Reducing the Time Required to Read 16 KB of Data
I want to reduce the time required to read 16 KB of data from the datalogger. Currently, it takes about 6 seconds to read all the data. How can I decrease this time?
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(12, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(12, UNIT_1_25_MS)
#define SLAVE_LATENCY 0
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS)
///////////////////////////////////////////ALLICATION SEND DATA
for(char i=0;i<66;i++)
DATA_SEND_BLUE_TX[0]=i+1;
nrf_fstorage_read(&f_storage,0x28000+i*240, &DATA_SEND_BLUE_TX[1],240);
DATA_SEND_BLUE_TX[241]=Chksum8_2sComplement(&DATA_SEND_BLUE_TX[1],240);
SEND_TO_APP( DATA_SEND_BLUE_TX,242);// 242 //56
void SEND_TO_APP(uint8_t * data_array, uint16_t index)
uint32_t err_code;
uint16_t length = index; count_send=0;
do
err_code = ble_data_send(&m_data, data_array, length, m_conn_handle);
count_send++;
} while (err_code == NRF_ERROR_RESOURCES);
uint32_t ble_data_send(ble_data_t * p_dat,
uint8_t *p_data,
uint16_t p_length,
uint16_t conn_handle)
ble_gatts_value_t gatts_value;
memset(&gatts_value, 0, sizeof(gatts_value));
gatts_value.len = p_length;
gatts_value.offset = 0;
gatts_value.p_value = p_data;
return sd_ble_gatts_value_set(p_dat->conn_handle, p_dat->tx_handles.value_handle, &gatts_value);
  • Hi Loc,
    Could you explain how you send data to the peer device?
    I can see you are setting the value of the characteristic using sd_ble_gatts_value_set() in ble_data_send()
    But then there is no guarantee that the value is notified to the peer device.
    Usually to send data to the peer device (the client) the server send a notification.
    Are you familiar with our example in the SDK, for example ble_app_hrs ? or ble_app_uart ?
  • Hi Hung,
    I am using the ble_app_uart example. The Android application sends a command to the BLE device, and then waits for the device to send back 66 data packets.
  • Hi Loc,
    Could you explain why you use sd_ble_gatts_value_set() . This only set the value of the characteristic, not sending the content to the peer.
    If you look at the ble_nus_data_send() in ble_nus.c you can find that we are using sd_ble_gatts_hvx() instead.
    Please also be aware that nRF5 SDK is very old and has been deprecated for a few years already. If you are developing a new product, it's recommended that you start with nRF Connect SDK .
  • Hi Hung,
    My current implementation is based on the ble_app_uart example using nRF5 SDK v16, where sd_ble_gatts_value_set() is used.
    I am planning to try the nRF Connect SDK. If I migrate to the new SDK, will the total time required to read all data be reduced or improved compared to nRF5 SDK
  • Hi Loc,
    Please point me to where you see that ?
    Here is the ble_nus.c file in SDK v16.0.0
     * Copyright (c) 2012 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    #include "sdk_common.h"
    #if NRF_MODULE_ENABLED(BLE_NUS)
    #include "ble.h"
    #include "ble_nus.h"
    #include "ble_srv_common.h"
    #define NRF_LOG_MODULE_NAME ble_nus
    #if BLE_NUS_CONFIG_LOG_ENABLED
    #define NRF_LOG_LEVEL       BLE_NUS_CONFIG_LOG_LEVEL
    #define NRF_LOG_INFO_COLOR  BLE_NUS_CONFIG_INFO_COLOR
    #define NRF_LOG_DEBUG_COLOR BLE_NUS_CONFIG_DEBUG_COLOR
    #else // BLE_NUS_CONFIG_LOG_ENABLED
    #define NRF_LOG_LEVEL       0
    #endif // BLE_NUS_CONFIG_LOG_ENABLED
    #include "nrf_log.h"
    NRF_LOG_MODULE_REGISTER();
    #define BLE_UUID_NUS_TX_CHARACTERISTIC 0x0003               /**< The UUID of the TX Characteristic. */
    #define BLE_UUID_NUS_RX_CHARACTERISTIC 0x0002               /**< The UUID of the RX Characteristic. */
    #define BLE_NUS_MAX_RX_CHAR_LEN        BLE_NUS_MAX_DATA_LEN /**< Maximum length of the RX Characteristic (in bytes). */
    #define BLE_NUS_MAX_TX_CHAR_LEN        BLE_NUS_MAX_DATA_LEN /**< Maximum length of the TX Characteristic (in bytes). */
    #define NUS_BASE_UUID                  {{0x9E, 0xCA, 0xDC, 0x24, 0x0E, 0xE5, 0xA9, 0xE0, 0x93, 0xF3, 0xA3, 0xB5, 0x00, 0x00, 0x40, 0x6E}} /**< Used vendor specific UUID. */
    /**@brief Function for handling the @ref BLE_GAP_EVT_CONNECTED event from the SoftDevice.
     * @param[in] p_nus     Nordic UART Service structure.
     * @param[in] p_ble_evt Pointer to the event received from BLE stack.
    static void on_connect(ble_nus_t * p_nus, ble_evt_t const * p_ble_evt)
        ret_code_t                 err_code;
        ble_nus_evt_t              evt;
        ble_gatts_value_t          gatts_val;
        uint8_t                    cccd_value[2];
        ble_nus_client_context_t * p_client = NULL;
        err_code = blcm_link_ctx_get(p_nus->p_link_ctx_storage,
                                     p_ble_evt->evt.gap_evt.conn_handle,
                                     (void *) &p_client);
        if (err_code != NRF_SUCCESS)
            NRF_LOG_ERROR("Link context for 0x%02X connection handle could not be fetched.",
                          p_ble_evt->evt.gap_evt.conn_handle);
        /* Check the hosts CCCD value to inform of readiness to send data using the RX characteristic */
        memset(&gatts_val, 0, sizeof(ble_gatts_value_t));
        gatts_val.p_value = cccd_value;
        gatts_val.len     = sizeof(cccd_value);
        gatts_val.offset  = 0;
        err_code = sd_ble_gatts_value_get(p_ble_evt->evt.gap_evt.conn_handle,
                                          p_nus->tx_handles.cccd_handle,
                                          &gatts_val);
        if ((err_code == NRF_SUCCESS)     &&
            (p_nus->data_handler != NULL) &&
            ble_srv_is_notification_enabled(gatts_val.p_value))
            if (p_client != NULL)
                p_client->is_notification_enabled = true;
            memset(&evt, 0, sizeof(ble_nus_evt_t));
            evt.type        = BLE_NUS_EVT_COMM_STARTED;
            evt.p_nus       = p_nus;
            evt.conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
            evt.p_link_ctx  = p_client;
            p_nus->data_handler(&evt);
    /**@brief Function for handling the @ref BLE_GATTS_EVT_WRITE event from the SoftDevice.
    static void on_write(ble_nus_t * p_nus, ble_evt_t const * p_ble_evt)
        ble_nus_evt_t                 evt;
        ble_nus_client_context_t    * p_client;
        ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
                                     p_ble_evt->evt.gatts_evt.conn_handle,
                          p_ble_evt->evt.gatts_evt.conn_handle);
        evt.p_nus       = p_nus;
        evt.conn_handle = p_ble_evt->evt.gatts_evt.conn_handle;
        if ((p_evt_write->handle == p_nus->tx_handles.cccd_handle) &&
            (p_evt_write->len == 2))
                if (ble_srv_is_notification_enabled(p_evt_write->data))
                    p_client->is_notification_enabled = false;
                    evt.type                          = BLE_NUS_EVT_COMM_STOPPED;
                if (p_nus->data_handler != NULL)
        else if ((p_evt_write->handle == p_nus->rx_handles.value_handle) &&
                 (p_nus->data_handler != NULL))
            evt.type                  = BLE_NUS_EVT_RX_DATA;
            evt.params.rx_data.p_data = p_evt_write->data;
            evt.params.rx_data.length = p_evt_write->len;
            // Do Nothing. This event is not relevant for this service.
    /**@brief Function for handling the @ref BLE_GATTS_EVT_HVN_TX_COMPLETE event from the SoftDevice.
    static void on_hvx_tx_complete(ble_nus_t * p_nus, ble_evt_t const * p_ble_evt)
        ble_nus_evt_t              evt;
            return;
        if (p_client->is_notification_enabled)
            evt.type        = BLE_NUS_EVT_TX_RDY;
            evt.p_nus       = p_nus;
    void ble_nus_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
        if ((p_context == NULL) || (p_ble_evt == NULL))
            return;
        ble_nus_t * p_nus = (ble_nus_t *)p_context;
            case BLE_GAP_EVT_CONNECTED:
                on_connect(p_nus, p_ble_evt);
            case BLE_GATTS_EVT_WRITE:
                on_write(p_nus, p_ble_evt);
            case BLE_GATTS_EVT_HVN_TX_COMPLETE:
                on_hvx_tx_complete(p_nus, p_ble_evt);
                // No implementation needed.
    uint32_t ble_nus_init(ble_nus_t * p_nus, ble_nus_init_t const * p_nus_init)
        ble_uuid_t            ble_uuid;
        ble_uuid128_t         nus_base_uuid = NUS_BASE_UUID;
        ble_add_char_params_t add_char_params;
        VERIFY_PARAM_NOT_NULL(p_nus);
        VERIFY_PARAM_NOT_NULL(p_nus_init);
        // Initialize the service structure.
        p_nus->data_handler = p_nus_init->data_handler;
        /**@snippet [Adding proprietary Service to the SoftDevice] */
        // Add a custom base UUID.
        err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_nus->uuid_type);
        VERIFY_SUCCESS(err_code);
        ble_uuid.type = p_nus->uuid_type;
        ble_uuid.uuid = BLE_UUID_NUS_SERVICE;
        // Add the service.
        err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
                                            &ble_uuid,
                                            &p_nus->service_handle);
        // Add the RX Characteristic.
        memset(&add_char_params, 0, sizeof(add_char_params));
        add_char_params.uuid                     = BLE_UUID_NUS_RX_CHARACTERISTIC;
        add_char_params.uuid_type                = p_nus->uuid_type;
        add_char_params.max_len                  = BLE_NUS_MAX_RX_CHAR_LEN;
        add_char_params.init_len                 = sizeof(uint8_t);
        add_char_params.is_var_len               = true;
        add_char_params.char_props.write         = 1;
        add_char_params.char_props.write_wo_resp = 1;
        add_char_params.read_access  = SEC_OPEN;
        add_char_params.write_access = SEC_OPEN;
        err_code = characteristic_add(p_nus->service_handle, &add_char_params, &p_nus->rx_handles);
            return err_code;
        // Add the TX Characteristic.
        /**@snippet [Adding proprietary characteristic to the SoftDevice] */
        add_char_params.uuid              = BLE_UUID_NUS_TX_CHARACTERISTIC;
        add_char_params.max_len           = BLE_NUS_MAX_TX_CHAR_LEN;
        add_char_params.char_props.notify = 1;
        add_char_params.cccd_write_access = SEC_OPEN;
        return characteristic_add(p_nus->service_handle, &add_char_params, &p_nus->tx_handles);
    uint32_t ble_nus_data_send(ble_nus_t * p_nus,
                               uint8_t   * p_data,
                               uint16_t  * p_length,
        ble_gatts_hvx_params_t     hvx_params;
        err_code = blcm_link_ctx_get(p_nus->p_link_ctx_storage, conn_handle, (void *) &p_client);
        if ((conn_handle == BLE_CONN_HANDLE_INVALID) || (p_client == NULL))
            return NRF_ERROR_NOT_FOUND;
        if (!p_client->is_notification_enabled)
        if (*p_length > BLE_NUS_MAX_DATA_LEN)
            return NRF_ERROR_INVALID_PARAM;
        memset(&hvx_params, 0, sizeof(hvx_params));
        hvx_params.handle = p_nus->tx_handles.value_handle;
        hvx_params.p_data = p_data;
        hvx_params.p_len  = p_length;
        hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
        return sd_ble_gatts_hvx(conn_handle, &hvx_params);
    #endif // NRF_MODULE_ENABLED(BLE_NUS)
    sd_ble_gatts_hvx() is used in ble_nus_data_send()
    What do you expect the sd_ble_gatts_value_set() do ?
  • Hi Hung,
    Maybe I am mistaken. I will check it again.Thank you for your help.
