Failure to compile hci_ipc for raytac_mdbt53v_db_40 board
Hello!
I am trying to compile hci_ipc sample for raytac_mdbt53v_db_40 board (using nRF SDK v3.2.1) and getting the following error:
west build -b raytac_mdbt53v_db_40/nrf5340/cpunet --pristine -- -DEXTRA_CONF=nrf5340_cpunet_iso_peripheral-bt_ll_sw_split.conf
-- west build: making build dir /home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build pristine
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: /home/hermanberdnikov/ncs-ws/ncs/venv/bin/python3 (found suitable version "3.14.2", minimum required is "3.10") found components: Interpreter
-- Cache files will be written to: /home/hermanberdnikov/.cache/zephyr
-- Found west (found suitable version "1.5.0", minimum required is "0.14.0")
-- Board: raytac_mdbt53v_db_40, qualifiers: nrf5340/cpunet
Parsing /home/hermanberdnikov/ncs-ws/ncs/zephyr/share/sysbuild/Kconfig
Loaded configuration '/home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/_sysbuild/empty.conf'
Merged configuration '/home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/_sysbuild/empty.conf'
Configuration saved to '/home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/zephyr/.config'
Kconfig header saved to '/home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/_sysbuild/autoconf.h'
   * Running CMake for hci_ipc *
-- Application: /home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc
-- CMake version: 4.2.1
-- Found Python3: /home/hermanberdnikov/ncs-ws/ncs/venv/bin/python (found suitable version "3.14.2", minimum required is "3.10") found components: Interpreter
-- Zephyr version: 4.2.99 (/home/hermanberdnikov/ncs-ws/ncs/zephyr)
-- ZEPHYR_TOOLCHAIN_VARIANT not set, trying to locate Zephyr SDK
-- Found host-tools: zephyr 0.17.4 (/home/hermanberdnikov/zephyr-sdk-0.17.4)
-- Found toolchain: zephyr 0.17.4 (/home/hermanberdnikov/zephyr-sdk-0.17.4)
-- Found Dtc: /home/hermanberdnikov/zephyr-sdk-0.17.4/sysroots/aarch64-pokysdk-linux/usr/bin/dtc (found suitable version "1.7.0", minimum required is "1.4.6")
-- Found BOARD.dts: /home/hermanberdnikov/ncs-ws/ncs/zephyr/boards/raytac/mdbt53v_db_40/raytac_mdbt53v_db_40_nrf5340_cpunet.dts
-- Generated zephyr.dts: /home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/hci_ipc/zephyr/zephyr.dts
-- Generated pickled edt: /home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/hci_ipc/zephyr/edt.pickle
-- Generated devicetree_generated.h: /home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/hci_ipc/zephyr/include/generated/zephyr/devicetree_generated.h
warning: Experimental symbol BT_LL_SW_SPLIT is enabled.
Parsing /home/hermanberdnikov/ncs-ws/ncs/zephyr/Kconfig
Loaded configuration '/home/hermanberdnikov/ncs-ws/ncs/zephyr/boards/raytac/mdbt53v_db_40/raytac_mdbt53v_db_40_nrf5340_cpunet_defconfig'
Merged configuration '/home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/prj.conf'
Merged configuration '/home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/hci_ipc/zephyr/.config.sysbuild'
Configuration saved to '/home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/hci_ipc/zephyr/.config'
Kconfig header saved to '/home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/hci_ipc/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: /home/hermanberdnikov/zephyr-sdk-0.17.4/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- Found assembler: /home/hermanberdnikov/zephyr-sdk-0.17.4/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
-- libmetal version: 1.8.0 (/home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc)
-- Build type:
-- Host:    Linux/aarch64
-- Target:  Generic/arm
-- Machine: arm
-- Vendor: none
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- open-amp version: 1.8.0 (/home/hermanberdnikov/ncs-ws/ncs/modules/lib/open-amp/open-amp)
-- Machine: arm
-- C_FLAGS :  -Wall -Wextra
-- Looking for include file fcntl.h
-- Looking for include file fcntl.h - found
-- Using ccache: /usr/bin/ccache
-- Found gen_kobject_list: /home/hermanberdnikov/ncs-ws/ncs/zephyr/scripts/build/gen_kobject_list.py
-- Configuring done (4.9s)
-- Generating done (0.2s)
-- Build files have been written to: /home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/hci_ipc
-- Configuring done (7.5s)
-- Generating done (0.0s)
[5/10] Performing build step for 'hci_ipc'
[1/256] Preparing syscall dependency handling
[5/256] Generating include/generated/zephyr/version.h
-- Zephyr version: 4.2.99 (/home/hermanberdnikov/ncs-ws/ncs/zephyr), build: ncs-v3.2.1
[12/256] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
FAILED: [code=1] zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
ccache /home/hermanberdnikov/zephyr-sdk-0.17.4/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DK_HEAP_MEM_POOL_SIZE=4096 -DNRF5340_XXAA_NETWORK -DNRF54L_CONFIGURATION_56_ENABLE=0 -DPICOLIBC_LONG_LONG_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -I/home/hermanberdnikov/ncs-ws/ncs/zephyr/kernel/include -I/home/hermanberdnikov/ncs-ws/ncs/zephyr/arch/arm/include -I/home/hermanberdnikov/ncs-ws/ncs/nrf/drivers/mpsl/clock_control -I/home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/hci_ipc/zephyr/include/generated/zephyr -I/home/hermanberdnikov/ncs-ws/ncs/zephyr/include -I/home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/hci_ipc/zephyr/include/generated -I/home/hermanberdnikov/ncs-ws/ncs/zephyr/soc/nordic -I/home/hermanberdnikov/ncs-ws/ncs/zephyr/soc/nordic/nrf53/. -I/home/hermanberdnikov/ncs-ws/ncs/zephyr/soc/nordic/common/. -I/home/hermanberdnikov/ncs-ws/ncs/zephyr/subsys/bluetooth -I/home/hermanberdnikov/ncs-ws/ncs/nrf/include -I/home/hermanberdnikov/ncs-ws/ncs/nrf/lib/multithreading_lock/. -I/home/hermanberdnikov/ncs-ws/ncs/nrf/subsys/bluetooth/controller/. -I/home/hermanberdnikov/ncs-ws/ncs/nrf/tests/include -I/home/hermanberdnikov/ncs-ws/ncs/modules/hal/cmsis_6/CMSIS/Core/Include -I/home/hermanberdnikov/ncs-ws/ncs/zephyr/modules/cmsis_6/. -I/home/hermanberdnikov/ncs-ws/ncs/nrf/modules/hal_nordic/. -I/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx -I/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/drivers/include -I/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/bsp/stable -I/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/bsp/stable/templates -I/home/hermanberdnikov/ncs-ws/ncs/zephyr/modules/hal_nordic/nrfx/. -I/home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/hci_ipc/modules/libmetal/libmetal/lib/include -I/home/hermanberdnikov/ncs-ws/ncs/modules/lib/open-amp/open-amp/lib/include -I/home/hermanberdnikov/ncs-ws/ncs/nrfxlib/softdevice_controller/include -I/home/hermanberdnikov/ncs-ws/ncs/nrfxlib/mpsl/fem/common/include -I/home/hermanberdnikov/ncs-ws/ncs/nrfxlib/mpsl/fem/nrf21540_gpio/include -I/home/hermanberdnikov/ncs-ws/ncs/nrfxlib/mpsl/fem/nrf21540_gpio_spi/include -I/home/hermanberdnikov/ncs-ws/ncs/nrfxlib/mpsl/fem/nrf2220/include -I/home/hermanberdnikov/ncs-ws/ncs/nrfxlib/mpsl/fem/nrf2240/include -I/home/hermanberdnikov/ncs-ws/ncs/nrfxlib/mpsl/fem/nrf22xx/include -I/home/hermanberdnikov/ncs-ws/ncs/nrfxlib/mpsl/fem/simple_gpio/include -I/home/hermanberdnikov/ncs-ws/ncs/nrfxlib/mpsl/fem/include -I/home/hermanberdnikov/ncs-ws/ncs/nrfxlib/mpsl/fem/include/protocol -I/home/hermanberdnikov/ncs-ws/ncs/nrfxlib/mpsl/include -I/home/hermanberdnikov/ncs-ws/ncs/nrfxlib/mpsl/include/protocol -isystem /home/hermanberdnikov/ncs-ws/ncs/zephyr/lib/libc/common/include -fno-strict-aliasing -Os -imacros /home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/hci_ipc/zephyr/include/generated/zephyr/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33+nodsp -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=/home/hermanberdnikov/zephyr-sdk-0.17.4/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/hermanberdnikov/ncs-ws/ncs/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/hermanberdnikov/ncs-ws/ncs/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/hermanberdnikov/ncs-ws/ncs=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -std=c99 -fno-lto -MD -MT zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj -MF zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj.d -o zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj -c /home/hermanberdnikov/ncs-ws/ncs/zephyr/arch/arm/core/offsets/offsets.c
In file included from /home/hermanberdnikov/ncs-ws/ncs/nrfxlib/mpsl/include/mpsl_clock.h:29,
                 from /home/hermanberdnikov/ncs-ws/ncs/nrfxlib/mpsl/include/mpsl.h:27,
                 from /home/hermanberdnikov/ncs-ws/ncs/nrf/subsys/bluetooth/controller/./bt_ctlr_used_resources.h:27,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/modules/hal_nordic/nrfx/./nrfx_reserved_resources.h:55,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/modules/hal_nordic/nrfx/./nrfx_reserved_resources_ncs.h:49,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/modules/hal_nordic/nrfx/./nrfx_config.h:23,
                 from /home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/nrfx.h:37,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/soc/nordic/common/./soc_nrf_common.h:14,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/soc/nordic/nrf53/./soc.h:15,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/modules/cmsis_6/./cmsis_core_m.h:24,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/modules/cmsis_6/./cmsis_core.h:10,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/include/zephyr/arch/arm/asm_inline_gcc.h:24,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/include/zephyr/arch/arm/asm_inline.h:18,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/include/zephyr/arch/arm/arch.h:30,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/include/zephyr/arch/cpu.h:19,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/include/zephyr/kernel_includes.h:36,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/include/zephyr/kernel.h:17,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/arch/arm/core/offsets/offsets_aarch32.c:29,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/arch/arm/core/offsets/offsets.c:9:
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:339:34: error: 'CLOCK_LFCLKSRC_SRC_LFRC' undeclared here (not in a function)
  339 |     NRF_CLOCK_LFCLK_RC         = CLOCK_LFCLKSRC_SRC_LFRC,                                               /**< Internal 32 kHz RC oscillator. */
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:399:37: error: 'CLOCK_HFCLKSTAT_SRC_HFXO' undeclared here (not in a function); did you mean 'NRF_CLOCK_LFCLKSTAT_SRC_Msk'?
  399 |     NRF_CLOCK_HFCLK_HIGH_ACCURACY = CLOCK_HFCLKSTAT_SRC_HFXO,  /**< External 32 MHz crystal oscillator. */
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:307:45: error: 'CLOCK_INTENSET_HFCLKSTARTED_Msk' undeclared here (not in a function); did you mean 'NRF_CLOCK_INTENSET_HFCLKSTARTED_Msk'?
  307 | #define NRF_CLOCK_INTENSET_HFCLKSTARTED_Msk CLOCK_INTENSET_HFCLKSTARTED_Msk
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:449:43: note: in expansion of macro 'NRF_CLOCK_INTENSET_HFCLKSTARTED_Msk'
  449 |     NRF_CLOCK_INT_HF_STARTED_MASK       = NRF_CLOCK_INTENSET_HFCLKSTARTED_Msk,  /**< Interrupt on HFCLKSTARTED event. */
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:275:48: error: 'CLOCK_INTENSET_LFCLKSTARTED_Msk' undeclared here (not in a function); did you mean 'NRF_CLOCK_INTENSET_LFCLKSTARTED_Msk'?
  275 | #define NRF_CLOCK_INTENSET_LFCLKSTARTED_Msk    CLOCK_INTENSET_LFCLKSTARTED_Msk
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:451:43: note: in expansion of macro 'NRF_CLOCK_INTENSET_LFCLKSTARTED_Msk'
  451 |     NRF_CLOCK_INT_LF_STARTED_MASK       = NRF_CLOCK_INTENSET_LFCLKSTARTED_Msk,  /**< Interrupt on LFCLKSTARTED event. */
In file included from /home/hermanberdnikov/zephyr-sdk-0.17.4/arm-zephyr-eabi/picolibc/include/sys/_types.h:52,
                 from /home/hermanberdnikov/zephyr-sdk-0.17.4/arm-zephyr-eabi/picolibc/include/stdio.h:49,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/include/zephyr/sys/printk.h:65,
                 from /home/hermanberdnikov/ncs-ws/ncs/zephyr/include/zephyr/kernel_includes.h:35:
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:497:47: error: unknown type name 'NRF_CLOCK_Type'
  497 |     NRF_CLOCK_TASK_HFCLKSTART      = offsetof(NRF_CLOCK_Type, TASKS_HFCLKSTART),      /**< Start HFCLK clock source. */
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:498:47: error: unknown type name 'NRF_CLOCK_Type'
  498 |     NRF_CLOCK_TASK_HFCLKSTOP       = offsetof(NRF_CLOCK_Type, TASKS_HFCLKSTOP),       /**< Stop HFCLK clock source. */
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:505:47: error: unknown type name 'NRF_CLOCK_Type'
  505 |     NRF_CLOCK_TASK_LFCLKSTART      = offsetof(NRF_CLOCK_Type, TASKS_LFCLKSTART),      /**< Start LFCLK clock source. */
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:506:47: error: unknown type name 'NRF_CLOCK_Type'
  506 |     NRF_CLOCK_TASK_LFCLKSTOP       = offsetof(NRF_CLOCK_Type, TASKS_LFCLKSTOP),       /**< Stop LFCLK clock source. */
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:539:50: error: unknown type name 'NRF_CLOCK_Type'
  539 |     NRF_CLOCK_EVENT_HFCLKSTARTED      = offsetof(NRF_CLOCK_Type, EVENTS_HFCLKSTARTED),      /**< HFCLK oscillator started. */
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:545:50: error: unknown type name 'NRF_CLOCK_Type'
  545 |     NRF_CLOCK_EVENT_LFCLKSTARTED      = offsetof(NRF_CLOCK_Type, EVENTS_LFCLKSTARTED),      /**< LFCLK oscillator started. */
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:582:18: error: expected ';' before 'void'
  582 | NRF_STATIC_INLINE void nrf_clock_int_enable(NRF_CLOCK_Type * p_reg, uint32_t mask);
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:582:45: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                             NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:591:18: error: expected ';' before 'void'
  591 | NRF_STATIC_INLINE void nrf_clock_int_disable(NRF_CLOCK_Type * p_reg, uint32_t mask);
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:591:46: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                              NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:602:1: error: unknown type name 'NRF_STATIC_INLINE'
  602 | NRF_STATIC_INLINE uint32_t nrf_clock_int_enable_check(NRF_CLOCK_Type const * p_reg, uint32_t mask);
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:602:28: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nrf_clock_int_enable_check'
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:628:1: error: unknown type name 'NRF_STATIC_INLINE'
  628 | NRF_STATIC_INLINE uint32_t nrf_clock_task_address_get(NRF_CLOCK_Type const * p_reg,
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:628:28: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nrf_clock_task_address_get'
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:637:18: error: expected ';' before 'void'
  637 | NRF_STATIC_INLINE void nrf_clock_task_trigger(NRF_CLOCK_Type * p_reg, nrf_clock_task_t task);
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:637:47: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                               NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:648:1: error: unknown type name 'NRF_STATIC_INLINE'
  648 | NRF_STATIC_INLINE uint32_t nrf_clock_event_address_get(NRF_CLOCK_Type const * p_reg,
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:648:28: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nrf_clock_event_address_get'
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:657:18: error: expected ';' before 'void'
  657 | NRF_STATIC_INLINE void nrf_clock_event_clear(NRF_CLOCK_Type * p_reg, nrf_clock_event_t event);
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:657:46: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                              NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:668:18: error: expected ';' before '_Bool'
  668 | NRF_STATIC_INLINE bool nrf_clock_event_check(NRF_CLOCK_Type const * p_reg, nrf_clock_event_t event);
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:668:46: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                              NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:679:18: error: expected ';' before '_Bool'
  679 | NRF_STATIC_INLINE bool nrf_clock_start_task_check(NRF_CLOCK_Type const * p_reg,
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:679:51: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                                   NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:695:18: error: expected ';' before '_Bool'
  695 | NRF_STATIC_INLINE bool nrf_clock_is_running(NRF_CLOCK_Type const * p_reg,
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:695:45: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                             NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:707:18: error: expected ';' before 'void'
  707 | NRF_STATIC_INLINE void nrf_clock_lf_src_set(NRF_CLOCK_Type * p_reg, nrf_clock_lfclk_t source);
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:707:45: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                             NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:721:1: error: unknown type name 'NRF_STATIC_INLINE'
  721 | NRF_STATIC_INLINE nrf_clock_lfclk_t nrf_clock_lf_src_get(NRF_CLOCK_Type const * p_reg);
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:721:37: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nrf_clock_lf_src_get'
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:764:1: error: unknown type name 'NRF_STATIC_INLINE'
  764 | NRF_STATIC_INLINE nrf_clock_hfclk_t nrf_clock_hf_src_get(NRF_CLOCK_Type const * p_reg);
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:764:37: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nrf_clock_hf_src_get'
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1032:18: error: expected ';' before 'void'
 1032 | NRF_STATIC_INLINE void nrf_clock_int_enable(NRF_CLOCK_Type * p_reg, uint32_t mask)
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1032:45: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                             NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1037:18: error: expected ';' before 'void'
 1037 | NRF_STATIC_INLINE void nrf_clock_int_disable(NRF_CLOCK_Type * p_reg, uint32_t mask)
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1037:46: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                              NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1042:1: error: unknown type name 'NRF_STATIC_INLINE'
 1042 | NRF_STATIC_INLINE uint32_t nrf_clock_int_enable_check(NRF_CLOCK_Type const * p_reg, uint32_t mask)
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1042:28: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nrf_clock_int_enable_check'
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1054:1: error: unknown type name 'NRF_STATIC_INLINE'
 1054 | NRF_STATIC_INLINE uint32_t nrf_clock_task_address_get(NRF_CLOCK_Type const * p_reg,
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1054:28: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nrf_clock_task_address_get'
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1060:18: error: expected ';' before 'void'
 1060 | NRF_STATIC_INLINE void nrf_clock_task_trigger(NRF_CLOCK_Type * p_reg, nrf_clock_task_t task)
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1060:47: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                               NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1065:1: error: unknown type name 'NRF_STATIC_INLINE'
 1065 | NRF_STATIC_INLINE uint32_t nrf_clock_event_address_get(NRF_CLOCK_Type const * p_reg,
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1065:28: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nrf_clock_event_address_get'
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1071:18: error: expected ';' before 'void'
 1071 | NRF_STATIC_INLINE void nrf_clock_event_clear(NRF_CLOCK_Type * p_reg, nrf_clock_event_t event)
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1071:46: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                              NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1077:18: error: expected ';' before '_Bool'
 1077 | NRF_STATIC_INLINE bool nrf_clock_event_check(NRF_CLOCK_Type const * p_reg, nrf_clock_event_t event)
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1077:46: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                              NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1082:18: error: expected ';' before '_Bool'
 1082 | NRF_STATIC_INLINE bool nrf_clock_start_task_check(NRF_CLOCK_Type const * p_reg,
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1082:51: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                                   NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1127:18: error: expected ';' before '_Bool'
 1127 | NRF_STATIC_INLINE bool nrf_clock_is_running(NRF_CLOCK_Type const * p_reg,
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1127:45: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                             NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1202:18: error: expected ';' before 'void'
 1202 | NRF_STATIC_INLINE void nrf_clock_lf_src_set(NRF_CLOCK_Type * p_reg, nrf_clock_lfclk_t source)
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1202:45: error: unknown type name 'NRF_CLOCK_Type'; did you mean 'NRF_CLOCK_H__'?
      |                                             NRF_CLOCK_H__
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1211:1: error: unknown type name 'NRF_STATIC_INLINE'
 1211 | NRF_STATIC_INLINE nrf_clock_lfclk_t nrf_clock_lf_src_get(NRF_CLOCK_Type const * p_reg)
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1211:37: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nrf_clock_lf_src_get'
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1236:1: error: unknown type name 'NRF_STATIC_INLINE'
 1236 | NRF_STATIC_INLINE nrf_clock_hfclk_t nrf_clock_hf_src_get(NRF_CLOCK_Type const * p_reg)
/home/hermanberdnikov/ncs-ws/ncs/modules/hal/nordic/nrfx/hal/nrf_clock.h:1236:37: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nrf_clock_hf_src_get'
/home/hermanberdnikov/ncs-ws/ncs/nrfxlib/mpsl/include/mpsl.h:86:66: error: unknown type name 'IRQn_Type'
   86 | int32_t mpsl_init(mpsl_clock_lfclk_cfg_t const * p_clock_config, IRQn_Type low_prio_irq, mpsl_assert_handler_t p_assert_handler);
/home/hermanberdnikov/ncs-ws/ncs/zephyr/modules/hal_nordic/nrfx/./nrfx_reserved_resources.h:60: warning: "NRFX_DPPI0_CHANNELS_USED_BY_BT_CTLR" redefined
   60 | #define NRFX_DPPI0_CHANNELS_USED_BY_BT_CTLR BT_CTLR_USED_PPI_CHANNELS
/home/hermanberdnikov/ncs-ws/ncs/zephyr/modules/hal_nordic/nrfx/./nrfx_reserved_resources_ncs.h:15: note: this is the location of the previous definition
   15 | #define NRFX_DPPI0_CHANNELS_USED_BY_BT_CTLR SDC_DPPI_CHANNELS_USED_MASK
FAILED: [code=1] _sysbuild/sysbuild/images/hci_ipc-prefix/src/hci_ipc-stamp/hci_ipc-build /home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/_sysbuild/sysbuild/images/hci_ipc-prefix/src/hci_ipc-stamp/hci_ipc-build
cd /home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build/hci_ipc && /usr/bin/cmake --build .
FATAL ERROR: command exited with status 1: /usr/bin/cmake --build /home/hermanberdnikov/ncs-ws/ncs/zephyr/samples/bluetooth/hci_ipc/build
The sample compiles fine for the nrf5340dk board though. Can somebody please pinpoint to where I can fix that and what exactly happens here?
Thank you,
Herman Berdnikov
