Channel Sounding Not Working with nRF Toolbox App and nRF54L15-DK
I'm trying to experiment with Bluetooth Channel Sounding using the nRF Toolbox App with an nRF54L15-DK. The app is running on a Google Pixel 10 running Android 16 QPR3 Beta 2. On the DK, I'm using the channel_sounding_ras_reflector app from NCS v3.1.1. These are the only modifications I've made:
  • CONFIG_BT_BONDABLE=y
  • CONFIG_BT_CTLR_SDC_CS_MAX_ANTENNA_PATHS=2
I have not made any modifications to the nRF Toolbox app.
The app fails to show any ranging data and gets stuck at "Initiating ranging..."
I have an RFCreations airtrace and can see nRF DK is rejecting the Channel Sounding Start command from the Pixel:
I also see some cases where the Channel Sounding Start appears to succeed:
Here is the CS Configuration being used:
Devices:
Central : 44:A2:8F:A0:48:76, Resolvable private
Peripheral : D2:42:A2:F3:A6:39, Static (Nordic CS Reflector)
"C2P, decrypted, #160509, LE-C: LL_CS_CONFIG_REQ":
Opcode : 0x30 (LL_CS_CONFIG_REQ)
LL_CS_CONFIG_REQ payload:
Config ID : 0x00 (0)
State : 0x1 (Configuration is enabled)
ChM : "0x15555555555554555554 (Used: 2, 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 26, 28, 30, 32, 34, 36, 38, 40, 42, 44, 46, 48, 50, 52, 54, 56, 58, 60, 62, 64, 66, 68, 70, 72, 74, 76, Unused: 0-1, 3, 5, 7, 9, 11, 13, 15, 17, 19, 21, 23-25, 27, 29, 31, 33, 35, 37, 39, 41, 43, 45, 47, 49, 51, 53, 55, 57, 59, 61, 63, 65, 67, 69, 71, 73, 75, 77-79)"
Channel Map Repetition : 0x01 (1)
Main Mode : 0x02 (Mode-2)
Sub Mode : 0xFF (Mode None)
Main Mode Min Steps : 0x00 (0)
Main Mode Max Steps : 0x00 (0)
Main Mode Repetition : 0x00 (0)
Mode 0 Steps : 0x03 (3)
CS SYNC PHY:
LE 1M PHY : 0x1 (Used)
LE 2M PHY : 0x0 (Not Used)
LE Coded PHY : 0x0 (Not Used)
RFU (2M 2BT or S=2 Coded in other PDUs) : 0x0 (Not Used)
RFU : 0x0 (0)
RTT Type : 0x0 (Sync AA only)
Role : 0x0 (Initiator)
IPT : 0x0 (Not Required)
RFU : 0x0 (Not Required)
ChSel : 0x0 (Channel Selection Algorithm 3b)
Ch3c Shape : 0x0 (Hat shape)
Ch3c Jump : 0x03 (Jump 3)
T IP1 : 0x05 (60 µs)
T IP2 : 0x01 (20 µs)
T FCS : 0x06 (80 µs)
T PM : 0x00 (10 µs)
RFU : 0x00 (0)
"P2C, decrypted, #160577, LE-C: LL_CS_CONFIG_RSP":
Opcode : 0x31 (LL_CS_CONFIG_RSP)
LL_CS_CONFIG_RSP payload:
RFU : 0x0 (0)
This Reflector DK works fine with another nRF54L15 DK programmed as the Initiator. Here is a diff between the failing config and the succeeding config (using the command "diff CS_Config--nRF54_Succeed CS_Config--Pixel_Fail > CS_Config_Diff.txt"):
1,2c1,2
<  "C2P then P2C, decrypted, Channel Sounding Configuration, 2 packets (#2588, #2616)":
<     "C2P then P2C, decrypted, Channel Sounding Configuration, 2 packets (#2588, #2616)"   :
>  "C2P then P2C, decrypted, Channel Sounding Configuration, 2 packets (#160509, #160577)":
4,5c4,5
<         Central        : D2:42:A2:F3:A6:39, Static
<         Peripheral        : CE:E9:DF:96:7C:F8, Static (CS RFLCT 1)
7c7
<     "C2P, decrypted, #2588, LE-C: LL_CS_CONFIG_REQ":
12,13c12,13
<             ChM        : "0x1FFFFFFFFFFFFC7FFFFC (Used: 2-22, 26-76, Unused: 0-1, 23-25, 77-79)"
<             Channel Map Repetition                                                        : 0x03 (3)
15,17c15,17
<             Sub Mode        : 0x01 (Mode-1)
<             Main Mode Min Steps                                                           : 0x02 (2)
<             Main Mode Max Steps                                                           : 0x05 (5)
33c33
<             Ch3c Jump        : 0x00 (Unknown)
36c36
<             T FCS        : 0x05 (60 µs)
41c41
<     "P2C, decrypted, #2616, LE-C: LL_CS_CONFIG_RSP":
Can you help explain what is going on here?
Chris
  • Hi
    I have done some testing on the nRF Toolbox and Channel Sounding just before Christmas, and have some input here.
    Make sure the
    CONFIG_BT_RAS_MAX_ANTENNA_PATHS and CONFIG_BT_CTLR_SDC_CS_MAX_ANTENNA_PATHS is set to 2, and that CONFIG_BT_CTLR_SDC_CS_NUM_ANTENNAS = 1 since there's only 1 antenna on the nRF54L15 DK and that the Bluetooth specification expects at least 2 antenna paths. Also make sure CONFIG_BT_BONDABLE=y
    When connecting and bonding, put the phone more than 0,5m when pairing and initiating ranging.
    Simon
  • Hello, when I was attempting to use the NVS V3.4.0 version of ras_initiator to measure distance with Pixel 10, I also encountered this problem.  。I'm not sure if it's also due to the number of antenna paths.
  • Hi
    Please make a separate ticket where you explain your problem in detail and what nRF device you are using if you need technical support. When using a phone to do Channel Sounding, the settings stated here are necessary as the Pixel 10 stack requires at least 2 antenna paths for Channel Sounding.
    Simon
  • Thank you for your reply. It seems to be the case indeed. Additionally, there seem to be some issues with the validity checking of the parameters for "max procedure interval" and "procedure len" in Pixel 10 and SDK v3.4.0. I have found the answer to this question in the discussion of another issue. It might be that the judgment in SDK v3.4.0 has become stricter.
