Since our Product Launch we have gotten feedback that pairing with some (but not all) Apple devices is a significant problem. Even through several attempted fixes we haven't gotten this to work.
We use the BT FTMS Profile, implemented on top of the S313 ANT+ and BLE Softdevice. There, our pairing setup looks like this:
1. Device connects, might read preferred connection parameters or not, which are:
ble_gap_conn_params_t {
min_conn_interval: 12, // 12 * 1.25ms = 15ms (ios-compatible min)
max_conn_interval: 24, // 24 * 1.25ms = 30ms (common "safe" max for iOS)
slave_latency: 0, // no slave latency
conn_sup_timeout: 500, // 500 * 10ms = 5s
2. (generally) discovers GATT services and such
3. One second after connection, our firmware sets the connection params itself (which are the same as above, and generally succeeds according to nrf-connect)
4. 800ms after that, our firmware triggers pairing. This generally shows a notification or confirmation window on devices, and tends to work as expected.
For all devices I have available from multiple manufacturers and with multiple OSses (Linux, Windows, Android, iOS including an iPhone 14 and an iPad Air), this works just fine. However, we've heard from several people that there's behavior like this:
1. Device gets selected in the fitness app or whereever, connects, pairing window pops up, connection works
2. Data gets received (no security on all the rx parts, so that makes sense), no control commands to e.g. set power get sent (which makes sense assuming the pairing didn't work, as writing to it requires just works security)
3. After 30-45ish seconds a new pairing prompt gets displayed. Same behavior loops after pressing pair again.
We've tried quite a few different ways to fix that, but nothing we found until now works so far, so we're kind of at a loss as to what we're doing wrong.
Some more info:
- io_caps are set to BLE_GAP_IO_CAPS_NONE, and the MITM flag is 0. Also, min_key_size = 7 and max_key_size = 16.
- Advertising interval is the Apple-recommended 20ms (32). Discoverability never was a problem, but can't hurt.
- Bonding is only triggered after 1.8s if and only if the device is not yet bonded, it's not just slammed down indiscriminately.
- LESC is not supported by our firmware (and it indicates this properly)
- Devices that don't work seem to be some macbooks, quite a few iPads, the iPhone 17 Pro, and the Apple TV. Pretty often people report that it works on some of their devices, but not on e.g. an iPad.
- The only other problematic device we saw is a Lenovo tablet that (according to what I think) doesn't accept pairing without LESC due to some bluetooth stack regression, but nothing we have in our hands allows us to replicate the issue until now.
- Some devices failed silently in the past, never showing a pairing prompt while just refusing to write to the Control Point behind the JustWorks security
- The device has the DIS service implemented, which is explicitly required by Apple. I have no idea if its presence has any relation on this problem, but it can't hurt I think.
I'd really appreciate any ideas or tips as to how to proceed here. This seems to be a consistent problem across some versions of Apple Bluetooth stacks, but it's hard to see a pattern for now. Any help would really be much appreciated!
