WAVESHARE E-ink display not working with nRF5340 mipi_dbi
I want to connect Waveshare E-ink display to nRF5340 using e-Paper Driver HAT. At first, I tried to make all the calls by my own, just by rewriting the code from the ESP driver. unfortunately, this ended up in nothing - the display was not updating, although all the SPI messenges were delivered and the configuration did not have any failures - the program worked well, only the display did not do anything.
Then I figured out, that I using the mipi_dbi for this is the most modern and easy approach. I then created the following overlay file
nrf5340dk_nrf5340_cpuapp_ns.overlay
#include <zephyr/dt-bindings/mipi_dbi/mipi_dbi.h>
&i2c0 {	status = "disabled";};
&spi0 {	status = "disabled";};
&spi1 {status = "disabled";};
&i2c1 {	status = "disabled";};
chosen {
    zephyr,display = &epd;
    mipi_dbi {
        compatible = "zephyr,mipi-dbi-spi";
        reset-gpios = <&gpio1 14 GPIO_ACTIVE_LOW>;
        dc-gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>;
        spi-dev = <&spi4>;
        #address-cells = <1>;
        #size-cells = <0>;
        epd: ssd1680@0 {
            compatible = "solomon,ssd1680";
            reg = <0>;
            mipi-max-frequency = <4000000>;
            busy-gpios = <&gpio1 15 GPIO_ACTIVE_HIGH>;
            height = <800>;
            width = <480>;
    &spi4 {
        //compatible = "nordic,nrf-spim";
        status = "okay";
        pinctrl-0 = <&spi4_default>;
        pinctrl-1 = <&spi4_sleep>;
        cs-gpios = <&gpio1 12 GPIO_ACTIVE_LOW>;
    &pinctrl {
        spi4_default: spi4_default {
            group1 {
                psels = <NRF_PSEL(SPIM_SCK, 1, 11)>,
                        <NRF_PSEL(SPIM_MOSI, 1, 10)>,
                        <NRF_PSEL(SPIM_MISO, 1, 8)>;
        spi4_sleep: spi4_sleep {
            group1 {
                low-power-enable;
prj.conf
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_SPI=y
CONFIG_GPIO=y
CONFIG_DISPLAY=y
CONFIG_SSD16XX=y
CONFIG_MIPI_DBI=y
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=3
main.c
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/display.h>
#include <string.h>
const struct device *display;
        display = DEVICE_DT_GET(DT_CHOSEN(zephyr_display)); //  DEVICE_DT_GET(DT_NODELABEL(epd));
        device_init(display);
        while (!device_is_ready(display))
		printk("Device not ready");
		k_msleep(100);
        display_blanking_off(display);
        static uint8_t fb[800 * 480 / 8];
        memset(fb, 0xFF, sizeof(fb));
        struct display_buffer_descriptor desc = {
        .width = 800,
        .height = 480,
        .pitch = 800,
        .buf_size = sizeof(fb),
        int ret = display_write(display, 0, 0, &desc, fb);
        if (ret) {
        printk("display_write failed: %d\n", ret);
As the result:
the program gets stuck in a while loop. the device has init_res = 22 '\026', which, as far as I understand, means wrong configuration, but I can not figure what is the problem in my case. please help. I am sure, that there is no any problem with my display, because it worked like a charm with ESP32, the problem is with the code
