How to Read 16 bit ADC Value on nRF Master app? not 8 bit!
FormerMember
FormerMember
Hello!
I'm trying to read 16 bit ADC Value on nRF Master app instead of only 8 bit, and I know that there is the example code on github which is only send me the 8 bit "uint8_t adc_result" data to nRF mater app
/* Interrupt handler for ADC data ready event */
void ADC_IRQHandler(void)
	uint8_t adc_result;
	/* Clear dataready event */
  NRF_ADC->EVENTS_END = 0;
  /* Write ADC result both to the UART and over BLE */
	adc_result = NRF_ADC->RESULT;
	app_uart_put(adc_result);
	ble_nus_send_string(&m_nus, &adc_result, 1);
	nrf_gpio_pin_toggle(LED_3);        //indicate on LED that the ADC interrupt handler is executing
	//Use the STOP task to save current. Workaround for PAN_028 rev1.5 anomaly 1.
  NRF_ADC->TASKS_STOP = 1;
	//Release the external crystal
	sd_clock_hfclk_release();
where it sends the ADC value over Bluetooth by the "ble_nus_send_string()" command:
uint32_t ble_nus_send_string(ble_nus_t * p_nus, uint8_t * string, uint16_t length)
    ble_gatts_hvx_params_t hvx_params;
    if (p_nus == NULL)
        return NRF_ERROR_NULL;
    if ((p_nus->conn_handle == BLE_CONN_HANDLE_INVALID) || (!p_nus->is_notification_enabled))
    if (length > BLE_NUS_MAX_DATA_LEN)
        return NRF_ERROR_INVALID_PARAM;
    memset(&hvx_params, 0, sizeof(hvx_params));
    hvx_params.handle = p_nus->rx_handles.value_handle;
    hvx_params.p_data = string;
    hvx_params.p_len  = &length;
    hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
    return sd_ble_gatts_hvx(p_nus->conn_handle, &hvx_params);
if I just similarly change the 'uint8_t adc_result' to 'uint16_t adc_result' it will show me endless ERROR.
Does anyone have any solutions for reading the ADC value on the nRF Mater Control panel app 16 bits instead of only 8 bits?
Any help is appreciated!
  • FormerMember
    0 FormerMember
    ADC_IRQHandler :
       static uint16_t adc_result;
        ble_nus_send_string(&m_nus, &adc_result);
    ble_nus_send_string :
    uint32_t ble_nus_send_string(ble_nus_t * p_nus, uint16_t * string)
            if (p_nus == NULL)
    static uint16_t adc_len = sizeof(string);
            hvx_params.p_data = (uint8_t*)&string;
            hvx_params.p_len  = &adc_len;
  • FormerMember
    0 FormerMember in reply to FormerMember
    RK, I really appreciated your kindly help. I decied to place the code only inside of the "ADC_IRQHandler" for now. Could you please help me check it?
       static uint16_t adc_len = sizeof( adc_result);
                hvx_params.p_data = (uint8_t*)&adc_result;
  • FormerMember
