Clarify the minimum mandatory external connections and pin/rail requirements for an nRF9151 to boot and run a flashed application, and determine why serial_lte_modem (SLM) shows no UART response on an external bare module wired directly to pads after successful SWD programming. Also confirm whether using 3.3 V on both VDD and VDD_GPIO is supported.
Reference (works)
- Board: nRF9151-DK
- Application: serial_lte_modem (SLM) from NCS
- Behavior: UART responds as expected (AT interface)
Failing target (external / wired pads)
- Hardware: external nRF9151 module/chip only; wires soldered directly to pads
- Behavior: after flashing SLM, no UART banner/AT response
Programming status (confirmed)
- The external module can be programmed via SWD successfully.
- nRF Connect / Programmer confirms the image was written correctly (flash operation completes without errors).
- The behavior diverges after flashing: DK runs and responds; external target is silent on UART.
Connections used
- SWD programming wiring
- VDD = 5 V
- GND
- SWDIO
- SWDCLK
- nRESET
- Runtime wiring for UART test (direct power)
- VDD = 5 V
- GND
- VDD_GPIO = 1.8 V
- ENABLE = HIGH
- P0.26 = TX
- P0.27 = RX
Additional test using the nRF9151-DK as a power/UART host (still fails)
- The external module was connected to the nRF9151-DK.
- The DK’s onboard modem TX/RX path was opened/disconnected to isolate the DK’s modem and reroute the DK UART TX/RX to the external module instead.
- The external module was powered using the DK native rails (5 V / 1.8 V) and tested through the DK’s UART interface.
- Result: SLM still does not respond on UART.
Requested from Nordic
- Definitive list of mandatory rails/pins/conditions (and sequencing) required for nRF9151 to:
- boot and execute a flashed application reliably
- expose UART for SLM
- Confirmation whether it is supported to power a design with:
- VDD = 3.3 V and VDD_GPIO = 3.3 V
- any restrictions, required configuration, or unsupported conditions
- Root-cause guidance for “flash verified but UART silent” on custom/bare hardware, including:
- SLM default UART instance and pin mapping differences between DK and custom target
- required devicetree/Kconfig changes to bind SLM UART to P0.26/P0.27
- reset/ENABLE handling and required pulls that can prevent the app from running or keep UART inactive
- any mandatory external circuitry/rails provided by the DK that are missing in a bare module wiring
