L2CAP CoC connection only one credit per connection interval
Using nrf connect SDK 2.5.0
The nrf device is an L2CAP CoC server. I am using an RPi 4 to test with. The application is for transferring data through UART to another chip on the board to perform OTA updates. The connection sets up and I can transfer data successfully from the RPi to the nrf, but I only get 1 credit per connection interval, so throughput is limited. I have a connection interval of 7.5ms, an MTU of 245, so 245/7.5e-3 = 32KBps, which is roughly what my setup achieves, however I should be able to get 3 credits per interval (PHY 1M), so 98KBps. I want to fix this as some clients may have a larger min connection interval, so this issue would be exacerbated in that case.
I have tried increasing CONFIG_BT_BUF_ACL_RX_COUNT
a snippet of the prj:
CONFIG_BT_L2CAP_TX_BUF_COUNT=2
CONFIG_BT_BUF_ACL_TX_COUNT=2
CONFIG_BT_BUF_ACL_RX_COUNT=20
CONFIG_BT_NUS_UART_BUFFER_SIZE=244
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
I have tried configuring the SD so that it has plenty of buffer
int configure_softdevice_buffers(void)
    sdc_cfg_t cfg;
    cfg.buffer_cfg.rx_packet_count = CONFIG_BT_BUF_ACL_RX_COUNT;
    cfg.buffer_cfg.tx_packet_count = CONFIG_BT_BUF_ACL_TX_COUNT;
    cfg.buffer_cfg.rx_packet_size  = CONFIG_BT_CTLR_DATA_LENGTH_MAX;
    cfg.buffer_cfg.tx_packet_size  = CONFIG_BT_CTLR_DATA_LENGTH_MAX;
    return sdc_cfg_set(SDC_DEFAULT_RESOURCE_CFG_TAG, SDC_CFG_TYPE_BUFFER_CFG, &cfg);
static int my_bt_low_level_init(void)
    int ret = configure_softdevice_buffers();
    if (ret) {
        printk("SDC Config failed: %d\n", ret);
    } else {
        printk("SDC Config success\n");
    return 0;
// Use PRE_KERNEL_1 to ensure this runs before the BT stack starts
SYS_INIT(my_bt_low_level_init, PRE_KERNEL_1, CONFIG_KERNEL_INIT_PRIORITY_DEVICE);
My server code is as basic as possible, except I have tried manually allocating a large enough net buf pool (size 20) using the alloc_buff callback. I tried without doing this initially with the same result. My recv callback does not do anything with the data currently, I just want to test the L2CAP connection speed first before adding UART.
#include <zephyr/kernel.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/l2cap.h>
LOG_MODULE_REGISTER(l2cap_channel);
#include "l2cap_channel.h"
/* Must match client */
#define L2CAP_PSM 0x0081
#define L2CAP_MTU 245
#define RX_BUFF_NUM 20
#define RX_BUFF_LENGTH 251
#define RX_BUFF_USER_DATA_SIZE 8
static struct bt_l2cap_le_chan l2cap_chan;
NET_BUF_POOL_FIXED_DEFINE(net_buff_pool_rx, RX_BUFF_NUM, RX_BUFF_LENGTH, RX_BUFF_USER_DATA_SIZE, NULL);
static uint32_t bytes_received = 0;
// L2CAP CALLBACKS
static void l2cap_connected(struct bt_l2cap_chan *chan)
    LOG_INF("L2CAP CoC connected");
static void l2cap_disconnected(struct bt_l2cap_chan *chan)
    LOG_INF("L2CAP CoC disconnected");
static int l2cap_recv(struct bt_l2cap_chan *chan, struct net_buf *buf)
    bytes_received += buf->len;
    return 0;
static struct net_buf *l2cap_chan_alloc_buf(struct bt_l2cap_chan *chan)
    struct net_buf *buf = net_buf_alloc(&net_buff_pool_rx, K_NO_WAIT);
    if (buf) {
        LOG_INF("Allocated buf for credit");
    } else {
        LOG_ERR("Failed to allocate buf for credit");
    return buf;
// CHANNEL OPS
static struct bt_l2cap_chan_ops l2cap_ops = {
    .connected = l2cap_connected,
    .disconnected = l2cap_disconnected,
    .recv = l2cap_recv,
    .alloc_buf  = l2cap_chan_alloc_buf,
// ACCEPT CALLBACK
static int l2cap_accept(struct bt_conn *conn, struct bt_l2cap_chan **chan)
    LOG_INF("L2CAP CoC accept");
    struct bt_l2cap_le_chan *le_chan = &l2cap_chan; // Ensure this is the LE struct
    // Force reset the RX state before assigning
    memset(&le_chan->rx, 0, sizeof(le_chan->rx));
    le_chan->chan.ops = &l2cap_ops;
    le_chan->rx.mtu = L2CAP_MTU;
    le_chan->rx.mps = L2CAP_MTU;
    le_chan->rx.init_credits = RX_BUFF_NUM / 2;
    *chan = &le_chan->chan;
    return 0;
// L2CAP SERVER
static struct bt_l2cap_server l2cap_server = {
    .psm = L2CAP_PSM,
    .sec_level = BT_SECURITY_L1,  // no auth no encryption
    .accept = l2cap_accept,
// PUBLIC METHODS
int l2cap_channel_init()
    return bt_l2cap_server_register(&l2cap_server);
Here is my btmon output from the RPi. it shows that I am only receiving 1 credit per connection interval even though the packet size that I am sending (30) is way less than the MTU. Note that this is not the same log as for the 32KBps connection, this is me testing with a lower MTU to prove out that there should be enough buffer on the controller to handle multiple credits.
< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7        #1 4.846002
        Type: Passive (0x00)
        Interval: 60.000 msec (0x0060)
        Window: 60.000 msec (0x0060)
        Own address type: Public (0x00)
        Filter policy: Ignore not in white list (0x01)
> HCI Event: Command Complete (0x0e) plen 4        #2 4.846421
      LE Set Scan Parameters (0x08|0x000b) ncmd 1
        Status: Success (0x00)
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2        #3 4.846526
        Scanning: Enabled (0x01)
        Filter duplicates: Enabled (0x01)
> HCI Event: Command Complete (0x0e) plen 4        #4 4.846851
      LE Set Scan Enable (0x08|0x000c) ncmd 1
> HCI Event: LE Meta Event (0x3e) plen 35        #5 5.142090
      LE Advertising Report (0x02)
        Num reports: 1
        Event type: Connectable undirected - ADV_IND (0x00)
        Address type: Random (0x01)
        Address: D7:85:74:5F:87:45 (Static)
        Data length: 23
        Flags: 0x06
          LE General Discoverable Mode
          BR/EDR Not Supported
        Name (complete): SX00000
        Company: Ericsson Technology Licensing (0)
          Data: 000000000000
        RSSI: -35 dBm (0xdd)
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2        #6 5.142149
        Scanning: Disabled (0x00)
        Filter duplicates: Disabled (0x00)
> HCI Event: Command Complete (0x0e) plen 4        #7 5.144100
< HCI Command: LE Create Connection (0x08|0x000d) plen 25        #8 5.144154
        Scan interval: 60.000 msec (0x0060)
        Scan window: 60.000 msec (0x0060)
        Filter policy: White list is not used (0x00)
        Peer address type: Random (0x01)
        Peer address: D7:85:74:5F:87:45 (Static)
        Min connection interval: 7.50 msec (0x0006)
        Max connection interval: 7.50 msec (0x0006)
        Connection latency: 0 (0x0000)
        Supervision timeout: 4000 msec (0x0190)
        Min connection length: 0.000 msec (0x0000)
        Max connection length: 0.000 msec (0x0000)
> HCI Event: Command Status (0x0f) plen 4        #9 5.144672
      LE Create Connection (0x08|0x000d) ncmd 1
> HCI Event: LE Meta Event (0x3e) plen 19        #10 5.349786
      LE Connection Complete (0x01)
        Handle: 64
        Role: Master (0x00)
        Connection interval: 7.50 msec (0x0006)
        Master clock accuracy: 0x00
@ MGMT Event: Device Connected (0x000b) plen 36        {0x0001} 5.349817
        LE Address: D7:85:74:5F:87:45 (Static)
        Flags: 0x00000008
          Unknown device flag (0x00000008)
        Data length: 23
        Flags: 0x06
          Data: 000000000000
< HCI Command: LE Read Remote Used Features (0x08|0x0016) plen 2        #11 5.349912
        Handle: 64
> HCI Event: Command Status (0x0f) plen 4        #12 5.350757
      LE Read Remote Used Features (0x08|0x0016) ncmd 1
> ACL Data RX: Handle 64 flags 0x02 dlen 7        #13 5.366017
      ATT: Exchange MTU Request (0x02) len 2
        Client RX MTU: 247
> HCI Event: LE Meta Event (0x3e) plen 12        #14 5.366685
      LE Read Remote Used Features (0x04)
        Handle: 64
        Features: 0x2d 0x00 0x00 0x00 0x00 0x00 0x00 0x00
          LE Encryption
          Extended Reject Indication
          Slave-initiated Features Exchange
          LE Data Packet Length Extension
< ACL Data TX: Handle 64 flags 0x00 dlen 18        #15 5.366734
      LE L2CAP: LE Connection Request (0x14) ident 1 len 10
        PSM: 129 (0x0081)
        Source CID: 64
        MTU: 672
        MPS: 247
        Credits: 3
< ACL Data TX: Handle 64 flags 0x00 dlen 7        #16 5.367263
      ATT: Exchange MTU Response (0x03) len 2
        Server RX MTU: 517
< ACL Data TX: Handle 64 flags 0x00 dlen 7        #17 5.367276
        Client RX MTU: 517
> HCI Event: LE Meta Event (0x3e) plen 11        #18 5.388874
      LE Data Length Change (0x07)
        Handle: 64
        Max TX octets: 251
        Max TX time: 2120
        Max RX octets: 251
        Max RX time: 2120
> ACL Data RX: Handle 64 flags 0x02 dlen 18        #19 5.396227
      LE L2CAP: LE Connection Response (0x15) ident 1 len 10
        Destination CID: 64
        MTU: 30
        MPS: 32
        Credits: 1
        Result: Connection successful (0x0000)
> HCI Event: Number of Completed Packets (0x13) plen 5        #20 5.396619
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 7        #21 5.411145
        Server RX MTU: 247
< ACL Data TX: Handle 64 flags 0x00 dlen 7        #22 5.411479
      ATT: Read Request (0x0a) len 2
        Handle: 0x0004
> HCI Event: Number of Completed Packets (0x13) plen 5        #23 5.418762
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #24 5.426104
      ATT: Read Response (0x0b) len 7
        Value: 53583030303030
< ACL Data TX: Handle 64 flags 0x00 dlen 7        #25 5.426409
        Handle: 0x0006
> ACL Data RX: Handle 64 flags 0x02 dlen 7        #26 5.441071
      ATT: Read Response (0x0b) len 2
        Value: 0000
< ACL Data TX: Handle 64 flags 0x00 dlen 11        #27 5.441421
      ATT: Read By Type Request (0x08) len 6
        Handle range: 0x0001-0xffff
        Attribute type: Unknown (0x2b3a)
> HCI Event: Number of Completed Packets (0x13) plen 5        #28 5.448773
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 9        #29 5.456084
      ATT: Error Response (0x01) len 4
        Handle: 0x0001
        Error: Attribute Not Found (0x0a)
< ACL Data TX: Handle 64 flags 0x00 dlen 11        #30 5.456288
      ATT: Read By Group Type Request (0x10) len 6
        Attribute group type: Primary Service (0x2800)
> ACL Data RX: Handle 64 flags 0x02 dlen 18        #31 5.471163
      ATT: Read By Group Type Response (0x11) len 13
        Attribute data length: 6
        Attribute group list: 2 entries
        Handle range: 0x0001-0x0001
        UUID: Generic Attribute Profile (0x1801)
        Handle range: 0x0002-0x0006
        UUID: Generic Access Profile (0x1800)
< ACL Data TX: Handle 64 flags 0x00 dlen 11        #32 5.471362
        Handle range: 0x0007-0xffff
> HCI Event: Number of Completed Packets (0x13) plen 5        #33 5.478772
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 26        #34 5.486695
      ATT: Read By Group Type Response (0x11) len 21
        Attribute data length: 20
        Attribute group list: 1 entry
        Handle range: 0x0007-0x000c
        UUID: Nordic UART Service (6e400001-b5a3-f393-e0a9-e50e24dcca9e)
< ACL Data TX: Handle 64 flags 0x00 dlen 11        #35 5.486873
        Handle range: 0x000d-0xffff
> ACL Data RX: Handle 64 flags 0x02 dlen 9        #36 5.501100
        Handle: 0x000d
> HCI Event: Number of Completed Packets (0x13) plen 5        #37 5.639217
        Num handles: 1
        Handle: 64
        Count: 1
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #38 15.397047
      Channel: 64 len 27 sdu 25 [PSM 129 mode LE Flow Control (0x80)] {chan 0}
        19 00 00 00 02 20 2d 37 01 24 41 35 01 24 43 35  ..... -7.$A5.$C5
        01 24 45 35 01 24 47 35 01 24 49                 .$E5.$G5.$I
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #39 15.397074
        19 00 35 01 24 00 00 00 00 00 00 00 00 00 00 00  ..5.$...........
        00 00 00 00 00 01 f3 01 24 4b 35                 ........$K5
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #40 15.397077
        19 00 01 24 00 00 00 00 a1 f3 01 24 5f d0 01 24  ...$.......$_..$
        7d 37 01 24 7d 37 01 24 7d 37 01                 }7.$}7.$}7.
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #41 15.397090
        19 00 24 7d 37 01 24 7d 37 01 24 7d 37 01 24 7d  ..$}7.$}7.$}7.$}
        37 01 24 7d 37 01 24 7d 37 01 24                 7.$}7.$}7.$
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #42 15.397099
        19 00 7d 37 01 24 7d 37 01 24 4d 35 01 24 5d 35  ..}7.$}7.$M5.$]5
        01 24 7d 37 01 24 7d 37 01 24 7d                 .$}7.$}7.$}
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #43 15.397107
        19 00 37 01 24 7d 37 01 24 7d 37 01 24 7d 37 01  ..7.$}7.$}7.$}7.
        24 7d 37 01 24 7d 37 01 24 7d 37                 $}7.$}7.$}7
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #44 15.397116
        19 00 01 24 7d 37 01 24 7d 37 01 24 7d 37 01 24  ...$}7.$}7.$}7.$
        6d 35 01 24 7d 37 01 24 7d 37 01                 m5.$}7.$}7.
> HCI Event: Number of Completed Packets (0x13) plen 5        #45 15.402052
        Num handles: 1
        Handle: 64
        Count: 2
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #46 15.402094
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #47 15.402102
        19 00 7d 37 01 24 7d 37 01 24 7d 37 01 24 7d 37  ..}7.$}7.$}7.$}7
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #48 15.402763
      LE L2CAP: LE Flow Control Credit (0x16) ident 1 len 4
        Source CID: 64
        Credits: 1
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #49 15.403728
      LE L2CAP: LE Flow Control Credit (0x16) ident 2 len 4
        Source CID: 64
        Credits: 1
> HCI Event: Number of Completed Packets (0x13) plen 5        #50 15.403878
        Num handles: 1
        Handle: 64
        Count: 2
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #51 15.403898
        19 00 37 01 24 7d 37 01 24 00 00 00 00 7d 37 01  ..7.$}7.$....}7.
< ACL Data TX: Handle 64 flags 0x00 dlen 12        #52 15.403905
      LE L2CAP: Disconnection Request (0x06) ident 2 len 4
        Destination CID: 64
        Source CID: 64
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #53 15.408912
      LE L2CAP: LE Flow Control Credit (0x16) ident 3 len 4
        Source CID: 64
        Credits: 1
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #54 15.409706
      LE L2CAP: LE Flow Control Credit (0x16) ident 4 len 4
        Source CID: 64
        Credits: 1
> HCI Event: Number of Completed Packets (0x13) plen 5        #55 15.410967
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #56 15.410981
      LE L2CAP: LE Flow Control Credit (0x16) ident 5 len 4
        Source CID: 64
        Credits: 1
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #57 15.411851
      LE L2CAP: LE Flow Control Credit (0x16) ident 6 len 4
        Source CID: 64
        Credits: 1
> HCI Event: Number of Completed Packets (0x13) plen 5        #58 15.411988
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #59 15.416413
      LE L2CAP: LE Flow Control Credit (0x16) ident 7 len 4
        Source CID: 64
        Credits: 1
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #60 15.417195
      LE L2CAP: LE Flow Control Credit (0x16) ident 8 len 4
        Source CID: 64
        Credits: 1
> HCI Event: Number of Completed Packets (0x13) plen 5        #61 15.417416
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #62 15.418040
      LE L2CAP: LE Flow Control Credit (0x16) ident 9 len 4
        Source CID: 64
        Credits: 1
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #63 15.423739
      LE L2CAP: Disconnection Response (0x07) ident 2 len 4
        Destination CID: 64
        Source CID: 64
> HCI Event: Number of Completed Packets (0x13) plen 5        #64 15.639354
        Num handles: 1
        Handle: 64
        Count: 1
  • Hi Simon,
    Unfortunately no change in behaviour with:
    CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=20
    CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=20
    CONFIG_BT_L2CAP_TX_BUF_COUNT=20
    CONFIG_BT_BUF_ACL_TX_COUNT=20
    Is there an example for L2CAP CoC? Maybe if I try a stripped back version, then try reintroducing the other code
  • Hi Paul
    I talked to the devs today, and using the CONFIG_BT_L2CAP_SEG_RECV and bt_l2cap_chan_ops.seg_recv should let the application control credits and is what we recommend here. You can check out the test sample avaliable in the Zephyr project for reference: zephyr/tests/bsim/bluetooth/host/l2cap/credits_seg_recv
    Simon
  • Great thank you for the help.
    So I tried this seg_recv callback, again, just doing as little as possible in the callback. All it does is give 6 more credits after 6 have been consumed. I give 10 initial credits in the connected callback. However, What I have found is that I still only get 1 packet every connection interval, so still capped at 32KBps.
    See here for Wireshark log.2026-01-21-wireshark_log.pcapng The data looks like this:
    peripheral-> central [LE flow control credits 10]
    empty PDUs ...
    t=0 central-> peripheral [CoC, Le information frame] 1
    t=2.2ms peripheral-> central [Empty PDU]
    t=2.5ms central-> peripheral [CoC, Le information frame] 2
    t=7.5ms central-> peripheral [CoC, Le information frame] 3 (identical data to 2 but with different header)
    t=9.7ms peripheral-> central [Empty PDU]
    t=10.0ms central-> peripheral [CoC, Le information frame] 4
    t=15.0ms central-> peripheral [CoC, Le information frame] 5 (identical data to 4 but with different header)
    t=17ms peripheral-> central [Empty PDU]
    this continues for 6 pairs of ...
    peripheral-> central [LE flow control credits 6]
    Why is the central sending duplicate packets that are 5ms apart? Is it waiting for the empty PDU from the peripheral? Looks like the Empty PDUs from the peripheral are ~7.5ms apart which is the connection interval.
    static void l2cap_chan_seg_recv(struct bt_l2cap_chan *chan, size_t sdu_len,
                                    off_t seg_offset, struct net_buf_simple *seg)
        /* * TODO: PROCESS DATA */
       // replenish credits
        credit_consumed_count++;
        if (credit_consumed_count >= CREDIT_BATCH_SIZE) {
            bt_l2cap_chan_give_credits(chan, credit_consumed_count);
            credit_consumed_count = 0; // Reset counter
        return;
        // Give initial credits
        bt_l2cap_chan_give_credits(chan, INITIAL_CREDITS);
        // reset credit consumed count
        credit_consumed_count=0;
        .seg_recv = l2cap_chan_seg_recv,
    Paul
  • Hi
    The C2P packets labeled as retransmissions without a preceding NACK is expected since the SoftDevice controller stays silent when it runs out of RX buffers in order to make the Central wait until the next connection event.
    You can try increasing CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT in your prj.conf as well as enabling the BT_CTLR_SDC_CONN_EVENT_EXTEND_DEFAULT config to allow for the controller to extend the connection event as much as possible if peers have more data to send and there are no conflicts with other roles of the same/higher priority.
    Simon
  • Hi Simon,
    So it is definitely the peripheral side that is slowing things down then.
    I tried these config, but no change unfortunately.
    CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=30000
    CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE=y
    Here is my BLE settings from my .config output file, maybe you can see something that I don't
    # Bluetooth Low Energy
    CONFIG_BT_MAX_CONN=1
    CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
    CONFIG_BT_LL_SOFTDEVICE=y
    # SoftDevice Controller
    CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y
    CONFIG_BT_HCI_TX_STACK_SIZE=768
    CONFIG_BT_RX_STACK_SIZE=1280
    # CONFIG_BT_CTLR_SDC_LLPM is not set
    # CONFIG_BT_CTLR_SDC_QOS_CHANNEL_SURVEY is not set
    CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=1
    # CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT_OVERRIDE is not set
    CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT=7500
    CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=12
    CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=12
    CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PRIO=6
    # CONFIG_BT_CTLR_DF is not set
    CONFIG_BT_LL_SOFTDEVICE_PERIPHERAL=y
    # CONFIG_BT_LL_SOFTDEVICE_MULTIROLE is not set
    # CONFIG_BT_LL_SOFTDEVICE_EXPERIMENTAL_ISO is not set
    CONFIG_BT_CTLR_FAL_SIZE=8
    CONFIG_BT_CTLR_ECDH_LIB_OBERON=y
    # CONFIG_BT_CTLR_ECDH_LIB_TINYCRYPT is not set
    CONFIG_BT_CTLR_ECDH_STACK_SIZE=900
    # CONFIG_BT_CTLR_ECDH_IN_MPSL_WORK is not set
    # CONFIG_BT_CTLR_LE_POWER_CONTROL is not set
    # end of SoftDevice Controller
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    # CONFIG_BT_GATT_DM is not set
    # CONFIG_BT_ADV_PROV is not set
    # CONFIG_BT_CONN_CTX is not set
    # Bluetooth Services
    CONFIG_BT_NRF_SERVICES=y
    # CONFIG_BT_AMS_CLIENT is not set
    # CONFIG_BT_ANCS_CLIENT is not set
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_BMS is not set
    # CONFIG_BT_CTS_CLIENT is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_GATTP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NSMS is not set
    CONFIG_BT_NUS=y
    # CONFIG_BT_NUS_AUTHEN is not set
    # CONFIG_BT_NUS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_NUS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_NUS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_NUS_LOG_LEVEL_INF is not set
    # CONFIG_BT_NUS_LOG_LEVEL_DBG is not set
    CONFIG_BT_NUS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_NUS_LOG_LEVEL=3
    # CONFIG_BT_NUS_CLIENT is not set
    # CONFIG_BT_RSCS is not set
    # CONFIG_BT_THROUGHPUT is not set
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    # CONFIG_BT_HRS_CLIENT is not set
    # CONFIG_BT_DDFS is not set
    # CONFIG_BT_MDS is not set
    # CONFIG_BT_CGMS is not set
    # CONFIG_BT_FAST_PAIR is not set
    # CONFIG_BT_DIS is not set
    CONFIG_BT_GATT_AUTO_SEC_REQ=y
    # end of Bluetooth Services
    # BLE over nRF RPC
    # CONFIG_BT_RPC is not set
    # CONFIG_BT_RPC_STACK is not set
    # CONFIG_BT_CENTRAL is not set
    CONFIG_BT_PERIPHERAL=y
    # CONFIG_BT_OBSERVER is not set
    CONFIG_BT_BROADCASTER=y
    CONFIG_BT_CONN=y
    # CONFIG_BT_REMOTE_VERSION is not set
    # CONFIG_BT_PHY_UPDATE is not set
    CONFIG_BT_DATA_LEN_UPDATE=y
    # CONFIG_BT_EXT_ADV is not set
    # CONFIG_BT_BAS is not set
    # CONFIG_BT_HRS is not set
    # CONFIG_BT_TPS is not set
    # CONFIG_BT_IAS is not set
    # CONFIG_BT_IAS_CLIENT is not set
    # CONFIG_BT_OTS is not set
    # CONFIG_BT_OTS_CLIENT is not set
    CONFIG_BT_BUF_ACL_TX_COUNT=12
    CONFIG_BT_BUF_ACL_RX_COUNT=12
    CONFIG_BT_BUF_EVT_RX_SIZE=68
    CONFIG_BT_BUF_EVT_RX_COUNT=12
    CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=43
    CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=6
    CONFIG_BT_BUF_CMD_TX_SIZE=65
    CONFIG_BT_HAS_HCI_VS=y
    CONFIG_BT_HCI_VS=y
    # CONFIG_BT_WAIT_NOP is not set
    CONFIG_BT_RPA=y
    # CONFIG_BT_ASSERT is not set
    CONFIG_BT_DEBUG_NONE=y
    # CONFIG_BT_DEBUG_LOG is not set
    # CONFIG_BT_DEBUG_MONITOR_UART is not set
    # CONFIG_BT_DEBUG_MONITOR_RTT is not set
    # CONFIG_BT_LONG_WQ is not set
    CONFIG_BT_HCI_HOST=y
    CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT=y
    CONFIG_BT_HCI_TX_PRIO=7
    CONFIG_BT_HCI_RESERVE=0
    # CONFIG_BT_RECV_BLOCKING is not set
    # CONFIG_BT_RECV_WORKQ_SYS is not set
    CONFIG_BT_RECV_WORKQ_BT=y
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    # CONFIG_BT_AUDIO is not set
    CONFIG_BT_SETTINGS=y
    CONFIG_BT_SETTINGS_CCC_LAZY_LOADING=y
    CONFIG_BT_SETTINGS_DELAYED_STORE=y
    CONFIG_BT_SETTINGS_DELAYED_STORE_MS=1000
    CONFIG_BT_SETTINGS_CCC_STORE_ON_WRITE=y
    CONFIG_BT_SETTINGS_USE_PRINTK=y
    # CONFIG_BT_FILTER_ACCEPT_LIST is not set
    CONFIG_BT_LIM_ADV_TIMEOUT=30
    CONFIG_BT_CONN_TX_USER_DATA_SIZE=8
    CONFIG_BT_CONN_TX_MAX=12
    # CONFIG_BT_CONN_PARAM_ANY is not set
    # CONFIG_BT_USER_DATA_LEN_UPDATE is not set
    CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
    # CONFIG_BT_REMOTE_INFO is not set
    CONFIG_BT_SMP=y
    # CONFIG_BT_PASSKEY_KEYPRESS is not set
    # CONFIG_BT_PRIVACY is not set
    # CONFIG_BT_SIGNING is not set
    # CONFIG_BT_SMP_APP_PAIRING_ACCEPT is not set
    # CONFIG_BT_SMP_SC_PAIR_ONLY is not set
    # CONFIG_BT_SMP_SC_ONLY is not set
    # CONFIG_BT_SMP_OOB_LEGACY_PAIR_ONLY is not set
    # CONFIG_BT_SMP_DISABLE_LEGACY_JW_PASSKEY is not set
    # CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE is not set
    # CONFIG_BT_ID_UNPAIR_MATCHING_BONDS is not set
    # CONFIG_BT_ID_ALLOW_UNAUTH_OVERWRITE is not set
    # CONFIG_BT_FIXED_PASSKEY is not set
    # CONFIG_BT_USE_DEBUG_KEYS is not set
    # CONFIG_BT_BONDABLE is not set
    # CONFIG_BT_BONDABLE_PER_CONNECTION is not set
    # CONFIG_BT_STORE_DEBUG_KEYS is not set
    CONFIG_BT_SMP_ENFORCE_MITM=y
    # CONFIG_BT_KEYS_OVERWRITE_OLDEST is not set
    CONFIG_BT_SMP_MIN_ENC_KEY_SIZE=7
    CONFIG_BT_L2CAP_TX_BUF_COUNT=12
    CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
    CONFIG_BT_L2CAP_RESCHED_MS=1000
    CONFIG_BT_L2CAP_DYNAMIC_CHANNEL=y
    # CONFIG_BT_L2CAP_ECRED is not set
    CONFIG_BT_L2CAP_SEG_RECV=y
    CONFIG_BT_ATT_ENFORCE_FLOW=y
    CONFIG_BT_ATT_PREPARE_COUNT=0
    CONFIG_BT_ATT_RETRY_ON_SEC_ERR=y
    CONFIG_BT_GATT_AUTO_RESUBSCRIBE=y
    # CONFIG_BT_GATT_SERVICE_CHANGED is not set
    CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
    CONFIG_BT_GATT_CLIENT=y
    CONFIG_BT_GATT_READ_MULTIPLE=y
    CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
    # CONFIG_BT_GATT_AUTO_DISCOVER_CCC is not set
    # CONFIG_BT_GATT_AUTO_UPDATE_MTU is not set
    CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
    # CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS is not set
    CONFIG_BT_DEVICE_NAME_GATT_WRITABLE=y
    CONFIG_DEVICE_NAME_GATT_WRITABLE_ENCRYPT=y
    # CONFIG_DEVICE_NAME_GATT_WRITABLE_AUTHEN is not set
    CONFIG_BT_MAX_PAIRED=1
    CONFIG_BT_CREATE_CONN_TIMEOUT=3
    CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
    CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
    CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
    CONFIG_BT_DEVICE_NAME_DYNAMIC=y
    CONFIG_BT_DEVICE_NAME_MAX=10
    CONFIG_BT_DEVICE_NAME="SX"
    # CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
    CONFIG_BT_DEVICE_APPEARANCE=0
    CONFIG_BT_ID_MAX=1
    CONFIG_BT_ECC=y
    # CONFIG_BT_TINYCRYPT_ECC is not set
    # CONFIG_BT_HOST_CCM is not set
    # CONFIG_BT_LOG_SNIFFER_INFO is not set
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_BREDR is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    CONFIG_BT_CRYPTO=y
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    Paul
