Firebase connection with nrf5340 and nrf7002 shield
Hello All,
I implemented the HTTPS call to Amazon using the certificate, and the POST request returns the device ID.
Like you docs: Exercise 2 - Adding TLS to the HTTP connection - Nordic Developer Academy
However, the project we are using does not use Amazon AWS but instead uses Firebase.
I imported the Root GTS R1 certificate (downloadable online), converted it using the appropriate script implemented in CMakeLists.txt.
When I run the code, in debug mode, when loading the certificate, I get this error:
https_client: IPv4 address of server found 216.239.36.54
Socket created
<err> net_sock_tls: Failed to parse CA certificate, err: -0x3b00
https_client: Connect failed : 22
What does this error mean?
I am fairly sure the CA certificate is correct, since I followed the same procedure I used for Amazon.
Also, using SSL commands via the command line, I noticed that Firebase has 3 certificates, while the Nordic link only has 1 (the Amazon one).
Could this be the problem?
Has anyone managed to connect to Firebase?
I am open to any kind of collaboration.
P.S.
When I call Firebase, I am calling the Firebase Functions (HTTPS POST, GET, etc.).
Thanks for any type of support.
Best regards
    Thanks for the detailed description. From the log, the failure happens while the device is loading/parsing the CA certificate (Failed to parse CA certificate), before the TLS handshake with Firebase starts. Since the same code works with the Amazon example, the most likely causes are either (a) an issue with the Firebase CA certificate file after conversion, or (b) the certificate using crypto parameters that require slightly different TLS settings. So to help narrow this down, could you please share the following:
    1. The exact hostname you are connecting to (for example, the Firebase Functions domain).
    2. The exact CA certificate file (.pem) you are provisioning (the one you converted and included in the build).
    3. Your nRF Connect SDK version, and whether you are building the non-secure TF-M target, as in the DevAcademy exercise.
    Additionally, from a PC, could you please run the following command and paste the output:
    openssl s_client -connect <hostname>:443 -servername <hostname> -showcerts
    This will show which certificate chain Firebase is using and help us confirm which CA should be provisioned on the device and once we have this information, we can advise whether this is a certificate conversion issue or if any additional TLS configuration is needed.
    Best Regards,
    Syed Maysum
  • Hello and thank you very much for your reply.
    My host name is the following:
    us-central1-project-fcce5.cloudfunctions.net
    Below is what I receive from the SSL call
    (openssl s_client -connect <hostname>:443 -servername <hostname> -showcerts)
    CONNECTED(000001B8)
    Certificate chain
     0 s:CN=misc.google.com
       i:C=US, O=Google Trust Services, CN=WR2
       a:PKEY: EC, (prime256v1); sigalg: sha256WithRSAEncryption
       v:NotBefore: Dec  3 15:50:23 2025 GMT; NotAfter: Feb 25 15:50:22 2026 GMT
    -----BEGIN CERTIFICATE-----
    MIIiWjCCIUKgAwIBAgIQbfyHOPZkJ7cK2IqmGMcRxzANBgkqhkiG9w0BAQsFADA7
    MQswCQYDVQQGEwJVUzEeMBwGA1UEChMVR29vZ2xlIFRydXN0IFNlcnZpY2VzMQww
    CgYDVQQDEwNXUjIwHhcNMjUxMjAzMTU1MDIzWhcNMjYwMjI1MTU1MDIyWjAaMRgw
    FgYDVQQDEw9taXNjLmdvb2dsZS5jb20wWTATBgcqhkjOPQIBBggqhkjOPQMBBwNC
    AAQYZ70FeDJ+nwApeV76UWeyA8Jz2d+mPzt2Tj2iVXm/M85X6JY2XUT+/4zSZkjJ
    jCJjJpKOhoc+8EYuWe179Tlto4IgRDCCIEAwDgYDVR0PAQH/BAQDAgeAMBMGA1Ud
    JQQMMAoGCCsGAQUFBwMBMAwGA1UdEwEB/wQCMAAwHQYDVR0OBBYEFM4VEPWkgcM9
    wUzQ5jH2uK6S+Vm8MB8GA1UdIwQYMBaAFN4bHu15FdQ+NyTDIbvsNDltQrIwMFgG
    CCsGAQUFBwEBBEwwSjAhBggrBgEFBQcwAYYVaHR0cDovL28ucGtpLmdvb2cvd3Iy
    MCUGCCsGAQUFBzAChhlodHRwOi8vaS5wa2kuZ29vZy93cjIuY3J0MIIeGQYDVR0R
    BIIeEDCCHgyCD21pc2MuZ29vZ2xlLmNvbYIUKi5hY3Rpb25zLmdvb2dsZS5jb22C
    FSouYmFzZWxpbmUuZ29vZ2xlLmNvbYIWKi5kZXZlbG9wZXIuZ29vZ2xlLmNvbYIX
    Ki5kZXZlbG9wZXJzLmdvb2dsZS5jb22CESouZXdvcS5nb29nbGUuY29tghEqLmFy
    dnIuZ29vZ2xlLmNvbYIVKi5maXJlYmFzZS5nb29nbGUuY29tghAqLmdncC5nb29n
    bGUuY29tghkqLnBlcnNvbmZpbmRlci5nb29nbGUub3JnghEqLnF1aWNrb2ZmaWNl
    LmNvbYITKi5zcGVlY2guZ29vZ2xlLmNvbYIsKi5zdG9yYWdlLW5pZ2h0bHktdGVz
    dC5nb29nbGV1c2VyY29udGVudC5jb22CNCouc3RvcmFnZS1wcmVwcm9kLXRlc3Qt
    dW5pZmllZC5nb29nbGV1c2VyY29udGVudC5jb22CLCouc3RvcmFnZS1zdGFnaW5n
    LXRlc3QuZ29vZ2xldXNlcmNvbnRlbnQuY29tgikqLnN0b3JhZ2UtdGVzdC10ZXN0
    Lmdvb2dsZXVzZXJjb250ZW50LmNvbYIUKi5zdXBwb3J0Lmdvb2dsZS5jb22CDiou
    d2lkZXZpbmUuY29tghYqLnN0YWdpbmcud2lkZXZpbmUuY29tghIqLnVhdC53aWRl
    dmluZS5jb22CGioudWF0LW5pZ2h0bHkud2lkZXZpbmUuY29tghNhbHBoYWdlbm9t
    ZWRvY3MuY29tghhhbHBoYWdlbm9tZWNvbW11bml0eS5jb22CDGFkZ29vZ2xlLm5l
    dIIOKi5hZGdvb2dsZS5uZXSCCmFkbWVsZC5jb22CDCouYWRtZWxkLmNvbYIXYWR2
    ZXJ0aXNlcmNvbW11bml0eS5jb22CG3d3dy5hZHZlcnRpc2VyY29tbXVuaXR5LmNv
    bYIYYWR2ZXJ0aXNlcnNjb21tdW5pdHkuY29tghoqLmFkdmVydGlzZXJzY29tbXVu
    aXR5LmNvbYIVYWR3b3Jkcy1jb21tdW5pdHkuY29tghcqLmFkd29yZHMtY29tbXVu
    aXR5LmNvbYISYWR3b3Jkc2V4cHJlc3MuY29tghQqLmFkd29yZHNleHByZXNzLmNv
    bYILYW1pZS5nb29nbGWCDSouYW1pZS5nb29nbGWCD2FuZ3VsYXJkYXJ0Lm9yZ4IR
    Ki5hbmd1bGFyZGFydC5vcmeCDGFwcGJyaWRnZS5jYYIOKi5hcHBicmlkZ2UuY2GC
    DGFwcGJyaWRnZS5pb4IOKi5hcHBicmlkZ2UuaW+CDGFwcGJyaWRnZS5pdIIOKi5h
    cHBicmlkZ2UuaXSCCmFwdHVyZS5jb22CDCouYXB0dXJlLmNvbYIRYmVhdHRoYXRx
    dW90ZS5jb22CEyouYmVhdHRoYXRxdW90ZS5jb22CCWJsaW5rLm9yZ4ILKi5ibGlu
    ay5vcmeCCmJyb3RsaS5vcmeCDCouYnJvdGxpLm9yZ4INYnVtcHNoYXJlLmNvbYIP
    Ki5idW1wc2hhcmUuY29tggpidW1wdG9wLmNhggwqLmJ1bXB0b3AuY2GCDWJ1bXB0
    dW5lcy5jb22CDyouYnVtcHR1bmVzLmNvbYILYnVtcHRvcC5jb22CDSouYnVtcHRv
    cC5jb22CC2J1bXB0b3AubmV0gg0qLmJ1bXB0b3AubmV0ggtidW1wdG9wLm9yZ4IN
    Ki5idW1wdG9wLm9yZ4IWYnVzaW5lc3Njb25uZWN0Lmdvb2dsZYIYKi5idXNpbmVz
    c2Nvbm5lY3QuZ29vZ2xlghBjYW1wdXNsb25kb24uY29tghIqLmNhbXB1c2xvbmRv
    bi5jb22CHGNlcnRpZmljYXRlLXRyYW5zcGFyZW5jeS5vcmeCHiouY2VydGlmaWNh
    dGUtdHJhbnNwYXJlbmN5Lm9yZ4IKY2hyb21lLmNvbYIMKi5jaHJvbWUuY29tgg5j
    aHJvbWVjYXN0LmNvbYIQKi5jaHJvbWVjYXN0LmNvbYIMY2hyb21pdW0ub3Jngg4q
    LmNocm9taXVtLm9yZ4IVKi5pc3N1ZXMuY2hyb21pdW0ub3JnghljbGlja3NlcnZl
    LmRhcnRzZWFyY2gubmV0ghxjbGlja3NlcnZlLnVrLmRhcnRzZWFyY2gubmV0ghxj
    bGlja3NlcnZlLmV1LmRhcnRzZWFyY2gubmV0gh1jbGlja3NlcnZlLnVzMi5kYXJ0
    c2VhcmNoLm5ldIIZY2xpY2tzZXJ2ZXIuZ29vZ2xlYWRzLmNvbYIWY2xvdWRidXJz
    dHJlc2VhcmNoLmNvbYIYKi5jbG91ZGJ1cnN0cmVzZWFyY2guY29tghJjbG91ZGZ1
    bmN0aW9ucy5uZXSCFCouY2xvdWRmdW5jdGlvbnMubmV0ghFjbG91ZHJvYm90aWNz
    LmNvbYITKi5jbG91ZHJvYm90aWNzLmNvbYIaY29kZWFzc2lzdC1hdXRvcHVzaC5n
    b29nbGWCGWNvZGVhc3Npc3Qtc3RhZ2luZy5nb29nbGWCEWNvZGVhc3Npc3QuZ29v
    Z2xlgg1jb25zY3J5cHQuY29tgg8qLmNvbnNjcnlwdC5jb22CDWNvbnNjcnlwdC5v
    cmeCDyouY29uc2NyeXB0Lm9yZ4IRY29va2llY2hvaWNlcy5vcmeCFXd3dy5jb29r
    aWVjaG9pY2VzLm9yZ4IJY29vdmEuY29tggsqLmNvb3ZhLmNvbYIJY29vdmEubmV0
    ggsqLmNvb3ZhLm5ldIIJY29vdmEub3JnggsqLmNvb3ZhLm9yZ4IUY29udGFjdGNl
    bnRlci5nb29nbGWCFiouY29udGFjdGNlbnRlci5nb29nbGWCGmNyZWF0b3JhY2Fk
    ZW15LnlvdXR1YmUuY29tgh53d3cuY3JlYXRvcmFjYWRlbXkueW91dHViZS5jb22C
    B2Nyci5jb22CCSouY3JyLmNvbYIJY3M0aHMuY29tggsqLmNzNGhzLmNvbYIJZGVi
    dWcuY29tggsqLmRlYnVnLmNvbYIQZGVidWdwcm9qZWN0LmNvbYISKi5kZWJ1Z3By
    b2plY3QuY29tgghkb3MuZ29vZ4IWc3R4bW9zcXVpdG9wcm9qZWN0LmNvbYIYKi5z
    dHhtb3NxdWl0b3Byb2plY3QuY29tghZzdHhtb3NxdWl0b3Byb2plY3QubmV0ghgq
    LnN0eG1vc3F1aXRvcHJvamVjdC5uZXSCFnN0eG1vc3F1aXRvcHJvamVjdC5vcmeC
    GCouc3R4bW9zcXVpdG9wcm9qZWN0Lm9yZ4Iac3Rjcm9peG1vc3F1aXRvcHJvamVj
    dC5jb22CHCouc3Rjcm9peG1vc3F1aXRvcHJvamVjdC5jb22CFnN5bnRoaWR0ZXh0
    ZGVtby5nb29nbGWCGCouc3ludGhpZHRleHRkZW1vLmdvb2dsZYIXdXN2aW1vc3F1
    aXRvcHJvamVjdC5jb22CGSoudXN2aW1vc3F1aXRvcHJvamVjdC5jb22CD3N0eG1v
    c3F1aXRvLmNvbYIRKi5zdHhtb3NxdWl0by5jb22CE3N0Y3JvaXhtb3NxdWl0by5j
    b22CFSouc3Rjcm9peG1vc3F1aXRvLmNvbYIQdXN2aW1vc3F1aXRvLmNvbYISKi51
    c3ZpbW9zcXVpdG8uY29tgg1kZXNpZ24uZ29vZ2xlgg8qLmRlc2lnbi5nb29nbGWC
    EmVudmlyb25tZW50Lmdvb2dsZYIUKi5lbnZpcm9ubWVudC5nb29nbGWCDGVwaXNv
    ZGljLmNvbYIOKi5lcGlzb2RpYy5jb22CC2ZhbWViaXQuY29tgg0qLmZhbWViaXQu
    Y29tggdmYml0LmNvggkqLmZiaXQuY2+CDmZlZWRidXJuZXIuY29tghAqLmZlZWRi
    dXJuZXIuY29tggpmZmxpY2suY29tggwqLmZmbGljay5jb22CFmZpbmFuY2VsZWFk
    c29ubGluZS5jb22CGCouZmluYW5jZWxlYWRzb25saW5lLmNvbYIJZy10dW4uY29t
    ggsqLmctdHVuLmNvbYIVZ2JjLmJlYXR0aGF0cXVvdGUuY29tghcqLmdiYy5iZWF0
    dGhhdHF1b3RlLmNvbYIUZ2Vycml0Y29kZXJldmlldy5jb22CFiouZ2Vycml0Y29k
    ZXJldmlldy5jb22CHSouaXNzdWVzLmdlcnJpdGNvZGVyZXZpZXcuY29tgg5nZXRi
    dW1wdG9wLmNvbYIQKi5nZXRidW1wdG9wLmNvbYIRZ2RtLXNpYS1kZW1vLmdvb2eC
    EyouZ2RtLXNpYS1kZW1vLmdvb2eCDGdpcHNjb3JwLmNvbYIOKi5naXBzY29ycC5j
    b22CDWdsb2JhbGVkdS5vcmeCDyouZ2xvYmFsZWR1Lm9yZ4IQZ29uZ2xjaHVhbmds
    Lm5ldIISKi5nb25nbGNodWFuZ2wubmV0gg1nb29nbGUuYmVybGlugg8qLmdvb2ds
    ZS5iZXJsaW6CCmdvb2dsZS5vcmeCDCouZ29vZ2xlLm9yZ4IPZ29vZ2xlLnZlbnR1
    cmVzghEqLmdvb2dsZS52ZW50dXJlc4IOZ29vZ2xlYXBwcy5jb22CECouZ29vZ2xl
    YXBwcy5jb22CE2dvb2dsZWNvbXBhcmUuY28udWuCFSouZ29vZ2xlY29tcGFyZS5j
    by51a4IRZ29vZ2xlZGFubWFyay5jb22CEyouZ29vZ2xlZGFubWFyay5jb22CEWdv
    b2dsZWZpbmxhbmQuY29tghMqLmdvb2dsZWZpbmxhbmQuY29tgg5nb29nbGVtYXBz
    LmNvbYIQKi5nb29nbGVtYXBzLmNvbYIQZ29vZ2xlcGhvdG9zLmNvbYISKi5nb29n
    bGVwaG90b3MuY29tgg5nb29nbGVwbGF5LmNvbYIQKi5nb29nbGVwbGF5LmNvbYIO
    Z29vZ2xlcGx1cy5jb22CECouZ29vZ2xlcGx1cy5jb22CEWdvb2dsZXN2ZXJpZ2Uu
    Y29tghMqLmdvb2dsZXN2ZXJpZ2UuY29tghpnb29nbGV0cmF2ZWxhZHNlcnZpY2Vz
    LmNvbYIcKi5nb29nbGV0cmF2ZWxhZHNlcnZpY2VzLmNvbYINZ3JpZGF3YXJlLmFw
    cIIPKi5ncmlkYXdhcmUuYXBwggdnc3JjLmlvggkqLmdzcmMuaW+CCmdzdWl0ZS5j
    b22CDCouZ3N1aXRlLmNvbYIPaGRycGx1c2RhdGEub3JnghEqLmhkcnBsdXNkYXRh
    Lm9yZ4IMaGluZGl3ZWIuY29tgg4qLmhpbmRpd2ViLmNvbYIQaG93dG9nZXRtby5j
    by51a4ISKi5ob3d0b2dldG1vLmNvLnVrgg5odG1sNXJvY2tzLmNvbYIQKi5odG1s
    NXJvY2tzLmNvbYIIaHdnby5jb22CCiouaHdnby5jb22CDWltcGVybWl1bS5jb22C
    DyouaW1wZXJtaXVtLmNvbYIKajJvYmpjLm9yZ4IMKi5qMm9iamMub3JnghNrZXl0
    cmFuc3BhcmVuY3kuY29tghUqLmtleXRyYW5zcGFyZW5jeS5jb22CE2tleXRyYW5z
    cGFyZW5jeS5mb2+CFSoua2V5dHJhbnNwYXJlbmN5LmZvb4ITa2V5dHJhbnNwYXJl
    bmN5Lm9yZ4IVKi5rZXl0cmFuc3BhcmVuY3kub3Jngg9sYXRlbnRsb2dpYy5jb22C
    ESoubGF0ZW50bG9naWMuY29tggtsaW5rLmdvb2dsZYINKi5saW5rLmdvb2dsZYIL
    bWRpYWxvZy5jb22CDSoubWRpYWxvZy5jb22CEW1mZy1pbnNwZWN0b3IuY29tghMq
    Lm1mZy1pbnNwZWN0b3IuY29tgg9tb2JpbGV2aWV3LnBhZ2WCESoubW9iaWxldmll
    dy5wYWdlgg5tb29kc3RvY2tzLmNvbYIQKi5tb29kc3RvY2tzLmNvbYIPbjMzOS5h
    c3AtY2MuY29tggduZWFyLmJ5ggkqLm5lYXIuYnmCCm9hdXRoei5jb22CDCoub2F1
    dGh6LmNvbYIUb21uaWRldmljZWxhYi5nb29nbGWCFioub21uaWRldmljZWxhYi5n
    b29nbGWCB29uLmhlcmWCCSoub24uaGVyZYIHb24yLmNvbYIJKi5vbjIuY29tghdv
    bmV3b3JsZG1hbnlzdG9yaWVzLmNvbYIZKi5vbmV3b3JsZG1hbnlzdG9yaWVzLmNv
    bYIJb3BhbC5nb29nggsqLm9wYWwuZ29vZ4IWcGFnZXNwZWVkbW9iaWxpemVyLmNv
    bYIYKi5wYWdlc3BlZWRtb2JpbGl6ZXIuY29tgg1wYWdldmlldy5tb2Jpgg8qLnBh
    Z2V2aWV3Lm1vYmmCFHBhcnR5bGlrZWl0czE5ODYub3JnghYqLnBhcnR5bGlrZWl0
    czE5ODYub3Jngg5wYXhsaWNlbnNlLm9yZ4IQKi5wYXhsaWNlbnNlLm9yZ4IMcGVu
    amEuZ29vZ2xlgg4qLnBlbmphLmdvb2dsZYIacGluZy5mZWVkYnVybmVyLmdvb2ds
    ZS5jb22CDHBpdHRwYXR0LmNvbYIOKi5waXR0cGF0dC5jb22CEnBvbHltZXJwcm9q
    ZWN0Lm9yZ4IUKi5wb2x5bWVycHJvamVjdC5vcmeCD3BvcHVsb3VzLnN0dWRpb4IR
    Ki5wb3B1bG91cy5zdHVkaW+CC3Bvc3RpbmkuY29tgg0qLnBvc3RpbmkuY29tgg9x
    dWVzdHZpc3VhbC5jb22CESoucXVlc3R2aXN1YWwuY29tggtxdWlrc2VlLmNvbYIN
    Ki5xdWlrc2VlLmNvbYIRcXVpY2tzaGFyZS5nb29nbGWCEyoucXVpY2tzaGFyZS5n
    b29nbGWCHHF1b3RlcHJveHkuYmVhdHRoYXRxdW90ZS5jb22CHioucXVvdGVwcm94
    eS5iZWF0dGhhdHF1b3RlLmNvbYIKcmF4aXVtLmNvbYIMKi5yYXhpdW0uY29tgg1y
    ZWNhcHRjaGEubmV0gg8qLnJlY2FwdGNoYS5uZXSCCnJldm9sdi5jb22CDCoucmV2
    b2x2LmNvbYIPcmlkZXBlbmd1aW4uY29tghEqLnJpZGVwZW5ndWluLmNvbYIWcm9v
    dG11c2ljLmJhbmRwYWdlLmNvbYIQd3d3LmJhbmRwYWdlLmNvbYIScy5zdmMtMS5n
    b29nbGUuY29tghQqLnMuc3ZjLTEuZ29vZ2xlLmNvbYIKc2FnZXR2LmNvbYIMKi5z
    YWdldHYuY29tggpzYXlub3cuY29tggwqLnNheW5vdy5jb22CC3NjaGVtZXIuY29t
    gg0qLnNjaGVtZXIuY29tghRzY3JlZW53aXNldHJlbmRzLmNvbYIWKi5zY3JlZW53
    aXNldHJlbmRzLmNvbYIZc2NyZWVud2lzZXRyZW5kc3BhbmVsLmNvbYIbKi5zY3Jl
    ZW53aXNldHJlbmRzcGFuZWwuY29tghdzZWFyY2hwbGF5Z3JvdW5kLmdvb2dsZYIZ
    Ki5zZWFyY2hwbGF5Z3JvdW5kLmdvb2dsZYIMc2hhcmUuZ29vZ2xlgg4qLnNoYXJl
    Lmdvb2dsZYIOc3RyYXRvem9uZS5jb22CECouc3RyYXRvem9uZS5jb22CEHN1cHBs
    aWVycy5nb29nbGWCEiouc3VwcGxpZXJzLmdvb2dsZYIScmV3YXJkcy5nb29nbGUu
    Y29tghQqLnJld2FyZHMuZ29vZ2xlLmNvbYIMc25hcHNlZWQuY29tgg4qLnNuYXBz
    ZWVkLmNvbYINc29sdmVmb3J4LmNvbYIPKi5zb2x2ZWZvcnguY29tgg9zcGFya2lm
    eS5nb29nbGWCESouc3BhcmtpZnkuZ29vZ2xlgg1zeW5lcmd5c2UuY29tgg8qLnN5
    bmVyZ3lzZS5jb22CEXRhZ3N1cHBvcnQuZ29vZ2xlghMqLnRhZ3N1cHBvcnQuZ29v
    Z2xlghJ0aGVjbGV2ZXJzZW5zZS5jb22CFCoudGhlY2xldmVyc2Vuc2UuY29tghR0
    aGlua3F1YXJ0ZXJseS5jby51a4IWKi50aGlua3F1YXJ0ZXJseS5jby51a4ISdGhp
    bmtxdWFydGVybHkuY29tghQqLnRoaW5rcXVhcnRlcmx5LmNvbYILdHhjbG91ZC5u
    ZXSCDSoudHhjbG91ZC5uZXSCCXR4dmlhLmNvbYILKi50eHZpYS5jb22CDXVzZXBs
    YW5uci5jb22CDyoudXNlcGxhbm5yLmNvbYINdjhwcm9qZWN0Lm9yZ4IPKi52OHBy
    b2plY3Qub3Jngg52ZWxvc3RyYXRhLmNvbYIQKi52ZWxvc3RyYXRhLmNvbYIZdmlk
    ZW9yZXZpZXdjb25zb2xlLmdvb2dsZYIbKi52aWRlb3Jldmlld2NvbnNvbGUuZ29v
    Z2xlgg92aXJ0dWFsLWFwcC5jb22CESoudmlydHVhbC1hcHAuY29tghV2aXJ0dWFs
    YXBwZGVsaXZlcnkuY2+CFyoudmlydHVhbGFwcGRlbGl2ZXJ5LmNvghZ2aXJ0dWFs
    YXBwZGVsaXZlcnkuY29tghgqLnZpcnR1YWxhcHBkZWxpdmVyeS5jb22CFXZpcnR1
    YWxhcHBkZWxpdmVyeS5pb4IXKi52aXJ0dWFsYXBwZGVsaXZlcnkuaW+CFnZpcnR1
    YWxhcHBkZWxpdmVyeS5uZXSCGCoudmlydHVhbGFwcGRlbGl2ZXJ5Lm5ldIIWdmly
    dHVhbGFwcGRlbGl2ZXJ5Lm9yZ4IYKi52aXJ0dWFsYXBwZGVsaXZlcnkub3Jnggp3
    YWxsZXQuY29tggwqLndhbGxldC5jb22CCXdheW1vLmNvbYILKi53YXltby5jb22C
    CHdhemUuY29tggoqLndhemUuY29tghR3ZWJhcHBmaWVsZGd1aWRlLmNvbYIWKi53
    ZWJhcHBmaWVsZGd1aWRlLmNvbYIKd2ViZ3B1LmRldoIMKi53ZWJncHUuZGV2ggl3
    ZWJncHUuaW+CCyoud2ViZ3B1LmlvghJ3ZWx0d2VpdHdhY2hzZW4uZGWCFnd3dy53
    ZWx0d2VpdHdhY2hzZW4uZGWCD3doYXRicm93c2VyLm9yZ4IRKi53aGF0YnJvd3Nl
    ci5vcmeCDXdvbWVud2lsbC5jb22CDyoud29tZW53aWxsLmNvbYIMd29tZW53aWxs
    Lmlkgg4qLndvbWVud2lsbC5pZIIMd29tZW53aWxsLmlugg4qLndvbWVud2lsbC5p
    boIQd29tZW53aWxsLmNvbS5icoISKi53b21lbndpbGwuY29tLmJyggx3b21lbndp
    bGwubXiCDioud29tZW53aWxsLm14ghV3b3JrYmVuY2hwbGF0Zm9ybS5jb22CFyou
    d29ya2JlbmNocGxhdGZvcm0uY29tghZ3b3JrYmVuY2hlZHVjYXRpb24uY29tghgq
    LndvcmtiZW5jaGVkdWNhdGlvbi5jb22CFndvcmtiZW5jaGVkdWNhdGlvbi5uZXSC
    GCoud29ya2JlbmNoZWR1Y2F0aW9uLm5ldIIKd3JrYm5jaC5pb4IMKi53cmtibmNo
    Lmlvgg13b3JkLWxlbnMuY29tgg8qLndvcmQtbGVucy5jb22CDHdvcmRsZW5zLmNv
    bYIOKi53b3JkbGVucy5jb22CDHdvcmRsZW5zLm5ldIIOKi53b3JkbGVucy5uZXSC
    CXguY29tcGFueYILKi54LmNvbXBhbnmCBngudGVhbYIIKi54LnRlYW2CDHh2aWFk
    dWN0LmFwcIIOKi54dmlhZHVjdC5hcHCCGHlvdXR1YmVtb2JpbGVzdXBwb3J0LmNv
    bYIaKi55b3V0dWJlbW9iaWxlc3VwcG9ydC5jb22CFHp1a3VuZnRzd2Vya3N0YXR0
    LmRlghh3d3cuenVrdW5mdHN3ZXJrc3RhdHQuZGWCICoubm9ydGhhbWVyaWNhLmFw
    aWdlZS5nb29nbGUuY29tghMqLmFwaWdlZS5nb29nbGUuY29tghVhY2NvdW50cy5t
    YW5kaWFudC5jb22CGHByb2FjdGl2ZS52aXJ1c3RvdGFsLmNvbYIaKi5wcm9hY3Rp
    dmUudmlydXN0b3RhbC5jb22CIyoubG9va2VyLXN0YWdpbmcuY2hyb25pY2xlLnNl
    Y3VyaXR5gg14d2ZhcHAuZ29vZ2xlgg8qLnh3ZmFwcC5nb29nbGWCGmJhbmR3aWR0
    aC52b2ljZS5nb29nbGUuY29tghZhdXRvZGF0YXRvb2xraXQuZ29vZ2xlghgqLmF1
    dG9kYXRhdG9vbGtpdC5nb29nbGUwEwYDVR0gBAwwCjAIBgZngQwBAgEwNgYDVR0f
    BC8wLTAroCmgJ4YlaHR0cDovL2MucGtpLmdvb2cvd3IyLzc1cjRaeUEzdkEwLmNy
    bDCCAQUGCisGAQQB1nkCBAIEgfYEgfMA8QB2AJaXZL9VWJet90OHaDcIQnfp8DrV
    9qTzNm5GpD8PyqnGAAABmuUh8IcAAAQDAEcwRQIhAKMKc2Pg82rIC7gRbHBP7grc
    FrP7i9pDC20eZ45TkJz+AiA33trHgpdHLGJlbWgSvEMUqsMq4KLZU9upgBOx2twf
    CgB3ABaDLavwqSUPD/A6pUX/yL/II9CHS/YEKSf45x8zE/X6AAABmuUh8IcAAAQD
    AEgwRgIhAOOqQPf0ffl4qWNLALvpVKuBguKvTSn+VVsVMz9uZtrMAiEApBNKfc+z
    e0mkWsUWI577e7qY4oCxDGfHvGPoxzHyWswwDQYJKoZIhvcNAQELBQADggEBAEaz
    5My+LzNViBNOy+qnBSW24RMCIVbV3nZQylZQepe/pcrlUPafEMzEZgtQCNFPUW9J
    hROXdFRKJ0gIFHvORkC05C+J1QTi1zB54LSdFDTjf+uJ2IeFdPa5yVVTspGoF9c9
    3O0xuJrNYcptbxiH7Ql6ZnvHvClCaEccdSwYUc51sU+2l5hg2CgWgFNKJ+GRoBgj
    UNPG4mrL1KcESG4UkYWsFGzR8ucqOLeYSjDqknaJIGXJai92QFBEgiu3hYyEl17Q
    69IfkShsBWM0gz5yTZUrqURfllKhB+tuqsAgpx5UvcNd8aUML/IFTJZneenMxvh+
    XrorFb9WOeOLA50fHJ4=
    -----END CERTIFICATE-----
     1 s:C=US, O=Google Trust Services, CN=WR2
       i:C=US, O=Google Trust Services LLC, CN=GTS Root R1
       a:PKEY: RSA, 2048 (bit); sigalg: sha256WithRSAEncryption
       v:NotBefore: Dec 13 09:00:00 2023 GMT; NotAfter: Feb 20 14:00:00 2029 GMT
    MIIFCzCCAvOgAwIBAgIQf/AFoHxM3tEArZ1mpRB7mDANBgkqhkiG9w0BAQsFADBH
    MQswCQYDVQQGEwJVUzEiMCAGA1UEChMZR29vZ2xlIFRydXN0IFNlcnZpY2VzIExM
    QzEUMBIGA1UEAxMLR1RTIFJvb3QgUjEwHhcNMjMxMjEzMDkwMDAwWhcNMjkwMjIw
    MTQwMDAwWjA7MQswCQYDVQQGEwJVUzEeMBwGA1UEChMVR29vZ2xlIFRydXN0IFNl
    cnZpY2VzMQwwCgYDVQQDEwNXUjIwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEK
    AoIBAQCp/5x/RR5wqFOfytnlDd5GV1d9vI+aWqxG8YSau5HbyfsvAfuSCQAWXqAc
    +MGr+XgvSszYhaLYWTwO0xj7sfUkDSbutltkdnwUxy96zqhMt/TZCPzfhyM1IKji
    aeKMTj+xWfpgoh6zySBTGYLKNlNtYE3pAJH8do1cCA8Kwtzxc2vFE24KT3rC8gIc
    LrRjg9ox9i11MLL7q8Ju26nADrn5Z9TDJVd06wW06Y613ijNzHoU5HEDy01hLmFX
    xRmpC5iEGuh5KdmyjS//V2pm4M6rlagplmNwEmceOuHbsCFx13ye/aoXbv4r+zgX
    FNFmp6+atXDMyGOBOozAKql2N87jAgMBAAGjgf4wgfswDgYDVR0PAQH/BAQDAgGG
    MB0GA1UdJQQWMBQGCCsGAQUFBwMBBggrBgEFBQcDAjASBgNVHRMBAf8ECDAGAQH/
    AgEAMB0GA1UdDgQWBBTeGx7teRXUPjckwyG77DQ5bUKyMDAfBgNVHSMEGDAWgBTk
    rysmcRorSCeFL1JmLO/wiRNxPjA0BggrBgEFBQcBAQQoMCYwJAYIKwYBBQUHMAKG
    GGh0dHA6Ly9pLnBraS5nb29nL3IxLmNydDArBgNVHR8EJDAiMCCgHqAchhpodHRw
    Oi8vYy5wa2kuZ29vZy9yL3IxLmNybDATBgNVHSAEDDAKMAgGBmeBDAECATANBgkq
    hkiG9w0BAQsFAAOCAgEARXWL5R87RBOWGqtY8TXJbz3S0DNKhjO6V1FP7sQ02hYS
    TL8Tnw3UVOlIecAwPJQl8hr0ujKUtjNyC4XuCRElNJThb0Lbgpt7fyqaqf9/qdLe
    SiDLs/sDA7j4BwXaWZIvGEaYzq9yviQmsR4ATb0IrZNBRAq7x9UBhb+TV+PfdBJT
    DhEl05vc3ssnbrPCuTNiOcLgNeFbpwkuGcuRKnZc8d/KI4RApW//mkHgte8y0YWu
    ryUJ8GLFbsLIbjL9uNrizkqRSvOFVU6xddZIMy9vhNkSXJ/UcZhjJY1pXAprffJB
    vei7j+Qi151lRehMCofa6WBmiA4fx+FOVsV2/7R6V2nyAiIJJkEd2nSi5SnzxJrl
    Xdaqev3htytmOPvoKWa676ATL/hzfvDaQBEcXd2Ppvy+275W+DKcH0FBbX62xevG
    iza3F4ydzxl6NJ8hk8R+dDXSqv1MbRT1ybB5W0k8878XSOjvmiYTDIfyc9acxVJr
    Y/cykHipa+te1pOhv7wYPYtZ9orGBV5SGOJm4NrB3K1aJar0RfzxC3ikr7Dyc6Qw
    qDTBU39CluVIQeuQRgwG3MuSxl7zRERDRilGoKb8uY45JzmxWuKxrfwT/478JuHU
    /oTxUFqOl2stKnn7QGTq8z29W+GgBLCXSBxC9epaHM0myFH/FJlniXJfHeytWt0=
     2 s:C=US, O=Google Trust Services LLC, CN=GTS Root R1
       i:C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA
       a:PKEY: RSA, 4096 (bit); sigalg: sha256WithRSAEncryption
       v:NotBefore: Jun 19 00:00:42 2020 GMT; NotAfter: Jan 28 00:00:42 2028 GMT
    MIIFYjCCBEqgAwIBAgIQd70NbNs2+RrqIQ/E8FjTDTANBgkqhkiG9w0BAQsFADBX
    MQswCQYDVQQGEwJCRTEZMBcGA1UEChMQR2xvYmFsU2lnbiBudi1zYTEQMA4GA1UE
    CxMHUm9vdCBDQTEbMBkGA1UEAxMSR2xvYmFsU2lnbiBSb290IENBMB4XDTIwMDYx
    OTAwMDA0MloXDTI4MDEyODAwMDA0MlowRzELMAkGA1UEBhMCVVMxIjAgBgNVBAoT
    GUdvb2dsZSBUcnVzdCBTZXJ2aWNlcyBMTEMxFDASBgNVBAMTC0dUUyBSb290IFIx
    MIICIjANBgkqhkiG9w0BAQEFAAOCAg8AMIICCgKCAgEAthECix7joXebO9y/lD63
    ladAPKH9gvl9MgaCcfb2jH/76Nu8ai6Xl6OMS/kr9rH5zoQdsfnFl97vufKj6bwS
    iV6nqlKr+CMny6SxnGPb15l+8Ape62im9MZaRw1NEDPjTrETo8gYbEvs/AmQ351k
    KSUjB6G00j0uYODP0gmHu81I8E3CwnqIiru6z1kZ1q+PsAewnjHxgsHA3y6mbWwZ
    DrXYfiYaRQM9sHmklCitD38m5agI/pboPGiUU+6DOogrFZYJsuB6jC511pzrp1Zk
    j5ZPaK49l8KEj8C8QMALXL32h7M1bKwYUH+E4EzNktMg6TO8UpmvMrUpsyUqtEj5
    cuHKZPfmghCN6J3Cioj6OGaK/GP5Afl4/Xtcd/p2h/rs37EOeZVXtL0m79YB0esW
    CruOC7XFxYpVq9Os6pFLKcwZpDIlTirxZUTQAs6qzkm06p98g7BAe+dDq6dso499
    iYH6TKX/1Y7DzkvgtdizjkXPdsDtQCv9Uw+wp9U7DbGKogPeMa3Md+pvez7W35Ei
    Eua++tgy/BBjFFFy3l3WFpO9KWgz7zpm7AeKJt8T11dleCfeXkkUAKIAf5qoIbap
    sZWwpbkNFhHax2xIPEDgfg1azVY80ZcFuctL7TlLnMQ/0lUTbiSw1nH69MG6zO0b
    9f6BQdgAmD06yK56mDcYBZUCAwEAAaOCATgwggE0MA4GA1UdDwEB/wQEAwIBhjAP
    BgNVHRMBAf8EBTADAQH/MB0GA1UdDgQWBBTkrysmcRorSCeFL1JmLO/wiRNxPjAf
    BgNVHSMEGDAWgBRge2YaRQ2XyolQL30EzTSo//z9SzBgBggrBgEFBQcBAQRUMFIw
    JQYIKwYBBQUHMAGGGWh0dHA6Ly9vY3NwLnBraS5nb29nL2dzcjEwKQYIKwYBBQUH
    MAKGHWh0dHA6Ly9wa2kuZ29vZy9nc3IxL2dzcjEuY3J0MDIGA1UdHwQrMCkwJ6Al
    oCOGIWh0dHA6Ly9jcmwucGtpLmdvb2cvZ3NyMS9nc3IxLmNybDA7BgNVHSAENDAy
    MAgGBmeBDAECATAIBgZngQwBAgIwDQYLKwYBBAHWeQIFAwIwDQYLKwYBBAHWeQIF
    AwMwDQYJKoZIhvcNAQELBQADggEBADSkHrEoo9C0dhemMXoh6dFSPsjbdBZBiLg9
    NR3t5P+T4Vxfq7vqfM/b5A3Ri1fyJm9bvhdGaJQ3b2t6yMAYN/olUazsaL+yyEn9
    WprKASOshIArAoyZl+tJaox118fessmXn1hIVw41oeQa1v1vg4Fv74zPl6/AhSrw
    9U5pCZEt4Wi4wStz6dTZ/CLANx8LZh1J7QJVj2fhMtfTJr9w4z30Z209fOU0iOMy
    +qduBmpvvYuR7hZL6Dupszfnw0Skfths18dG9ZKb59UhvmaSGZRVbNQpsg3BZlvi
    d0lIKO2d1xozclOzgjXPYovJJIultzkMu34qQb9Sz/yilrbCgj8=
    Server certificate
    subject=CN=misc.google.com
    issuer=C=US, O=Google Trust Services, CN=WR2
    No client certificate CA names sent
    Peer signing digest: SHA256
    Peer signature type: ecdsa_secp256r1_sha256
    Negotiated TLS1.3 group: X25519MLKEM768
    SSL handshake has read 12879 bytes and written 1665 bytes
    Verification: OK
    New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
    Protocol: TLSv1.3
    Server public key is 256 bit
    This TLS version forbids renegotiation.
    Compression: NONE
    Expansion: NONE
    No ALPN negotiated
    Early data was not sent
    Verify return code: 0 (ok)
    This is the cerrtifcate.pem that I'm using (is the last one in code above).
    I'm using NCS 3.1.1 and at the moment I'm NOT using "non-secure TF-M target".
    For building project i'm using  Target: nrf5340dk/nrf5340/cpuapp
    But I do not think that should be the problem because with amazon everything is working good.
    Thanking you in advance for everything.
    Kind regards.
    Thanks for sharing the certificate chain and details. From the openssl output, the Firebase Functions server presents a chain where the intermediate CA (WR2) uses an RSA-2048 key, and the root CA you provisioned (GTS Root R1) uses an RSA-4096 key. The Amazon DevAcademy example works because it uses an RSA-2048 root CA, which fits within the default limits. When using an RSA-4096 root CA, it can fail already while loading/parsing the certificate, which matches the error you see.
    To move forward, there are two options. Option 1 is to provision the intermediate CA instead of the root:
    Subject: C=US, O=Google Trust Services, CN=WR2
    Key size: RSA-2048
    Convert and include this certificate the same way as in the DevAcademy exercise and retry. This usually works without any additional TLS configuration changes.
    Option 2 if you prefer to keep using the RSA-4096 root CA, then you will need to increase TLS/mbedTLS limits to support 4096-bit RSA keys (for example, increasing the mbedTLS heap and MPI size). If you want to go this route, you may check out the configurations mentioned in this related devzone case.
    Best Regards,
    Syed Maysum
  • Hi and thank you very much for your response.
    Thanks to your valuable advice, I was able to solve the problem.
    This is the third project I’m developing for Nordic, and the support you provide is truly invaluable, which is why I always choose Nordic whenever I can.
    I would like to add the following information.
    In the past, I had already tried using the WR2 certificate, but if I remember correctly, I encountered an error during the handshake.
    To solve the problem, I followed the instructions I found in the link from your response.
    I am very grateful because I don’t have much experience with the HTTPS protocol, and your advice was EXTREMELY IMPORTANT. I had also tried asking my colleagues and friends, but none of them had considered this point.
    I have one last question:
    I noticed that disabling BLE makes the HTTPS protocol work much better, does that match with your experience?
    For me, disabling BLE is not a problem; it’s just information to better understand how it works.
    Thanks again for everything.
