L2CAP CoC connection only one credit per connection interval
Using nrf connect SDK 2.5.0
The nrf device is an L2CAP CoC server. I am using an RPi 4 to test with. The application is for transferring data through UART to another chip on the board to perform OTA updates. The connection sets up and I can transfer data successfully from the RPi to the nrf, but I only get 1 credit per connection interval, so throughput is limited. I have a connection interval of 7.5ms, an MTU of 245, so 245/7.5e-3 = 32KBps, which is roughly what my setup achieves, however I should be able to get 3 credits per interval (PHY 1M), so 98KBps. I want to fix this as some clients may have a larger min connection interval, so this issue would be exacerbated in that case.
I have tried increasing CONFIG_BT_BUF_ACL_RX_COUNT
a snippet of the prj:
CONFIG_BT_L2CAP_TX_BUF_COUNT=2
CONFIG_BT_BUF_ACL_TX_COUNT=2
CONFIG_BT_BUF_ACL_RX_COUNT=20
CONFIG_BT_NUS_UART_BUFFER_SIZE=244
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
I have tried configuring the SD so that it has plenty of buffer
int configure_softdevice_buffers(void)
    sdc_cfg_t cfg;
    cfg.buffer_cfg.rx_packet_count = CONFIG_BT_BUF_ACL_RX_COUNT;
    cfg.buffer_cfg.tx_packet_count = CONFIG_BT_BUF_ACL_TX_COUNT;
    cfg.buffer_cfg.rx_packet_size  = CONFIG_BT_CTLR_DATA_LENGTH_MAX;
    cfg.buffer_cfg.tx_packet_size  = CONFIG_BT_CTLR_DATA_LENGTH_MAX;
    return sdc_cfg_set(SDC_DEFAULT_RESOURCE_CFG_TAG, SDC_CFG_TYPE_BUFFER_CFG, &cfg);
static int my_bt_low_level_init(void)
    int ret = configure_softdevice_buffers();
    if (ret) {
        printk("SDC Config failed: %d\n", ret);
    } else {
        printk("SDC Config success\n");
    return 0;
// Use PRE_KERNEL_1 to ensure this runs before the BT stack starts
SYS_INIT(my_bt_low_level_init, PRE_KERNEL_1, CONFIG_KERNEL_INIT_PRIORITY_DEVICE);
My server code is as basic as possible, except I have tried manually allocating a large enough net buf pool (size 20) using the alloc_buff callback. I tried without doing this initially with the same result. My recv callback does not do anything with the data currently, I just want to test the L2CAP connection speed first before adding UART.
#include <zephyr/kernel.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/l2cap.h>
LOG_MODULE_REGISTER(l2cap_channel);
#include "l2cap_channel.h"
/* Must match client */
#define L2CAP_PSM 0x0081
#define L2CAP_MTU 245
#define RX_BUFF_NUM 20
#define RX_BUFF_LENGTH 251
#define RX_BUFF_USER_DATA_SIZE 8
static struct bt_l2cap_le_chan l2cap_chan;
NET_BUF_POOL_FIXED_DEFINE(net_buff_pool_rx, RX_BUFF_NUM, RX_BUFF_LENGTH, RX_BUFF_USER_DATA_SIZE, NULL);
static uint32_t bytes_received = 0;
// L2CAP CALLBACKS
static void l2cap_connected(struct bt_l2cap_chan *chan)
    LOG_INF("L2CAP CoC connected");
static void l2cap_disconnected(struct bt_l2cap_chan *chan)
    LOG_INF("L2CAP CoC disconnected");
static int l2cap_recv(struct bt_l2cap_chan *chan, struct net_buf *buf)
    bytes_received += buf->len;
    return 0;
static struct net_buf *l2cap_chan_alloc_buf(struct bt_l2cap_chan *chan)
    struct net_buf *buf = net_buf_alloc(&net_buff_pool_rx, K_NO_WAIT);
    if (buf) {
        LOG_INF("Allocated buf for credit");
    } else {
        LOG_ERR("Failed to allocate buf for credit");
    return buf;
// CHANNEL OPS
static struct bt_l2cap_chan_ops l2cap_ops = {
    .connected = l2cap_connected,
    .disconnected = l2cap_disconnected,
    .recv = l2cap_recv,
    .alloc_buf  = l2cap_chan_alloc_buf,
// ACCEPT CALLBACK
static int l2cap_accept(struct bt_conn *conn, struct bt_l2cap_chan **chan)
    LOG_INF("L2CAP CoC accept");
    struct bt_l2cap_le_chan *le_chan = &l2cap_chan; // Ensure this is the LE struct
    // Force reset the RX state before assigning
    memset(&le_chan->rx, 0, sizeof(le_chan->rx));
    le_chan->chan.ops = &l2cap_ops;
    le_chan->rx.mtu = L2CAP_MTU;
    le_chan->rx.mps = L2CAP_MTU;
    le_chan->rx.init_credits = RX_BUFF_NUM / 2;
    *chan = &le_chan->chan;
    return 0;
// L2CAP SERVER
static struct bt_l2cap_server l2cap_server = {
    .psm = L2CAP_PSM,
    .sec_level = BT_SECURITY_L1,  // no auth no encryption
    .accept = l2cap_accept,
// PUBLIC METHODS
int l2cap_channel_init()
    return bt_l2cap_server_register(&l2cap_server);
Here is my btmon output from the RPi. it shows that I am only receiving 1 credit per connection interval even though the packet size that I am sending (30) is way less than the MTU. Note that this is not the same log as for the 32KBps connection, this is me testing with a lower MTU to prove out that there should be enough buffer on the controller to handle multiple credits.
< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7        #1 4.846002
        Type: Passive (0x00)
        Interval: 60.000 msec (0x0060)
        Window: 60.000 msec (0x0060)
        Own address type: Public (0x00)
        Filter policy: Ignore not in white list (0x01)
> HCI Event: Command Complete (0x0e) plen 4        #2 4.846421
      LE Set Scan Parameters (0x08|0x000b) ncmd 1
        Status: Success (0x00)
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2        #3 4.846526
        Scanning: Enabled (0x01)
        Filter duplicates: Enabled (0x01)
> HCI Event: Command Complete (0x0e) plen 4        #4 4.846851
      LE Set Scan Enable (0x08|0x000c) ncmd 1
> HCI Event: LE Meta Event (0x3e) plen 35        #5 5.142090
      LE Advertising Report (0x02)
        Num reports: 1
        Event type: Connectable undirected - ADV_IND (0x00)
        Address type: Random (0x01)
        Address: D7:85:74:5F:87:45 (Static)
        Data length: 23
        Flags: 0x06
          LE General Discoverable Mode
          BR/EDR Not Supported
        Name (complete): SX00000
        Company: Ericsson Technology Licensing (0)
          Data: 000000000000
        RSSI: -35 dBm (0xdd)
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2        #6 5.142149
        Scanning: Disabled (0x00)
        Filter duplicates: Disabled (0x00)
> HCI Event: Command Complete (0x0e) plen 4        #7 5.144100
< HCI Command: LE Create Connection (0x08|0x000d) plen 25        #8 5.144154
        Scan interval: 60.000 msec (0x0060)
        Scan window: 60.000 msec (0x0060)
        Filter policy: White list is not used (0x00)
        Peer address type: Random (0x01)
        Peer address: D7:85:74:5F:87:45 (Static)
        Min connection interval: 7.50 msec (0x0006)
        Max connection interval: 7.50 msec (0x0006)
        Connection latency: 0 (0x0000)
        Supervision timeout: 4000 msec (0x0190)
        Min connection length: 0.000 msec (0x0000)
        Max connection length: 0.000 msec (0x0000)
> HCI Event: Command Status (0x0f) plen 4        #9 5.144672
      LE Create Connection (0x08|0x000d) ncmd 1
> HCI Event: LE Meta Event (0x3e) plen 19        #10 5.349786
      LE Connection Complete (0x01)
        Handle: 64
        Role: Master (0x00)
        Connection interval: 7.50 msec (0x0006)
        Master clock accuracy: 0x00
@ MGMT Event: Device Connected (0x000b) plen 36        {0x0001} 5.349817
        LE Address: D7:85:74:5F:87:45 (Static)
        Flags: 0x00000008
          Unknown device flag (0x00000008)
        Data length: 23
        Flags: 0x06
          Data: 000000000000
< HCI Command: LE Read Remote Used Features (0x08|0x0016) plen 2        #11 5.349912
        Handle: 64
> HCI Event: Command Status (0x0f) plen 4        #12 5.350757
      LE Read Remote Used Features (0x08|0x0016) ncmd 1
> ACL Data RX: Handle 64 flags 0x02 dlen 7        #13 5.366017
      ATT: Exchange MTU Request (0x02) len 2
        Client RX MTU: 247
> HCI Event: LE Meta Event (0x3e) plen 12        #14 5.366685
      LE Read Remote Used Features (0x04)
        Handle: 64
        Features: 0x2d 0x00 0x00 0x00 0x00 0x00 0x00 0x00
          LE Encryption
          Extended Reject Indication
          Slave-initiated Features Exchange
          LE Data Packet Length Extension
< ACL Data TX: Handle 64 flags 0x00 dlen 18        #15 5.366734
      LE L2CAP: LE Connection Request (0x14) ident 1 len 10
        PSM: 129 (0x0081)
        Source CID: 64
        MTU: 672
        MPS: 247
        Credits: 3
< ACL Data TX: Handle 64 flags 0x00 dlen 7        #16 5.367263
      ATT: Exchange MTU Response (0x03) len 2
        Server RX MTU: 517
< ACL Data TX: Handle 64 flags 0x00 dlen 7        #17 5.367276
        Client RX MTU: 517
> HCI Event: LE Meta Event (0x3e) plen 11        #18 5.388874
      LE Data Length Change (0x07)
        Handle: 64
        Max TX octets: 251
        Max TX time: 2120
        Max RX octets: 251
        Max RX time: 2120
> ACL Data RX: Handle 64 flags 0x02 dlen 18        #19 5.396227
      LE L2CAP: LE Connection Response (0x15) ident 1 len 10
        Destination CID: 64
        MTU: 30
        MPS: 32
        Credits: 1
        Result: Connection successful (0x0000)
> HCI Event: Number of Completed Packets (0x13) plen 5        #20 5.396619
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 7        #21 5.411145
        Server RX MTU: 247
< ACL Data TX: Handle 64 flags 0x00 dlen 7        #22 5.411479
      ATT: Read Request (0x0a) len 2
        Handle: 0x0004
> HCI Event: Number of Completed Packets (0x13) plen 5        #23 5.418762
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #24 5.426104
      ATT: Read Response (0x0b) len 7
        Value: 53583030303030
< ACL Data TX: Handle 64 flags 0x00 dlen 7        #25 5.426409
        Handle: 0x0006
> ACL Data RX: Handle 64 flags 0x02 dlen 7        #26 5.441071
      ATT: Read Response (0x0b) len 2
        Value: 0000
< ACL Data TX: Handle 64 flags 0x00 dlen 11        #27 5.441421
      ATT: Read By Type Request (0x08) len 6
        Handle range: 0x0001-0xffff
        Attribute type: Unknown (0x2b3a)
> HCI Event: Number of Completed Packets (0x13) plen 5        #28 5.448773
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 9        #29 5.456084
      ATT: Error Response (0x01) len 4
        Handle: 0x0001
        Error: Attribute Not Found (0x0a)
< ACL Data TX: Handle 64 flags 0x00 dlen 11        #30 5.456288
      ATT: Read By Group Type Request (0x10) len 6
        Attribute group type: Primary Service (0x2800)
> ACL Data RX: Handle 64 flags 0x02 dlen 18        #31 5.471163
      ATT: Read By Group Type Response (0x11) len 13
        Attribute data length: 6
        Attribute group list: 2 entries
        Handle range: 0x0001-0x0001
        UUID: Generic Attribute Profile (0x1801)
        Handle range: 0x0002-0x0006
        UUID: Generic Access Profile (0x1800)
< ACL Data TX: Handle 64 flags 0x00 dlen 11        #32 5.471362
        Handle range: 0x0007-0xffff
> HCI Event: Number of Completed Packets (0x13) plen 5        #33 5.478772
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 26        #34 5.486695
      ATT: Read By Group Type Response (0x11) len 21
        Attribute data length: 20
        Attribute group list: 1 entry
        Handle range: 0x0007-0x000c
        UUID: Nordic UART Service (6e400001-b5a3-f393-e0a9-e50e24dcca9e)
< ACL Data TX: Handle 64 flags 0x00 dlen 11        #35 5.486873
        Handle range: 0x000d-0xffff
> ACL Data RX: Handle 64 flags 0x02 dlen 9        #36 5.501100
        Handle: 0x000d
> HCI Event: Number of Completed Packets (0x13) plen 5        #37 5.639217
        Num handles: 1
        Handle: 64
        Count: 1
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #38 15.397047
      Channel: 64 len 27 sdu 25 [PSM 129 mode LE Flow Control (0x80)] {chan 0}
        19 00 00 00 02 20 2d 37 01 24 41 35 01 24 43 35  ..... -7.$A5.$C5
        01 24 45 35 01 24 47 35 01 24 49                 .$E5.$G5.$I
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #39 15.397074
        19 00 35 01 24 00 00 00 00 00 00 00 00 00 00 00  ..5.$...........
        00 00 00 00 00 01 f3 01 24 4b 35                 ........$K5
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #40 15.397077
        19 00 01 24 00 00 00 00 a1 f3 01 24 5f d0 01 24  ...$.......$_..$
        7d 37 01 24 7d 37 01 24 7d 37 01                 }7.$}7.$}7.
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #41 15.397090
        19 00 24 7d 37 01 24 7d 37 01 24 7d 37 01 24 7d  ..$}7.$}7.$}7.$}
        37 01 24 7d 37 01 24 7d 37 01 24                 7.$}7.$}7.$
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #42 15.397099
        19 00 7d 37 01 24 7d 37 01 24 4d 35 01 24 5d 35  ..}7.$}7.$M5.$]5
        01 24 7d 37 01 24 7d 37 01 24 7d                 .$}7.$}7.$}
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #43 15.397107
        19 00 37 01 24 7d 37 01 24 7d 37 01 24 7d 37 01  ..7.$}7.$}7.$}7.
        24 7d 37 01 24 7d 37 01 24 7d 37                 $}7.$}7.$}7
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #44 15.397116
        19 00 01 24 7d 37 01 24 7d 37 01 24 7d 37 01 24  ...$}7.$}7.$}7.$
        6d 35 01 24 7d 37 01 24 7d 37 01                 m5.$}7.$}7.
> HCI Event: Number of Completed Packets (0x13) plen 5        #45 15.402052
        Num handles: 1
        Handle: 64
        Count: 2
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #46 15.402094
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #47 15.402102
        19 00 7d 37 01 24 7d 37 01 24 7d 37 01 24 7d 37  ..}7.$}7.$}7.$}7
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #48 15.402763
      LE L2CAP: LE Flow Control Credit (0x16) ident 1 len 4
        Source CID: 64
        Credits: 1
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #49 15.403728
      LE L2CAP: LE Flow Control Credit (0x16) ident 2 len 4
        Source CID: 64
        Credits: 1
> HCI Event: Number of Completed Packets (0x13) plen 5        #50 15.403878
        Num handles: 1
        Handle: 64
        Count: 2
< ACL Data TX: Handle 64 flags 0x00 dlen 31        #51 15.403898
        19 00 37 01 24 7d 37 01 24 00 00 00 00 7d 37 01  ..7.$}7.$....}7.
< ACL Data TX: Handle 64 flags 0x00 dlen 12        #52 15.403905
      LE L2CAP: Disconnection Request (0x06) ident 2 len 4
        Destination CID: 64
        Source CID: 64
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #53 15.408912
      LE L2CAP: LE Flow Control Credit (0x16) ident 3 len 4
        Source CID: 64
        Credits: 1
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #54 15.409706
      LE L2CAP: LE Flow Control Credit (0x16) ident 4 len 4
        Source CID: 64
        Credits: 1
> HCI Event: Number of Completed Packets (0x13) plen 5        #55 15.410967
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #56 15.410981
      LE L2CAP: LE Flow Control Credit (0x16) ident 5 len 4
        Source CID: 64
        Credits: 1
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #57 15.411851
      LE L2CAP: LE Flow Control Credit (0x16) ident 6 len 4
        Source CID: 64
        Credits: 1
> HCI Event: Number of Completed Packets (0x13) plen 5        #58 15.411988
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #59 15.416413
      LE L2CAP: LE Flow Control Credit (0x16) ident 7 len 4
        Source CID: 64
        Credits: 1
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #60 15.417195
      LE L2CAP: LE Flow Control Credit (0x16) ident 8 len 4
        Source CID: 64
        Credits: 1
> HCI Event: Number of Completed Packets (0x13) plen 5        #61 15.417416
        Num handles: 1
        Handle: 64
        Count: 2
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #62 15.418040
      LE L2CAP: LE Flow Control Credit (0x16) ident 9 len 4
        Source CID: 64
        Credits: 1
> ACL Data RX: Handle 64 flags 0x02 dlen 12        #63 15.423739
      LE L2CAP: Disconnection Response (0x07) ident 2 len 4
        Destination CID: 64
        Source CID: 64
> HCI Event: Number of Completed Packets (0x13) plen 5        #64 15.639354
        Num handles: 1
        Handle: 64
        Count: 1
