Is BLE + raw IEEE 802.15.4 TX (PHY only, no Thread/Zigbee) officially supported on nRF52840 with MPSL?
Hello Nordic team,
I am working on an nRF52840 project using nRF Connect SDK (Zephyr-based, v2.x / v3.x) and I would like to clarify the official support status of a specific multiprotocol use case.
I have intentionally limited this question to two focused points to avoid ambiguity.
1. Target Use Case
  • Device: nRF52840
  • SDK: nRF Connect SDK (Zephyr)
  • Protocols:
    • Bluetooth LE (SoftDevice Controller)
    • IEEE 802.15.4 PHY only (raw TX)
      • No Thread
      • No Zigbee
      • No MAC / NET stack usage
  • Radio sharing via MPSL (dynamic multiprotocol)
The 802.15.4 side is used only for custom raw frame transmission (driver-level TX), not for any standardized 802.15.4-based stack.
2. Observations So Far
  • BLE and IEEE 802.15.4 TX can both be enabled and initialized.
  • A single 802.15.4 TX call works while BLE is active.
  • However, periodic or continuous TX loops do not behave reliably:
    • TX returns success (0)
    • But repeated transmissions do not appear on a sniffer
    • No explicit runtime error is reported
  • All development was done using the nRF IEEE 802.15.4 radio driver + MPSL, not the legacy raw radio HAL.
3. Documentation Gap
From available documentation and samples, I understand that:
  • nRF52840 officially supports BLE + Thread/Zigbee concurrency via MPSL.
  • Multiprotocol support is clearly documented for full 802.15.4 stacks.
  • However, I cannot find an explicit statement or reference confirming:
    BLE + custom raw IEEE 802.15.4 TX (PHY only) is officially supported and validated
4. Questions (Primary Scope)
  1. Is BLE + raw IEEE 802.15.4 TX (PHY only, no Thread/Zigbee) an officially supported use case on nRF52840 when using MPSL?
  2. If supported in principle, are there any known limitations or design constraints (e.g. scheduling, TX frequency, timeslot behavior) that would explain why periodic TX may silently stop or not appear on a sniffer?
I am intentionally not asking for code review or full implementation guidance yet.
I would like to first understand the official support boundary and expectations.
5. Next Steps
Depending on the answers to the two questions above, I plan to:
  • Adjust the architecture (e.g. move to Thread/Zigbee, or dedicated timeslot handling), or
  • Continue debugging within the supported configuration and ask follow-up implementation questions.
Thank you for your time and clarification.
Ryan
  • It looks like the issue was related to the RF performance of the nRF52840 DK board.
    After switching to our custom board, everything is working properly and the RF behavior is stable.
    It was a bit unexpected and confusing at first, but now the root cause seems clear.
    Thank you very much for your support and guidance throughout the debugging process — it was really helpful.
    Ryan
    00> *** Booting nRF Connect SDK v3.2.1-d8887f6f32df ***
    00> *** Using Zephyr OS v4.2.99-ec78104f1569 ***
    00> [00:00:00.000,305] <inf> ieee802154_tx: === Step 1: Starting ===
    00> [00:00:00.100,463] <inf> ieee802154_tx: === Step 2: Initializing Radio ===
    00> [00:00:00.200,836] <inf> ieee802154_tx: === Step 3: Setting Channel ===
    00> [00:00:00.300,964] <inf> ieee802154_tx: === Step 4: Setting TX Power ===
    00> [00:00:00.401,092] <inf> ieee802154_tx: === Step 5: Setting Promiscuous Mode ===
    00> [00:00:00.501,220] <inf> ieee802154_tx: === Step 6: Entering RX Mode ===
    00> [00:00:00.501,373] <inf> ieee802154_tx: RX mode entered successfully.
    00> [00:00:01.001,495] <inf> ieee802154_tx: === Radio Ready! Starting TX Loop ===
    00>
    00> [00:00:01.001,586] <inf> ieee802154_tx: TX Packet #1 [Dest: 0xFFFF, Src: 0x1111, PAN: 0x2435]
    00> [00:00:01.001,678] <inf> ieee802154_tx: Transmit request accepted. (ret = 0)
    00> [00:00:01.003,601] <inf> ieee802154_tx: >>> TX Success!
    00> ]
    00>
    00>
    00>
    00> [00:00:28.007,690] <inf> ieee802154_tx: TX Packet #28 [Dest: 0xFFFF, Src: 0x1111, PAN: 0x2435]
    00> [00:00:28.007,812] <inf> ieee802154_tx: Transmit request accepted. (ret = 0)
    00> [00:00:28.009,735] <inf> ieee802154_tx: >>> TX Success!
    00> [00:00:29.007,965] <inf> ieee802154_tx: TX Packet #29 [Dest: 0xFFFF, Src: 0x1111, PAN: 0x2435]
    00> [00:00:29.008,056] <inf> ieee802154_tx: Transmit request accepted. (ret = 0)
    00> [00:00:29.009,979] <inf> ieee802154_tx: >>> TX Success!
    00> [00:00:30.008,178] <inf> ieee802154_tx: TX Packet #30 [Dest: 0xFFFF, Src: 0x1111, PAN: 0x2435]
    00> [00:00:30.008,300] <inf> ieee802154_tx: Transmit request accepted. (ret = 0)
    00> [00:00:30.010,223] <inf> ieee802154_tx: >>> TX Success!
    00> [00:00:31.008,453] <inf> ieee802154_tx: TX Packet #31 [Dest: 0xFFFF, Src: 0x1111, PAN: 0x2435]
    00> [00:00:31.008,544] <inf> ieee802154_tx: Transmit request accepted. (ret = 0)
