Added BAS service to nfc peripheral example caused phone to disconnect (0x13)
I noticed on my custom PCB that pairing stopped working, and was getting "reason 0x13" as the disconnect. This disconnect reason I believe is from the phone disconnecting.
I moved  back to the nrf5340DK (sdk/toolchain v3.2.1), and ran the nfc peripheral example code. This worked, so then I added in my prj.conf file to the example code, and process of elimination led me to the cause of the disconnect being the CONFIG_BT_BAS=Y.
When this is enabled, the phone issues a disconnet after nfc pairing.  If I comment it out, i.e. don't include it, the nfc pairing works fine, and the phone doesn't issue a disconnect.
Is there reason why this might be  happening? I'm using an S23 + Andriod 12, however interestingly enough, it does work on my OnePlus 13 running Android 16.
I guess in the bigger picture it's not the worst problem to have, as I could make a custom service/characteristic that sends the battery value, but it's worth asking, in case I'm doing something wrong.
I  pasted  below my prj.conf file
# Copyright (c) 2020 Nordic Semiconductor ASA
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_DK_LIBRARY=y
CONFIG_NFC_T4T_NRFXLIB=y
CONFIG_NFC_NDEF=y
CONFIG_NFC_NDEF_MSG=y
CONFIG_NFC_NDEF_RECORD=y
CONFIG_NFC_NDEF_LE_OOB_REC=y
CONFIG_NFC_NDEF_CH_MSG=y
CONFIG_NFC_NDEF_TNEP_RECORD=y
CONFIG_NFC_TNEP_TAG=y
CONFIG_NFC_NDEF_PARSER=y
CONFIG_NFC_NDEF_CH_PARSER=y
CONFIG_NFC_NDEF_LE_OOB_REC_PARSER=y
CONFIG_NFC_TNEP_CH=y
CONFIG_BT=y
CONFIG_BT_SMP=y
CONFIG_BT_SMP_APP_PAIRING_ACCEPT=y
# Keep support for legacy pairing to retain compatibility
# with older Andorid phones that may not support OOB SC pairing
CONFIG_BT_SMP_SC_PAIR_ONLY=n
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_NFC_pairing"
CONFIG_BT_DIS=y
CONFIG_BT_DIS_MANUF_NAME=y
CONFIG_BT_DIS_MANUF_NAME_STR="NordicSemiconductor"
CONFIG_BT_DIS_PNP=y
CONFIG_BT_DIS_PNP_VID_SRC=2
CONFIG_BT_DIS_PNP_VID=0x1915
CONFIG_BT_DIS_PNP_PID=0xEEEB
CONFIG_BT_DIS_PNP_VER=0x0100
CONFIG_MAIN_STACK_SIZE=3072
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_DK_LIBRARY=y
CONFIG_POLL=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
########################### Everything  above is the  default  example  nfc  peripheral code, below is  from my project
# enable console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_GPIO=y
CONFIG_I2C=y
CONFIG_ADC=y
CONFIG_MULTITHREADING=y
CONFIG_LOG=y
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
CONFIG_CRC=y
CONFIG_RING_BUFFER=y
CONFIG_POLL=y
# # Watchdog timer
# CONFIG_WDT_LOG_LEVEL_DBG=y
# CONFIG_WATCHDOG=y
# CONFIG_WDT_DISABLE_AT_BOOT=n
# CONFIG_UART_1_ASYNC=y
# CONFIG_UART_1_INTERRUPT_DRIVEN=n
# CONFIG_UART_1_NRF_HW_ASYNC=y
# CONFIG_UART_1_NRF_HW_ASYNC_TIMER=2
# Boot
# CONFIG_NCS_BOOT_BANNER=n
# CONFIG_BOOT_BANNER=n
# CONFIG_BOOT_DELAY=0
# Increase stack size for the main thread and System Workqueue
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_BT_RX_STACK_SIZE=2048
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_NORDIC_QSPI_NOR=y
# Bluetooth Services
CONFIG_BT_BAS=y                     # Battery Service
# # Enable FOTA over Bluetooth LE
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
# CONFIG_WATCHDOG=y
  • Hi Jerome,
    I suspect that the attribute table has been cached and not updated on the phone. This will cause a mismatch when you add the BAS service to the device. Please try to delete the bond information on the phone, reset Bluetooth (reset phone if needed) and test again.
    You can try adding this:
    CONFIG_BT_GATT_SERVICE_CHANGED=y
    So that the phone should know that the attribute table may change and it should do service discovery when receive a notification. But this only works if the attribute table has not been cached.
    If you add the BAS service to other sample, do you see the same issue on the S23 ?
