nRF91 modem watchdog fault when re-activating LTE
I have an application with a shipping mode that when enabled/disabled calls `conn_mgr_all_if_connect/conn_mgr_all_if_disconnect`.
These functions eventually end up in `lte_net_if.c`, running `lte_lc_func_mode_set` with either `LTE_LC_FUNC_MODE_ACTIVATE_LTE` or `LTE_LC_FUNC_MODE_DEACTIVATE_LTE`.
Connecting to the LTE network on boot works fine, as does entering shipping mode.
The modem fault occurs when attempting to re-activate the modem after it has already been active.
If less than a minute has passed since the modem was de-activated, it re-activates fine and the application continues as per normal.
If over a minute has passed, the modem faults more or less immediately with:
[00:01:26.754,638] <inf> app: Device activated, enable LTE
[00:01:26.982,513] <err> nrf_modem: Modem has crashed, reason 0x2, PC: 0x468de
This issue is 100% reproducible (happens every time), always with the same error code and program counter.
The error code corresponds with NRF_MODEM_FAULT_HW_WD_RESET.
Replacing `LTE_LC_FUNC_MODE_ACTIVATE_LTE` and `LTE_LC_FUNC_MODE_DEACTIVATE_LTE` with `LTE_LC_FUNC_MODE_NORMAL` and `LTE_LC_FUNC_MODE_OFFLINE` does not change the behavior of the fault.
nrfxlib version: Tag v3.1.1 (Commit 3b210a24d3bc7ecfc268e0feab6436306b11e7cb)
Modem firmware: mfw_nrf91x1_2.0.4
Modem model: nRF9151-LACA
