nRF54L15 – LSM6DS3 Initialization Fails on Custom PCB (SDK v3.0.2)
I am using nRF54L15 with SDK v3.0.2. I am facing an issue while initializing the LSM6DS3 sensor on a custom PCB.
Device Initialization Code:
#define LSM_NODE DT_NODELABEL(lsm6dsl)
static const struct device *lsm6dsl_dev = DEVICE_DT_GET(LSM_NODE);
if (!device_is_ready(lsm6dsl_dev))
      LOG_ERR("LSM6DSL not ready\n");
      return -ENODEV;
Issue Description:
The device_is_ready() check fails, and I receive the following log:
<err> lsm6ds1: LSM6DSL not ready
Observations:
  • When I scan/read the I2C bus, I am able to detect the correct I2C address of the LSM6DS3 sensor.
  • The same firmware and overlay configuration work correctly on the nRF54L15 DK, The issue occurs only on the custom PCB.
I am attaching the overlay file for reference.
Could you please suggest what might cause device_is_ready() to fail on the custom PCB, even though the sensor responds on the I2C bus and the same firmware works correctly on the nRF54L15 DK?
&pinctrl {
    i2c21_default: i2c21_default {
        group1 {
            psels = <NRF_PSEL(TWIM_SCL, 1, 11)>,  /* P1.11 */
                    <NRF_PSEL(TWIM_SDA, 1, 12)>;  /* P1.12 */
    i2c21_sleep: i2c21_sleep {
        group1 {
            low-power-enable;  /* Put SCL/SDA in low-leakage state during deep sleep */
/* Remove button2 node */
 /delete-node/ &button2;
/* Remove sw2 alias */
     aliases {
         /delete-property/ sw2;
&i2c21 {
    status = "okay";
    clock-frequency = <I2C_BITRATE_STANDARD>;
    pinctrl-0 = <&i2c21_default>;
    pinctrl-1 = <&i2c21_sleep>;
    fdc1004: fdc1004@50 {
        compatible = "i2c-device";
        reg = <0x50>;  // 7-bit I2C address
        status = "okay";
    lsm6dsl: lsm6dsl@6a {
        compatible = "st,lsm6dsl";
        reg = <0x6a>; // 7-bit I2C address
        status = "okay";
        irq-gpios = <&gpio1 8 GPIO_ACTIVE_HIGH>; // INT1 connected here
        wakeup-source;  // system can wake from deep sleep
    pcf_rtc: rtc@51 {
        compatible = "nxp,pcf8563";
        reg = <0x51>; // 7-bit I2C address
        status = "okay";
    max17048: fuelgauge@36 {
        reg = <0x36>; // 7-bit I2C address
        status = "okay";
&spi00 {
    status = "okay";
    cs-gpios = <&gpio2 5 GPIO_ACTIVE_LOW>, <&gpio2 6 GPIO_ACTIVE_LOW>;  // P2.05 = CS1 , P2.06 = CS2
    //cs-gpios = <&gpio2 5 GPIO_ACTIVE_LOW>;
    pinctrl-0 = <&spi00_default>;
    pinctrl-1 = <&spi00_sleep>;
    w25q64: w25q64jv@1 {
        compatible = "jedec,spi-nor";
        reg = <1>;
        spi-max-frequency = <8000000>;
        size = <67108864>; /* 8 MB */
        jedec-id = [ef 40 17];
        has-dpd;
        t-enter-dpd = <3000>;
        t-exit-dpd  = <30000>;
        status = "okay";
    chosen {
        nvs-partition = &storage_partition;
&cpuapp_rram {
    partitions {
        #address-cells = <1>;
        #size-cells = <1>;
        storage_partition: partition@15c000 {
            label = "storage";
            reg = <0x15c000 DT_SIZE_K(36)>; // 36KB internal flash partition
&led0 {
    gpios = <&gpio1 6 0>;
&uart20_default {
    group2 {
        psels = <NRF_PSEL(UART_CTS, 1, 7)>;
&uart20_sleep {
    group1 {
        psels = <NRF_PSEL(UART_TX, 1, 4)>, <NRF_PSEL(UART_CTS, 1, 7)>;
&led1 {
    gpios = <&gpio1 5 0>;
