MPSL ASSERT: 112, 695 (NCS 3.1.1)
After upgrading from NCS 2.5.2 to NCS 3.1.1, I get quite frequent MPSL assertion errors on a nRF52840.
Can you shed some light into what this assertion error is about, please?
Thanks
    According to some similar cases, the causes of the MPSL assert errors after upgrading can be due to:
    32 MHz crystal (HFCLK) issues such as the crystal starting too slow or if it's is marginal due to solder joints, incorrect load capacitors or if these aren't there, temperature/supply effects. I would also suggest you to check that your app isn't using TIMERO after upgrading. Also ensure that you don't allocate PPI/DPPI channels or other resources which MPSL reserves. You can also test and increase CONFIG_MPSL_HFCLK_LATENCY and check if the asserts still show. Another cause can also be long time periods with interrupts disabled or heavy flash/ rram operations while BLE and other radio activity runs. Unfortunately, because the MPSL assert pair you mentioned is an internal code, we cannot decode those numbers.
    Best Regards,
    Samruddhi
  • Thank you for your prompt answer!
    We figured out what the issue was: we accidentally had the RTC0, which we otherwise don't use, enabled in the devicetree, where the Zephyr driver then (also) configures it. Simply removing it fixed the issue.
    Unfortunately does mpsl_init.c currently (v3.1.1) not validate this in its Kconfig validation part
