I am using a Thingy91x, with some additional sensors attached via qwiic cable.
Initially to test the Thingy91x I inserted the SIM and scanned the QR code on the Thingy91x to get the device initialised in nrfCloud. The hello.nrfcloud page loaded in a browser and I could see data from the Thingy91x. I enabled GNSS via the page, and checked that GNSS worked when outdoors and the fallback to WIFI worked when indoors.
I then created my own custom firmware taking sample code from hello.nrfcloud. Sampling from the internal sensors and my added external ones is working fine, but I am having trouble with using the nrfCloud location services to get Assisted GNSS files when AGNSS is enabled and to get GPS coordinates from Cellular data.
I am using the location_init() to initialise and pass in my handler.
I am then using location_config_defaults_set(&config, location_methods_size, location_method_types); with
static enum location_method location_method_types[] = {
LOCATION_METHOD_GNSS,
LOCATION_METHOD_CELLULAR
I then call err = location_request(&config);
In my logs though I keep getting an error -13
[00:00:26.445,617] <inf> nrf_cloud_coap_cell_location_sample: Location request started
%NCELLMEAS: 0,"01991102","26201","05D8",128,1300,120,38,14,26119,1300,215,32,1,0,6400,479,63,24,24,1444,335,39,21,33,20370
[00:00:27.082,794] <err> location: Failed to acquire location using cloud location, error: -13
[00:00:27.092,285] <err> location: Location acquisition failed and fallbacks are also done
[00:00:27.101,257] <err> nrf_cloud_coap_cell_location_sample: Location request failed
I think this is an authentication issue to the nrfCloud services, but I can't find a way to resolve it. I know the device should be registered ok as hello.nrfcloud worked.
I have tried various config settings. Below are my base settings, but I have also tried:
- CONFIG_NRF_CLOUD_CLIENT_ID_SRC_IMEI=n and CONFIG_NRF_CLOUD_CLIENT_ID_SRC_INTERNAL_UUID=y
- CONFIG_NRF_CLOUD_CLIENT_ID_SRC_IMEI=y and CONFIG_NRF_CLOUD_CLIENT_ID_PREFIX="oob-" commented out
- CONFIG_NRF_CLOUD_CLIENT_ID_SRC_IMEI=y and CONFIG_NRF_CLOUD_CLIENT_ID_PREFIX="nrf-"
# --- Hardware & Library Enable ---
CONFIG_LOCATION=y
CONFIG_LOCATION_DATA_DETAILS=y
CONFIG_LOCATION_SERVICE_NRF_CLOUD=y
CONFIG_LOCATION_METHODS_LIST_SIZE=3
CONFIG_LOCATION_METHOD_GNSS=y
CONFIG_LOCATION_METHOD_WIFI=n
CONFIG_LOCATION_METHOD_CELLULAR=y
# --- Verified Credentials (OOB Factory Tag) ---
CONFIG_NRF_CLOUD_SEC_TAG=16842753
# --- Assistance & System ---
CONFIG_NRF_CLOUD_AGNSS=y
# Transport
CONFIG_COAP=y
CONFIG_NRF_CLOUD_COAP=y
CONFIG_NRF_CLOUD_COAP_SERVER_HOSTNAME="coap.nrfcloud.com"
CONFIG_NRF_CLOUD_COAP_SEC_TAG=16842753
CONFIG_NRF_CLOUD_COAP_JWT_SEC_TAG=4242
CONFIG_NRF_CLOUD_COAP_SERVER_PORT=5684
CONFIG_NRF_CLOUD_COAP_KEEPOPEN=y
CONFIG_NRF_CLOUD_COAP_MAX_RETRIES=10
CONFIG_NRF_CLOUD_COAP_DOWNLOADS=y
CONFIG_NRF_CLOUD_COAP_DISCONNECT_ON_FAILED_REQUEST=y
CONFIG_NRF_CLOUD_COAP_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_COAP_LOG_LEVEL=3
# end of Transport
Can you point out what I am doing wrong. Thanks
