Recommended approach for radio_test-like firmware on custom nRF52840 board
We are working with a custom nRF52840 PCB and would like guidance on the correct and supported way to build a firmware equivalent to the radio_test sample on the nRF52840 DK, specifically for RF testing with command-based control (TX/RX/carrier/sweep).
On the DK, radio_test works out of the box via UART/USB, but on custom hardware we are running into multiple dependencies and assumptions that make radio_test difficult to reuse reliably.
Before continuing further, we would like to clarify:
  1. Is radio_test_sample intended to be reused on custom boards, or is it DK-specific?
  2. If not, what is the Nordic-recommended and supported approach for creating a radio_test hex firmware for a custom nRF52840 pcb design.
  3. We also would like to have UART serial commands access where we can pass commands like: parameters_print, start)tx_sweep etc......ALL in a custom PCB
    We are happy to share the PCB schematic and pin mappings if required. We are mainly looking for direction on the correct approach, rather than ad-hoc fixes.
Any guidance from the Nordic team would be greatly appreciated.
    Yes, you can use this on any custom nRF5x design.
    • If not, what is the Nordic-recommended and supported approach for creating a radio_test hex firmware for a custom nRF52840 pcb design.
    • We also would like to have UART serial commands access where we can pass commands like: parameters_print, start)tx_sweep etc......ALL in a custom PCB
    You will need to setup the pins to your desired GPIOs, as well as any other hardware related configuration specific to your board.
    Typical things:
    * DCDC present? If not, add this to your board overlay:
    &reg1 {
    	regulator-initial-mode = <NRF5X_REG_MODE_LDO>;
    * external 32.768 kHz xtal present? If not, enable internal 32k RC oscillator:
    And here is a example overlay for uart0. Feel free to take this and change as desired:
    &pinctrl {
    	uart0_default_alt: uart0_default_alt {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 1, 1)>,
    				<NRF_PSEL(UART_RX, 1, 2)>,
    				<NRF_PSEL(UART_RTS, 1, 3)>,
    				<NRF_PSEL(UART_CTS, 1, 4)>;
    	uart0_sleep_alt: uart0_sleep_alt {
    		group1 {
    			low-power-enable;
    &uart0 {
    	current-speed = <115200>;
    	status = "okay";
    	pinctrl-0 = <&uart0_default_alt>;
    	pinctrl-1 = <&uart0_sleep_alt>;
    Håkon
  • Thanks for this
    I have 2 questions in my mind:
    1. Whatever you changes regarding overlays etc that you have suggested, can I add or modify in the already existing radio_test firmware?
    2. Do we have anything to do with the schematic diagram of the PCB board ? I mean, considering the TX and RX pins etc.
    Yes, you can add a overlay with your specified pins or other settings. See our ncs dev academy for more details, specifically lesson 3 here:
    https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/
    Yes, the chosen UART pins must match how your custom board has been routed.
    Håkon
  • It worked!!
    Just added an overlay nrf52840dk_nrf52840.overlay
    and did some changes to the prj.conf file
    Now I'm able to send commands to my custom PCB just like the nrf52840 DK using the radio_test firmware.
    I am glad to hear that this worked as intended! Hope you have a wonderful day!
    Håkon
