MQTT connection fails over NB-IoT using nRF9151 DK and Serial Modem
Hello Nordic Support Team,
I am experiencing an issue when using MQTT over an NB-IoT connection with the nRF9151 DK, and I would like to ask for clarification and guidance.
Setup:
- Hardware: nRF9151 DK
- Zephyr version 3.2.1
- Firmware: Nordic Serial Modem (used to control the device via AT commands)
- Protocol: MQTT
- Broker: test.mosquitto.org (public test broker)
- SIM: 1NCE - confirmed to support NB-IoT in my region
Description of the issue:
I am using the MQTT API through AT commands (docs.nordicsemi.com/.../at_mqtt.html) to connect to an MQTT broker.
When the modem is configured to use LTE, the MQTT connection works correctly and I am able to connect, publish, and subscribe without issues.
However, when the modem is configured to use NB-IoT, the MQTT connection fails and the connection to the broker cannot be established. The same configuration, commands, and broker are used, with the only difference being the access technology (NB-IoT instead of LTE).
What I have verified:
- The SIM card supports NB-IoT in my geographic area
- Network registration to NB-IoT is successful: i verify this by looking for valid PSM timer values ​​in AT+CEREG unsolicited notifications
Are there known limitations or specific requirements when using MQTT over NB-IoT with the Serial Modem on nRF9151?
Is MQTT over TCP fully supported over NB-IoT in this setup, or are there known constraints depending on the network or broker?
Any guidance, documentation references, or recommended configuration for using MQTT over NB-IoT would be greatly appreciated.
Thank you for your support.
Federica
  • Hi Federica,
    Could you share a log of what occurs (and possibly a modem trace)?
    If the RSRP (signal strength) is low, it can be problematic as you will get a heavily reduced overall throughput if retransmissions occur on-air (CE level increases).
    TCP based communication tend to suffer in terms of timeout, due to the lower overall throughput on NB-IoT as compared to LTE M1.
    Other than that, there is no technical reason why it should not work; but you will see a difference in terms of robustness, especially when coverage is bad.
    Håkon
  • Hi Håkon,
    I was able to solve the problem by reviewing other tickets on this portal: I found that the device needed to be configured to use PCO instead of EPCO (which is the default option in the Serial Modem firmware). After setting the command AT%XEPCO=0, the MQTT connection was successfully established.
    At the moment, I have not experienced any timeout-related issues. However, since the system will need to be replicated on a larger scale, it would be better to prevent future issues.
    For this reason, I would appreciate receiving documentation or reference material regarding CoAP management via AT commands. Unlike MQTT, I didn't find a dedicated section for CoAP in the Serial Modem AT command documentation.
    Any guidance or documentation you can share would be greatly appreciated.
    Federica
  • Hi Federica,
    Glad to hear that you found the root cause of the issue.
    Serial Modem does not expose a CoAP AT command set, unfortunately. Here is the overall socket commands that are covered:
    https://docs.nordicsemi.com/bundle/addon-serial_modem-latest/page/index.html
    Specific protocols, like lwm2m carrier library, are possible to enable, but these are higher level application specific functions.
    However, you can setup a generic udp (datagram) socket.
    An alternative is to use the coap client:
    https://docs.nordicsemi.com/bundle/ncs-3.2.2/page/nrf/samples/net/coap_client/README.html
    Håkon
