VS Code nRF Connect build output corrupted / overwritten in integrated terminal after recent updates (Windows)
I’m running into a terminal output issue with nRF Connect for VS Code on Windows that seems to have appeared after recent updates. I did not have this problem in 2025 with older versions.
Problem description
When building an application using the nRF Connect VS Code extension (Build button / build task), the build output in the VS Code integrated terminal becomes unreadable:
  • characters are misaligned
  • lines appear to be partially overwritten
  • Ninja progress lines ([x/y]) and compiler errors get mixed together
  • error messages are very hard to read or truncated
This looks like carriage-return (\r) redraw handling going wrong in the terminal.
Example symptoms (simplified):
[39/213] Building C object ...
ninja: build stopped: subcommand failed.modbus_peripheral_t *peripheral)
What works reliably
If I do not use the VS Code integrated terminal, but instead:
  1. Launch an external toolchain shell:
nrfutil toolchain-manager launch --terminal powershell --ncs-version v3.1.0
  1. Then run the exact same west build command manually:
west build --build-dir c:/Users/loicg/work/in-terra/wip/embedded/logr-logic-workspace/logr-logic/app/build_dev `
c:/Users/loicg/work/in-terra/wip/embedded/logr-logic-workspace/logr-logic/app `
--pristine `
--board [email protected]/nrf52840 `
--no-sysbuild `
-DCONFIG_DEBUG_OPTIMIZATIONS=y `
-DCONFIG_DEBUG_THREAD_INFO=y `
-DCONF_FILE="prj.conf" `
-DEXTRA_CONF_FILE="overlay-bt.conf;overlay-gpio-expander.conf;overlay-lora.conf;overlay-measurement.conf;overlay-modbus-wpre.conf;overlay-modbus.conf;overlay-nus-console.conf;overlay-nus-shell.conf;overlay-powerboard.conf;overlay-uart-dynpincontrol.conf;overlay-settings.conf" `
-DDTC_OVERLAY_FILE="dts-bme280.overlay;dts-gpio-hogs.overlay;dts-modbus.overlay;dts-nus-console.overlay;dts-uart0-dynpinctrl.overlay"
Arrow right️ The output is perfectly readable in that case.
So this appears to be specific to how the VS Code integrated terminal / tasks handle the build output, not a toolchain or project issue.
Things I’ve already tried (no success)
  • Disabling terminal GPU acceleration
  • Restarting VS Code after changing settings
  • Switching shells for nRF Connect tasks:
    • PowerShell 7 (pwsh)
    • cmd.exe
  • Disabling ConPTY
  • Disabling shell integration
  • Increasing terminal scrollback
  • Verifying that the correct toolchain and environment are used
None of these resolved the mixed / overwritten output when the build is launched from nRF Connect inside VS Code.
Environment
  • OS: Windows
  • nRF Connect for VS Code: recent version (problem appeared after recent updates)
  • NCS: v3.1.0
  • Build system: west / CMake / Ninja
  • Board: [email protected]/nrf52840
Question
  • Is this a known issue with recent nRF Connect VS Code releases or VS Code terminal integration?
  • Is there a recommended way to force non-redrawing / line-based output for builds launched from the extension?
  • Or a way to make nRF Connect run builds in an external terminal instead of the integrated one?
Thanks for any pointers — happy to provide logs or try test builds if needed.
