Hi together,
I'm using the NUS example (NRF52832) for client and peripheral, which is running quite well. My goal is to inform the peripheral application when notification was enabled on central side. Thus I added the line cccd_md.wr_auth = 1; in the function rx_char_add and added
case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
/* we get this event on peripheral side, when central enabled notifications */
if(p_ble_evt->evt.gatts_evt.params.authorize_request.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
/* reply with SUCCESS/ALLOWED */
ble_gatts_rw_authorize_reply_params_t rw_authorize_reply_params;
memset(&rw_authorize_reply_params, 0, sizeof(rw_authorize_reply_params));
rw_authorize_reply_params.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
rw_authorize_reply_params.params.write.gatt_status = BLE_GATT_STATUS_SUCCESS;
rw_authorize_reply_params.params.write.update = 1;
err_code = sd_ble_gatts_rw_authorize_reply(m_ble_nus.conn_handle, &rw_authorize_reply_params);
in the function on_ble_evt. With this, as soon the the function ble_nus_c_rx_notif_enable was called from central, the peripheral got a BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST such that I was able to inform the application that the central has enabled notifications.
The described code was running very well with softdevice S132 1.0.0-3-alpha and sdk 0.9.2.
Now I'm using S132 V2.0.0 and nRF5 SDK 11.0.0 and get the following error: After connection setup, when I want to send data to the central using ble_nus_string_send the function sd_ble_gatts_hvx returns 0x3401. This was not the case, when using the "old" softdevice. How can I solve this problem?
Is there another way to inform the peripheral when a central connected and discovered all services successfully?
Thank you!
