Matter device become offline in multi-fabric when multiple devices are provisioned
Hello DevZone,
One customer meets an issue. Needs an expert about Matter.
There are 5 Matter over Thread window covering devices which are already commissioned in 2 fabrics, the Apple HomePod & Google Home.
When only 1 device is powered on. The device is working fine.
When they turned on another device, the first device become unstable and was offline on Apple Home App.
(They have passed the Matter certification. And I'm sure all the 5 devices have different DAC and discriminators)
NCS version: v2.9.2
Here is the log:
2025.12.30.txt
Some useful information to read this log:
1. Timestamp:
 There are 2 types of timestamp in the log. One is from device log.
Like `[17:55:39.053,527]`, it is the hours since the device starts.
Like `[08:13:23.326]`, it is the local time from PC serial communication tools.
2. Fabrics
There are 2 fabrics at the beginning: Fabric 1 (DEC758BE) and Fabric 3 (50E8938D)
But I don't know which one is Google, and which one is Apple.
3. Preliminary analysis by AI
What the customer did at 17h59m is just turning on another device.
Jayant
  • Hello Susheel.
    After testing, those configs don't help.
    Larry has told me that Apple doesn't have good support for SSED. So I helped the customer change to SED.
    Now they met issues like:
     ReceivedTofile-COM38-2026_1_8_11-11-47.DAT
    Meanwhile, Larry has built an environment that has 3 fabric and several DKs configured as SED. It was running the whole weekend, and no errors happens.
    So I think there may be something wrong in customer's code. I will compare customer's code with the NCS v2.9.2 samples and see what is different.
  • Hi Jayant,
    Susheel is out of the office, so I have been assigned to the ticket.
    It seems like the customer is running out of memory, since "DataVersionFilter pool full, ignore this filter" is printed when you get CHIP_ERROR_NO_MEMORY. It could be because of insufficient heap or too small packet buffer pool.
    They can enable Matter memory profiling to see actual heap/stack usage and where they are running out:
    CONFIG_CHIP_MEMORY_PROFILING=y
    If the failure happens because of insufficient heap, they can increase the heap with:
    CONFIG_CHIP_MALLOC_SYS_HEAP_SIZE=
    If the issue is due to the packet buffer pool, they can increase this with:
    CONFIG_CHIP_SYSTEM_PACKETBUFFER_POOL_SIZE=
    If the customer has not already done so, I would also recommend going through the Memory footprint optimization guide to optimize their application.
    Marte
  • Hi  and
    Sorry for late response, we were reproducing this issue for a long time.
    Unfortunately, those configs don't help. Increasing the memory size is not enough.
    Now the customer confirms that this issue also happens when the distance between the device and HomePod mini is too far, even if there is only Apple fabric (iOS 26.2), no Google.
    We added some logs in Matter SDK and we found some new details.
    For the function `InteractionModelEngine::ReleaseDataVersionFilterList`, it was always called during normal activities.
    But sometimes the device will not release the DataVersionFilter, and this function will never be called:
    Normal interactive:
    issue situation:
    It keeps allocate DataVersionFilter until it fails.
    Jayant
  • Hi Jayant,
    Just to verify, by "this issue" do you mean the DataVersionFilter pool full error, or is this also related to devices becoming unstable/offline?
    Marte
  • By "this issue" I mean the DataVersionFilter pool full error.
    Please help to check the `InteractionModelEngine::ReleaseDataVersionFilterList` function. In which condition this function will not be called
