I try to set custom compiler flags for the whole project including Zephyr via prj.conf / CONFIG_COMPILER_OPT to compute worst case stack usage as follows:
CONFIG_COMPILER_OPT="-fcallgraph-info=su -O3 -ffp-contract=fast"
The "-fcallgraph-info=su" option should create an *.ci file for each compilation unit in the build folder [1].
Sometimes when i run the build get a bunch of *.ci files in the build directory but most of the time they are not created.
Setting the option via "target_compile_options" works for my code but i obviously need the option to be applied to the Zephyr code too.
This is rather annoying as it seems to happen completely random.
nRF Connect SDK v3.1.1
nRF Connect for VS Code Extension Pack v2025.4.4
