Scan beacons
Hi.
I'm currently trying to scan beacons with timeslot example.
However, I found that there're more than 20% of loss while scanning beacons broadcast.
I think that's huge even if broadcast has no guarantee to be transferred.
I set up 1 beacon to broadcast with specified UUID in a short interval.
The interval is 20ms and I achieved this with repeating start & stop manually.
The beacon broadcast for 256 time and each time change minor value of packet. (0x00 to 0xFF)
Then, I set a scanner to scan beacon broadcast packets with specified UUID.
(I make it compare UUID of each packet manually.)
For the physical environment, I placed a beacon and a scanner close to each other. (less than 20cm)
And then, I checked out how much loss happened in the scanner side.
For various combinations of scan interval & window value, loss rate always exceeds 20%.
I wonder if this is expected normal performance.
Can I get a code review for this test?
Or can I get a verified result & sample code for testing?
Thanks in advance.
    Any particular reason why you do it with timeslot API? When using normal dual-role stack (S130) on nRF51 DK I have basically zero packet loss when scanning with 100% duty cycle down to 10 broadcasters @20ms interval (beacons if you want but I simply use connectable adv. to be able to go below 100ms with standard BLE stack). If S13x scans at 100% duty cycle I get resolution down to ~1 adv per ms (1000 adv. reports per second) and if I'd be also advertising I expect to keep it very close to that because advertising Tx+Rx blocks radio for <1ms.
    Cheers Jan
  • Hi, hard to even spot the update in your question. have you thought about some better structuring (when it comes to technical debate)?;) Cheers Jan
