Issues creating multiple LittleFS file systems in external flash
I'm having some issues creating multiple LittleFS file systems on a project.  This is part of a larger project, so I used the Zephyr LittleFS test code to create a demonstration of the problem I'm encountering:
https://github.com/repoocaj/littlefs
My project is currently being built with NCS 2.6.1 but we are working on updating to NCS 3.2.1.
What I'm trying to do is to create two LittleFS file systems on an external flash.  I want one smaller one that will be used for device data that that isn't updated very often, but must exist for the device to function correctly.  The second file system will be for logs generated by the device.  If logging fails at some point in the future, it is not a problem.  I wanted to separate the file systems so that if flash used for the loggin wears out, the device can still function correctly.
In my device tree, I have two entries defined in my fstab:
	fstab {
		compatible = "zephyr,fstab";
		app_fs: app_fs {
			compatible = "zephyr,fstab,littlefs";
			mount-point = "/fs";
			partition = <&app_fs_part>;
			automount;
			read-size = <16>;
			prog-size = <16>;
			cache-size = <64>;
			lookahead-size = <32>;
			block-cycles = <512>;
		log_fs: log_fs{
            mount-point = "/log";
            partition = <&log_fs_part>;
            automount;
            read-size = <16>;
            prog-size = <16>;
            cache-size = <4096>;
            lookahead-size = <64>;
            block-cycles = <128>;
I also have two partitions defined for my external flash:
&mx25r64 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		app_fs_part: partition@0 {
			label = "storage";
			reg = <0x00000000 0x00010000>;
		log_fs_part: partition@10000 {
			label = "logs";
			reg = <0x00010000 0x00050000>;
If I build this on my `master` branch with NCS 2.6.1 and flash it to a nRF58240DK, it works as expected.  I see two file systems of the expected size created on the external flash:
D: fs register 1: 0
I: littlefs partition at /fs
I: LittleFS version 2.5, disk version 2.0
D: FS area 0 at 0x0 for 65536 bytes
I: FS at mx25r6435f@0:0x0 is 16 0x1000-byte blocks with 512 cycle
I: sizes: rd 16 ; pr 16 ; ca 64 ; la 32
D: fs mounted at /fs
I: Automount /fs succeeded
I: littlefs partition at /log
D: FS area 1 at 0x10000 for 327680 bytes
I: FS at mx25r6435f@0:0x10000 is 80 0x1000-byte blocks with 512 cycle
I: sizes: rd 16 ; pr 16 ; ca 4096 ; la 64
D: fs mounted at /log
I: Automount /log succeeded
*** Booting nRF Connect SDK v3.5.99-ncs1-1-2-g0210b6b71faf ***
Sample program to r/w files on littlefs
Area 0 at 0x0 on mx25r6435f@0 for 65536 bytes
/fs was automounted
/fs: bsize = 16 ; frsize = 4096 ; blocks = 16 ; bfree = 14
Listing dir / ...
[DIR ] fs
[DIR ] log
Listing dir /fs ...
[FILE] boot_count (size = 1)
Listing dir /log ...
/fs/boot_count read count:2 (bytes: 1)
/fs/boot_count write new boot count 3: [wr:1]
I: /fs unmounted
D: fs unmounted from /fs
/fs unmount: 0
However, if I build the same project with NCS 2.8.0 and flash it to the same board, it doesn't work.  It's now using the internal flash and both file systems are using the same area of flash and are of the same size:
D: fs register 1: 0
I: LittleFS version 2.9, disk version 2.1
D: FS area 1 at 0xfa000 for 24576 bytes
I: FS at flash-controller@4001e000:0xfa000 is 6 0x1000-byte blocks with 512 cycle
E: WEST_TOPDIR/modules/fs/littlefs/lfs.c:1374: Corrupted dir pair at {0x0, 0x1}
W: can't mount (LFS -84); formatting
I: /fs mounted
*** Booting nRF Connect SDK v2.8.0-a2386bfc8401 ***
*** Using Zephyr OS v3.7.99-0bc3393fb112 ***
Area 1 at 0xfa000 on flash-controller@4001e000 for 24576 bytes
/fs was automounted
/fs: bsize = 16 ; frsize = 4096 ; blocks = 6 ; bfree = 4
Listing dir / ...
[DIR ] fs
[DIR ] log
Listing dir /fs ...
/fs/boot_count read count:0 (bytes: 0)
/fs/boot_count write new boot count 1: [wr:1]
I: /fs unmounted
/fs unmount: 0
Although, it is using some of the information from the fstab device tree entry.  For example, the `lookahead-size` for the first file system is defined as 32 and the second as 64.  Those are correctly listed in the output above as `la 32` and `la 64`.
So my first question is why is this happening?
I also tried enabling MCUboot on this example as that is necessary on my larger project for DFU.  I found that when I enabled MCUboot and built with NCS 2.6.1, I observe output similar to that seen when building with 2.8.0:
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Image index: 0, Swap type: none
I: boot_image_check_hook: 1
I: boot_image_check()
I: bootutil_img_validate()
I: bootutil_tlv_iter_next: 0
I:   type: 16
I: EXPECTED_HASH_TLV
I:   type: 1
I: IMAGE_TLV_KEYHASH
I:   type: 34
I: EXPECTED_SIG_TLV
I: bootutil_verify_sig: 0
I: bootutil_tlv_iter_next: 1
I: valid_signature: 0
I: boot_image_check: 0
I: Valid header
I: Bootloader chainload address offset: 0xc000
D: fs register 1: 0irst image slot
D: FS area 6 at 0xfa000 for 24576 bytes
E: WEST_TOPDIR/modules/fs/littlefs/lfs.c:1234: Corrupted dir pair at {0x0, 0x1}
I: /fs mounted
Area 6 at 0xfa000 on flash-controller@4001e000 for 24576 bytes
/fs was automounted
Listing dir / ...
[DIR ] fs
[DIR ] log
Listing dir /fs ...
I: /fs unmounted
/fs unmount: 0
That is, it's creating the partitions in internal flash instead of external and they're of the wrong size and both are mounting the same location.
I'm assuming that this is something to do with the partition manager was wondering if anyone else has encountered this and what they might have done to solve it.
I tried building this example with NCS 3.2.1 just to make sure I wasn't missing a fix that had been added to Zephy or NCS but that build also doesn't work correctly.
Thanks for any help and advice!
Jeff
  • Hi Jeff,
    Jeff said:
    Now everything (including block-cycles) has changed to match the device tree fstab values except for the size of the partition.
    In NCS v3.2.1 all sizes should match fstab values. The partition sizes are expected to be taken from partition manager static configuration.
    You can try out configuration files shown below (2 lfs_part partitions of 64 KB and 1 MB are made in external flash as can be seen from partition manager report)
    pm_static.yml
    app:
      address: 0x0
      end_address: 0x100000
      region: flash_primary
    external_flash:
      address: 0x6000
      end_address: 0x800000
      region: external_flash
    littlefs_storage:
      address: 0x0
      device: DT_CHOSEN(nordic_pm_ext_flash)
      end_address: 0x6000
      placement:
        before:
        - tfm_storage
        - end
    lfs_part_1:
      address: 0x6000
      end_address: 0x16000
      placement:
        before:
        - tfm_storage
        - end
    lfs_part_2:
      address: 0x16000
      end_address: 0x116000
      placement:
        before:
        - tfm_storage
        - end
    sram_primary:
      address: 0x20000000
      end_address: 0x20040000
      region: sram_primary
    nrf52840dk_nrf52840.overlay
     * Copyright (c) 2019 Peter Bigot Consulting, LLC
    	chosen {
    		nordic,pm-ext-flash = &mx25r64;
    /delete-node/ &storage_partition;
    	fstab {
    		app_fs: app_fs {
    			automount;
    			read-size = <16>;
    			prog-size = <16>;
    			cache-size = <64>;
    		log_fs: log_fs{
                automount;
                read-size = <16>;
                prog-size = <16>;
    		log_fs_2: log_fs_2{
                mount-point = "/log_2";
                partition = <&log_fs_part_2>;
                automount;
                read-size = <16>;
                prog-size = <16>;
    &mx25r64 {
    	partitions {
    		#size-cells = <1>;
    			label = "storage";
    			label = "logs";
    		log_fs_part_2: partition@50000 {
    			label = "logs_2";
    			reg = <0x00050000 0x00090000>;
    Partition manager report (west build -t partition_manger_report)
    external_flash (0x800000 - 8192kB):
    | 0x0: littlefs_storage (0x6000 - 24kB)      |
    | 0x6000: external_flash (0x7fa000 - 8168kB) |
    | 0x6000: lfs_part_1 (0x10000 - 64kB)        |
    | 0x16000: lfs_part_2 (0x100000 - 1024kB)    |
      flash_primary (0x100000 - 1024kB):
    | 0x0: app (0x100000 - 1024kB) |
      sram_primary (0x40000 - 256kB):
    | 0x20000000: sram_primary (0x40000 - 256kB) |
    Jeff said:
    If I need to create a 'pm_static.yml' to define my partitions for the partition manager, how does that relate to the device tree fstab entries?
    When partition manager is used, entries in the devicetree are not used.
    For having multiple littlefs partitions when using partition manager, following SDK changes are also needed:
    diff --git a/subsys/fs/littlefs_fs.c b/subsys/fs/littlefs_fs.c
    index 5abbf95f949..0e155437fc5 100644
    --- a/subsys/fs/littlefs_fs.c
    +++ b/subsys/fs/littlefs_fs.c
    @@ -1105,8 +1105,8 @@ struct fs_mount_t FS_FSTAB_ENTRY(DT_DRV_INST(inst)) = { \
            .fs_data = &fs_data_##inst, \
            .storage_dev = (void *) \
                    COND_CODE_1(USE_PARTITION_MANAGER, \
    -                           (COND_CODE_1(FIXED_PARTITION_EXISTS(littlefs_storage), \
    -                                        (FIXED_PARTITION_ID(littlefs_storage)), \
    +                           (COND_CODE_1(FIXED_PARTITION_EXISTS(lfs_part##inst), \
    +                                        (FIXED_PARTITION_ID(lfs_part##inst)), \
                                             (FIXED_PARTITION_ID(storage)))), \
                                (DT_FIXED_PARTITION_ID(FS_PARTITION(inst)))), \
            .flags = FSTAB_ENTRY_DT_MOUNT_FLAGS(DT_DRV_INST(inst)), \
    Dejan
  • Did you ever solve this or did Jeff give up on the grounds that this is so spectacularly complicated? Here's the thing. I'd also like to put little fs onto external flash after the secondary app partition. It sounds like you don't have a working recipe and are cobbling together a process where you create a starting point that generates a partition.yml. Then you hand modify the partition.yml and save it as static_pm.yml. Do I have that right?
  • I did get a working solution but then got sidetracked onto a higher priority issue and am just getting back to this.
    Dejan's reply above was almost correct. When he patched the SDK, he named the new partitions 'lfs_part_X' where X is a digit starting at 0.  The entries in the pm_static.yml need to start at 0(not 1 as given in his example code.  After making that change, I could mount two different partitions.
    My final .overlay file has these sections in it:
        /* External flash definition. */
        ext_flash: w25q128jv@0  {
    		compatible = "jedec,spi-nor";
    		reg = <0>;
    		spi-max-frequency = <100000000>;    // HW max is 133 MHz
    		jedec-id = [ef 70 18];
    		size = <0x8000000>;                 // Memory's size in bits (128 Mbits)
            partitions {
                #size-cells = <1>;
                app_fs: partition@0 {
                    status = "okay";
                    // label is only used to document entry in pm_static.yml
                    label = "lfs_part_0";
                    reg = <0x0 0x500000>;       // Partition size in bytes (5 MBytes)
                log_fs: partition@500000 {
                    status = "okay";
                    label = "lfs_part_1";
                    reg = <0x500000 0x900000>;  // Partition size in bytes (9 MBytes)
        /* Configuration for littleFS to be mounted before boot */
        fstab {
            fs: fs{
                partition = <&app_fs>;
                automount;
                read-size = <16>;
                prog-size = <16>;
            log: log{
                mount-point = "/data";
                partition = <&log_fs>;
                automount;
                read-size = <16>;
                prog-size = <16>;
    My pm_static.yml contains:
    # The external partitions need to follow the naming pattern defined in
    # zephyr/subsys/fs/littlefs_fs.c of the NCS SDK that is used to build the
    # application.  This defaults to 'littlefs_storage' in the standard release
    # which only allows a single instance of a LittleFS filesystem to be defined.
    # Our fork of the SDK has been patched to change this to 'lfs_part_?' which
    # allows multiple partitions to be defined.
    lfs_part_0:
      address: 0x0
      end_address: 0x500000
    lfs_part_1:
      address: 0x500000
      end_address: 0x1000000
    I think I also had an issue with the system still wanting to create a 'littlefs_storage' partition and ended up setting this in my prj.conf to stop that:
    # Set the size of the 'littlefs_storage' partition to zero, so that it doesn't get created
    CONFIG_PM_PARTITION_SIZE_LITTLEFS=0x0
    I plan on updating my example code repo to show a working example but haven't had the time to do that yet.
    Hopefully this will get you started on the right path.
    Jeff
  • You must have the patience of a saint to have figured that out. Well done and thanks for sharing the solution in such a digestible format.
