Unstable ACLK
Greetings,
We want to use the MCK of the I2S module as a clock output for an external device. For that, we need a freuqency of around 4,096MHz.
ACLK originates from the 32MHz HFXO, and can be set to 12.288MHz (nrf5340_PS 4.11.1.3 Audio oscillator).
The master clock generator can now divide ACLK by 3 to arrive at 4,096MHz.
Devicetree overlay:
i2s_rx: &i2s0 {
	status = "okay";
	clock-source = "ACLK";
	pinctrl-0 = <&i2s0_default_alt>;
	pinctrl-names = "default";
&clock {
    hfclkaudio-frequency = <12288000>;
Using the Zephyr API, the I2S registers can not be configured directly, but it works with a small workaround:
/* --- I2S Parameter --- */
#define SAMPLE_RATE_HZ     128000u
#define WORD_SIZE_BITS     16u
#define CHANNELS           2u
With this, I set the bit-clock to 4,096MHz. MCK should be the same.
Now, measuring MCK (or SCK) with the oscilloscope shows, that we get an unstable frequency between 4,125MHz and 4,135MHz.
The main issue for us is not that the frequency is slightly off, but that it appears to be unstable.
I wonder how that can be. The quarz frequency should be reliable, and the Master clock generator just divides the frequency by 3.
So I would suspect the generation of ACLK to be unstable.
How exactly is ACLK created? Or do you have any idea what could cause this behavior, or whether there is anything incorrect in my setup?
Thanks a lot :)
  • Hi again, and thanks for the patience.
    RafaelV said:
    but we can see an even higher deviation of about 19kHz, resulting in around 1500ppm.
    At the same time, the duty cycle seems stable now. I suppose the distorted duty cycle we saw above stems from the MCK generator.
    I am not sure if I understand - what is the deviation you are seeing if not duty cycle?
    I would also recommend that you check this with a frequency analyzer, even though 4GSa/s does sound okay.
    RafaelV said:
    For us, it is mostly important that the frequency is stable long-term, and doesn't drift. The relatively high jitter mainly makes us cautious about the clock source and its determinism.
    Understood. Though this depends on the HFXO, you can always choose a crystal with better properties if you prefer. I wouldn't say that we've found out that there is a 1500ppm jitter here, but even if it were that, shouldn't lead to drift.
    RafaelV said:
    hfclkaudio comes from the 32MHz HFXO crystal. The 12,288MHz hfclkaudio can not be achieved through simple division of 32MHz. Do you know, how hfclkaudio is created internally? If we know it to be deterministic, so no delay being introduced, we could exclude an additional drift, that would suffice for us.
    This might help if you want more of a technical understanding.
    Elfving
