nRF91 modem watchdog fault when re-activating LTE
I have an application with a shipping mode that when enabled/disabled calls `conn_mgr_all_if_connect/conn_mgr_all_if_disconnect`.
These functions eventually end up in `lte_net_if.c`, running `lte_lc_func_mode_set` with either `LTE_LC_FUNC_MODE_ACTIVATE_LTE` or `LTE_LC_FUNC_MODE_DEACTIVATE_LTE`.
Connecting to the LTE network on boot works fine, as does entering shipping mode.
The modem fault occurs when attempting to re-activate the modem after it has already been active.
If less than a minute has passed since the modem was de-activated, it re-activates fine and the application continues as per normal.
If over a minute has passed, the modem faults more or less immediately with:
[00:01:26.754,638] <inf> app: Device activated, enable LTE
[00:01:26.982,513] <err> nrf_modem: Modem has crashed, reason 0x2, PC: 0x468de
This issue is 100% reproducible (happens every time), always with the same error code and program counter.
The error code corresponds with NRF_MODEM_FAULT_HW_WD_RESET.
Replacing `LTE_LC_FUNC_MODE_ACTIVATE_LTE` and `LTE_LC_FUNC_MODE_DEACTIVATE_LTE` with `LTE_LC_FUNC_MODE_NORMAL` and `LTE_LC_FUNC_MODE_OFFLINE` does not change the behavior of the fault.
nrfxlib version: Tag v3.1.1 (Commit 3b210a24d3bc7ecfc268e0feab6436306b11e7cb)
Modem firmware: mfw_nrf91x1_2.0.4
Modem model: nRF9151-LACA
    We tested the same shutdown, wait and re-initialization sequence in a clean nRF Connect SDK v3.1.0 environment on nRF9161DK. We have attached the main.c and prj.conf used for this test for your reference. The sequence was to connect LTE, bring LTE offline, call nrf_modem_lib_shutdown(), wait for more than 60 seconds, then call nrf_modem_lib_init() and reconnect LTE. In this setup, the modem reliably re-initializes and reconnects after the wait period, and we do not see an NRF_MODEM_FAULT_HW_WD_RESET (0x2).
    *** Booting nRF Connect SDK v3.1.0-6c6e5b32496e ***
    *** Using Zephyr OS v4.1.99-1612683d4010 ***
    [00:00:00.406,127] <inf> app: Init modem library (boot)
    [00:00:00.653,900] <inf> app: nrf_modem_lib_init() err=0
    [00:00:00.653,930] <inf> app: Enable LTE for first time
    [00:00:07.089,691] <inf> app: lte_lc_connect() err=0
    [00:00:07.089,721] <inf> app: Waiting 15 seconds to enter shipping mode...
    [00:00:22.089,782] <inf> app: Bring down LTE for shipping mode
    [00:00:22.549,072] <inf> app: lte_lc_offline() err=0
    [00:00:22.549,072] <inf> app: Shutting down modem library...
    [00:00:22.566,162] <inf> app: nrf_modem_lib_shutdown() err=0
    [00:00:22.566,162] <inf> app: 65 seconds to exit shipping mode
    [00:00:27.566,253] <inf> app: 60 seconds to exit shipping mode
    [00:00:32.566,345] <inf> app: 55 seconds to exit shipping mode
    [00:00:37.566,436] <inf> app: 50 seconds to exit shipping mode
    [00:00:42.566,528] <inf> app: 45 seconds to exit shipping mode
    [00:00:47.566,619] <inf> app: 40 seconds to exit shipping mode
    [00:00:52.566,711] <inf> app: 35 seconds to exit shipping mode
    [00:00:57.566,802] <inf> app: 30 seconds to exit shipping mode
    [00:01:02.566,894] <inf> app: 25 seconds to exit shipping mode
    [00:01:07.566,986] <inf> app: 20 seconds to exit shipping mode
    [00:01:12.567,077] <inf> app: 15 seconds to exit shipping mode
    [00:01:17.567,169] <inf> app: 10 seconds to exit shipping mode
    [00:01:22.567,260] <inf> app: 5 seconds to exit shipping mode
    [00:01:27.567,352] <inf> app: Re-init modem library...
    [00:01:27.815,948] <inf> app: nrf_modem_lib_init() err=0
    [00:01:28.016,052] <inf> app: Exiting shipping mode: reconnect LTE
    [00:01:34.214,813] <inf> app: lte_lc_connect() err=0
    This indicates the watchdog reset is not caused by the modem firmware or the shutdown delay itself, but is likely related to how LTE and the modem are being controlled in the application when using the connection-manager path.
    As next steps to isolate the issue in your setup, we recommend first ensuring that all components that may access the modem are fully stopped before calling conn_mgr_all_if_down(). In particular, please verify that all LTE sockets are closed, any DNS/REST/HTTP clients are stopped, no AT commands are in progress, and modem tracing (if enabled) is idle.
    We also recommend running the LTE down/up sequence from a dedicated application context (for example an application thread or work item), rather than directly from a network or connection-manager callback. As a diagnostic step, you can temporarily bypass conn_mgr_all_if_*() and directly call lte_lc_offline(), nrf_modem_lib_shutdown(), nrf_modem_lib_init(), and lte_lc_connect() to confirm whether the watchdog reset is specific to the connection-manager integration.
    Best Regards,
    Syed Maysum
    4403.prj.conf
    #include <zephyr/kernel.h>
    #include <modem/lte_lc.h>
    #include <modem/nrf_modem_lib.h>
    LOG_MODULE_REGISTER(app, LOG_LEVEL_INF);
    static void lte_connect_once(void)
    	int err = lte_lc_connect();
    	LOG_INF("lte_lc_connect() err=%d", err);
    static void lte_go_offline(void)
    	int err = lte_lc_offline();
    	LOG_INF("lte_lc_offline() err=%d", err);
    	int err;
    	LOG_INF("Init modem library (boot)");
    	err = nrf_modem_lib_init();
    	LOG_INF("nrf_modem_lib_init() err=%d", err);
    	if (err) {
    		LOG_ERR("Modem lib init failed: %d", err);
    		return 0;
    	LOG_INF("Enable LTE for first time");
    	lte_connect_once();
    	LOG_INF("Waiting 15 seconds to enter shipping mode...");
    	k_sleep(K_SECONDS(15));
    	LOG_INF("Bring down LTE for shipping mode");
    	lte_go_offline();
    	LOG_INF("Shutting down modem library...");
    	err = nrf_modem_lib_shutdown();
    	LOG_INF("nrf_modem_lib_shutdown() err=%d", err);
    	int countdown = 65;
    	while (countdown > 0) {
    		LOG_INF("%d seconds to exit shipping mode", countdown);
    		k_sleep(K_SECONDS(5));
    		countdown -= 5;
    	LOG_INF("Re-init modem library...");
    	k_sleep(K_MSEC(200));
    	LOG_INF("Exiting shipping mode: reconnect LTE");
    	lte_connect_once();
    	k_sleep(K_FOREVER);
  • > We tested the same shutdown, wait and re-initialization sequence in a clean nRF Connect SDK v3.1.0 environment on nRF9161DK. In this setup, the modem reliably re-initializes and reconnects after the wait period, and we do not see an NRF_MODEM_FAULT_HW_WD_RESET (0x2).
    Was any attempt made to run the minimal reproducible sample that you asked for and I provided?
    That is not a surprise (in that extra work needs to happen to trigger the fault, e.g. UDP packets).
    So the suggestion is to throw out all the integrations with Zephyr APIs that Nordic has written? I have little interest in attempting to re-architecture my networking flow to diagnose a fault in a component I don't control and can't debug just because you haven't run the sample I have already spent time providing.
    You can already see this is being done in the provided example.
    This is a watchdog failure inside the modem core. How could it have anything to do with the connection manager? The modem literally faults before `nrf_modem_lib_init` even returns.
    Thanks for the detailed feedback. I understand your point, and I agree that reworking application architecture just to debug a modem fault isn’t ideal.
    I are currently trying to build and run the exact minimal sample you shared, using your west workspace. While setting this up in a clean environment, I am hitting a TF-M build error on nrf9161dk/nrf9161/ns. I am checking it internally and once we have the sample building, we’ll proceed with reproducing the modem watchdog issue and report back.
    Best Regards,
    Syed Maysum
  • > I are currently trying to build and run the exact minimal sample you shared, using your west workspace. While setting this up in a clean environment, I am hitting a TF-M build error on nrf9161dk/nrf9161/ns.
    Can you share the build error? A clean environment build works fine locally for me.
    (.zephyr_venv) jordan@TAURUS:~/code$ mkdir fault_demo
    (.zephyr_venv) jordan@TAURUS:~/code$ cd fault_demo/
    (.zephyr_venv) jordan@TAURUS:~/code/fault_demo$ west init -m [email protected]:Embeint/infuse-sdk.git
    (.zephyr_venv) jordan@TAURUS:~/code/fault_demo$ cd infuse-sdk/
    (.zephyr_venv) jordan@TAURUS:~/code/fault_demo/infuse-sdk$ git checkout example/nrf91_modem_fault
    (.zephyr_venv) jordan@TAURUS:~/code/fault_demo/infuse-sdk$ west update
    (.zephyr_venv) jordan@TAURUS:~/code/fault_demo/infuse-sdk$ west build -b nrf9161dk/nrf9161/ns ./samples/nrf91_modem_fault/
    [506/506] Linking C executable zephyr/zephyr.elf
               FLASH:      193308 B       704 KB     26.81%
                 RAM:       79684 B       168 KB     46.32%
         RetainedMem:          0 GB        256 B      0.00%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from /home/jordan/code/fault_demo/infuse-sdk/build/zephyr/zephyr.elf for board: nrf9161dk
    Thanks for sharing your build steps.
    On my side (Windows environment), I set up a clean workspace and followed essentially the same flow as you:
    mkdir fault_demo
    cd fault_demo
    west init -m https://github.com/Embeint/infuse-sdk.git
    west update
    cd infuse-sdk
    west update
    west build -b nrf9161dk/nrf9161/ns samples/nrf91_modem_fault -p always
    However, the build fails during the TF-M stage with:
    zephyr/modules/trusted-firmware-m/nordic/include/RTE_Device.h:14:10:
    fatal error: zephyr/devicetree.h: No such file or directory
    The file does exist in the workspace, so it appears that the TF-M compile step is not picking up Zephyr’s include path on my host. I’m checking this internally to proceed with reproducing the watchdog issue and will get back to you by tomorrow.
    Best Regards,
    Syed Maysum
