Hi Nordic Community,
I am working with the nRF52833 and I have a question regarding the electrical characteristics of the dedicated USB signal pins (D+ and D-) when the USB peripheral is unused (USBD is disabled).
I understand from the Product Specification that the USB pull-up (1.5 kΩ) on D+ is disabled by default after a chip reset and is only connected when enabled by software via the USBPULLUP register after the USBD is enabled [USB pull-up].
I also understand that when the device is plugged into a USB Host (PC) while the USBD peripheral is disabled, the Host's internal 15 kΩ pull-down resistors will pull both D+ and D- lines to ground (Logic Low / SE0 state).
My question is: From the nRF52833 device side, what is the exact state of the D+ and D- pins when the ENABLE register is set to Disabled?
Can you confirm if these pins are in a strictly High-Impedance (High-Z) state? I want to ensure there are no internal pull-downs or other active circuitry on the nRF52833 side that would affect the lines or consume current when the USB peripheral is not in use.
Thanks in advance for your help.
