I'm using beacon mode to transmit a set of data which is stored as hex code. I've set the advertising data to iterate through the data set 10 times. When looking at the data with a sniffer on Wireshark, all the data is not sent, and it will sometimes send the data in a group rather than separately. Ideally, I would be able to send the data most efficiently. Code is attached and the data is stored in data.h. Not sure if this is an issue with Wireshark or I need to store data in different packet sizes before sending.
/* main.c - Application main entry point */
* Copyright (c) 2015-2016 Intel Corporation
#include <zephyr/types.h>
#include <stddef.h>
#include <zephyr/sys/util.h>
#include <stdbool.h>
#include <zephyr/kernel.h>
#include <zephyr/bluetooth/hci.h>
#include "Tdata.h"
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
#define LED_DRIVE 0x74 //bit 7 -0 off 1 on, bit 0:6 LED driving strength. 000 0000: 4mA 000 0001: 6mA 000 0010: 8mA
#define COMPANY_ID_CODE 0x0059
static unsigned char url_data[] = { 0x17, '/', '/', 'a', 'c', 'a', 'd', 'e', 'm',
'y', '.', 'n', 'o', 'r', 'd', 'i', 'c', 's',
'e', 'm', 'i', '.', 'c', 'o', 'm' };
/*Create an LE Advertising Parameters variable */
static struct bt_le_adv_param *adv_param =
BT_LE_ADV_PARAM(BT_LE_ADV_OPT_NONE, /* No options specified */
32, /* Min Advertising Interval 500ms (800*0.625ms) [20ms (32*0.625)] */
40, /* Max Advertising Interval 500.625ms (801*0.625ms) [25ms (35*0.625)] */
NULL); /* Set to NULL for undirected advertising */
typedef struct adv_mfg_data {
uint16_t company_code; /* Company Identifier Code. */
uint16_t Transmit; /* Recordings from sensor*/
} adv_mfg_data_type;
static adv_mfg_data_type adv_mfg_data = {COMPANY_ID_CODE,0x00};
/*Set Advertisement data*/
static const struct bt_data ad[] = {
BT_DATA_BYTES(BT_DATA_FLAGS, BT_LE_AD_NO_BREDR),
BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
BT_DATA(BT_DATA_MANUFACTURER_DATA, (unsigned char *)&adv_mfg_data, sizeof(adv_mfg_data)),
/* Set Scan Response data */
static const struct bt_data sd[] = {
BT_DATA(BT_DATA_URI, url_data, sizeof(url_data)),
static void bt_ready(int err)
char addr_s[BT_ADDR_LE_STR_LEN];
bt_addr_le_t addr = {0};
size_t count = 1;
if (err) {
printk("Bluetooth init failed (err %d)\n", err);
return;
printk("Bluetooth initialized\n");
/* Start advertising */
err = bt_le_adv_start(BT_LE_ADV_NCONN_IDENTITY, ad, ARRAY_SIZE(ad),
sd, ARRAY_SIZE(sd));
if (err) {
printk("Advertising failed to start (err %d)\n", err);
return;
/* For connectable advertising you would use
* bt_le_oob_get_local(). For non-connectable non-identity
* advertising an non-resolvable private address is used;
* there is no API to retrieve that.
bt_id_get(&addr, &count);
bt_addr_le_to_str(&addr, addr_s, sizeof(addr_s));
printk("Beacon started, advertising as %s\n", addr_s);
int i, j;
int err;
printk("Starting Beacon\n");
/* Initialize the Bluetooth Subsystem */
err = bt_enable(bt_ready);
if (err) {
for(i=0; i<10; i++){
for(j=0; j<sizeof(data); j++){
/*Update the advertising data dynamically */
adv_mfg_data.Transmit = data[j];
bt_le_adv_update_data(ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
return 0;
