Hi Luca,
It looks like the Fast Pair advertising is not set active during your test for some reason. The phone might be falling back to the 2 s interval. In the Locator Tag sample, Fast Pair advertising is only enabled when the pairing‑mode trigger is active, and it is explicitly turned off after the first Account Key write / provisioning. Make sure pairing mode is ON before starting the test and stays ON throughout it. On nRF52 DK the sample expects you to re‑enter pairing mode after each test step (Button 1 I think). Verif that in your logs that the Fast pair is activated.
check in code where fp_adv_pairing_mode_request is set to false and temporarily for testing set that to true to understand if this is contributing to the failing test. if you comment out fp_adv_pairing_mode_request set to false, then the fast pairing will stay active during the entirety of your test.
Make sure that the phone does not have any bonded paired entries for your device under test.
Hi Susheel,
first thank you for your answer.
What do you mean by this interval? If the DUT is not allowing to pair after receiving an Account Key, it should not work after a delay of 10s, or am I missing something? I only found a factory reset schedule which expires 5min after receiving the first account key.
Fast Pair advertising is enabled, but in the not-discoverable state. Which is the same as in Clock-Synchronization mode, as far as I understand, so it is not allowing to pair to a new phone.
Pressing Button 1 after a disconnect produces the Log message: "I: Fast Pair: pairing mode change is not available when the Account Key is in the NVM storage" and does not change the test outcome.
I did this in fmdn_provisioning_state_changed and fp_account_key_written (inside the main.c) which led to the test passing.
Please find attached the log for failing test (fp_adv_pairing_mode_request = false) see L.137 where Button 1 was pressed.
*** Booting NCS locator tag v3.1.1-107a3c48bbbb ***
*** Using nRF Connect SDK v3.1.1-e2a97fe2578a ***
*** Using Zephyr OS v4.1.99-ff8f0c579eeb ***
I: Starting Bluetooth Fast Pair locator tag sample 3.1.1
I: 2 Sectors of 4096 bytes
I: alloc wra: 0, f88
I: data wra: 0, 78
I: SoftDevice Controller build revision:
I: fc de 41 eb a2 d1 42 24 |..A...B$
I: 00 b5 f8 57 9f ac 9d 9e |...W....
I: aa c9 b4 34 |...4
I: HW Platform: Nordic Semiconductor (0x0002)
I: HW Variant: nRF52x (0x0002)
I: Firmware: Standard Bluetooth controller (0x00) Version 252.16862 Build 1121034987
I: No ID address. App must call settings_load()
I: Bluetooth initialized
I: HCI transport: SDC
I: Identity[0]: DE:92:EC:DD:B8:EA (random)
I: Identity[1]: F6:31:63:AE:26:E1 (random)
I: HCI: version 6.1 (0x0f) revision 0x1069, manufacturer 0x0059
I: LMP: version 6.1 (0x0f) subver 0x1069
I: Settings loaded
I: FMDN: setting battery level to 100 %
I: FMDN level: Normal
I: DULT level: Full
D: FMDN State: TX power set to 0 [dBm]
D: FMDN State: enabled
D: Motion detector is not running: owner nearby
I: DULT enabled
D: Fast Pair is enabled
I: Fast Pair Adv Manager: prepared the advertising set
I: Fast Pair Adv Manager: RPA expired
I: Fast Pair Adv Manager: RPA rotation in the inactive advertising state
I: Fast Pair Adv Manager: setting RPA timeout to 753 [s]
I: Fast Pair Adv Manager: module enabled
I: Fast Pair Adv Manager: advertising request from trigger "pairing_mode": enable
D: Fast Pair Adv Manager: set pairing mode to true
D: Fast Pair Adv Manager: set RPA rotation suspended to true
I: Fast Pair Adv Manager: triggers state change to: active
I: Fast Pair Adv Manager: advertising in the discoverable mode
I: Sample has started
I: Fast Pair Adv Manager: connected to 4D:0B:CB:A6:F2:04 (random)
W: Notify name not supported (KBP request)
D: Key-based Pairing write: res=80 conn=0x20002088
D: Confirmed passkey
D: Passkey write: res=16 conn=0x20002088
I: FMDN: connection authenticated using the Bluetooth bond: 0x20002088
I: Fast Pair Adv Manager: security changed: 4D:0B:CB:A6:F2:04 (random) level 4
D: Bonding complete
D: Account Key stored
I: Fast Pair Adv Manager: advertising request from trigger "fmdn_provisioning": enable
I: Fast Pair: Account Key write
I: Fast Pair Adv Manager: advertising request from trigger "pairing_mode": disable
D: Fast Pair Adv Manager: set pairing mode to false
D: Account Key write: res=16 conn=0x20002088
I: Fast Pair Adv Manager: disconnected from D4:3A:2C:8B:12:03 (public) (reason 19)
I: Fast Pair Adv Manager: advertising in the not-discoverable mode
I: Fast Pair Adv Manager: connected to D4:3A:2C:8B:12:03 (public)
I: Fast Pair Adv Manager: security changed: D4:3A:2C:8B:12:03 (public) level 4
I: Beacon Actions CCCD write, handle: 0, value: 0x0001
D: Beacon Actions GATT Read Request
D: Beacon Actions: challenge-response enabled for the next write:
D: 85 cb ef 79 0b a4 f5 e3 |...y....
D: Beacon Actions read: res=9 conn=0x20002088
D: Beacon Actions GATT Write Request:
D: 00 08 2a 4a 68 08 2c 1a |..*Jh.,.
D: 41 a0 |A.
D: Beacon Actions: consuming random nonce read operation
D: Beacon Actions: Beacon Parameters Read request: setting response TX power to 4 [dBm] encoded as 0x04
D: FMDN Clock: reading the last value: 628 [s]
D: Beacon Actions response:
D: 00 18 31 39 0f 82 8e a2 |..19....
D: 44 ae 3c 2a 03 b0 e5 33 |D.<*...3
D: 31 2f 26 b8 4a 65 db c9 |1/&.Je..
D: 55 3b |U;
I: FMDN: clock information synchronized with the authenticated Bluetooth peer
D: Beacon Actions write: res=10 conn=0x20002088
D: ee 51 a6 74 5f 37 f7 56 |.Q.t_7.V
D: 02 28 3a 91 a8 14 69 39 |.(:...i9
D: 9e 55 19 30 02 eb c5 21 |.U.0...!
D: 3b b4 5e 3f 05 79 63 57 |;.^?.ycW
D: 0f 55 db 9b 7a e6 f1 59 |.U..z..Y
D: b4 16 be 98 3c f5 bc 6f |....<..o
D: e6 b8 |..
I: Fast Pair Adv Manager: advertising request from trigger "fmdn_provisioning": disable
D: Fast Pair Adv Manager: set RPA rotation suspended to false
I: Fast Pair Adv Manager: triggers state change to: inactive
I: FMDN: state changed to provisioned
D: FMDN State: RPA expired
D: FMDN Clock: reading the last value: 629 [s]
D: FMDN State: calculating new rotation time: 395 s + 179 s
D: EID seed data:
D: ff ff ff ff ff ff ff ff |........
D: ff ff ff 0a 00 00 00 00 |........
D: 00 00 00 00 00 00 00 00 |........
D: 00 00 00 0a 00 00 00 00 |........
D: EIK:
D: ab 4d d5 88 67 0c 81 87 |.M..g...
D: c5 50 0c 26 14 32 3c c0 |.P.&.2<.
D: 50 d5 3c e0 a4 3e 5a d6 |P.<..>Z.
D: 8e 65 1c 76 6e 5b 6d 17 |.e.vn[m.
D: Encrypted EID seed data:
D: 33 aa 10 38 10 95 0e be |3..8....
D: 9a c7 35 4f 06 74 bb 4a |..5O.t.J
D: 6d f4 bd f8 34 ee 5a 10 |m...4.Z.
D: 22 05 5b 8e 56 e5 c1 c8 |".[.V...
D: EID:
D: 41 02 0b e4 f7 df 7b 73 |A.....{s
D: 0f 2b cf 40 9d 07 50 94 |[email protected].
D: 06 05 42 40 |..B@
D: FMDN State: Hashed Flags byte:
D: Bitmask: 0x02
D: Hash: 0xE0
D: Final value: 0xE2
D: FMDN State: FMDN Frame type: 0x40
D: FMDN State: rotating advertising payload
D: FMDN State: next rotation in 574 [s]
I: Fast Pair Adv Manager: the last timeout has occurred 29 [s] ago
D: FMDN State: forcing advertising payload rotation
D: FMDN State: advertising started
D: FMDN State: Successful provisioning of the EIK
D: 02 08 02 91 be cc 95 f4 |........
D: 45 26 |E&
D: Beacon Actions write: res=42 conn=0x20002088
I: Beacon Actions CCCD write, handle: 0, value: 0x0000
D: FMDN State: connected to D4:3A:2C:8B:12:03 (public)
I: FMDN: connection authenticated using the Bluetooth bond: 0x20002158
D: FMDN State: disconnected from D4:3A:2C:8B:12:03 (public) (reason 19)
D: 07 c6 95 73 7e d4 de bd |...s~...
D: Beacon Actions read: res=9 conn=0x20002158
D: 03 10 9f 7f 60 60 b5 57 |....``.W
D: 7d 0f 60 b2 65 58 cb 0f |}.`.eX..
D: 24 ff |$.
D: FMDN State: advertising stopped
I: Fast Pair Adv Manager: the last timeout has occurred 291 [s] ago
I: Fast Pair Adv Manager: setting RPA timeout to 765 [s]
I: FMDN: state changed to unprovisioned
D: FMDN State: Successful unprovisioning of the EIK
D: 03 08 d9 b6 63 cf f6 03 |....c...
D: 0e c9 |..
D: Beacon Actions write: res=18 conn=0x20002158
I: Performing reset to factory settings...
I: Fast Pair Adv Manager: module disabled
D: FMDN State: disabled
I: DULT reset completed
D: Fast Pair is disabled
I: Factory Reset: resetting Bluetooth identity within the factory reset
I: DULT enabled
I: Fast Pair Adv Manager: the last timeout has occurred 3 [s] ago
I: Fast Pair Adv Manager: setting RPA timeout to 770 [s]
I: Reset to factory settings has completed
I: The device has been reset to factory settings
I: Please press a button to put the device in the Fast Pair discoverable advertising mode
And for the passing test (fp_adv_pairing_mode_request = true)
I: alloc wra: 0, fe8
I: data wra: 0, 0
I: Identity: DE:92:EC:DD:B8:EA (random)
I: Settings loaded
I: DULT level: Full
I: DULT enabled
I: Fast Pair Adv Manager: setting RPA timeout to 808 [s]
I: Fast Pair Adv Manager: connected to 5D:F6:C0:88:2D:F4 (random)
I: Fast Pair Adv Manager: security changed: 5D:F6:C0:88:2D:F4 (random) level 4
D: Bonding complete
D: 7a 27 4d 04 bd 33 8b 40 |z'M..3.@
D: 00 08 63 a4 c7 f2 c3 95 |..c.....
D: f5 b4 |..
D: FMDN Clock: reading the last value: 43 [s]
D: 00 18 56 6e 2f b8 39 49 |..Vn/.9I
D: b2 32 d7 c8 19 b8 a8 2f |.2...../
D: 11 b9 b3 0d 68 15 2c 30 |....h.,0
D: 32 13 |2.
D: 3e 1a ff ba 79 08 de 6c |>...y..l
D: 02 28 fd 3c 47 b1 1b 75 |.(.<G..u
D: fe d8 25 f1 8f 3d 0b b7 |..%..=..
D: 65 dd 8f 82 db e7 83 fd |e.......
D: b1 e0 6e 90 6b 0c 89 35 |..n.k..5
D: 84 fc 4b ea cc e9 6d b5 |..K...m.
D: 23 97 |#.
D: FMDN Clock: reading the last value: 44 [s]
D: FMDN State: calculating new rotation time: 980 s + 157 s
D: EID seed data:
D: EIK:
D: ab d3 d1 02 2c 75 d6 eb |....,u..
D: e4 11 b4 d0 bc 0d 7e 70 |......~p
D: 6e 7f 63 91 34 c2 1e 2d |n.c.4..-
D: ad 17 a5 94 4f 17 75 f2 |....O.u.
D: 6c 9b 4f 79 a1 d4 ea 33 |l.Oy...3
D: 14 9e 87 65 e6 35 32 03 |...e.52.
D: 35 59 90 95 cf 25 76 2f |5Y...%v/
D: 27 55 7d 69 0c 44 13 97 |'U}i.D..
D: EID:
D: d2 bc e6 af ac c5 f3 49 |.......I
D: 4c ed fe fb 24 51 2c 32 |L...$Q,2
D: 4f 45 43 9a |OEC.
D: Bitmask: 0x02
D: Hash: 0xDF
D: Final value: 0xDD
D: FMDN State: next rotation in 1137 [s]
I: Fast Pair Adv Manager: the last timeout has occurred 44 [s] ago
I: Fast Pair Adv Manager: RPA rotation is in the suspended mode
D: 02 08 ca c0 70 2d ed 98 |....p-..
D: 42 0c |B.
D: a9 7c 03 72 97 a1 e8 69 |.|.r...i
D: 03 10 78 9d 42 c1 6d 92 |..x.B.m.
D: 59 89 3e ed 44 cc d6 af |Y.>.D...
D: 8d 9a |..
I: Fast Pair Adv Manager: the last timeout has occurred 227 [s] ago
I: Fast Pair Adv Manager: setting RPA timeout to 777 [s]
D: 03 08 44 65 f4 f1 d2 57 |..De...W
D: 73 20 |s
D: Beacon Actions write: res=18 conn=0x20002088
I: Fast Pair Adv Manager: advertising is disabled
I: DULT enabled
I: Fast Pair Adv Manager: setting RPA timeout to 776 [s]
I checked in the settings that there are no devices bonded (saved) on that phone.
Now that we have got the test passing, how do we proceed? With fp_adv_pairing_mode_request always set to true the device probably does not adhere to the FMDN guidelines, I would imagine.
I just received word from Amanda in another ticket of mine (Locator Tag example cannot be put into pairing mode after account key write at Fast Pair Validator App test "Provisioning for non-owner", clarifying that the Test "Scan and Connect timing" is not mandatory for locator tags, as described by Google here: developers.google.com/.../fmdn-certification-guideline
