NRF_NVMC->CONFIG hangs on setting NRF_NVMC_MODE_WRITE in Zephyr (without Softdevice)
I am using the Zephyr NVS Settings module. In some cases this happens: I try to save a value with `settings_save_one()`, which internally calls `nvs_write()`.
I debugged it down to `nrf_nvmc_mode_set()`, which is trying to set the `NRF_NVMC->CONFIG` register to `NRF_NVMC_MODE_WRITE`.
But it keeps hanging there.
NCS 2.1.4
Zephyr 3.1.99
Custom Board with nRF52832
Enabled features:
- PWM
- ADC (SAADC)
- ESB Shockburst
- NVS Settings
- UART
- CONFIG_PM=y
- CONFIG_MPU_ALLOW_FLASH_WRITE=y
- CONFIG_DEBUG=y
Things that I have tried/checked:
  • There is no softdevice in the flash
  • I am not using BLE (but ESB Shockburst, maybe this is a problem?)
  • Settings partition is at 0x7c000 (0x4000 size), `CONFIG_SETTINGS_NVS_SECTOR_COUNT=2`
  • I call it on the main thread not in an ISR
  • Zephyr workers and other threads are still running
  • Application is not overlapping (size is around 0x489F0)
I have added some debug prints to the SDK to trace down the spot where it fails. See the logs at the bottom.
This is the code snippet where it fails:
The "Finished" is never printed
nrf_nvmc_mode_set(NRF_NVMC, NRF_NVMC_MODE_WRITE);
NRF_STATIC_INLINE void nrf_nvmc_mode_set(NRF_NVMC_Type *p_reg,
                                         nrf_nvmc_mode_t mode)
    printk("BPROT CONFIG0: 0x%08x\n", NRF_BPROT->CONFIG0);
    printk("BPROT CONFIG1: 0x%08x\n", NRF_BPROT->CONFIG1);
    printk("NRF_NVMC->READY: 0x%08x\n", NRF_NVMC->READY);
    printk("FICR FLASH: %lu kB\n", NRF_FICR->INFO.FLASH);
    printk("FICR RAM: %lu kB\n", NRF_FICR->INFO.RAM);
    unsigned int key = irq_lock();
    printk("nrf_nvmc_mode_set: Set mode %d\n", mode);
    p_reg->CONFIG = (uint32_t)mode;
    irq_unlock(key);
    printk("nrf_nvmc_mode_set: Finished\n");
nvs_write: Enter while #1
nvs_write: Exit while #1
nvs_write: Enter while #2
nvs_write: Enter nvs_flash_wrt_entry
nvs_flash_wrt_entry: Writing entry id 49153 at offset 8 len 4
nvs_flash_wrt_entry: Writing data at 8
nvs_flash_al_wrt: Writing 4 bytes at 7c008
soc_flash_nrf: write addr 0x0007c008 len 4
write_op: context 0x20005190
write_op: Enter write 4-byte aligned data
write_op: Write 4 bytes at flash addr 0x0007c008 from data addr 0x20001efc
nvmc_word_write: addr 0x0007c008, value 0x0000001e
nvmc_write_mode_set: Set write mode
BPROT CONFIG0: 0x00000000
BPROT CONFIG1: 0x00000000
NRF_NVMC->READY: 0x00000001
FICR FLASH: 512 kB
FICR RAM: 64 kB
nrf_nvmc_mode_set: Set mode 1
  • Today I found out that it works when I change the IRQ setup for my ADC. But this is not feasible for my project. I still don't get how this can be related to the NVMC deadlock...
    // This works for the NVMC
    IRQ_DIRECT_CONNECT(SAADC_IRQn, IRQ_PRIO_LOWEST, nrfx_saadc_irq_handler, 0);
    // This is what my project requires but it has the deadlock problem
    IRQ_CONNECT(SAADC_IRQn, IRQ_PRIO_LOWEST, nrfx_saadc_irq_handler, 0, 0);
  • Hi!
    Seems strange that the IRQ setup for ADC should effect this then.
    Could you do something like this, and print the back-trace ?
    cd build/app_name/
    west attach
    info threads
    thread apply all bt
  • This is captured at the point where settings_save_one is called:
    -exec info threads
      Id   Target Id                                                Frame
      3    Thread 536877128 (idle UNKNOWN PRIO 15)                  arch_cpu_idle () at ./zephyr-firmware/zephyr/arch/arm/core/aarch32\cpu_idle.S:129
      4    Thread 536876920 (logging PENDING PRIO 14)               arch_swap (key=key@entry=0) at ./zephyr-firmware/zephyr/arch/arm/core/aarch32/swap.c:53
    * 5    Thread 536877488 (sysworkq RUNNING PRIO 255)             Settings::_save_all_internal (work=<optimized out>) at ../src/settings/settings.cpp:127
      6    Thread 536874472 (shockburst_tx_thread SUSPENDED PRIO 5) arch_swap (key=key@entry=0) at ./zephyr-firmware/zephyr/arch/arm/core/aarch32/swap.c:53
    -exec thread apply all bt
    Thread 6 (Thread 536874472):
    #0  arch_swap (key=key@entry=0) at ./zephyr-firmware/zephyr/arch/arm/core/aarch32/swap.c:53
    #1  0x00039408 in z_swap_irqlock (key=0) at ./zephyr-firmware/zephyr/kernel/include/kswap.h:185
    #2  z_swap (key=..., lock=0x200031b4 <sched_spinlock>) at ./zephyr-firmware/zephyr/kernel/include/kswap.h:196
    #3  z_tick_sleep (ticks=<optimized out>) at ./zephyr-firmware/zephyr/kernel/sched.c:1432
    #4  0x00039472 in z_impl_k_sleep (timeout=...) at ./zephyr-firmware/zephyr/kernel/sched.c:1464
    #5  0x000133f8 in k_sleep (timeout=...) at zephyr/include/generated/syscalls/kernel.h:100
    #6  ShockburstIoController::tx_thread () at ../src/hardware/io/shockburst_io_controller.cpp:306
    #7  0x00027f48 in z_thread_entry (entry=0x1332d <ShockburstIoController::tx_thread(void*, void*, void*)>, p1=<optimized out>, p2=<optimized out>, p3=<optimized out>) at ./zephyr-firmware/zephyr/lib/os/thread_entry.c:36
    #8  0xaaaaaaaa in ?? ()
    Backtrace stopped: previous frame identical to this frame (corrupt stack?)
    Thread 5 (Thread 536877488):
    #0  Settings::_save_all_internal (work=<optimized out>) at ../src/settings/settings.cpp:127
    #1  0x000382ea in work_queue_main (workq_ptr=0x200019b0 <k_sys_work_q>, p2=<optimized out>, p3=<optimized out>) at ./zephyr-firmware/zephyr/kernel/work.c:668
    #2  0x00027f48 in z_thread_entry (entry=0x38259 <work_queue_main>, p1=<optimized out>, p2=<optimized out>, p3=<optimized out>) at ./zephyr-firmware/zephyr/lib/os/thread_entry.c:36
    #3  0xaaaaaaaa in ?? ()
    Thread 4 (Thread 536876920):
    #1  0x00038ea4 in z_swap_irqlock (key=0) at ./zephyr-firmware/zephyr/kernel/include/kswap.h:185
    #2  z_swap (key=..., lock=0x200031a0 <lock>) at ./zephyr-firmware/zephyr/kernel/include/kswap.h:196
    #3  z_pend_curr (lock=lock@entry=0x200031a0 <lock>, key=..., wait_q=wait_q@entry=0x20000d10 <log_process_thread_sem>, timeout=...) at ./zephyr-firmware/zephyr/kernel/sched.c:842
    #4  0x00037fe0 in z_impl_k_sem_take (sem=sem@entry=0x20000d10 <log_process_thread_sem>, timeout=...) at ./zephyr-firmware/zephyr/kernel/sem.c:143
    #5  0x0002a274 in k_sem_take (timeout=..., sem=0x20000d10 <log_process_thread_sem>) at zephyr/include/generated/syscalls/kernel.h:1054
    #6  log_process_thread_func (dummy1=<optimized out>, dummy2=<optimized out>, dummy3=<optimized out>) at ./zephyr-firmware/zephyr/subsys/logging/log_core.c:681
    #7  0x00027f48 in z_thread_entry (entry=0x2a21d <log_process_thread_func>, p1=<optimized out>, p2=<optimized out>, p3=<optimized out>) at ./zephyr-firmware/zephyr/lib/os/thread_entry.c:36
    Thread 3 (Thread 536877128):
    #0  arch_cpu_idle () at ./zephyr-firmware/zephyr/arch/arm/core/aarch32\cpu_idle.S:129
    #1  0x000379a4 in k_cpu_idle () at ./zephyr-firmware/zephyr/include/zephyr/kernel.h:5616
    #2  idle (unused1=<optimized out>, unused2=<optimized out>, unused3=<optimized out>) at ./zephyr-firmware/zephyr/kernel/idle.c:83
    #3  0x00027f48 in z_thread_entry (entry=0x37991 <idle>, p1=<optimized out>, p2=<optimized out>, p3=<optimized out>) at ./zephyr-firmware/zephyr/lib/os/thread_entry.c:36
    #4  0xaaaaaaaa in ?? ()
  • So it seems you are stuck here:
    How does the function at settings.cpp:127 look like ?
  • It's basically a loop which calls settings_save_one for multiple items but it keeps hanging on the first one.
