hci_uart sample to send Channel Sounding test-related HCI commands (specifically HCI_LE_CS_TEST and HCI_LE_CS_TEST_END) to the Nordic nRF54L15 DK. Could you please advise on the required configurations I need to implement for this?hci_uart sample to send Channel Sounding test-related HCI commands (specifically HCI_LE_CS_TEST and HCI_LE_CS_TEST_END) to the Nordic nRF54L15 DK. Could you please advise on the required configurations I need to implement for this?Hello,
1) You need to first enable Channel sounding in the controller when building hci_uart. This must be done via Kconfig:
west build -b nrf54l15dk/nrf54l15/cpuapp --pristine -- -DCONFIG_BT_CTLR_CHANNEL_SOUNDING=y
2) Ensure that the CS controller options are set as needed (this is optional):
BT_CTLR_SDC_CS_COUNT
BT_CTRL_SDC_CS_ROLE_*
BT_CTRL_SDC_CS_STEP_MODE3
3) Then you can flash the hci_uart image to your DK. After building, you can program the DK via west flash
4) You can then send CS test HCI commands over UART:
HCI_LE_CS_TEST
HCI_LE_CS_TEST_END
I recommend you to take a look at our following documentations:
LE CS doc - Explains about Channel Sounding, which capabilities are supported, how its enabled with Kconfig.
Developing with CS - Lists Kconfig options for channel sounding
Testing CS implementation - Mentions using HCI UART sample
Best Regards,
Samruddhi
Thank you very much!
