nPM1300 fuel gauge SoC
Hi
Setup: nPM1300, nRF54L15-based board, SDK 2.9.2
I am trying to figure out how to use the nPM1300.
So far, I have not succeeded. Quite frequently, after power cycling my device, the SoC read from the fuel gauge, after rebooting, is quite different (e.g. 20% difference) from the SoC before power down.
My code calls nrf_fuel_gauge_process() every 100 ms.
ret = read_sensors(charger, &voltage, &current, &temp, &chg_status);
soc = nrf_fuel_gauge_process(voltage, current, temp, delta, charging_active, NULL);
Some of the things I have tried…
ONE
Simple usage.
Provide no further information to the fuel gauge.
On power up, initialise the fuel gauge straight away.
ret = read_sensors(charger, &p.v0, &p.i0, &p.t0, &chg_status);
sensor_channel_get(charger, SENSOR_CHAN_GAUGE_DESIRED_CHARGING_CURRENT, &v);
nrf_fuel_gauge_init(&p, NULL);
TWO
Same as ONE, except wait 30 seconds before initialising
THREE
When the SoC reaches 100%, re-initialise the fuel gauge:
int ret = read_sensors(charger, &p.v0, &p.i0, &p.t0, &chg_status);
FOUR
After a few seconds after powering up, read the V,I,T
then initialise the fuel gauge using these values
FIVE
Save V,I,T values to Flash on a regular basis, and on power-up, restore these  saved values and use them to initialise the fuel gauge.
SIX
Maintain an array of saved V,I,T values (e.g. size 120), and save the average of this circular array to Flash every so often (e.g. every 2 minutes for test purposes).
On power-up, restore these saved averages, and use them to initialise the fuel gauge.
FURTHER INFORMATION
In all cases, there is often quite a large drop or rise in the SoC after power cycling the device.
Here is a sample of the output while charging / discharging (from two separate logs).
One thing of note: the voltage and current fluctuate quite a bit during discharge.
Charging:
[00:13:31.976,257] : delta: 0.100000, V: 4.233, I: -0.019, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2122, Chging 1, Conn 1, ChgSt 17
[00:13:32.076,293] : delta: 0.100000, V: 4.233, I: -0.017, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2095, Chging 1, Conn 1, ChgSt 17
[00:13:32.176,239] : delta: 0.100000, V: 4.233, I: -0.018, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2107, Chging 1, Conn 1, ChgSt 17
[00:13:32.276,275] : delta: 0.100000, V: 4.233, I: -0.017, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2092, Chging 1, Conn 1, ChgSt 17
[00:13:32.376,312] : delta: 0.100000, V: 4.233, I: -0.017, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2091, Chging 1, Conn 1, ChgSt 17
[00:13:32.476,379] : delta: 0.101000, V: 4.233, I: -0.019, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2115, Chging 1, Conn 1, ChgSt 17
[00:13:32.576,293] : delta: 0.099000, V: 4.233, I: -0.018, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2101, Chging 1, Conn 1, ChgSt 17
[00:13:32.676,300] : delta: 0.100000, V: 4.233, I: -0.017, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2087, Chging 1, Conn 1, ChgSt 17
[00:13:32.776,367] : delta: 0.101000, V: 4.233, I: -0.017, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2085, Chging 1, Conn 1, ChgSt 17
[00:13:32.876,312] : delta: 0.099000, V: 4.233, I: -0.019, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2110, Chging 1, Conn 1, ChgSt 17
[00:13:32.976,348] : delta: 0.101000, V: 4.233, I: -0.018, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2096, Chging 1, Conn 1, ChgSt 17
[00:13:33.076,385] : delta: 0.100000, V: 4.233, I: -0.017, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2081, Chging 1, Conn 1, ChgSt 17
[00:13:33.176,330] : delta: 0.099000, V: 4.228, I: -0.018, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2093, Chging 1, Conn 1, ChgSt 17
[00:13:33.276,336] : delta: 0.100000, V: 4.233, I: -0.017, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2079, Chging 1, Conn 1, ChgSt 17
[00:13:33.376,403] : delta: 0.101000, V: 4.233, I: -0.019, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2103, Chging 1, Conn 1, ChgSt 17
[00:13:33.476,348] : delta: 0.100000, V: 4.228, I: -0.018, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2090, Chging 1, Conn 1, ChgSt 17
[00:13:33.576,354] : delta: 0.100000, V: 4.233, I: -0.018, T: 25.82, SoC: 98.59, TTE: nan, TTF: 2088, Chging 1, Conn 1, ChgSt 17
[00:13:33.676,452] : delta: 0.100000, V: 4.233, I: -0.019, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2100, Chging 1, Conn 1, ChgSt 17
[00:13:33.776,367] : delta: 0.100000, V: 4.228, I: -0.018, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2086, Chging 1, Conn 1, ChgSt 17
[00:13:33.876,342] : delta: 0.100000, V: 4.233, I: -0.016, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2057, Chging 1, Conn 1, ChgSt 17
[00:13:33.976,470] : delta: 0.100000, V: 4.233, I: -0.019, T: 25.93, SoC: 98.59, TTE: nan, TTF: 2096, Chging 1, Conn 1, ChgSt 17
[00:13:34.076,354] : delta: 0.100000, V: 4.228, I: -0.018, T: 25.93, SoC: 98.60, TTE: nan, TTF: 2082, Chging 1, Conn 1, ChgSt 17
[00:13:34.176,361] : delta: 0.100000, V: 4.233, I: -0.018, T: 25.93, SoC: 98.60, TTE: nan, TTF: 2081, Chging 1, Conn 1, ChgSt 17
[00:13:34.276,428] : delta: 0.100000, V: 4.233, I: -0.018, T: 25.93, SoC: 98.60, TTE: nan, TTF: 2079, Chging 1, Conn 1, ChgSt 17
[00:13:34.376,373] : delta: 0.100000, V: 4.233, I: -0.017, T: 25.93, SoC: 98.60, TTE: nan, TTF: 2065, Chging 1, Conn 1, ChgSt 17
[00:13:34.476,379] : delta: 0.100000, V: 4.233, I: -0.018, T: 25.93, SoC: 98.60, TTE: nan, TTF: 2077, Chging 1, Conn 1, ChgSt 17
Discharging:
[00:14:18.076,660] : delta: 0.100000, V: 3.994, I: 0.011, T: 26.03, SoC: 96.79, TTE: 15040, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:18.176,727] : delta: 0.100000, V: 3.984, I: 0.023, T: 26.03, SoC: 96.79, TTE: 15039, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:18.276,794] : delta: 0.100000, V: 3.994, I: 0.023, T: 26.03, SoC: 96.79, TTE: 15039, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:18.376,678] : delta: 0.100000, V: 3.989, I: 0.067, T: 26.03, SoC: 96.79, TTE: 15039, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:18.476,745] : delta: 0.100000, V: 3.989, I: 0.019, T: 26.03, SoC: 96.78, TTE: 15039, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:18.576,812] : delta: 0.100000, V: 3.999, I: 0.021, T: 26.03, SoC: 96.78, TTE: 15038, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:18.676,696] : delta: 0.100000, V: 3.989, I: 0.023, T: 26.03, SoC: 96.78, TTE: 15038, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:18.776,763] : delta: 0.100000, V: 3.994, I: 0.019, T: 26.03, SoC: 96.78, TTE: 15038, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:18.876,922] : delta: 0.100000, V: 3.999, I: 0.039, T: 26.03, SoC: 96.78, TTE: 15038, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:18.976,715] : delta: 0.100000, V: 4.003, I: 0.043, T: 26.03, SoC: 96.78, TTE: 15037, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:19.076,782] : delta: 0.100000, V: 3.994, I: 0.011, T: 26.03, SoC: 96.78, TTE: 15037, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:19.176,940] : delta: 0.100000, V: 3.999, I: 0.067, T: 26.03, SoC: 96.78, TTE: 15037, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:19.276,733] : delta: 0.100000, V: 3.994, I: 0.023, T: 26.03, SoC: 96.78, TTE: 15037, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:19.376,800] : delta: 0.100000, V: 3.984, I: 0.022, T: 26.03, SoC: 96.78, TTE: 15036, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:19.476,959] : delta: 0.100000, V: 3.994, I: 0.035, T: 26.03, SoC: 96.78, TTE: 15036, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:19.576,812] : delta: 0.100000, V: 4.003, I: 0.022, T: 26.03, SoC: 96.78, TTE: 15036, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:19.676,788] : delta: 0.100000, V: 3.994, I: 0.019, T: 26.03, SoC: 96.78, TTE: 15035, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:19.776,947] : delta: 0.100000, V: 4.003, I: 0.021, T: 26.03, SoC: 96.78, TTE: 15035, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:19.876,861] : delta: 0.100000, V: 3.994, I: 0.021, T: 26.03, SoC: 96.78, TTE: 15035, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:19.976,837] : delta: 0.100000, V: 3.994, I: 0.009, T: 26.03, SoC: 96.77, TTE: 15035, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:20.076,995] : delta: 0.100000, V: 4.003, I: 0.039, T: 26.03, SoC: 96.77, TTE: 15035, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:20.176,879] : delta: 0.100000, V: 4.003, I: 0.020, T: 26.03, SoC: 96.77, TTE: 15034, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:20.276,855] : delta: 0.100000, V: 3.994, I: 0.019, T: 26.03, SoC: 96.77, TTE: 15034, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:20.377,014] : delta: 0.100000, V: 3.994, I: 0.021, T: 26.03, SoC: 96.77, TTE: 15034, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:20.477,020] : delta: 0.100000, V: 3.989, I: 0.019, T: 26.03, SoC: 96.77, TTE: 15034, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:20.576,843] : delta: 0.100000, V: 3.999, I: 0.019, T: 26.03, SoC: 96.77, TTE: 15033, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:20.677,032] : delta: 0.100000, V: 3.994, I: 0.039, T: 26.03, SoC: 96.77, TTE: 15033, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:20.776,885] : delta: 0.100000, V: 3.994, I: 0.011, T: 26.03, SoC: 96.77, TTE: 15033, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:20.876,922] : delta: 0.100000, V: 3.999, I: 0.021, T: 26.03, SoC: 96.77, TTE: 15033, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:20.977,050] : delta: 0.100000, V: 4.003, I: 0.019, T: 26.03, SoC: 96.77, TTE: 15032, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:21.076,934] : delta: 0.100000, V: 3.994, I: 0.039, T: 26.03, SoC: 96.77, TTE: 15032, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:21.176,940] : delta: 0.100000, V: 3.989, I: 0.019, T: 26.03, SoC: 96.77, TTE: 15032, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:21.277,069] : delta: 0.100000, V: 3.999, I: 0.019, T: 26.03, SoC: 96.77, TTE: 15032, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:21.377,075] : delta: 0.100000, V: 3.994, I: 0.019, T: 26.03, SoC: 96.77, TTE: 15032, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:21.476,959] : delta: 0.100000, V: 3.979, I: 0.043, T: 25.62, SoC: 96.77, TTE: 15031, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:21.577,087] : delta: 0.100000, V: 4.003, I: 0.019, T: 26.03, SoC: 96.77, TTE: 15031, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:21.677,062] : delta: 0.100000, V: 3.999, I: 0.022, T: 26.03, SoC: 96.77, TTE: 15031, TTF: nan, Chging 0, Conn 0, ChgSt 0
[00:14:21.776,947] : delta: 0.100000, V: 3.999, I: 0.009, T: 26.03, SoC: 96.76, TTE: 15031, TTF: nan, Chging 0, Conn 0, ChgSt 0
Question: Do you have any suggestions on how I could get more reliable SoC values from the chip?
Question: Is there a maximum interval between nrf_fuel_gauge_process() calls (i.e. a maximum delta) beyond which the update is not reliable (e.g. 500 ms?)
Question: Does the fuel gauge algorithm average its input over time?
Thanks
  • Hi Audun,
    I am using SDK 3.1.1. I use the same application when Flashing. Sometimes, I modify the application slightly (e.g. add one debug global variable). Always SDK 3.1.1.
    When I first posted this ticket I was using SDK 2.9.2, but I then upgraded to SDK 3.1.1 to use the nrf_fuel_gauge_state_get() function.
  • Hi Garrett
    I'm sorry about the late update. Audun will get back to you when we have reproduced this on our end. Thank you for your patience.
    Simon
  • Thanks for the details,
    I do have one more theory of what could have gone wrong. The state blob includes a pointer to the battery model. If this is no longer valid after you have changed the binary, the behavior would change.
    Can you try to update the pointer within the binary blob before passing it on to nrf_fuel_gauge_init()? I assume you have the data in RAM already.
    #include <zephyr/sys/byteorder.h>
    sys_put_le32(&battery_model, &fuel_gauge_state.fuel_gauge_state_buf[224]);
    This API needs to be updated on our side to allow the battery model to be moved around. It's inconvenient to require this pointer to be static across firmware updates.
    Audun
