f_printf() support long long argument and FF_PRINT_FLOAT = 1/2
/  makes f_printf() support floating point argument. These features want C99 or later.
/  When FF_LFN_UNICODE >= 1 with LFN enabled, string API functions convert the character
/  encoding in it. FF_STRF_ENCODE selects assumption of character encoding ON THE FILE
/  to be read/written via those functions.
/   0: ANSI/OEM in current CP
/   1: Unicode in UTF-16LE
/   2: Unicode in UTF-16BE
/   3: Unicode in UTF-8
/ Locale and Namespace Configurations
#define FF_CODE_PAGE    932
/* This option specifies the OEM code page to be used on the target system.
/  Incorrect code page setting can cause a file open failure.
/   437 - U.S.
/   720 - Arabic
/   737 - Greek
/   771 - KBL
/   775 - Baltic
/   850 - Latin 1
/   852 - Latin 2
/   855 - Cyrillic
/   857 - Turkish
/   860 - Portuguese
/   861 - Icelandic
/   862 - Hebrew
/   863 - Canadian French
/   864 - Arabic
/   865 - Nordic
/   866 - Russian
/   869 - Greek 2
/   932 - Japanese (DBCS)
/   936 - Simplified Chinese (DBCS)
/   949 - Korean (DBCS)
/   950 - Traditional Chinese (DBCS)
/     0 - Include all code pages above and configured by f_setcp()
#define FF_USE_LFN      0
#define FF_MAX_LFN      255
/* The FF_USE_LFN switches the support for LFN (long file name).
/   0: Disable LFN. FF_MAX_LFN has no effect.
/   1: Enable LFN with static working buffer on the BSS. Always NOT thread-safe.
/   2: Enable LFN with dynamic working buffer on the STACK.
/   3: Enable LFN with dynamic working buffer on the HEAP.
/  To enable the LFN, ffunicode.c needs to be added to the project. The LFN feature
/  requiers certain internal working buffer occupies (FF_MAX_LFN + 1) * 2 bytes and
/  additional (FF_MAX_LFN + 44) / 15 * 32 bytes when exFAT is enabled.
/  The FF_MAX_LFN defines size of the working buffer in UTF-16 code unit and it can
/  be in range of 12 to 255. It is recommended to be set 255 to fully support the LFN
/  specification.
/  When use stack for the working buffer, take care on stack overflow. When use heap
/  memory for the working buffer, memory management functions, ff_memalloc() and
/  ff_memfree() exemplified in ffsystem.c, need to be added to the project. */
#define FF_LFN_UNICODE  0
/* This option switches the character encoding on the API when LFN is enabled.
/   0: ANSI/OEM in current CP (TCHAR = char)
/   1: Unicode in UTF-16 (TCHAR = WCHAR)
/   2: Unicode in UTF-8 (TCHAR = char)
/   3: Unicode in UTF-32 (TCHAR = DWORD)
/  Also behavior of string I/O functions will be affected by this option.
/  When LFN is not enabled, this option has no effect. */
#define FF_LFN_BUF      255
#define FF_SFN_BUF      12
/* This set of options defines size of file name members in the FILINFO structure
/  which is used to read out directory items. These values should be suffcient for
/  the file names to read. The maximum possible length of the read file name depends
/  on character encoding. When LFN is not enabled, these options have no effect. */
#define FF_FS_RPATH     0
/* This option configures support for relative path.
/   0: Disable relative path and remove related API functions.
/   1: Enable relative path. f_chdir() and f_chdrive() are available.
/   2: f_getcwd() is available in addition to 1.
/ Drive/Volume Configurations
#define FF_VOLUMES      2
/* Number of volumes (logical drives) to be used. (1-10) */
#define FF_STR_VOLUME_ID    1
#define FF_VOLUME_STRS      "SD","SD1","SDHC0"
/* FF_STR_VOLUME_ID switches support for volume ID in arbitrary strings.
/  When FF_STR_VOLUME_ID is set to 1 or 2, arbitrary strings can be used as drive
/  number in the path name. FF_VOLUME_STRS defines the volume ID strings for each
/  logical drive. Number of items must not be less than FF_VOLUMES. Valid
/  characters for the volume ID strings are A-Z, a-z and 0-9, however, they are
/  compared in case-insensitive. If FF_STR_VOLUME_ID >= 1 and FF_VOLUME_STRS is
/  not defined, a user defined volume string table is needed as:
/  const char* VolumeStr[FF_VOLUMES] = {"ram","flash","sd","usb",...
#define FF_MULTI_PARTITION  1
/* This option switches support for multiple volumes on the physical drive.
/  By default (0), each logical drive number is bound to the same physical drive
/  number and only an FAT volume found on the physical drive will be mounted.
/  When this feature is enabled (1), each logical drive number can be bound to
/  arbitrary physical drive and partition listed in the VolToPart[]. Also f_fdisk()
/  will be available. */
#define FF_MIN_SS       512
#define FF_MAX_SS       512
/* This set of options configures the range of sector size to be supported. (512,
/  1024, 2048 or 4096) Always set both 512 for most systems, generic memory card and
/  harddisk, but a larger value may be required for on-board flash memory and some
/  type of optical media. When FF_MAX_SS is larger than FF_MIN_SS, FatFs is
/  configured for variable sector size mode and disk_ioctl() needs to implement
/  GET_SECTOR_SIZE command. */
#define FF_LBA64        0
/* This option switches support for 64-bit LBA. (0:Disable or 1:Enable)
/  To enable the 64-bit LBA, also exFAT needs to be enabled. (FF_FS_EXFAT == 1) */
#define FF_MIN_GPT      0x10000000
/* Minimum number of sectors to switch GPT as partitioning format in f_mkfs() and
/  f_fdisk(). 2^32 sectors maximum. This option has no effect when FF_LBA64 == 0. */
#define FF_USE_TRIM     0
/* This option switches support for ATA-TRIM. (0:Disable or 1:Enable)
/  To enable this feature, also CTRL_TRIM command should be implemented to
/  the disk_ioctl(). */
/ System Configurations
#define FF_FS_TINY      0
/* This option switches tiny buffer configuration. (0:Normal or 1:Tiny)
/  At the tiny configuration, size of file object (FIL) is shrinked FF_MAX_SS bytes.
/  Instead of private sector buffer eliminated from the file object, common sector
/  buffer in the filesystem object (FATFS) is used for the file data transfer. */
#define FF_FS_EXFAT     0
/* This option switches support for exFAT filesystem. (0:Disable or 1:Enable)
/  To enable exFAT, also LFN needs to be enabled. (FF_USE_LFN >= 1)
/  Note that enabling exFAT discards ANSI C (C89) compatibility. */
#define FF_FS_NORTC     0
#define FF_NORTC_MON    11
#define FF_NORTC_MDAY   1
#define FF_NORTC_YEAR   2024
/* The option FF_FS_NORTC switches timestamp feature. If the system does not have
/  an RTC or valid timestamp is not needed, set FF_FS_NORTC = 1 to disable the
/  timestamp feature. Every object modified by FatFs will have a fixed timestamp
/  defined by FF_NORTC_MON, FF_NORTC_MDAY and FF_NORTC_YEAR in local time.
/  To enable timestamp function (FF_FS_NORTC = 0), get_fattime() need to be added
/  to the project to read current time form real-time clock. FF_NORTC_MON,
/  FF_NORTC_MDAY and FF_NORTC_YEAR have no effect.
/  These options have no effect in read-only configuration (FF_FS_READONLY = 1). */
#define FF_FS_NOFSINFO  0
/* If you need to know correct free space on the FAT32 volume, set bit 0 of this
/  option, and f_getfree() at the first time after volume mount will force
/  a full FAT scan. Bit 1 controls the use of last allocated cluster number.
/  bit0=0: Use free cluster count in the FSINFO if available.
/  bit0=1: Do not trust free cluster count in the FSINFO.
/  bit1=0: Use last allocated cluster number in the FSINFO if available.
/  bit1=1: Do not trust last allocated cluster number in the FSINFO.
#define FF_FS_LOCK      0
/* The option FF_FS_LOCK switches file lock function to control duplicated file open
/  and illegal operation to open objects. This option must be 0 when FF_FS_READONLY
/  is 1.
/  0:  Disable file lock function. To avoid volume corruption, application program
/      should avoid illegal open, remove and rename to the open objects.
/  >0: Enable file lock function. The value defines how many files/sub-directories
/      can be opened simultaneously under file lock control. Note that the file
/      lock control is independent of re-entrancy. */
#define FF_FS_REENTRANT 0
#define FF_FS_TIMEOUT   1000
/* The option FF_FS_REENTRANT switches the re-entrancy (thread safe) of the FatFs
/  module itself. Note that regardless of this option, file access to different
/  volume is always re-entrant and volume control functions, f_mount(), f_mkfs()
/  and f_fdisk(), are always not re-entrant. Only file/directory access to
/  the same volume is under control of this featuer.
/   0: Disable re-entrancy. FF_FS_TIMEOUT have no effect.
/   1: Enable re-entrancy. Also user provided synchronization handlers,
/      ff_mutex_create(), ff_mutex_delete(), ff_mutex_take() and ff_mutex_give(),
/      must be added to the project. Samples are available in ffsystem.c.
/  The FF_FS_TIMEOUT defines timeout period in unit of O/S time tick.
/* Zephyr specific configuration override */
/* The ZEPHYR_CONFIG_OVERRIDE should be given header file name that will contain
/  series of undefs and redefinitions of the FF_ identifiers from the ffconf.h
/  it needs to override
#ifdef ZEPHYR_CONFIG_OVERRIDE
#define FFCONF_STRINGIZE_AGAIN(x) #x
#define FFCONF_STRINGIZE(x) FFCONF_STRINGIZE_AGAIN(x)
#include FFCONF_STRINGIZE(ZEPHYR_CONFIG_OVERRIDE)
#undef FFCONF_STRINGIZE
#undef FFCONF_STRINGIZE_AGAIN
/* End of Zephyr specific configuration override */
/*--- End of configuration options ---*/
Thank you !
