Hi DevZone Community,
I am facing a build issue while working with the following environment:
Environment
SDK: nRF Connect SDK v1.9.1
Hardware: nRF9160 DK (custom board)
Toolchain: v2.0.0
Since older toolchain versions (v1.x.x) are no longer supported, Toolchain v2.0.0 or later is required for building and execution. However, I am currently unable to build my project using Toolchain v2.0.0 with NCS v1.9.1.
I am encountering the following error during the build process:
west build --build-dir d:/im830/build d:/im830 --pristine --board im830_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION="NONE" -DCONFIG_DEBUG_OPTIMIZATIONS=y -DCONFIG_DEBUG_THREAD_INFO=y -DCONF_FILE="prj.conf" -DBOARD_ROOT=d:/im830 -- west build: generating a build system Including boilerplate (Zephyr base): C:/ncs/v1.9.1/zephyr/cmake/app/boilerplate.cmake -- Application: D:/im830 -- Zephyr version: 2.7.99 (C:/ncs/v1.9.1/zephyr), build: v2.7.99-ncs1-1 -- Found Python3: C:/ncs/toolchains/v2.0.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter -- Found west (found suitable version "0.13.1", minimum required is "0.7.1") -- Board: im830_nrf9160_ns, Revision: 0.1.0 -- Cache files will be written to: C:/ncs/v1.9.1/zephyr/.cache -- Found host-tools: zephyr 0.14.1 (C:/ncs/toolchains/v2.0.0/opt/zephyr-sdk) -- Found dtc: C:/ncs/toolchains/v2.0.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6") -- Found toolchain: zephyr 0.14.1 (C:/ncs/toolchains/v2.0.0/opt/zephyr-sdk) -- Found BOARD.dts: D:/im830/boards/arm/im830_nrf9160/im830_nrf9160_ns.dts -- Generated zephyr.dts: D:/im830/build/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: D:/im830/build/zephyr/include/generated/devicetree_unfixed.h -- Generated device_extern.h: D:/im830/build/zephyr/include/generated/device_extern.h -- Including generated dts.cmake file: D:/im830/build/zephyr/dts.cmake warning: Experimental symbol NET_SOCKETS_OFFLOAD is enabled. D:/im830/prj.conf:59: warning: attempt to assign the value 'y' to the undefined symbol AT_CMD D:/im830/prj.conf:60: warning: attempt to assign the value 'y' to the undefined symbol AT_NOTIF D:/im830/prj.conf:116: warning: attempt to assign the value 'y' to the undefined symbol BSD_LIBRARY D:/im830/prj.conf:117: warning: attempt to assign the value 'n' to the undefined symbol BSD_LIBRARY_SYS_INIT Parsing D:/im830/Kconfig Loaded configuration 'D:/im830/boards/arm/im830_nrf9160/im830_nrf9160_ns_defconfig' Merged configuration 'D:/im830/prj.conf' Merged configuration 'D:/im830/build/zephyr/misc/generated/extra_kconfig_options.conf' error: Aborting due to Kconfig warnings CMake Error at C:/ncs/v1.9.1/zephyr/cmake/kconfig.cmake:272 (message): command failed with return code: 1 Call Stack (most recent call first): C:/ncs/v1.9.1/zephyr/cmake/app/boilerplate.cmake:544 (include) C:/ncs/v1.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include) C:/ncs/v1.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate) CMakeLists.txt:5 (find_package) -- Configuring incomplete, errors occurred! FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\v2.0.0\opt\bin\cmake.EXE' '-DWEST_PYTHON=C:\ncs\toolchains\v2.0.0\opt\bin\python.exe' '-Bd:\im830\build' '-Sd:\im830' -GNinja -DBOARD=im83 0_nrf9160_ns -DNCS_TOOLCHAIN_VERSION=NONE -DCONFIG_DEBUG_OPTIMIZATIONS=y -DCONFIG_DEBUG_THREAD_INFO=y -DCONF_FILE=prj.conf -DBOARD_ROOT=d:/im830 * The terminal process terminated with exit code: 1. * Terminal will be reused by tasks, press any key to close it.
I would like to know:
Is it officially supported to build an application using NCS v1.9.1 with Toolchain v2.0.0?
If not, is there any recommended workaround or migration approach?
Your guidance and suggestions would be greatly appreciated.
Thank you.
