I am using nRF52833 with nrf connect sdk for vs code (SDK and Toolchain version : 2.9.1).
Hello Nordic Team,
I am using OTA DFU with MCUboot on the nRF Connect SDK (v2.9.0) in a no-sysbuild setup. OTA DFU is working correctly for downgrade prevention, but I need strict version enforcement so that only strictly higher versions are accepted.
Target behavior:
Lower version → Rejected (already working)
Same version → Rejected (required)
Higher version → Accepted (already working)
Setup details:
I am using a VERSION file in my application:
VERSION_MAJOR = 1
VERSION_MINOR = 0
PATCHLEVEL = 2
VERSION_TWEAK = 2
EXTRAVERSION =
In my application prj.conf:
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
In the child image configuration (mcuboot.conf):
CONFIG_MCUBOOT_DOWNGRADE_PREVENTION=y
CONFIG_BOOT_UPGRADE_ONLY=y
CONFIG_BOOT_VERSION_CMP_USE_BUILD_NUMBER=y
Observed behavior:
OTA with a lower version → Correctly rejected
OTA with a higher version → Correctly accepted
OTA with the same version but a modified application (e.g., device name changed) → Accepted
OTA with the same version and the same binary → Skipped
Requirement:
I want MCUboot to reject:
Images with the same version as the currently running firmware
And accept only:
i am sharing log
same version - VERSION_MAJOR = 1 VERSION_MINOR = 0 PATCHLEVEL = 2 VERSION_TWEAK = 2 EXTRAVERSION = nRF Connect, 2026-01-22 embel11 (E7:92:37:BC:B3:AB) V 15:26:42.793 Connecting to E7:92:37:BC:B3:AB... D 15:26:42.793 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M) D 15:26:43.056 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2) I 15:26:43.056 Connected to E7:92:37:BC:B3:AB V 15:26:43.057 Discovering services... D 15:26:43.057 gatt.discoverServices() D 15:26:43.101 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED D 15:26:43.180 [Callback] Services discovered with status: 0 I 15:26:43.180 Services discovered V 15:26:43.187 Generic Attribute (0x1801) - Service Changed [I] (0x2A05) Client Characteristic Configuration (0x2902) - Client Supported Features [R W] (0x2B29) - Database Hash [R] (0x2B2A) Generic Access (0x1800) - Device Name [R] (0x2A00) - Appearance [R] (0x2A01) - Peripheral Preferred Connection Parameters [R] (0x2A04) SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84) - SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48) Client Characteristic Configuration (0x2902) D 15:26:43.187 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true) I 15:26:43.658 PHY updated (TX: LE 2M, RX: LE 2M) V 15:26:47.556 [McuMgr] Connecting... D 15:26:47.559 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M) D 15:26:47.596 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED) I 15:26:47.600 [McuMgr] Connected to E7:92:37:BC:B3:AB D 15:26:47.603 [McuMgr] wait(300) V 15:26:47.908 [McuMgr] Discovering services... D 15:26:47.913 [McuMgr] gatt.discoverServices() I 15:26:47.927 [McuMgr] Services discovered V 15:26:47.932 [McuMgr] Primary service found V 15:26:47.936 [McuMgr] Requesting new MTU... D 15:26:47.941 [McuMgr] gatt.requestMtu(498) I 15:26:48.078 [McuMgr] MTU changed to: 498 D 15:26:48.086 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true) V 15:26:48.096 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48 D 15:26:48.103 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00) I 15:26:48.204 Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms) I 15:26:48.211 [McuMgr] Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms) I 15:26:48.217 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb V 15:26:48.221 [McuMgr] Waiting for value change... V 15:26:48.224 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 15:26:48.226 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x000000010000FF06A0, WRITE COMMAND) I 15:26:48.229 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 15:26:48.433 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-19-00-00-FF-06-BF-68-62-75-66-5F-73-69-7A-65-19-09-AB-69-62-75-66-5F-63-6F-75-6E-74-04-FF I 15:26:48.441 [McuMgr] Wait for value changed complete A 15:26:48.452 [McuMgr] Received Header (Version: 0, Op: 1, Flags: 0, Len: 25, Group: 0, Seq: 255, Command: 6) CBOR {"buf_size":2475,"buf_count":4} I 15:26:48.468 [McuMgr] SMP reassembly supported with buffer size: 2475 bytes and count: 4 V 15:26:48.473 [McuMgr] Requesting connection priority: HIGH (11.25–15ms, 0, 5s)... D 15:26:48.475 [McuMgr] gatt.requestConnectionPriority(HIGH) A 15:26:48.489 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 1, Group: 0, Seq: 0, Command: 8) CBOR {} V 15:26:48.684 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 15:26:48.688 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000100000008A0, WRITE COMMAND) I 15:26:48.700 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 15:26:48.700 Connection parameters updated (interval: 11.25ms, latency: 0, timeout: 420ms) I 15:26:48.712 [McuMgr] Connection parameters updated (interval: 11.25ms, latency: 0, timeout: 420ms) I 15:26:48.737 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-15-00-00-00-08-BF-6A-62-6F-6F-74-6C-6F-61-64-65-72-67-4D-43-55-62-6F-6F-74-FF A 15:26:48.749 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 21, Group: 0, Seq: 0, Command: 8) CBOR {"bootloader":"MCUboot"} A 15:26:48.768 [McuMgr] Sending (20 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 12, Group: 0, Seq: 1, Command: 8) CBOR {"query":"mode"} V 15:26:48.770 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 15:26:48.774 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000C00000108A1657175657279646D6F6465, WRITE COMMAND) I 15:26:48.784 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 15:26:48.787 Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 5000ms) I 15:26:48.792 [McuMgr] Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 5000ms) I 15:26:48.818 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-08-00-00-01-08-BF-64-6D-6F-64-65-03-FF A 15:26:48.821 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 8, Group: 0, Seq: 1, Command: 8) CBOR {"mode":3} A 15:26:48.829 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 1, Group: 1, Seq: 2, Command: 0) CBOR {} V 15:26:48.833 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 15:26:48.836 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000100010200A0, WRITE COMMAND) I 15:26:48.842 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 15:26:48.866 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-88-00-01-02-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-67-31-2E-30-2E-32-2E-33-64-68-61-73-68-58-20-10-A8-85-31-46-AB-E7-9A-D9-1D-32-68-2A-EA-82-EB-1D-DF-69-08-30-66-8A-20-7C-9E-91-C6-96-DA-07-D4-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF A 15:26:48.869 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 136, Group: 1, Seq: 2, Command: 0) CBOR {"images":[{"slot":0,"version":"1.0.2.3","hash":"EKiFMUar55rZHTJoKuqC6x3faQgwZoogfJ6RxpbaB9Q=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0} V 15:26:48.876 [McuMgr] Uploading firmware... A 15:26:55.164 [McuMgr] 129355 bytes sent in 5965 ms (21.69 kB/s) V 15:26:55.220 [McuMgr] New state: TEST A 15:26:55.225 [McuMgr] Sending (57 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 49, Group: 1, Seq: 58, Command: 0) CBOR {"confirm":false,"hash":"nK8uEoLqHQk2XWq7RXsGI4+KEalPyCp/fb74SPjYdn0="} V 15:26:55.230 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 15:26:55.234 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00003100013A00A267636F6E6669726DF4646861736858209CAF2E1282EA1D09365D6ABB457B06238F8A11A94FC82A7F7DBEF848F8D8767D, WRITE COMMAND) I 15:26:55.245 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 15:26:55.282 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-F8-00-01-3A-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-67-31-2E-30-2E-32-2E-33-64-68-61-73-68-58-20-10-A8-85-31-46-AB-E7-9A-D9-1D-32-68-2A-EA-82-EB-1D-DF-69-08-30-66-8A-20-7C-9E-91-C6-96-DA-07-D4-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-BF-64-73-6C-6F-74-01-67-76-65-72-73-69-6F-6E-67-31-2E-30-2E-32-2E-33-64-68-61-73-68-58-20-9C-AF-2E-12-82-EA-1D-09-36-5D-6A-BB-45-7B-06-23-8F-8A-11-A9-4F-C8-2A-7F-7D-BE-F8-48-F8-D8-76-7D-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F5-69-63-6F-6E-66-69-72-6D-65-64-F4-66-61-63-74-69-76-65-F4-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF A 15:26:55.286 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 248, Group: 1, Seq: 58, Command: 0) CBOR {"images":[{"slot":0,"version":"1.0.2.3","hash":"EKiFMUar55rZHTJoKuqC6x3faQgwZoogfJ6RxpbaB9Q=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false},{"slot":1,"version":"1.0.2.3","hash":"nK8uEoLqHQk2XWq7RXsGI4+KEalPyCp/fb74SPjYdn0=","bootable":true,"pending":true,"confirmed":false,"active":false,"permanent":false}],"splitStatus":0} V 15:26:55.298 [McuMgr] New state: RESET A 15:26:55.311 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 1, Group: 0, Seq: 59, Command: 5) CBOR {} V 15:26:55.315 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 15:26:55.318 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00000100003B05A0, WRITE COMMAND) I 15:26:55.328 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 15:26:55.358 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-02-00-00-3B-05-BF-FF A 15:26:55.363 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 2, Group: 0, Seq: 59, Command: 5) CBOR {} D 15:27:00.584 [Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0) E 15:27:00.585 Error 8 (0x8): GATT CONN TIMEOUT I 15:27:00.585 Disconnected D 15:27:00.588 [McuMgr] [Callback] Connection state changed with status: 8 and new state: 0 (DISCONNECTED) W 15:27:00.603 [McuMgr] Error: (0x8): GATT CONN TIMEOUT I 15:27:00.610 [McuMgr] Disconnected D 15:27:00.640 [McuMgr] gatt.close() D 15:27:00.651 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED V 15:27:05.378 [McuMgr] Connecting... D 15:27:05.384 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M) V 15:27:05.391 [McuMgr] New state: CONFIRM D 15:27:05.772 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED) I 15:27:05.778 [McuMgr] Connected to E7:92:37:BC:B3:AB D 15:27:05.781 [McuMgr] wait(300) D 15:27:05.787 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED V 15:27:06.086 [McuMgr] Discovering services... D 15:27:06.091 [McuMgr] gatt.discoverServices() I 15:27:06.100 [McuMgr] Services discovered V 15:27:06.105 [McuMgr] Primary service found V 15:27:06.110 [McuMgr] Requesting new MTU... D 15:27:06.114 [McuMgr] gatt.requestMtu(498) I 15:27:06.210 [McuMgr] MTU changed to: 498 D 15:27:06.215 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true) V 15:27:06.222 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48 D 15:27:06.226 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00) I 15:27:06.384 [McuMgr] PHY updated (TX: LE 2M, RX: LE 2M) I 15:27:06.390 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb V 15:27:06.395 [McuMgr] Waiting for value change... V 15:27:06.400 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 15:27:06.403 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x000000010000FF06A0, WRITE COMMAND) I 15:27:06.407 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 15:27:06.473 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-19-00-00-FF-06-BF-68-62-75-66-5F-73-69-7A-65-19-09-AB-69-62-75-66-5F-63-6F-75-6E-74-04-FF I 15:27:06.477 [McuMgr] Wait for value changed complete A 15:27:06.482 [McuMgr] Received Header (Version: 0, Op: 1, Flags: 0, Len: 25, Group: 0, Seq: 255, Command: 6) CBOR {"buf_size":2475,"buf_count":4} I 15:27:06.490 [McuMgr] SMP reassembly supported with buffer size: 2475 bytes and count: 4 A 15:27:06.495 [McuMgr] Sending (57 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 49, Group: 1, Seq: 0, Command: 0) CBOR {"confirm":true,"hash":"nK8uEoLqHQk2XWq7RXsGI4+KEalPyCp/fb74SPjYdn0="} V 15:27:06.499 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 15:27:06.502 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00003100010000A267636F6E6669726DF5646861736858209CAF2E1282EA1D09365D6ABB457B06238F8A11A94FC82A7F7DBEF848F8D8767D, WRITE COMMAND) I 15:27:06.508 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 15:27:06.564 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-88-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-67-31-2E-30-2E-32-2E-33-64-68-61-73-68-58-20-9C-AF-2E-12-82-EA-1D-09-36-5D-6A-BB-45-7B-06-23-8F-8A-11-A9-4F-C8-2A-7F-7D-BE-F8-48-F8-D8-76-7D-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF A 15:27:06.570 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 136, Group: 1, Seq: 0, Command: 0) CBOR {"images":[{"slot":0,"version":"1.0.2.3","hash":"nK8uEoLqHQk2XWq7RXsGI4+KEalPyCp/fb74SPjYdn0=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0} V 15:27:06.580 [McuMgr] Disconnecting... D 15:27:06.586 [McuMgr] gatt.disconnect() D 15:27:06.601 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 0 (DISCONNECTED) I 15:27:06.605 [McuMgr] Disconnected D 15:27:06.608 [McuMgr] gatt.close() D 15:27:06.620 gatt.close() D 15:27:06.622 wait(200) V 15:27:06.823 Connecting to E7:92:37:BC:B3:AB... D 15:27:06.823 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M) D 15:27:06.846 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2) I 15:27:06.846 Connected to E7:92:37:BC:B3:AB V 15:27:06.889 Discovering services... D 15:27:06.889 gatt.discoverServices() D 15:27:06.931 [Callback] Services discovered with status: 0 I 15:27:06.931 Services discovered V 15:27:06.941 Generic Attribute (0x1801) - Service Changed [I] (0x2A05) Client Characteristic Configuration (0x2902) - Client Supported Features [R W] (0x2B29) - Database Hash [R] (0x2B2A) Generic Access (0x1800) - Device Name [R] (0x2A00) - Appearance [R] (0x2A01) - Peripheral Preferred Connection Parameters [R] (0x2A04) SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84) - SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48) Client Characteristic Configuration (0x2902) D 15:27:06.941 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true) I 15:27:10.930 Connection parameters updated (interval: 11.25ms, latency: 0, timeout: 420ms) I 15:27:11.602 Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms) lower version -VERSION_MAJOR = 1 VERSION_MINOR = 0 PATCHLEVEL = 2 VERSION_TWEAK = 1 EXTRAVERSION = log-nRF Connect, 2026-01-22 embel (E7:92:37:BC:B3:AB) V 14:51:03.557 Connecting to E7:92:37:BC:B3:AB... D 14:51:03.557 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M) D 14:51:04.155 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2) I 14:51:04.156 Connected to E7:92:37:BC:B3:AB V 14:51:04.156 Discovering services... D 14:51:04.156 gatt.discoverServices() D 14:51:04.174 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED D 14:51:04.286 [Callback] Services discovered with status: 0 I 14:51:04.286 Services discovered V 14:51:04.291 Generic Attribute (0x1801) - Service Changed [I] (0x2A05) Client Characteristic Configuration (0x2902) - Client Supported Features [R W] (0x2B29) - Database Hash [R] (0x2B2A) Generic Access (0x1800) - Device Name [R] (0x2A00) - Appearance [R] (0x2A01) - Peripheral Preferred Connection Parameters [R] (0x2A04) SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84) - SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48) Client Characteristic Configuration (0x2902) D 14:51:04.291 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true) I 14:51:04.605 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms) I 14:51:04.687 Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms) V 14:51:08.074 [McuMgr] Connecting... D 14:51:08.077 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M) D 14:51:08.102 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED) I 14:51:08.104 [McuMgr] Connected to E7:92:37:BC:B3:AB D 14:51:08.106 [McuMgr] wait(300) V 14:51:08.408 [McuMgr] Discovering services... D 14:51:08.412 [McuMgr] gatt.discoverServices() I 14:51:08.418 [McuMgr] Services discovered V 14:51:08.420 [McuMgr] Primary service found V 14:51:08.423 [McuMgr] Requesting new MTU... D 14:51:08.425 [McuMgr] gatt.requestMtu(498) I 14:51:08.513 [McuMgr] MTU changed to: 498 D 14:51:08.518 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true) V 14:51:08.521 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48 D 14:51:08.523 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00) I 14:51:08.692 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb V 14:51:08.698 [McuMgr] Waiting for value change... V 14:51:08.701 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:51:08.704 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x000000010000FF06A0, WRITE COMMAND) I 14:51:08.708 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:51:08.828 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-19-00-00-FF-06-BF-68-62-75-66-5F-73-69-7A-65-19-09-AB-69-62-75-66-5F-63-6F-75-6E-74-04-FF I 14:51:08.834 [McuMgr] Wait for value changed complete A 14:51:08.837 [McuMgr] Received Header (Version: 0, Op: 1, Flags: 0, Len: 25, Group: 0, Seq: 255, Command: 6) CBOR {"buf_size":2475,"buf_count":4} I 14:51:08.844 [McuMgr] SMP reassembly supported with buffer size: 2475 bytes and count: 4 V 14:51:08.847 [McuMgr] Requesting connection priority: HIGH (11.25–15ms, 0, 5s)... D 14:51:08.848 [McuMgr] gatt.requestConnectionPriority(HIGH) A 14:51:08.856 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 1, Group: 0, Seq: 0, Command: 8) CBOR {} V 14:51:09.054 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:51:09.057 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000100000008A0, WRITE COMMAND) I 14:51:09.062 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:51:09.188 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-15-00-00-00-08-BF-6A-62-6F-6F-74-6C-6F-61-64-65-72-67-4D-43-55-62-6F-6F-74-FF A 14:51:09.195 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 21, Group: 0, Seq: 0, Command: 8) CBOR {"bootloader":"MCUboot"} A 14:51:09.215 [McuMgr] Sending (20 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 12, Group: 0, Seq: 1, Command: 8) CBOR {"query":"mode"} V 14:51:09.218 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:51:09.220 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000C00000108A1657175657279646D6F6465, WRITE COMMAND) I 14:51:09.224 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:51:09.277 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-08-00-00-01-08-BF-64-6D-6F-64-65-03-FF I 14:51:09.278 Connection parameters updated (interval: 11.25ms, latency: 0, timeout: 420ms) I 14:51:09.283 [McuMgr] Connection parameters updated (interval: 11.25ms, latency: 0, timeout: 420ms) A 14:51:09.285 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 8, Group: 0, Seq: 1, Command: 8) CBOR {"mode":3} A 14:51:09.307 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 1, Group: 1, Seq: 2, Command: 0) CBOR {} V 14:51:09.311 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:51:09.312 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000100010200A0, WRITE COMMAND) I 14:51:09.317 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:51:09.334 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-88-00-01-02-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-67-31-2E-30-2E-32-2E-32-64-68-61-73-68-58-20-5A-AC-3A-05-3D-A9-78-BF-AB-54-59-9A-EC-2C-B9-C2-D5-68-0A-4C-0F-49-F7-9E-FE-CD-FB-6D-2A-C0-98-44-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF A 14:51:09.338 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 136, Group: 1, Seq: 2, Command: 0) CBOR {"images":[{"slot":0,"version":"1.0.2.2","hash":"Wqw6BT2peL+rVFma7Cy5wtVoCkwPSfee/s37bSrAmEQ=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0} V 14:51:09.349 [McuMgr] Uploading firmware... I 14:51:09.399 Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 5000ms) A 14:51:16.884 [McuMgr] 129351 bytes sent in 7171 ms (18.04 kB/s) V 14:51:16.933 [McuMgr] New state: TEST A 14:51:16.947 [McuMgr] Sending (57 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 49, Group: 1, Seq: 58, Command: 0) CBOR {"confirm":false,"hash":"w30dZ3r4V9F9pxlb9+dYIsAclqmk0ZrFYMZN4kueqXU="} V 14:51:16.951 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:51:16.953 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00003100013A00A267636F6E6669726DF464686173685820C37D1D677AF857D17DA7195BF7E75822C01C96A9A4D19AC560C64DE24B9EA975, WRITE COMMAND) I 14:51:16.969 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:51:16.994 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-F8-00-01-3A-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-67-31-2E-30-2E-32-2E-32-64-68-61-73-68-58-20-5A-AC-3A-05-3D-A9-78-BF-AB-54-59-9A-EC-2C-B9-C2-D5-68-0A-4C-0F-49-F7-9E-FE-CD-FB-6D-2A-C0-98-44-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-BF-64-73-6C-6F-74-01-67-76-65-72-73-69-6F-6E-67-31-2E-30-2E-32-2E-31-64-68-61-73-68-58-20-C3-7D-1D-67-7A-F8-57-D1-7D-A7-19-5B-F7-E7-58-22-C0-1C-96-A9-A4-D1-9A-C5-60-C6-4D-E2-4B-9E-A9-75-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F5-69-63-6F-6E-66-69-72-6D-65-64-F4-66-61-63-74-69-76-65-F4-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF A 14:51:16.999 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 248, Group: 1, Seq: 58, Command: 0) CBOR {"images":[{"slot":0,"version":"1.0.2.2","hash":"Wqw6BT2peL+rVFma7Cy5wtVoCkwPSfee/s37bSrAmEQ=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false},{"slot":1,"version":"1.0.2.1","hash":"w30dZ3r4V9F9pxlb9+dYIsAclqmk0ZrFYMZN4kueqXU=","bootable":true,"pending":true,"confirmed":false,"active":false,"permanent":false}],"splitStatus":0} V 14:51:17.010 [McuMgr] New state: RESET A 14:51:17.022 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 1, Group: 0, Seq: 59, Command: 5) CBOR {} V 14:51:17.024 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:51:17.025 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00000100003B05A0, WRITE COMMAND) I 14:51:17.031 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:51:17.063 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-02-00-00-3B-05-BF-FF A 14:51:17.068 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 2, Group: 0, Seq: 59, Command: 5) CBOR {} D 14:51:22.311 [Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0) E 14:51:22.311 Error 8 (0x8): GATT CONN TIMEOUT I 14:51:22.311 Disconnected D 14:51:22.312 [McuMgr] [Callback] Connection state changed with status: 8 and new state: 0 (DISCONNECTED) W 14:51:22.325 [McuMgr] Error: (0x8): GATT CONN TIMEOUT I 14:51:22.328 [McuMgr] Disconnected D 14:51:22.341 [McuMgr] gatt.close() D 14:51:22.351 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED V 14:51:27.089 [McuMgr] Connecting... D 14:51:27.092 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M) V 14:51:27.096 [McuMgr] New state: CONFIRM D 14:51:27.511 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED) I 14:51:27.515 [McuMgr] Connected to E7:92:37:BC:B3:AB D 14:51:27.529 [McuMgr] wait(300) D 14:51:27.534 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED V 14:51:27.836 [McuMgr] Discovering services... D 14:51:27.840 [McuMgr] gatt.discoverServices() I 14:51:27.848 [McuMgr] Services discovered V 14:51:27.850 [McuMgr] Primary service found V 14:51:27.854 [McuMgr] Requesting new MTU... D 14:51:27.856 [McuMgr] gatt.requestMtu(498) I 14:51:27.957 [McuMgr] Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms) I 14:51:27.960 [McuMgr] MTU changed to: 498 D 14:51:27.970 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true) V 14:51:27.973 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48 D 14:51:27.975 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00) I 14:51:27.999 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb V 14:51:28.002 [McuMgr] Waiting for value change... V 14:51:28.005 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:51:28.007 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x000000010000FF06A0, WRITE COMMAND) I 14:51:28.011 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:51:28.023 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-19-00-00-FF-06-BF-68-62-75-66-5F-73-69-7A-65-19-09-AB-69-62-75-66-5F-63-6F-75-6E-74-04-FF I 14:51:28.026 [McuMgr] Wait for value changed complete A 14:51:28.030 [McuMgr] Received Header (Version: 0, Op: 1, Flags: 0, Len: 25, Group: 0, Seq: 255, Command: 6) CBOR {"buf_size":2475,"buf_count":4} I 14:51:28.036 [McuMgr] SMP reassembly supported with buffer size: 2475 bytes and count: 4 I 14:51:28.043 [McuMgr] PHY updated (TX: LE 2M, RX: LE 2M) A 14:51:28.046 [McuMgr] Sending (57 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 49, Group: 1, Seq: 0, Command: 0) CBOR {"confirm":true,"hash":"w30dZ3r4V9F9pxlb9+dYIsAclqmk0ZrFYMZN4kueqXU="} V 14:51:28.048 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:51:28.050 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00003100010000A267636F6E6669726DF564686173685820C37D1D677AF857D17DA7195BF7E75822C01C96A9A4D19AC560C64DE24B9EA975, WRITE COMMAND) I 14:51:28.061 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:51:28.083 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-13-00-01-00-00-BF-63-65-72-72-BF-65-67-72-6F-75-70-01-62-72-63-08-FF-FF A 14:51:28.086 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 19, Group: 1, Seq: 0, Command: 0) CBOR {"err":{"group":1,"rc":8}} V 14:51:28.095 [McuMgr] Disconnecting... D 14:51:28.097 [McuMgr] gatt.disconnect() D 14:51:28.116 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 0 (DISCONNECTED) I 14:51:28.119 [McuMgr] Disconnected D 14:51:28.121 [McuMgr] gatt.close() D 14:51:28.135 gatt.close() D 14:51:28.136 wait(200) V 14:51:28.338 Connecting to E7:92:37:BC:B3:AB... D 14:51:28.338 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M) D 14:51:28.346 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2) I 14:51:28.346 Connected to E7:92:37:BC:B3:AB V 14:51:28.355 Discovering services... D 14:51:28.355 gatt.discoverServices() D 14:51:28.449 [Callback] Services discovered with status: 0 I 14:51:28.449 Services discovered V 14:51:28.454 Generic Attribute (0x1801) - Service Changed [I] (0x2A05) Client Characteristic Configuration (0x2902) - Client Supported Features [R W] (0x2B29) - Database Hash [R] (0x2B2A) Generic Access (0x1800) - Device Name [R] (0x2A00) - Appearance [R] (0x2A01) - Peripheral Preferred Connection Parameters [R] (0x2A04) SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84) - SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48) Client Characteristic Configuration (0x2902) D 14:51:28.454 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true) I 14:51:28.766 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms) I 14:51:28.852 Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms) I 14:51:32.726 Connection parameters updated (interval: 11.25ms, latency: 0, timeout: 420ms) I 14:51:33.221 Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms) upper version - VERSION_MAJOR = 1 VERSION_MINOR = 0 PATCHLEVEL = 2 VERSION_TWEAK = 3 EXTRAVERSION = log- nRF Connect, 2026-01-22 embel (E7:92:37:BC:B3:AB) V 14:57:49.118 Connecting to E7:92:37:BC:B3:AB... D 14:57:49.118 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M) D 14:57:49.490 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2) I 14:57:49.490 Connected to E7:92:37:BC:B3:AB V 14:57:49.496 Discovering services... D 14:57:49.496 gatt.discoverServices() D 14:57:49.593 [Callback] Services discovered with status: 0 I 14:57:49.593 Services discovered V 14:57:49.596 Generic Attribute (0x1801) - Service Changed [I] (0x2A05) Client Characteristic Configuration (0x2902) - Client Supported Features [R W] (0x2B29) - Database Hash [R] (0x2B2A) Generic Access (0x1800) - Device Name [R] (0x2A00) - Appearance [R] (0x2A01) - Peripheral Preferred Connection Parameters [R] (0x2A04) SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84) - SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48) Client Characteristic Configuration (0x2902) D 14:57:49.596 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true) I 14:57:50.066 PHY updated (TX: LE 2M, RX: LE 2M) D 14:57:50.084 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED I 14:57:54.605 Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms) V 14:58:17.765 [McuMgr] Connecting... D 14:58:17.769 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M) D 14:58:17.877 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED) I 14:58:17.880 [McuMgr] Connected to E7:92:37:BC:B3:AB D 14:58:17.883 [McuMgr] wait(300) V 14:58:18.187 [McuMgr] Discovering services... D 14:58:18.192 [McuMgr] gatt.discoverServices() I 14:58:18.223 [McuMgr] Services discovered V 14:58:18.234 [McuMgr] Primary service found V 14:58:18.242 [McuMgr] Requesting new MTU... D 14:58:18.248 [McuMgr] gatt.requestMtu(498) I 14:58:18.372 [McuMgr] MTU changed to: 498 D 14:58:18.377 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true) V 14:58:18.385 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48 D 14:58:18.391 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00) I 14:58:18.542 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb V 14:58:18.550 [McuMgr] Waiting for value change... V 14:58:18.555 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:58:18.559 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x000000010000FF06A0, WRITE COMMAND) I 14:58:18.567 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:58:18.643 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-19-00-00-FF-06-BF-68-62-75-66-5F-73-69-7A-65-19-09-AB-69-62-75-66-5F-63-6F-75-6E-74-04-FF I 14:58:18.652 [McuMgr] Wait for value changed complete A 14:58:18.663 [McuMgr] Received Header (Version: 0, Op: 1, Flags: 0, Len: 25, Group: 0, Seq: 255, Command: 6) CBOR {"buf_size":2475,"buf_count":4} I 14:58:18.681 [McuMgr] SMP reassembly supported with buffer size: 2475 bytes and count: 4 V 14:58:18.685 [McuMgr] Requesting connection priority: HIGH (11.25–15ms, 0, 5s)... D 14:58:18.691 [McuMgr] gatt.requestConnectionPriority(HIGH) A 14:58:18.727 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 1, Group: 0, Seq: 0, Command: 8) CBOR {} V 14:58:18.922 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:58:18.931 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000100000008A0, WRITE COMMAND) I 14:58:18.944 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:58:18.966 Connection parameters updated (interval: 11.25ms, latency: 0, timeout: 420ms) I 14:58:18.980 [McuMgr] Connection parameters updated (interval: 11.25ms, latency: 0, timeout: 420ms) I 14:58:18.993 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-15-00-00-00-08-BF-6A-62-6F-6F-74-6C-6F-61-64-65-72-67-4D-43-55-62-6F-6F-74-FF A 14:58:19.002 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 21, Group: 0, Seq: 0, Command: 8) CBOR {"bootloader":"MCUboot"} A 14:58:19.016 [McuMgr] Sending (20 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 12, Group: 0, Seq: 1, Command: 8) CBOR {"query":"mode"} V 14:58:19.020 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:58:19.025 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000C00000108A1657175657279646D6F6465, WRITE COMMAND) I 14:58:19.034 Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 5000ms) I 14:58:19.041 [McuMgr] Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 5000ms) I 14:58:19.048 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:58:19.085 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-08-00-00-01-08-BF-64-6D-6F-64-65-03-FF A 14:58:19.090 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 8, Group: 0, Seq: 1, Command: 8) CBOR {"mode":3} A 14:58:19.104 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 1, Group: 1, Seq: 2, Command: 0) CBOR {} V 14:58:19.109 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:58:19.113 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000100010200A0, WRITE COMMAND) I 14:58:19.122 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:58:19.154 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-88-00-01-02-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-67-31-2E-30-2E-32-2E-32-64-68-61-73-68-58-20-5A-AC-3A-05-3D-A9-78-BF-AB-54-59-9A-EC-2C-B9-C2-D5-68-0A-4C-0F-49-F7-9E-FE-CD-FB-6D-2A-C0-98-44-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF A 14:58:19.159 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 136, Group: 1, Seq: 2, Command: 0) CBOR {"images":[{"slot":0,"version":"1.0.2.2","hash":"Wqw6BT2peL+rVFma7Cy5wtVoCkwPSfee/s37bSrAmEQ=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0} V 14:58:19.173 [McuMgr] Uploading firmware... A 14:58:25.500 [McuMgr] 129350 bytes sent in 5985 ms (21.61 kB/s) V 14:58:25.567 [McuMgr] New state: TEST A 14:58:25.588 [McuMgr] Sending (57 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 49, Group: 1, Seq: 58, Command: 0) CBOR {"confirm":false,"hash":"EKiFMUar55rZHTJoKuqC6x3faQgwZoogfJ6RxpbaB9Q="} V 14:58:25.593 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:58:25.597 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00003100013A00A267636F6E6669726DF46468617368582010A8853146ABE79AD91D32682AEA82EB1DDF690830668A207C9E91C696DA07D4, WRITE COMMAND) I 14:58:25.627 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:58:25.666 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-F8-00-01-3A-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-67-31-2E-30-2E-32-2E-32-64-68-61-73-68-58-20-5A-AC-3A-05-3D-A9-78-BF-AB-54-59-9A-EC-2C-B9-C2-D5-68-0A-4C-0F-49-F7-9E-FE-CD-FB-6D-2A-C0-98-44-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-BF-64-73-6C-6F-74-01-67-76-65-72-73-69-6F-6E-67-31-2E-30-2E-32-2E-33-64-68-61-73-68-58-20-10-A8-85-31-46-AB-E7-9A-D9-1D-32-68-2A-EA-82-EB-1D-DF-69-08-30-66-8A-20-7C-9E-91-C6-96-DA-07-D4-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F5-69-63-6F-6E-66-69-72-6D-65-64-F4-66-61-63-74-69-76-65-F4-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF A 14:58:25.676 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 248, Group: 1, Seq: 58, Command: 0) CBOR {"images":[{"slot":0,"version":"1.0.2.2","hash":"Wqw6BT2peL+rVFma7Cy5wtVoCkwPSfee/s37bSrAmEQ=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false},{"slot":1,"version":"1.0.2.3","hash":"EKiFMUar55rZHTJoKuqC6x3faQgwZoogfJ6RxpbaB9Q=","bootable":true,"pending":true,"confirmed":false,"active":false,"permanent":false}],"splitStatus":0} V 14:58:25.706 [McuMgr] New state: RESET A 14:58:25.714 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 1, Group: 0, Seq: 59, Command: 5) CBOR {} V 14:58:25.718 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:58:25.737 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00000100003B05A0, WRITE COMMAND) I 14:58:25.749 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:58:25.770 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-02-00-00-3B-05-BF-FF A 14:58:25.777 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 2, Group: 0, Seq: 59, Command: 5) CBOR {} D 14:58:31.019 [McuMgr] [Callback] Connection state changed with status: 8 and new state: 0 (DISCONNECTED) D 14:58:31.021 [Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0) E 14:58:31.023 Error 8 (0x8): GATT CONN TIMEOUT I 14:58:31.023 Disconnected W 14:58:31.024 [McuMgr] Error: (0x8): GATT CONN TIMEOUT I 14:58:31.028 [McuMgr] Disconnected D 14:58:31.032 [McuMgr] gatt.close() D 14:58:31.071 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED V 14:58:35.808 [McuMgr] Connecting... D 14:58:35.831 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M) V 14:58:35.844 [McuMgr] New state: CONFIRM D 14:58:36.350 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED) I 14:58:36.366 [McuMgr] Connected to E7:92:37:BC:B3:AB D 14:58:36.388 [McuMgr] wait(300) D 14:58:36.419 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED V 14:58:36.692 [McuMgr] Discovering services... D 14:58:36.697 [McuMgr] gatt.discoverServices() I 14:58:36.728 [McuMgr] Services discovered V 14:58:36.733 [McuMgr] Primary service found V 14:58:36.750 [McuMgr] Requesting new MTU... D 14:58:36.756 [McuMgr] gatt.requestMtu(498) I 14:58:36.870 [McuMgr] PHY updated (TX: LE 2M, RX: LE 2M) I 14:58:36.903 [McuMgr] MTU changed to: 498 D 14:58:36.906 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true) V 14:58:36.910 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48 D 14:58:36.913 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00) I 14:58:37.032 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb V 14:58:37.036 [McuMgr] Waiting for value change... V 14:58:37.039 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:58:37.041 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x000000010000FF06A0, WRITE COMMAND) I 14:58:37.045 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:58:37.123 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-19-00-00-FF-06-BF-68-62-75-66-5F-73-69-7A-65-19-09-AB-69-62-75-66-5F-63-6F-75-6E-74-04-FF I 14:58:37.126 [McuMgr] Wait for value changed complete A 14:58:37.129 [McuMgr] Received Header (Version: 0, Op: 1, Flags: 0, Len: 25, Group: 0, Seq: 255, Command: 6) CBOR {"buf_size":2475,"buf_count":4} I 14:58:37.137 [McuMgr] SMP reassembly supported with buffer size: 2475 bytes and count: 4 A 14:58:37.143 [McuMgr] Sending (57 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 49, Group: 1, Seq: 0, Command: 0) CBOR {"confirm":true,"hash":"EKiFMUar55rZHTJoKuqC6x3faQgwZoogfJ6RxpbaB9Q="} V 14:58:37.145 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 14:58:37.148 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00003100010000A267636F6E6669726DF56468617368582010A8853146ABE79AD91D32682AEA82EB1DDF690830668A207C9E91C696DA07D4, WRITE COMMAND) I 14:58:37.153 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 14:58:37.215 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-88-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-67-31-2E-30-2E-32-2E-33-64-68-61-73-68-58-20-10-A8-85-31-46-AB-E7-9A-D9-1D-32-68-2A-EA-82-EB-1D-DF-69-08-30-66-8A-20-7C-9E-91-C6-96-DA-07-D4-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF A 14:58:37.219 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 136, Group: 1, Seq: 0, Command: 0) CBOR {"images":[{"slot":0,"version":"1.0.2.3","hash":"EKiFMUar55rZHTJoKuqC6x3faQgwZoogfJ6RxpbaB9Q=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0} V 14:58:37.227 [McuMgr] Disconnecting... D 14:58:37.230 [McuMgr] gatt.disconnect() D 14:58:37.248 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 0 (DISCONNECTED) I 14:58:37.252 [McuMgr] Disconnected D 14:58:37.256 [McuMgr] gatt.close() D 14:58:37.266 gatt.close() D 14:58:37.270 wait(200) V 14:58:37.471 Connecting to E7:92:37:BC:B3:AB...
