FAILURE response when reading RebootCount in GeneralDiagnosticsCluster
The RebootCount attribute of the GeneralDiagnosticsCluster is returning a FAILURE response.
This issue is causing failures in Matter test cases TC-ACE-2.1.
CONFIG_CHIP_LAST_FABRIC_REMOVED_ERASE_ONLY is required. What kind of response is possible?
  • nRF5340DK
  • NCS2.9.2
  • Door Lock
  • pri.conf: CONFIG_CHIP_LAST_FABRIC_REMOVED_ERASE_ONLY=y
Steps to Reproduce:
  1. Perform commissioning.
  2. Perform decommissioning (remove fabric).
  3. Perform re-commissioning.
  4. Attempt to read the RebootCount from the GeneralDiagnosticsCluster.
ubuntu@raspberrypi-obtr:~/th$ ~/connectedhomeip/out/host/chip-tool generaldiagnostics read reboot-count 2 0
[1769154746.645] [234597:234597] [DL] ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_tool_kvs
[1769154746.647] [234597:234597] [DL] ChipLinuxStorage::Init: Attempt to re-initialize with KVS config file: /tmp/chip_kvs, IGNORING.
[1769154746.652] [234597:234597] [DL] ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
[1769154746.652] [234597:234597] [DL] ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
[1769154746.653] [234597:234597] [DL] ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
[1769154746.659] [234597:234597] [DL] Wrote settings to /tmp/chip_counters.ini
[1769154746.659] [234597:234597] [DL] NVS set: chip-counters/reboot-count = 2 (0x2)
[1769154746.660] [234597:234597] [DL] Got Ethernet interface: eth0
[1769154746.660] [234597:234597] [DL] Found the primary Ethernet interface:eth0
[1769154746.661] [234597:234597] [DL] Got WiFi interface: wlan0
[1769154746.661] [234597:234597] [DL] Failed to reset WiFi statistic counts
[1769154746.661] [234597:234597] [PAF] WiFiPAF: WiFiPAFLayer::Init()
[1769154746.661] [234597:234597] [IN] UDP::Init bind&listen port=0
[1769154746.662] [234597:234597] [IN] UDP::Init bound to port=53750
[1769154746.662] [234597:234597] [IN] UDP::Init bind&listen port=0
[1769154746.662] [234597:234597] [IN] UDP::Init bound to port=38981
[1769154746.662] [234597:234597] [IN] BLEBase::Init - setting/overriding transport
[1769154746.662] [234597:234597] [IN] WiFiPAFBase::Init - setting/overriding transport
[1769154746.662] [234597:234597] [IN] TransportMgr initialized
[1769154746.662] [234597:234597] [FP] Initializing FabricTable from persistent storage
[1769154746.662] [234597:234597] [TS] Last Known Good Time: 2023-10-14T01:16:48
[1769154746.664] [234597:234597] [FP] Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x69C2586FB58E786E, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1769154746.667] [234597:234597] [DMG] Ember attribute persistence requires setting up
[1769154746.667] [234597:234597] [ZCL] Using ZAP configuration...
[1769154746.695] [234597:234597] [CTL] System State Initialized...
[1769154746.695] [234597:234597] [CTL] Setting attestation nonce to random value
[1769154746.695] [234597:234597] [CTL] Setting CSR nonce to random value
[1769154746.695] [234597:234599] [DL] CHIP task running
[1769154746.696] [234597:234599] [CTL] Setting attestation nonce to random value
[1769154746.696] [234597:234599] [CTL] Setting CSR nonce to random value
[1769154746.697] [234597:234599] [CTL] Generating NOC
[1769154746.698] [234597:234599] [FP] Validating NOC chain
[1769154746.700] [234597:234599] [FP] NOC chain validation successful
[1769154746.700] [234597:234599] [FP] Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1769154746.700] [234597:234599] [TS] Last Known Good Time: 2023-10-14T01:16:48
[1769154746.700] [234597:234599] [TS] New proposed Last Known Good Time: 2021-01-01T00:00:00
[1769154746.700] [234597:234599] [TS] Retaining current Last Known Good Time
[1769154746.704] [234597:234599] [FP] Metadata for Fabric 0x1 persisted to storage.
[1769154746.706] [234597:234599] [TS] Committing Last Known Good Time to storage: 2023-10-14T01:16:48
[1769154746.708] [234597:234599] [CTL] Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 69C2586FB58E786E)
[1769154746.723] [234597:234599] [TOO] Sending command to node 0x2
[1769154746.724] [234597:234599] [CSM] FindOrEstablishSession: PeerId = [1:0000000000000002]
[1769154746.724] [234597:234599] [CSM] FindOrEstablishSession: No existing OperationalSessionSetup instance found
[1769154746.724] [234597:234599] [DIS] OperationalSessionSetup[1:0000000000000002]: State change 1 --> 2
[1769154746.726] [234597:234599] [DIS] Lookup started for 69C2586FB58E786E-0000000000000002
[1769154746.727] [234597:234599] [DIS] Lookup clearing interface for non LL address
[1769154746.727] [234597:234599] [DIS] UDP:[fd11:25::5318:efbe:829e:daf1%eth0]:5540: new best score: 5 (for 69C2586FB58E786E-0000000000000002)
[1769154746.727] [234597:234599] [DIS] Checking node lookup status for 69C2586FB58E786E-0000000000000002 after 3 ms
[1769154746.727] [234597:234599] [DIS] Keeping DNSSD lookup active
[1769154746.728] [234597:234599] [DIS] Lookup clearing interface for non LL address
[1769154746.728] [234597:234599] [DIS] UDP:[fd11:25::5318:efbe:829e:daf1%eth0]:5540: score has not improved: 5 (for 69C2586FB58E786E-0000000000000002)
[1769154746.728] [234597:234599] [DIS] Checking node lookup status for 69C2586FB58E786E-0000000000000002 after 4 ms
[1769154746.728] [234597:234599] [DIS] Keeping DNSSD lookup active
[1769154746.729] [234597:234599] [DIS] Lookup clearing interface for non LL address
[1769154746.729] [234597:234599] [DIS] UDP:[fd11:25::5318:efbe:829e:daf1%docker0]:5540: score has not improved: 5 (for 69C2586FB58E786E-0000000000000002)
[1769154746.729] [234597:234599] [DIS] Checking node lookup status for 69C2586FB58E786E-0000000000000002 after 5 ms
[1769154746.729] [234597:234599] [DIS] Keeping DNSSD lookup active
[1769154746.730] [234597:234599] [DIS] Lookup clearing interface for non LL address
[1769154746.730] [234597:234599] [DIS] UDP:[fd11:25::5318:efbe:829e:daf1%br-3ddb1bb9db70]:5540: score has not improved: 5 (for 69C2586FB58E786E-0000000000000002)
[1769154746.730] [234597:234599] [DIS] Checking node lookup status for 69C2586FB58E786E-0000000000000002 after 6 ms
[1769154746.730] [234597:234599] [DIS] Keeping DNSSD lookup active
[1769154746.732] [234597:234599] [DIS] Lookup clearing interface for non LL address
[1769154746.732] [234597:234599] [DIS] UDP:[fd11:25::5318:efbe:829e:daf1%br-2a23e734cc28]:5540: score has not improved: 5 (for 69C2586FB58E786E-0000000000000002)
[1769154746.732] [234597:234599] [DIS] Checking node lookup status for 69C2586FB58E786E-0000000000000002 after 8 ms
[1769154746.732] [234597:234599] [DIS] Keeping DNSSD lookup active
[1769154746.733] [234597:234599] [DIS] UDP:[fd11:25::5318:efbe:829e:daf1%br-2a23e734cc28]:5540: score has not improved: 5 (for 69C2586FB58E786E-0000000000000002)
[1769154746.733] [234597:234599] [DIS] Checking node lookup status for 69C2586FB58E786E-0000000000000002 after 8 ms
[1769154746.733] [234597:234599] [DIS] Keeping DNSSD lookup active
[1769154746.733] [234597:234599] [DIS] Lookup clearing interface for non LL address
[1769154746.733] [234597:234599] [DIS] UDP:[fd11:25::5318:efbe:829e:daf1%vethdaf5719]:5540: score has not improved: 5 (for 69C2586FB58E786E-0000000000000002)
[1769154746.733] [234597:234599] [DIS] Checking node lookup status for 69C2586FB58E786E-0000000000000002 after 9 ms
[1769154746.734] [234597:234599] [DIS] Lookup clearing interface for non LL address
[1769154746.734] [234597:234599] [DIS] UDP:[fd11:25::5318:efbe:829e:daf1%veth2b97f27]:5540: score has not improved: 5 (for 69C2586FB58E786E-0000000000000002)
[1769154746.734] [234597:234599] [DIS] Checking node lookup status for 69C2586FB58E786E-0000000000000002 after 10 ms
[1769154746.734] [234597:234599] [DIS] Keeping DNSSD lookup active
[1769154746.735] [234597:234599] [DIS] Lookup clearing interface for non LL address
[1769154746.735] [234597:234599] [DIS] UDP:[fd11:25::5318:efbe:829e:daf1%vethb213e12]:5540: score has not improved: 5 (for 69C2586FB58E786E-0000000000000002)
[1769154746.735] [234597:234599] [DIS] Checking node lookup status for 69C2586FB58E786E-0000000000000002 after 11 ms
[1769154746.735] [234597:234599] [DIS] Keeping DNSSD lookup active
[1769154746.736] [234597:234599] [DIS] Lookup clearing interface for non LL address
[1769154746.736] [234597:234599] [DIS] UDP:[fd11:25::5318:efbe:829e:daf1%veth5479bfb]:5540: score has not improved: 5 (for 69C2586FB58E786E-0000000000000002)
[1769154746.736] [234597:234599] [DIS] Checking node lookup status for 69C2586FB58E786E-0000000000000002 after 12 ms
[1769154746.736] [234597:234599] [DIS] Keeping DNSSD lookup active
[1769154746.736] [234597:234599] [DIS] UDP:[fd11:25::5318:efbe:829e:daf1%vethd4182d3]:5540: score has not improved: 5 (for 69C2586FB58E786E-0000000000000002)
[1769154746.924] [234597:234599] [DIS] Checking node lookup status for 69C2586FB58E786E-0000000000000002 after 200 ms
[1769154746.924] [234597:234599] [DIS] OperationalSessionSetup[1:0000000000000002]: Updating device address to UDP:[fd11:25::5318:efbe:829e:daf1]:5540 while in state 2
[1769154746.924] [234597:234599] [DIS] OperationalSessionSetup[1:0000000000000002]: State change 2 --> 3
[1769154746.925] [234597:234599] [IN] SecureSession[0xffff7c00c070]: Allocated Type:2 LSID:21621
[1769154746.925] [234597:234599] [SC] Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000002
[1769154746.927] [234597:234599] [EM] <<< [E:60840i S:0 M:196631889] (U) Msg TX from 7B2BFFA4C9058961 to 0:0000000000000000 [0000] [UDP:[fd11:25::5318:efbe:829e:daf1]:5540] --- Type 0000:30 (SecureChannel:CASE_Sigma1) (B:196)
[1769154746.928] [234597:234599] [EM] ??1 [E:60840i S:0 M:196631889] (U) Msg Retransmission to 0:0000000000000000 scheduled for 3336ms from now [State:Idle II:3000 AI:2200 AT:300]
[1769154746.928] [234597:234599] [SC] Sent Sigma1 msg to <0000000000000002, 1> [II:500ms AI:300ms AT:4000ms]
[1769154746.928] [234597:234599] [DIS] OperationalSessionSetup[1:0000000000000002]: State change 3 --> 4
[1769154747.030] [234597:234599] [EM] >>> [E:60840i S:0 M:259727808 (Ack:196631889)] (U) Msg RX from 0:0000000000000000 [0000] to 7B2BFFA4C9058961 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
[1769154747.030] [234597:234599] [EM] Found matching exchange: 60840i, Delegate: 0xffff7c00bd88
[1769154747.030] [234597:234599] [EM] Rxd Ack; Removing MessageCounter:196631889 from Retrans Table on exchange 60840i
[1769154747.225] [234597:234599] [EM] >>> [E:60840i S:0 M:259727809 (Ack:196631889)] (U) Msg RX from 0:0000000000000000 [0000] to 7B2BFFA4C9058961 --- Type 0000:31 (SecureChannel:CASE_Sigma2) (B:751)
[1769154747.226] [234597:234599] [EM] Found matching exchange: 60840i, Delegate: 0xffff7c00bd88
[1769154747.226] [234597:234599] [EM] CHIP MessageCounter:196631889 not in RetransTable on exchange 60840i
[1769154747.226] [234597:234599] [SC] Received Sigma2 msg
[1769154747.226] [234597:234599] [SC] Found MRP parameters in the message
[1769154747.231] [234597:234599] [SC] Peer <0000000000000002, 1> assigned session ID 11643
[1769154747.231] [234597:234599] [SC] Sending Sigma3
[1769154747.232] [234597:234599] [EM] <<< [E:60840i S:0 M:196631890 (Ack:259727809)] (U) Msg TX from 7B2BFFA4C9058961 to 0:0000000000000000 [0000] [UDP:[fd11:25::5318:efbe:829e:daf1]:5540] --- Type 0000:32 (SecureChannel:CASE_Sigma3) (B:598)
[1769154747.232] [234597:234599] [EM] ??1 [E:60840i S:0 M:196631890] (U) Msg Retransmission to 0:0000000000000000 scheduled for 2707ms from now [State:Active II:3000 AI:2200 AT:300]
[1769154747.232] [234597:234599] [SC] Sent Sigma3 msg
[1769154747.545] [234597:234599] [EM] >>> [E:60840i S:0 M:259727810 (Ack:196631890)] (U) Msg RX from 0:0000000000000000 [0000] to 7B2BFFA4C9058961 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
[1769154747.545] [234597:234599] [EM] Found matching exchange: 60840i, Delegate: 0xffff7c00bd88
[1769154747.545] [234597:234599] [EM] Rxd Ack; Removing MessageCounter:196631890 from Retrans Table on exchange 60840i
[1769154747.756] [234597:234599] [EM] >>> [E:60840i S:0 M:259727811 (Ack:196631890)] (U) Msg RX from 0:0000000000000000 [0000] to 7B2BFFA4C9058961 --- Type 0000:40 (SecureChannel:StatusReport) (B:34)
[1769154747.756] [234597:234599] [EM] Found matching exchange: 60840i, Delegate: 0xffff7c00bd88
[1769154747.756] [234597:234599] [EM] CHIP MessageCounter:196631890 not in RetransTable on exchange 60840i
[1769154747.756] [234597:234599] [SC] Success status report received. Session was established
[1769154747.761] [234597:234599] [SC] SecureSession[0xffff7c00c070, LSID:21621]: State change 'kEstablishing' --> 'kActive'
[1769154747.761] [234597:234599] [IN] SecureSession[0xffff7c00c070]: Activated - Type:2 LSID:21621
[1769154747.761] [234597:234599] [IN] New secure session activated for device <0000000000000002, 1>, LSID:21621 PSID:11643!
[1769154747.761] [234597:234599] [DIS] OperationalSessionSetup[1:0000000000000002]: State change 4 --> 5
[1769154747.761] [234597:234599] [TOO] Sending ReadAttribute to:
[1769154747.761] [234597:234599] [TOO]  cluster 0x0000_0033, attribute: 0x0000_0001, endpoint 0
[1769154747.761] [234597:234599] [DMG] SendReadRequest ReadClient[0xffff7c00ea20]: Sending Read Request
[1769154747.761] [234597:234599] [DMG] 0 data version filters provided, 0 not relevant, 0 encoded, 0 skipped due to lack of space
[1769154747.761] [234597:234599] [EM] <<< [E:60841i S:21621 M:149374553] (S) Msg TX from 000000000001B669 to 1:0000000000000002 [786E] [UDP:[fd11:25::5318:efbe:829e:daf1]:5540] --- Type 0001:02 (IM:ReadRequest) (B:51)
[1769154747.762] [234597:234599] [EM] ??1 [E:60841i S:21621 M:149374553] (S) Msg Retransmission to 1:0000000000000002 scheduled for 2699ms from now [State:Active II:3000 AI:2200 AT:300]
[1769154747.762] [234597:234599] [DMG] MoveToState ReadClient[0xffff7c00ea20]: Moving to [AwaitingIn]
[1769154747.762] [234597:234599] [EM] <<< [E:60840i S:0 M:196631891 (Ack:259727811)] (U) Msg TX from 7B2BFFA4C9058961 to 0:0000000000000000 [0000] [UDP:[fd11:25::5318:efbe:829e:daf1]:5540] --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
[1769154747.762] [234597:234599] [EM] Flushed pending ack for MessageCounter:259727811 on exchange 60840i
[1769154747.965] [234597:234599] [EM] >>> [E:60841i S:21621 M:11254306 (Ack:149374553)] (S) Msg RX from 1:0000000000000002 [786E] to 000000000001B669 --- Type 0001:05 (IM:ReportData) (B:67)
[1769154747.965] [234597:234599] [EM] Found matching exchange: 60841i, Delegate: 0xffff7c00ea30
[1769154747.965] [234597:234599] [EM] Rxd Ack; Removing MessageCounter:149374553 from Retrans Table on exchange 60841i
[1769154747.966] [234597:234599] [DMG] ReportDataMessage =
[1769154747.966] [234597:234599] [DMG] {
[1769154747.966] [234597:234599] [DMG]  AttributeReportIBs =
[1769154747.966] [234597:234599] [DMG]  [
[1769154747.966] [234597:234599] [DMG]          AttributeReportIB =
[1769154747.966] [234597:234599] [DMG]                  AttributeStatusIB =
[1769154747.966] [234597:234599] [DMG]                          AttributePathIB =
[1769154747.966] [234597:234599] [DMG]                                  Endpoint = 0x0,
[1769154747.967] [234597:234599] [DMG]                                  Cluster = 0x33,
[1769154747.967] [234597:234599] [DMG]                                  Attribute = 0x0000_0001,
[1769154747.967] [234597:234599] [DMG]                          }
[1769154747.967] [234597:234599] [DMG]                          StatusIB =
[1769154747.967] [234597:234599] [DMG]                          {
[1769154747.967] [234597:234599] [DMG]                                  status = 0x01 (FAILURE),
[1769154747.967] [234597:234599] [DMG]                          },
[1769154747.968] [234597:234599] [DMG]          },
[1769154747.968] [234597:234599] [DMG]  ],
[1769154747.968] [234597:234599] [DMG]  SuppressResponse = true,
[1769154747.968] [234597:234599] [DMG]  InteractionModelRevision = 11
[1769154747.968] [234597:234599] [TOO] Response Failure: IM Error 0x00000501: General error: 0x01 (FAILURE)  <--------------------------------------------------------------------------------
[1769154747.969] [234597:234599] [EM] <<< [E:60841i S:21621 M:149374554 (Ack:11254306)] (S) Msg TX from 000000000001B669 to 1:0000000000000002 [786E] [UDP:[fd11:25::5318:efbe:829e:daf1]:5540] --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
[1769154747.969] [234597:234599] [EM] Flushed pending ack for MessageCounter:11254306 on exchange 60841i
[1769154747.969] [234597:234597] [CTL] Shutting down the commissioner
[1769154747.969] [234597:234597] [PAF] WiFiPAF: Closing all WiFiPAF sessions to shutdown
[1769154747.969] [234597:234597] [CTL] Shutting down the controller
[1769154747.970] [234597:234597] [IN] Expiring all sessions for fabric 0x1!!
[1769154747.970] [234597:234597] [IN] SecureSession[0xffff7c00c070]: MarkForEviction Type:2 LSID:21621
[1769154747.970] [234597:234597] [SC] SecureSession[0xffff7c00c070, LSID:21621]: State change 'kActive' --> 'kPendingEviction'
[1769154747.970] [234597:234597] [IN] SecureSession[0xffff7c00c070]: Released - Type:2 LSID:21621
[1769154747.970] [234597:234597] [FP] Forgetting fabric 0x1
[1769154747.970] [234597:234597] [TS] Pending Last Known Good Time: 2023-10-14T01:16:48
[1769154747.970] [234597:234597] [TS] Previous Last Known Good Time: 2023-10-14T01:16:48
[1769154747.970] [234597:234597] [TS] Reverted Last Known Good Time to previous value
[1769154747.970] [234597:234597] [CTL] Shutting down the commissioner
[1769154747.970] [234597:234597] [PAF] WiFiPAF: Closing all WiFiPAF sessions to shutdown
[1769154747.970] [234597:234597] [CTL] Shutting down the controller
[1769154747.970] [234597:234597] [CTL] Shutting down the System State, this will teardown the CHIP Stack
[1769154747.972] [234597:234597] [DMG] All ReadHandler-s are clean, clear GlobalDirtySet
[1769154747.972] [234597:234597] [FP] Shutting down FabricTable
[1769154747.972] [234597:234597] [TS] Pending Last Known Good Time: 2023-10-14T01:16:48
[1769154747.973] [234597:234597] [TS] Previous Last Known Good Time: 2023-10-14T01:16:48
[1769154747.973] [234597:234597] [TS] Reverted Last Known Good Time to previous value
[1769154747.982] [234597:234597] [DL] Wrote settings to /tmp/chip_counters.ini
[1769154747.982] [234597:234597] [DL] NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1769154747.982] [234597:234597] [DL] Inet Layer shutdown
[1769154747.982] [234597:234597] [DL] BLE Layer shutdown
[1769154747.982] [234597:234597] [DL] WiFi-PAF Layer shutdown
[1769154747.982] [234597:234597] [PAF] WiFiPAF: Closing all WiFiPAF sessions to shutdown
[1769154747.982] [234597:234597] [DL] System Layer shutdown
[1769154747.982] [234597:234597] [TOO] Run command failure: IM Error 0x00000501: General error: 0x01 (FAILURE)
    Sorry for the late reply. I need to run this by our Matter team. I will get back to you as soon as I know more.
    Edvin
    It seems like it is in fact a bug. When the last fabric is removed, the factory reset is essentially performed. Since we remove all of the data, we also remove the reboot count variable - but we do not reboot ourselves due to KConfig, and we don't re-initialize the setting. Since the setting does not exist, the error is returned.
    The solution is to either reboot the board once (the reboot count will be re-initialized on the reboot), or change the implementation of the last fabric removal:
    diff --git a/samples/matter/common/src/app/fabric_table_delegate.h b/samples/matter/common/src/app/fabric_table_delegate.h
    index 5e914cd4cf..b9dc2d8327 100644
    --- a/samples/matter/common/src/app/fabric_table_delegate.h
    +++ b/samples/matter/common/src/app/fabric_table_delegate.h
    @@ -60,6 +60,8 @@ private:
                                    chip::DeviceLayer::PersistedStorage::KeyValueStoreMgrImpl().DoFactoryReset();
                                    /* Erase Network credentials and disconnect */
                                    chip::DeviceLayer::ConnectivityMgr().ErasePersistentInfo();
    +                               /* Make sure Reboot Count is set to 1 */
    +                               chip::DeviceLayer::ConfigurationMgr().StoreRebootCount(1);
    #ifdef CONFIG_CHIP_WIFI
                                    chip::DeviceLayer::WiFiManager::Instance().Disconnect();
                                    chip::DeviceLayer::ConnectivityMgr().ClearWiFiStationProvision();
    The above change works for me (the person looking into this from the Matter Team), and I don't see the error anymore. Though the reboot count is reset to 1. The user might read it before ErasePersistentInfo() and set it again to the same value if they prefer.
    There is a task started internally to fix this in a future release, but I do not have details on exactly how it will be implemented.
    Edvin
