What is the speed of updating TXP
Hi
I am wondering when I use this function, how much time do I need between I set a TXP and a TXP has been successfully updated. I am developing an application that needs to quickly change the TXP, maybe 5 times per second.
static void set_tx_power(uint8_t handle_type, uint16_t handle, int8_t tx_pwr_lvl)
	 struct bt_hci_cp_vs_write_tx_power_level *cp;
	 struct bt_hci_rp_vs_write_tx_power_level *rp;
	 struct net_buf *buf, *rsp = NULL;
	 int err;
	 buf = bt_hci_cmd_create(BT_HCI_OP_VS_WRITE_TX_POWER_LEVEL,
							 sizeof(*cp));
	 if (!buf) {
		 printk("Unable to allocate command buffer\n");
		 return;
	 cp = net_buf_add(buf, sizeof(*cp));
	 cp->handle = sys_cpu_to_le16(handle);
	 cp->handle_type = handle_type;
	 cp->tx_power_level = tx_pwr_lvl;
	 err = bt_hci_cmd_send_sync(BT_HCI_OP_VS_WRITE_TX_POWER_LEVEL,
								buf, &rsp);
	 if (err) {
		 printk("Set Tx power err: %d\n", err);
		 return;
	 rp = (void *)rsp->data;
	 printk("Actual Tx Power: %d\n", rp->selected_tx_power);
	 net_buf_unref(rsp);
In other words, after using this function, can I get a return to verify that the TXP has been successfully updated? Or do you have any information on the time? How can I test the required time.
Thank you so much
