L2CAP CoC connection only one credit per connection interval
Using nrf connect SDK 2.5.0
The nrf device is an L2CAP CoC server. I am using an RPi 4 to test with. The application is for transferring data through UART to another chip on the board to perform OTA updates. The connection sets up and I can transfer data successfully from the RPi to the nrf, but I only get 1 credit per connection interval, so throughput is limited. I have a connection interval of 7.5ms, an MTU of 245, so 245/7.5e-3 = 32KBps, which is roughly what my setup achieves, however I should be able to get 3 credits per interval (PHY 1M), so 98KBps. I want to fix this as some clients may have a larger min connection interval, so this issue would be exacerbated in that case.
I have tried increasing CONFIG_BT_BUF_ACL_RX_COUNT
a snippet of the prj:
CONFIG_BT_L2CAP_TX_BUF_COUNT=2
CONFIG_BT_BUF_ACL_TX_COUNT=2
CONFIG_BT_BUF_ACL_RX_COUNT=20
CONFIG_BT_NUS_UART_BUFFER_SIZE=244
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
I have tried configuring the SD so that it has plenty of buffer
int configure_softdevice_buffers(void)
    sdc_cfg_t cfg;
    cfg.buffer_cfg.rx_packet_count = CONFIG_BT_BUF_ACL_RX_COUNT;
    cfg.buffer_cfg.tx_packet_count = CONFIG_BT_BUF_ACL_TX_COUNT;
    cfg.buffer_cfg.rx_packet_size  = CONFIG_BT_CTLR_DATA_LENGTH_MAX;
    cfg.buffer_cfg.tx_packet_size  = CONFIG_BT_CTLR_DATA_LENGTH_MAX;
    return sdc_cfg_set(SDC_DEFAULT_RESOURCE_CFG_TAG, SDC_CFG_TYPE_BUFFER_CFG, &cfg);
static int my_bt_low_level_init(void)
    int ret = configure_softdevice_buffers();
    if (ret) {
        printk("SDC Config failed: %d\n", ret);
    } else {
        printk("SDC Config success\n");
    return 0;
// Use PRE_KERNEL_1 to ensure this runs before the BT stack starts
SYS_INIT(my_bt_low_level_init, PRE_KERNEL_1, CONFIG_KERNEL_INIT_PRIORITY_DEVICE);
My server code is as basic as possible, except I have tried manually allocating a large enough net buf pool (size 20) using the alloc_buff callback. I tried without doing this initially with the same result. My recv callback does not do anything with the data currently, I just want to test the L2CAP connection speed first before adding UART.
#include <zephyr/kernel.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/l2cap.h>
LOG_MODULE_REGISTER(l2cap_channel);
#include "l2cap_channel.h"
/* Must match client */
#define L2CAP_PSM 0x0081
#define L2CAP_MTU 245
#define RX_BUFF_NUM 20
#define RX_BUFF_LENGTH 251
#define RX_BUFF_USER_DATA_SIZE 8
static struct bt_l2cap_le_chan l2cap_chan;
NET_BUF_POOL_FIXED_DEFINE(net_buff_pool_rx, RX_BUFF_NUM, RX_BUFF_LENGTH, RX_BUFF_USER_DATA_SIZE, NULL);
static uint32_t bytes_received = 0;
// L2CAP CALLBACKS
static void l2cap_connected(struct bt_l2cap_chan *chan)
    LOG_INF("L2CAP CoC connected");
static void l2cap_disconnected(struct bt_l2cap_chan *chan)
    LOG_INF("L2CAP CoC disconnected");
static int l2cap_recv(struct bt_l2cap_chan *chan, struct net_buf *buf)
    bytes_received += buf->len;
    return 0;
static struct net_buf *l2cap_chan_alloc_buf(struct bt_l2cap_chan *chan)
    struct net_buf *buf = net_buf_alloc(&net_buff_pool_rx, K_NO_WAIT);
    if (buf) {
        LOG_INF("Allocated buf for credit");
    } else {
        LOG_ERR("Failed to allocate buf for credit");
    return buf;
// CHANNEL OPS
static struct bt_l2cap_chan_ops l2cap_ops = {
    .connected = l2cap_connected,
    .disconnected = l2cap_disconnected,
    .recv = l2cap_recv,
    .alloc_buf  = l2cap_chan_alloc_buf,
// ACCEPT CALLBACK
static int l2cap_accept(struct bt_conn *conn, struct bt_l2cap_chan **chan)
    LOG_INF("L2CAP CoC accept");
    struct bt_l2cap_le_chan *le_chan = &l2cap_chan; // Ensure this is the LE struct
    // Force reset the RX state before assigning
    memset(&le_chan->rx, 0, sizeof(le_chan->rx));
    le_chan->chan.ops = &l2cap_ops;
    le_chan->rx.mtu = L2CAP_MTU;
    le_chan->rx.mps = L2CAP_MTU;
    le_chan->rx.init_credits = RX_BUFF_NUM / 2;
    *chan = &le_chan->chan;
    return 0;
// L2CAP SERVER
static struct bt_l2cap_server l2cap_server = {
    .psm = L2CAP_PSM,
    .sec_level = BT_SECURITY_L1,  // no auth no encryption
    .accept = l2cap_accept,
// PUBLIC METHODS
int l2cap_channel_init()
    return bt_l2cap_server_register(&l2cap_server);
Here is my btmon output from the RPi. it shows that I am only receiving 1 credit per connection interval even though the packet size that I am sending (30) is way less than the MTU. Note that this is not the same log as for the 32KBps connection, this is me testing with a lower MTU to prove out that there should be enough buffer on the controller to handle multiple credits.
< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7        #1 4.846002
        Type: Passive (0x00)
        Interval: 60.000 msec (0x0060)
        Window: 60.000 msec (0x0060)
        Own address type: Public (0x00)
        Filter policy: Ignore not in white list (0x01)
> HCI Event: Command Complete (0x0e) plen 4        #2 4.846421
      LE Set Scan Parameters (0x08|0x000b) ncmd 1
        Status: Success (0x00)
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2        #3 4.846526
        Scanning: Enabled (0x01)
        Filter duplicates: Enabled (0x01)
> HCI Event: Command Complete (0x0e) plen 4        #4 4.846851
      LE Set Scan Enable (0x08|0x000c) ncmd 1
> HCI Event: LE Meta Event (0x3e) plen 35        #5 5.142090
      LE Advertising Report (0x02)
        Num reports: 1
        Event type: Connectable undirected - ADV_IND (0x00)
        Address type: Random (0x01)
        Address: D7:85:74:5F:87:45 (Static)
        Data length: 23
        Flags: 0x06
          LE General Discoverable Mode
          BR/EDR Not Supported
        Name (complete): SX00000
        Company: Ericsson Technology Licensing (0)
          Data: 000000000000
        RSSI: -35 dBm (0xdd)
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2        #6 5.142149
        Scanning: Disabled (0x00)
        Filter duplicates: Disabled (0x00)
> HCI Event: Command Complete (0x0e) plen 4        #7 5.144100
< HCI Command: LE Create Connection (0x08|0x000d) plen 25        #8 5.144154
        Scan interval: 60.000 msec (0x0060)
        Scan window: 60.000 msec (0x0060)
        Filter policy: White list is not used (0x00)
        Peer address type: Random (0x01)
        Peer address: D7:85:74:5F:87:45 (Static)
        Min connection interval: 7.50 msec (0x0006)
        Max connection interval: 7.50 msec (0x0006)
        Connection latency: 0 (0x0000)
        Supervision timeout: 4000 msec (0x0190)
        Min connection length: 0.000 msec (0x0000)
        Max connection length: 0.000 msec (0x0000)
> HCI Event: Command Status (0x0f) plen 4        #9 5.144672
      LE Create Connection (0x08|0x000d) ncmd 1
> HCI Event: LE Meta Event (0x3e) plen 19        #10 5.349786
      LE Connection Complete (0x01)
        Handle: 64
        Role: Master (0x00)
        Connection interval: 7.50 msec (0x0006)
        Master clock accuracy: 0x00
@ MGMT Event: Device Connected (0x000b) plen 36        {0x0001} 5.349817
        LE Address: D7:85:74:5F:87:45 (Static)
        Flags: 0x00000008
          Unknown device flag (0x00000008)
        Data length: 23
        Flags: 0x06
          Data: 000000000000
< HCI Command: LE Read Remote Used Features (0x08|0x0016) plen 2        #11 5.349912
        Handle: 64
> HCI Event: Command Status (0x0f) plen 4        #12 5.350757
      LE Read Remote Used Features (0x08|0x0016) ncmd 1
> ACL Data RX: Handle 64 flags 0x02 dlen 7        #13 5.366017
      ATT: Exchange MTU Request (0x02) len 2
        Client RX MTU: 247
> HCI Event: LE Meta Event (0x3e) plen 12        #14 5.366685
      LE Read Remote Used Features (0x04)
        Handle: 64
        Features: 0x2d 0x00 0x00 0x00 0x00 0x00 0x00 0x00
          LE Encryption
          Extended Reject Indication
          Slave-initiated Features Exchange
          LE Data Packet Length Extension
< ACL Data TX: Handle 64 flags 0x00 dlen 18        #15 5.366734
      LE L2CAP: LE Connection Request (0x14) ident 1 len 10
        PSM: 129 (0x0081)
        Source CID: 64
        MTU: 672
        MPS: 247
        Credits: 3
< ACL Data TX: Handle 64 flags 0x00 dlen 7        #16 5.367263
      ATT: Exchange MTU Response (0x03) len 2
        Server RX MTU: 517
< ACL Data TX: Handle 64 flags 0x00 dlen 7        #17 5.367276
        Client RX MTU: 517
> HCI Event: LE Meta Event (0x3e) plen 11        #18 5.388874
      LE Data Length Change (0x07)
        Handle: 64
        Max TX octets: 251
        Max TX time: 2120
        Max RX octets: 251
        Max RX time: 2120
> ACL Data RX: Handle 64 flags 0x02 dlen 18        #19 5.396227
      LE L2CAP: LE Connection Response (0x15) ident 1 len 10
        Destination CID: 64
        MTU: 30
        MPS: 32
        Credits: 1
        Result: Connection successful (0x0000)
> HCI Event: Number of Completed Packets (0x13) plen 5        #20 5.396619
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 7        #21 5.411145
        Server RX MTU: 247
< ACL Data TX: Handle 64 flags 0x00 dlen 7        #22 5.411479
      ATT: Read Request (0x0a) len 2
        Handle: 0x0004
> HCI Event: Number of Completed Packets (0x13) plen 5        #23 5.418762
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #24 5.426104
      ATT: Read Response (0x0b) len 7
        Value: 53583030303030
< ACL Data TX: Handle 64 flags 0x00 dlen 7        #25 5.426409
        Handle: 0x0006
> ACL Data RX: Handle 64 flags 0x02 dlen 7        #26 5.441071
      ATT: Read Response (0x0b) len 2
        Value: 0000
< ACL Data TX: Handle 64 flags 0x00 dlen 11        #27 5.441421
      ATT: Read By Type Request (0x08) len 6
        Handle range: 0x0001-0xffff
        Attribute type: Unknown (0x2b3a)
> HCI Event: Number of Completed Packets (0x13) plen 5        #28 5.448773
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 9        #29 5.456084
      ATT: Error Response (0x01) len 4
        Handle: 0x0001
        Error: Attribute Not Found (0x0a)
< ACL Data TX: Handle 64 flags 0x00 dlen 11        #30 5.456288
      ATT: Read By Group Type Request (0x10) len 6
        Attribute group type: Primary Service (0x2800)
> ACL Data RX: Handle 64 flags 0x02 dlen 18        #31 5.471163
      ATT: Read By Group Type Response (0x11) len 13
        Attribute data length: 6
        Attribute group list: 2 entries
        Handle range: 0x0001-0x0001
        UUID: Generic Attribute Profile (0x1801)
        Handle range: 0x0002-0x0006
        UUID: Generic Access Profile (0x1800)
< ACL Data TX: Handle 64 flags 0x00 dlen 11        #32 5.471362
        Handle range: 0x0007-0xffff
> HCI Event: Number of Completed Packets (0x13) plen 5        #33 5.478772
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 26        #34 5.486695
      ATT: Read By Group Type Response (0x11) len 21
        Attribute data length: 20
        Attribute group list: 1 entry
        Handle range: 0x0007-0x000c
        UUID: Nordic UART Service (6e400001-b5a3-f393-e0a9-e50e24dcca9e)
< ACL Data TX: Handle 64 flags 0x00 dlen 11        #35 5.486873
        Handle range: 0x000d-0xffff
> ACL Data RX: Handle 64 flags 0x02 dlen 9        #36 5.501100
        Handle: 0x000d
> HCI Event: Number of Completed Packets (0x13) plen 5        #37 5.639217
        Num handles: 1
        Handle: 64
        Count: 1
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #38 15.397047
      Channel: 64 len 27 sdu 25 [PSM 129 mode LE Flow Control (0x80)] {chan 0}
        19 00 00 00 02 20 2d 37 01 24 41 35 01 24 43 35  ..... -7.$A5.$C5
        01 24 45 35 01 24 47 35 01 24 49                 .$E5.$G5.$I
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #39 15.397074
        19 00 35 01 24 00 00 00 00 00 00 00 00 00 00 00  ..5.$...........
        00 00 00 00 00 01 f3 01 24 4b 35                 ........$K5
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #40 15.397077
        19 00 01 24 00 00 00 00 a1 f3 01 24 5f d0 01 24  ...$.......$_..$
        7d 37 01 24 7d 37 01 24 7d 37 01                 }7.$}7.$}7.
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #41 15.397090
        19 00 24 7d 37 01 24 7d 37 01 24 7d 37 01 24 7d  ..$}7.$}7.$}7.$}
        37 01 24 7d 37 01 24 7d 37 01 24                 7.$}7.$}7.$
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #42 15.397099
        19 00 7d 37 01 24 7d 37 01 24 4d 35 01 24 5d 35  ..}7.$}7.$M5.$]5
        01 24 7d 37 01 24 7d 37 01 24 7d                 .$}7.$}7.$}
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #43 15.397107
        19 00 37 01 24 7d 37 01 24 7d 37 01 24 7d 37 01  ..7.$}7.$}7.$}7.
        24 7d 37 01 24 7d 37 01 24 7d 37                 $}7.$}7.$}7
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #44 15.397116
        19 00 01 24 7d 37 01 24 7d 37 01 24 7d 37 01 24  ...$}7.$}7.$}7.$
        6d 35 01 24 7d 37 01 24 7d 37 01                 m5.$}7.$}7.
> HCI Event: Number of Completed Packets (0x13) plen 5        #45 15.402052
        Num handles: 1
        Handle: 64
        Count: 2
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #46 15.402094
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #47 15.402102
        19 00 7d 37 01 24 7d 37 01 24 7d 37 01 24 7d 37  ..}7.$}7.$}7.$}7
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #48 15.402763
      LE L2CAP: LE Flow Control Credit (0x16) ident 1 len 4
        Source CID: 64
        Credits: 1
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #49 15.403728
      LE L2CAP: LE Flow Control Credit (0x16) ident 2 len 4
        Source CID: 64
        Credits: 1
> HCI Event: Number of Completed Packets (0x13) plen 5        #50 15.403878
        Num handles: 1
        Handle: 64
        Count: 2
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #51 15.403898
        19 00 37 01 24 7d 37 01 24 00 00 00 00 7d 37 01  ..7.$}7.$....}7.
< ACL Data TX: Handle 64 flags 0x00 dlen 12        #52 15.403905
      LE L2CAP: Disconnection Request (0x06) ident 2 len 4
        Destination CID: 64
        Source CID: 64
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #53 15.408912
      LE L2CAP: LE Flow Control Credit (0x16) ident 3 len 4
        Source CID: 64
        Credits: 1
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #54 15.409706
      LE L2CAP: LE Flow Control Credit (0x16) ident 4 len 4
        Source CID: 64
        Credits: 1
> HCI Event: Number of Completed Packets (0x13) plen 5        #55 15.410967
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #56 15.410981
      LE L2CAP: LE Flow Control Credit (0x16) ident 5 len 4
        Source CID: 64
        Credits: 1
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #57 15.411851
      LE L2CAP: LE Flow Control Credit (0x16) ident 6 len 4
        Source CID: 64
        Credits: 1
> HCI Event: Number of Completed Packets (0x13) plen 5        #58 15.411988
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #59 15.416413
      LE L2CAP: LE Flow Control Credit (0x16) ident 7 len 4
        Source CID: 64
        Credits: 1
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #60 15.417195
      LE L2CAP: LE Flow Control Credit (0x16) ident 8 len 4
        Source CID: 64
        Credits: 1
> HCI Event: Number of Completed Packets (0x13) plen 5        #61 15.417416
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #62 15.418040
      LE L2CAP: LE Flow Control Credit (0x16) ident 9 len 4
        Source CID: 64
        Credits: 1
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #63 15.423739
      LE L2CAP: Disconnection Response (0x07) ident 2 len 4
        Destination CID: 64
        Source CID: 64
> HCI Event: Number of Completed Packets (0x13) plen 5        #64 15.639354
        Num handles: 1
        Handle: 64
        Count: 1
  • Hi Simon,
    I have tried with different connection intervals, and found that by increasing the connection interval I get the expected behaviour. Until the end of the connection interval then a  retransmission occurs. But now the  retransmission duration is much longer, so the gains that I get from it behaving well initially are largely lost here. Do you think that the SDC is running out of buffer and that is why the nrf is idling for a whole connection interval? Shouldn't the RX buffer be freed after the seg_recv callback? Why would the SDC be running out of buffer? It does not seem to make a difference if I increase CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT.
    It looks like this:
    t=0 central-> peripheral [CoC, Le information frame] 1
    t=2.2ms peripheral-> central [NACK]
    t=2.5 central-> peripheral [CoC, Le information frame] 2
    t=4.7ms peripheral-> central [NACK]
    t=5.0ms central-> peripheral [CoC, Le information frame] 3
    t=[connection interval] central-> peripheral [CoC, Le information frame]
    t=[(connection interval)x2] central-> peripheral [CoC, Le information frame Retransition]
    t=[(connection interval)x2 +2ms] peripheral-> central [ACK]
    See below for Wireshark logs:
    2026-01-23_15ms_interval_6credits.pcapng
    2026-01-23_30ms_12cred.pcapng
    Best Regards,
    Paul
  • Hi Paul
    Right now, we suspect buffer starvation on the SDC side, correct. I'll see if I can reproduce this and experiment with some values later this week. We have created an internal ticket to keep track of this issue on our end now as well. Until we have some progress on our end, all I can recommend is that you play around with buffer values in your application and see if anything helps the throughput.
    Simon
  • Hi Simon,
    OK, thank you. I look forward to hearing the result of your testing.
    Best Regards,
    Paul
  • Hi Paul
    I need to set the expectations straight here. I have been out sick, so I have not been able to work on reproducing this, and will have to resume that on Monday. I'll get back to on Tuesday at the latest with my results. Do you by chance have a project that can reproduce this behavior on a Development Kit to shorten the time it will take for me to get this up and running?
    Simon
  • Hi Simon,
    Apologies for not getting back sooner.
    As I said previously, this project was built on an existing project, so I have had to strip out a lot of code. Hopefully this helps. This project should work with the Nrf 52 DK board. (board called dev_board inside the boards folder)
    l2cap-test.zip
    Paul
