DFU Bootloader uploading smaller App
we have a NRF52832 based project / product. We are using a DFU bootloader for application and SD update. The update is done from a master microcontroller using UART.
Our update packages are created using the Nordic Tools and uploaded to the master microcontroller via ftp. All that is working just fine.
We just have one problem: If we update the application with a smaller file than the one that is installed, the update fails. The bootloader reports "nrf_dfu_validation: Hash verification failed."
It looks like the hash is generated over a larger area of flash than the size of the application itself. When the application that has been installed before is smaller there seems to be a rest of the old application in the flash memory and the hash generation fails.
What can be done to avoid this problem?
    I'm not aware of any known issues that could explain this. Some suggestions for troubleshooting this further:
    1. Attach a debugger and read out the bootloader settings page at the end of flash and check if the application size (nrf_dfu_settings_t -> bank0 -> image_size)
    2. Read out the app image from bank0 and compare it to the original binary to see if there are any discrepancies.
    Please also let me know what SDK version your bootloader was based on, and what the exact size of the app image in the working and failing case.
    Vidar
    the debugger reports the correct image sizes. The code itself written to the flash is correct as well. Exactly the same image can be uploaded when there hasn't been a larger image installed before. As soon as I increase the application size by using some const arrays the image installs fine.
    Please note that I am only using a single bank as my application might be too large for bank switching in the future.
    The app sizes are 159138 and 159432 bytes.
    The bootloader is based on SDK 17.1.0.
    Marcus
    can you show what you mean by this? Are you reading the image size from the settings struct, and does this match the size of the binary you uploaded?
    Can you show me how you confirmed this?
    the debug of the bootloader shows the image size when the CRC is computed. That is the size I upload in my code. As my master microcontroller doesn't have code to unzip I have a tool that unzips the update package and packs everything into a single file with a header that contains the sizes of all parts of the update. Furthermore I do a CRC over this package so that I know that the data that has been uploaded to the master is correct.
    I am sure that the correct code is written to the flash because exactly the same image file doesn't fail when there hasn't been a larger file on the nRF52 before. I did that some dozen times back and forth and it only and consistently fails when there has been a larger image in flash before.
    Furthermore before the signature is checked, a CRC is computed for the uploaded image by the bootloader. That CRC is correct (shown by the debugger). Only the ECDSA signature verification fails. My guess is, that the SHA256 that uses 512Bit/64 Byte blocks doesn't have the correct padding if there is some old data in flash. The CRC in contrast is done byte by byte and doesn't need any padding.
    Marcus
  • Hi Marcus,
    I don't recall seeing any issues like this before. The hash function should accepts input of arbitrary length and handle any required padding internally.
    The flash is also erased progressively in 0x1000 byte sectors as the image is received by the bootloader, so any data following the application should still be 0xFFFF (until you reach the next page aligned address). I still think it's worth reading out the flash as suggested initially. Then you can easily compare what is actually different in the working and  failing cases.
    Reading flash with nrfutil
    nrfutil device read --address 0x0 --bytes 0x80000 > flash_content.txt
    With nrfjprog
    nrfjprog --memrd 0x0 --n 0x80000 > flash_content.txt
