Can't generate DFU package with nrfutil
I have installed nrfutil from PyPI using the instructions in section 2 of the nRF Util User Guide v 6.1.0. My main purpose for using nrfutil is to generate a DFU package. Whenever I try to use the nrfutil pkg generate command I get the error message: “Subcommand nrfutil-pkg.exe not found”. If I use the nrfutil list command it finds 0 installable commands.
The version of nrfutil I have installed is:
nrfutil 8.1.1 (b6089d0 2025-08-21)
commit-hash: b6089d08a9cfdb292f8ab8d21e0908ded814cd11
commit-date: 2025-08-21
host: x86_64-pc-windows-msvc
build-timestamp: 2025-08-21T14:12:43.593658000Z
classification: nrf-external
How do I install the nrfutil-pkg subcommand? I didn’t see any description about this in the User Guide. Please help as the DFU function is important for a product release that our company is doing.
Also I saw “Subcommand nrfutil-dfu.exe not found”
    Are you working with nRF5SDK DFU? Please be aware that this command tool only support for nRF5 SDK.
    You can run "nrfutil install nrf5sdk-tools" to install the tool, then you can use nrfutil nrf5sdk-tools dfu function.
    [00:00:07] ###### 100% [Install packages] Install packages
    >nrfutil nrf5sdk-tools --help
    Usage: pc_nrfutil_legacy_v6.1.7.exe [OPTIONS] COMMAND [ARGS]...
    Options:
      -v, --verbose            Increase verbosity of output. Can be specified more
                               than once (up to -v -v -v -v).  [x>=0]
      -o, --output <filename>  Log output to file
      --help                   Show this message and exit.
    Commands:
      dfu       Perform a Device Firmware Update over serial, BLE, Thread, Zigbee
                or ANT transport given a DFU package (zip file).
      keys      Generate and display private and public keys.
      pkg       Display or generate a DFU package (zip file).
      settings  Generate and display Bootloader DFU settings.
      version   Display nrfutil version.
      zigbee    Zigbee-related commands and utilities.
    >nrfutil nrf5sdk-tools dfu --help
    Usage: pc_nrfutil_legacy_v6.1.7.exe dfu [OPTIONS] COMMAND [ARGS]...
      This set of commands supports Device Firmware Upgrade procedures over both
      BLE and serial transports.
    Options:
    Commands:
      ant         Update the firmware on a device over an ANT connection.
      ble         Update the firmware on a device over a BLE connection.
      serial      Update the firmware on a device over a UART serial connection.
                  The DFU target must be a chip using digital I/O pins as an UART.
      thread      Update the firmware on a device over a Thread connection.
      usb-serial  Update the firmware on a device over a USB serial connection.
                  The DFU target must be a chip with USB pins (i.e. nRF52840) and
                  provide a USB ACM CDC serial interface.
      zigbee      Update the firmware on a device over a Zigbee connection.
    Amanda H.
  • Thank you. I was able to install nrf5sdk-tools. Now nrfutil pkg generate --help is working. I am using the nRF5_SDK_17.0.2 SDK for my application development. I tried the following but got:
    C:\Firmware\DFU_pkg>nrfutil pkg generate --application app.hex BD_dfu_package.zip
    Usage: pc_nrfutil_legacy_v6.1.7.exe pkg generate [OPTIONS] ZIPFILE
    Try 'pc_nrfutil_legacy_v6.1.7.exe pkg generate --help' for help.
    Error: --hw-version required.
    I am targeting the nRF52840 device. The help doc says "--hw-version INTEGER            The hardware version."
    What integer do I use for the nRF52840 micro?
