nRF9151 TF-M Boot Hang When Enabling NVS for Onomondo SoftSIM
Hardware:
nRF9151 DK
Board: nrf9151dk/nrf9151/ns
  • nRF Connect SDK version: 3.2.1
  • Zephyr version: 0.17
Issue Description:
I have a working LWM2M application with TF-M enabled. When I integrate Onomondo SoftSIM library, it requires CONFIG_NVS=y to be enabled. However, as soon as I enable NVS, the device hangs during boot and never reaches main().
Broken Configuration (with NVS):
CONFIG_BUILD_WITH_TFM=y
CONFIG_LWM2M_CLIENT_UTILS=y
CONFIG_NVS=y
CONFIG_PM_PARTITION_SIZE_NVS_STORAGE=0x8000
CONFIG_SOFTSIM=y
Partition Layout:
The partition layout appears correct with no overlaps. NVS is in non-secure region:
nvs_storage:
  address: 0xe8000
  end_address: 0xf0000
  region: flash_primary
tfm_its:
  address: 0xf8000
tfm_otp_nv_counters:
  address: 0xfa000
tfm_nonsecure:
  address: 0x18000
  end_address: 0x78000
Questions:
  1. Is this a known SPU (System Protection Unit) permissions issue where NVS tries to access flash before TF-M configures the regions as non-secure?
  2. How can I configure TF-M to allow the NVS flash region (0xe8000-0xf0000) to be accessible from non-secure code during early boot?
  3. Is there a recommended initialization order or additional TF-M configuration needed when combining TF-M + NVS on nRF9151?
Any guidance would be greatly appreciated.
    Apology for the confusion. Here is the file. For me, the Path is:
    nrf9151-firmware\build\app\zephyr\.config
    # Zephyr
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    # CONFIG_NET_L2_ETHERNET is not set
    # CONFIG_REGULATOR is not set
    CONFIG_MAIN_STACK_SIZE=8152
    # CONFIG_FPU is not set
    CONFIG_SHELL_STACK_SIZE=2048
    CONFIG_SERIAL=y
    CONFIG_SPI=y
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MEMC is not set
    # CONFIG_MODEM is not set
    CONFIG_COAP_INIT_ACK_TIMEOUT_MS=4000
    # CONFIG_NET_IPV6 is not set
    CONFIG_HW_STACK_PROTECTION=y
    CONFIG_BOARD_NRF9151DK=y
    # CONFIG_I2C is not set
    CONFIG_NUM_IRQS=65
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_MP_MAX_NUM_CPUS=1
    CONFIG_SOC_RESET_HOOK=y
    CONFIG_CLOCK_CONTROL=y
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_ROM_START_OFFSET=0
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_XIP=y
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    # CONFIG_COUNTER is not set
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_CPU_HAS_ARM_MPU=y
    # CONFIG_SHARED_INTERRUPTS is not set
    # CONFIG_PM_DEVICE is not set
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_USE_DT_CODE_PARTITION=y
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    # CONFIG_ZERO_LATENCY_IRQS is not set
    CONFIG_NUM_PREEMPT_PRIORITIES=10
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_GEN_ISR_TABLES=y
    CONFIG_INIT_STACKS=y
    CONFIG_TIMESLICE_SIZE=20
    CONFIG_FLASH_LOAD_OFFSET=0x50000
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    # CONFIG_BUILD_OUTPUT_S19 is not set
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_FLASH_FILL_BUFFER_SIZE=32
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    CONFIG_FLASH=y
    CONFIG_NET_TCP_CHECKSUM=y
    CONFIG_NET_UDP_CHECKSUM=y
    # CONFIG_POWER_DOMAIN is not set
    # CONFIG_MFD is not set
    CONFIG_GPIO=y
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    # CONFIG_NET_L2_IEEE802154 is not set
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    # CONFIG_CACHE is not set
    CONFIG_LOG=y
    CONFIG_CMSIS_CORE_HAS_SYSTEM_CORE_CLOCK=y
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_ROMSTART_RELOCATION_ROM is not set
    CONFIG_DCACHE_LINE_SIZE=32
    # CONFIG_RESET is not set
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_LOG_DOMAIN_NAME=""
    CONFIG_SHELL_BACKEND_SERIAL=y
    CONFIG_ASSERT=y
    CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048
    # CONFIG_DEVICE_DEPS is not set
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
    # CONFIG_SYSCON is not set
    CONFIG_CONSOLE=y
    # CONFIG_WINSTREAM is not set
    CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_REBOOT=y
    CONFIG_FLASH_INIT_PRIORITY=50
    CONFIG_GEN_IRQ_START_VECTOR=0
    CONFIG_SRAM_OFFSET=0
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    # CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set
    CONFIG_BOOTLOADER_MCUBOOT=y
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_KERNEL_MEM_POOL=y
    CONFIG_MULTITHREADING=y
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    # CONFIG_WATCHDOG is not set
    CONFIG_ICACHE_LINE_SIZE=32
    # Devicetree Info
    CONFIG_DT_HAS_ARDUINO_UNO_ADC_ENABLED=y
    CONFIG_DT_HAS_ARDUINO_HEADER_R3_ENABLED=y
    CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
    CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_FIXED_SUBPARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
    CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF91_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF91X_REGULATORS_ENABLED=y
    CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_PSA_CRYPTO_RNG_ENABLED=y
    # end of Devicetree Info
    # Modules
    # CONFIG_BUILD_ONLY_NO_BLOBS is not set
    # Available modules.
    # proxiCure-firmware (D:/ProxiCure/Firmware/proxiCure-firmware)
    # Drivers
    # CONFIG_BLINK is not set
    # end of Drivers
    # Custom libraries
    # CONFIG_CUSTOM is not set
    # end of Custom libraries
    CONFIG_ZEPHYR_PROXICURE_FIRMWARE_MODULE=y
    # end of proxiCure-firmware (D:/ProxiCure/Firmware/proxiCure-firmware)
    # nrf (D:/ProxiCure/Firmware/nrf)
    CONFIG_LOG_BUFFER_SIZE=1024
    CONFIG_MBEDTLS_MPI_MAX_SIZE=384
    CONFIG_MBEDTLS_PSA_KEY_SLOT_COUNT=32
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    # CONFIG_ZMS is not set
    CONFIG_NVS=y
    # CONFIG_NVS_LOOKUP_CACHE is not set
    CONFIG_NET_PKT_RX_COUNT=4
    CONFIG_NET_PKT_TX_COUNT=4
    # CONFIG_NET_PKT_TXTIME is not set
    # CONFIG_NET_PKT_TIMESTAMP is not set
    CONFIG_NET_RX_STACK_SIZE=1500
    CONFIG_NET_TX_STACK_SIZE=1200
    CONFIG_MBEDTLS=y
    # CONFIG_MBEDTLS_TLS_VERSION_1_2 is not set
    # CONFIG_MBEDTLS_MAC_SHA256_ENABLED is not set
    # CONFIG_MBEDTLS_CTR_DRBG_ENABLED is not set
    # CONFIG_MBEDTLS_MD_C is not set
    # CONFIG_MBEDTLS_TLS_LIBRARY is not set
    # CONFIG_MBEDTLS_X509_LIBRARY is not set
    # CONFIG_MBEDTLS_ENABLE_HEAP is not set
    # CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C is not set
    # CONFIG_MBEDTLS_LEGACY_CRYPTO_C is not set
    CONFIG_TFM_MCUBOOT_IMAGE_NUMBER=1
    CONFIG_TFM_CRYPTO_RNG_MODULE_ENABLED=y
    CONFIG_TFM_PARTITION_CRYPTO=y
    CONFIG_TFM_PARTITION_PLATFORM=y
    # Nordic nRF Connect
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_NRF_SECURITY_ENABLER=y
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    CONFIG_UPDATEABLE_IMAGE_NUMBER=1
    # Subsystems
    # Bootloader
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_IS_SECURE_BOOTLOADER is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATION_STRUCT_HAS_HASH=y
    CONFIG_SB_VALIDATION_STRUCT_HAS_PUBLIC_KEY=y
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # CONFIG_SECURE_BOOT_STORAGE is not set
    # CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
    # CONFIG_NCS_MCUBOOT_BOOTLOADER_SIGN_MERGED_BINARY is not set
    # CONFIG_NCS_MCUBOOT_MANIFEST_UPDATES is not set
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # BLE over nRF RPC
    CONFIG_HEAP_MEM_POOL_SIZE=30000
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    CONFIG_DFU_TARGET=y
    CONFIG_DFU_TARGET_MCUBOOT=y
    CONFIG_DFU_TARGET_STREAM=y
    # CONFIG_DFU_TARGET_MCUBOOT_SAVE_PROGRESS is not set
    # CONFIG_DFU_TARGET_STREAM_SAVE_PROGRESS is not set
    # CONFIG_DFU_TARGET_STREAM_SYNCHRONOUS is not set
    CONFIG_DFU_TARGET_MODEM_DELTA=y
    CONFIG_DFU_TARGET_MODEM_TIMEOUT=60
    # CONFIG_DFU_TARGET_CUSTOM is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_OFF is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_ERR is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_WRN is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_INF is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_DBG is not set
    CONFIG_DFU_TARGET_LOG_LEVEL_DEFAULT=y
    CONFIG_DFU_TARGET_LOG_LEVEL=3
    # end of DFU
    # CONFIG_ESB is not set
    # CONFIG_EMDS is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # CONFIG_NRF_CLOUD is not set
    # CONFIG_REST_CLIENT is not set
    CONFIG_DOWNLOADER=y
    # Thread and stack buffers
    CONFIG_DOWNLOADER_STACK_SIZE=4096
    CONFIG_DOWNLOADER_MAX_HOSTNAME_SIZE=256
    CONFIG_DOWNLOADER_MAX_FILENAME_SIZE=255
    CONFIG_DOWNLOADER_MAX_REDIRECTS=10
    # CONFIG_DOWNLOADER_SHELL is not set
    CONFIG_DOWNLOADER_TRANSPORT_PARAMS_SIZE=256
    CONFIG_DOWNLOADER_TRANSPORT_HTTP=y
    # CONFIG_DOWNLOADER_TRANSPORT_COAP is not set
    # CONFIG_DOWNLOADER_LOG_LEVEL_OFF is not set
    # CONFIG_DOWNLOADER_LOG_LEVEL_ERR is not set
    # CONFIG_DOWNLOADER_LOG_LEVEL_WRN is not set
    # CONFIG_DOWNLOADER_LOG_LEVEL_INF is not set
    # CONFIG_DOWNLOADER_LOG_LEVEL_DBG is not set
    CONFIG_DOWNLOADER_LOG_LEVEL_DEFAULT=y
    CONFIG_DOWNLOADER_LOG_LEVEL=3
    CONFIG_FOTA_DOWNLOAD=y
    CONFIG_FOTA_SOCKET_RETRIES=2
    CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y
    CONFIG_FOTA_CLIENT_AUTOSCHEDULE_UPDATE=y
    CONFIG_FOTA_DOWNLOAD_MCUBOOT_FLASH_BUF_SZ=512
    CONFIG_FOTA_DOWNLOAD_BUF_SZ=2048
    # CONFIG_FOTA_DOWNLOAD_NATIVE_TLS is not set
    CONFIG_FOTA_DOWNLOAD_FILE_NAME_LENGTH=128
    CONFIG_FOTA_DOWNLOAD_HOST_NAME_LENGTH=128
    CONFIG_FOTA_DOWNLOAD_RESOURCE_LOCATOR_LENGTH=512
    CONFIG_FOTA_DOWNLOAD_SEC_TAG_LIST_SIZE_MAX=5
    # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_OFF is not set
    # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_ERR is not set
    # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_WRN is not set
    # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_INF is not set
    # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_DBG is not set
    CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_DEFAULT=y
    CONFIG_FOTA_DOWNLOAD_LOG_LEVEL=3
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AWS_FOTA is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # CONFIG_ZZHC is not set
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_COAP_UTILS is not set
    CONFIG_LWM2M_CLIENT_UTILS_DEVICE_OBJ_SUPPORT=y
    CONFIG_LWM2M_CLIENT_UTILS_SECURITY_OBJ_SUPPORT=y
    CONFIG_LWM2M_CLIENT_UTILS_SERVER="coaps://18.208.250.9:5684"
    CONFIG_LWM2M_CLIENT_UTILS_SERVER_TLS_TAG=35724861
    CONFIG_LWM2M_CLIENT_UTILS_BOOTSTRAP_TLS_TAG=35724862
    CONFIG_LWM2M_CLIENT_UTILS_CONN_MON_OBJ_SUPPORT=y
    CONFIG_LWM2M_CONN_MON_BEARER_MAX=2
    CONFIG_LWM2M_CONN_HOLD_TIME_RSRP=60
    # CONFIG_LWM2M_CLIENT_UTILS_LOCATION_OBJ_SUPPORT is not set
    CONFIG_LWM2M_CLIENT_UTILS_FIRMWARE_UPDATE_OBJ_SUPPORT=y
    CONFIG_LWM2M_CLIENT_UTILS_DOWNLOADER_SEC_TAG=16842753
    CONFIG_LWM2M_CLIENT_UTILS_FIRMWARE_UPDATE_THREAD_STACK_SIZE=2048
    # CONFIG_LWM2M_CLIENT_UTILS_ADV_FIRMWARE_UPDATE_OBJ_SUPPORT is not set
    # CONFIG_LWM2M_CLIENT_UTILS_GROUND_FIX_OBJ_SUPPORT is not set
    # CONFIG_LWM2M_CLIENT_UTILS_GNSS_ASSIST_OBJ_SUPPORT is not set
    # CONFIG_LWM2M_CLIENT_UTILS_CELL_CONN_OBJ_SUPPORT is not set
    CONFIG_LWM2M_CLIENT_UTILS_RAI=y
    # CONFIG_LWM2M_CLIENT_UTILS_LTE_CONNEVAL is not set
    # CONFIG_LWM2M_CLIENT_UTILS_DTLS_CID is not set
    # CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_OFF is not set
    # CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_ERR is not set
    # CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_WRN is not set
    # CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_INF is not set
    # CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_DBG is not set
    CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_DEFAULT=y
    CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL=3
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # CONFIG_WIFI_PROV_CORE_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_PROV_CORE_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_PROV_CORE_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_PROV_CORE_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_PROV_CORE_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_PROV_CORE_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_PROV_CORE_LOG_LEVEL=3
    # end of Application protocols
    # CONFIG_OPENTHREAD_RPC is not set
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # CONFIG_NFC_RPC is not set
    # end of NFC
    CONFIG_APP_EVENT_MANAGER=y
    CONFIG_APP_EVENT_MANAGER_REBOOT_ON_EVENT_ALLOC_FAIL=y
    CONFIG_APP_EVENT_MANAGER_SHOW_EVENTS=y
    # CONFIG_APP_EVENT_MANAGER_SHOW_EVENT_HANDLERS is not set
    # CONFIG_APP_EVENT_MANAGER_TRACE_EVENT_DATA is not set
    CONFIG_APP_EVENT_MANAGER_SHELL=y
    # CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_OFF is not set
    # CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_ERR is not set
    # CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_WRN is not set
    # CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_INF is not set
    # CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_DBG is not set
    CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_DEFAULT=y
    CONFIG_APP_EVENT_MANAGER_LOG_LEVEL=3
    # CONFIG_APP_EVENT_MANAGER_USE_DEPRECATED_LOG_FUN is not set
    CONFIG_APP_EVENT_MANAGER_LOG_EVENT_TYPE=y
    CONFIG_APP_EVENT_MANAGER_MAX_EVENT_CNT=32
    # CONFIG_APP_EVENT_MANAGER_PROVIDE_EVENT_SIZE is not set
    # CONFIG_APP_EVENT_MANAGER_POSTINIT_HOOK is not set
    # CONFIG_APP_EVENT_MANAGER_SUBMIT_HOOKS is not set
    # CONFIG_APP_EVENT_MANAGER_PREPROCESS_HOOKS is not set
    # CONFIG_APP_EVENT_MANAGER_POSTPROCESS_HOOKS is not set
    # CONFIG_APP_EVENT_MANAGER_PROFILER_TRACER is not set
    # CONFIG_NRF_PROFILER is not set
    CONFIG_FW_INFO=y
    # CONFIG_FW_INFO_API is not set
    CONFIG_FW_INFO_OFFSET=0x200
    CONFIG_FW_INFO_FIRMWARE_VERSION=1
    CONFIG_FW_INFO_MAGIC_COMMON=0x281ee6de
    CONFIG_FW_INFO_MAGIC_FIRMWARE_INFO=0x8fcebb4c
    CONFIG_FW_INFO_MAGIC_EXT_API=0xb845acea
    CONFIG_FW_INFO_HARDWARE_ID=91
    CONFIG_FW_INFO_VERSION=2
    CONFIG_FW_INFO_CRYPTO_ID=0
    CONFIG_FW_INFO_MAGIC_COMPATIBILITY_ID=0
    CONFIG_FW_INFO_MAGIC_LEN=12
    CONFIG_FW_INFO_VALID_VAL=0x9102FFFF
    CONFIG_EXT_API_SUPPORTED=y
    CONFIG_EXT_API_PROVIDE_EXT_API_UNUSED=y
    # CONFIG_EXT_API_PROVIDE_EXT_API_OPTIONAL is not set
    # CONFIG_EXT_API_PROVIDE_EXT_API_REQUIRED is not set
    # CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED is not set
    # CONFIG_EXT_API_PROVIDE_EXT_API_ATLEAST_OPTIONAL is not set
    # Debug
    # CONFIG_NRF_CPU_LOAD is not set
    # CONFIG_ETB_TRACE is not set
    # CONFIG_PPI_TRACE is not set
    CONFIG_PPI_TRACE_PIN_CNT=8
    # end of Debug
    # Multiprotocol service layer (MPSL)
    # CONFIG_MPSL_FEM_ONLY is not set
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    CONFIG_MPSL_HFCLK_LATENCY=1400
    CONFIG_MPSL_INIT_PRIORITY=40
    CONFIG_MPSL_FORCE_RRAM_ON_ALL_THE_TIME=y
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=3
    # end of Multiprotocol service layer (MPSL)
    # Partition Manager
    CONFIG_PARTITION_MANAGER_ENABLED=y
    CONFIG_FLASH_MAP_CUSTOM=y
    CONFIG_SRAM_SIZE=128
    CONFIG_SRAM_BASE_ADDRESS=0x20020000
    # Zephyr subsystem configurations
    CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x2000
    CONFIG_PM_PARTITION_ALIGN_SETTINGS_STORAGE=0x8000
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_PATH=""
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
    # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x40000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # Full Modem Firmware Update Management(FMFU)
    # end of Full Modem Firmware Update Management(FMFU)
    # Additional MCUmgr configuration
    # Additional MCUmgr group configuration
    # Additional MCUmgr OS group management functionality
    # end of Additional MCUmgr OS group management functionality
    # Additional MCUmgr image management group functionality
    # end of Additional MCUmgr image management group functionality
    # end of Additional MCUmgr group configuration
    # end of Additional MCUmgr configuration
    # CONFIG_CAF is not set
    # CONFIG_DM_MODULE is not set
    # nRF Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    CONFIG_NRF_SECURITY=y
    # Nordic-added meta types
    CONFIG_PSA_HAS_CIPHER_SUPPORT=y
    CONFIG_PSA_HAS_KEY_SUPPORT=y
    CONFIG_PSA_HAS_MAC_SUPPORT=y
    # Nordic added alg types
    # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # CONFIG_PSA_WANT_ALG_HSS is not set
    # CONFIG_PSA_WANT_ALG_LMS is not set
    # CONFIG_PSA_WANT_ALG_ML_DSA is not set
    # CONFIG_PSA_WANT_ALG_XMSS is not set
    # CONFIG_PSA_WANT_ALG_XMSS_MT is not set
    # CONFIG_PSA_WANT_ALG_ML_KEM is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
    # CONFIG_PSA_WANT_ALG_SHA_256_192 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
    # CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    CONFIG_PSA_WANT_ALG_ECB_NO_PADDING=y
    # CONFIG_PSA_WANT_ALG_CHACHA20 is not set
    # CONFIG_PSA_WANT_ALG_XCHACHA20_POLY1305 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE128_256 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_192 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_256 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    # CONFIG_PSA_WANT_ALG_AES_KW is not set
    # CONFIG_PSA_WANT_ALG_AES_KWP is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE_H2E is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE is not set
    # Nordic added ECC curve types
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    # Nordic addded RNG configuration
    CONFIG_PSA_WANT_GENERATE_RANDOM=y
    # Nordic added key types
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_WPA3_SAE_PT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_XCHACHA20 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HSS_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_LMS_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_XMSS_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_XMSS_MT_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_44 is not set
    # CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_65 is not set
    # CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_87 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_512 is not set
    # CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_768 is not set
    # CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_1024 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_PUBLIC_KEY is not set
    CONFIG_MBEDTLS_CFG_FILE="nrf-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG=y
    CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG_FILE="nrf-psa-crypto-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE="nrf-psa-crypto-user-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    CONFIG_PSA_CORE_OBERON=y
    # PSA Driver Support
    CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS=y
    CONFIG_PSA_DEFAULT_OFF=y
    CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT=y
    CONFIG_PSA_CRYPTO_DRIVER_OBERON=y
    # CONFIG_PSA_CRYPTO_DRIVER_CC3XX is not set
    # Choose DRBG algorithm
    # CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
    CONFIG_PSA_WANT_ALG_HMAC_DRBG=y
    CONFIG_PSA_USE_HMAC_DRBG_DRIVER=y
    # end of Choose DRBG algorithm
    # CryptoCell PSA Driver Configuration
    CONFIG_PSA_USE_CC3XX_HMAC_DRBG_DRIVER=y
    # end of CryptoCell PSA Driver Configuration
    # CRACEN PSA Driver Configuration
    # end of CRACEN PSA Driver Configuration
    # AES key size configuration
    CONFIG_PSA_WANT_AES_KEY_SIZE_128=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_192=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_256=y
    # end of AES key size configuration
    # RSA key size configuration
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_1024 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_1536 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_2048 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_3072 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_4096 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_6144 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_8192 is not set
    CONFIG_PSA_MAX_RSA_KEY_BITS=0
    # end of RSA key size configuration
    CONFIG_PSA_ACCEL_GENERATE_RANDOM=y
    CONFIG_PSA_NEED_CC3XX_HMAC_DRBG_DRIVER=y
    # CONFIG_CRACEN_LOG_LEVEL_OFF is not set
    # CONFIG_CRACEN_LOG_LEVEL_ERR is not set
    # CONFIG_CRACEN_LOG_LEVEL_WRN is not set
    # CONFIG_CRACEN_LOG_LEVEL_INF is not set
    # CONFIG_CRACEN_LOG_LEVEL_DBG is not set
    CONFIG_CRACEN_LOG_LEVEL_DEFAULT=y
    CONFIG_CRACEN_LOG_LEVEL=3
    CONFIG_PSA_NEED_OBERON_CBC_NO_PADDING_AES=y
    CONFIG_PSA_NEED_OBERON_ECB_NO_PADDING_AES=y
    CONFIG_PSA_NEED_OBERON_CIPHER_DRIVER=y
    CONFIG_PSA_NEED_OBERON_CMAC=y
    CONFIG_PSA_NEED_OBERON_MAC_DRIVER=y
    # PSA API support
    CONFIG_MBEDTLS_USE_PSA_CRYPTO=y
    # CONFIG_MBEDTLS_PSA_STATIC_KEY_SLOTS is not set
    CONFIG_PSA_CRYPTO_SYS_INIT=y
    # end of PSA API support
    CONFIG_MBEDTLS_PLATFORM_MEMORY=y
    CONFIG_MBEDTLS_PLATFORM_C=y
    CONFIG_MBEDTLS_MEMORY_C=y
    CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C=y
    CONFIG_MBEDTLS_THREADING_C=y
    CONFIG_MBEDTLS_BASE64_C=y
    CONFIG_MBEDTLS_OID_C=y
    CONFIG_MBEDTLS_ASN1_WRITE_C=y
    CONFIG_MBEDTLS_ASN1_PARSE_C=y
    CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT=y
    CONFIG_MBEDTLS_AES_SETKEY_ENC_ALT=y
    CONFIG_MBEDTLS_AES_SETKEY_DEC_ALT=y
    CONFIG_MBEDTLS_AES_ENCRYPT_ALT=y
    CONFIG_MBEDTLS_AES_DECRYPT_ALT=y
    CONFIG_MBEDTLS_CHACHA20_ALT=y
    CONFIG_MBEDTLS_POLY1305_ALT=y
    CONFIG_MBEDTLS_ECDH_GEN_PUBLIC_ALT=y
    CONFIG_MBEDTLS_ECDH_COMPUTE_SHARED_ALT=y
    CONFIG_MBEDTLS_ECDSA_GENKEY_ALT=y
    CONFIG_MBEDTLS_ECDSA_SIGN_ALT=y
    CONFIG_MBEDTLS_ECDSA_VERIFY_ALT=y
    CONFIG_MBEDTLS_ECJPAKE_ALT=y
    CONFIG_MBEDTLS_SHA1_ALT=y
    CONFIG_MBEDTLS_SHA224_ALT=y
    CONFIG_MBEDTLS_SHA256_ALT=y
    CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256=y
    CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES=1
    CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY=y
    # CONFIG_NRF_SECURITY_ADVANCED is not set
    CONFIG_OBERON_ONLY_PSA_ENABLED=y
    CONFIG_OBERON_ONLY_ENABLED=y
    # Legacy mbed TLS crypto APIs
    CONFIG_MBEDTLS_MPI_WINDOW_SIZE=6
    # CONFIG_MBEDTLS_CIPHER_C is not set
    # CONFIG_MBEDTLS_PK_C is not set
    # CONFIG_MBEDTLS_PEM_PARSE_C is not set
    # CONFIG_MBEDTLS_PEM_WRITE_C is not set
    # end of Legacy mbed TLS crypto APIs
    # Zephyr legacy configurations
    # CONFIG_MBEDTLS_KEY_EXCHANGE_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_KEY_EXCHANGE_SOME_PSK_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_CIPHER_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_MAC_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_MAC_MD5_ENABLED is not set
    # CONFIG_MBEDTLS_HMAC_DRBG_ENABLED is not set
    # CONFIG_MBEDTLS_CIPHER is not set
    # CONFIG_MBEDTLS_MD is not set
    # CONFIG_MBEDTLS_ENTROPY_ENABLED is not set
    # CONFIG_MBEDTLS_GENPRIME_ENABLED is not set
    # end of Zephyr legacy configurations
    CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y
    # end of nRF Security
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEST is not set
    # Log levels
    # end of Log levels
    # end of Audio Modules
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEMPLATE is not set
    # CONFIG_UART_ASYNC_ADAPTER is not set
    # Logging over RPC
    # CONFIG_LOG_FORWARDER_RPC is not set
    # CONFIG_LOG_BACKEND_RPC is not set
    CONFIG_LOG_BACKED_RPC_CRASH_INFO_FILENAME_SIZE=255
    # end of Logging over RPC
    # CONFIG_NRF_COMPRESS is not set
    # MCUboot IDs (informative only, do not change)
    CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=0
    CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_EXTRA_1_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_EXTRA_2_IMAGE_NUMBER=-1
    # end of MCUboot IDs (informative only, do not change)
    # end of Subsystems
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=3
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
    CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
    CONFIG_WPAS_READY_TIMEOUT_MS=10000
    # Libraries
    # CONFIG_APP_JWT is not set
    # Binary libraries
    # end of Binary libraries
    CONFIG_NRF_MODEM_LIB=y
    # Memory configuration
    CONFIG_NRF_MODEM_LIB_HEAP_SIZE=1024
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_NRF9X_SOCKETS_GETADDRINFO=192
    CONFIG_NRF_MODEM_LIB_SHMEM_CTRL_SIZE=0x4e8
    CONFIG_NRF_MODEM_LIB_SHMEM_TX_SIZE=8320
    CONFIG_NRF_MODEM_LIB_SHMEM_RX_SIZE=8192
    CONFIG_NRF_MODEM_LIB_SHMEM_TRACE_SIZE=0
    CONFIG_NRF_MODEM_LIB_SENDMSG_BUF_SIZE=128
    # CONFIG_NRF_MODEM_LIB_MEM_DIAG is not set
    # end of Memory configuration
    # CONFIG_NRF_MODEM_LIB_TRACE is not set
    CONFIG_NRF_MODEM_LIB_ON_FAULT_DO_NOTHING=y
    # CONFIG_NRF_MODEM_LIB_ON_FAULT_RESET_MODEM is not set
    # CONFIG_NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC is not set
    CONFIG_NRF_MODEM_LIB_CFUN_HOOKS=y
    # CONFIG_NRF_MODEM_LIB_FAULT_STRERROR is not set
    # Shell
    # CONFIG_NRF_MODEM_LIB_SHELL_TRACE is not set
    # end of Shell
    CONFIG_NRF_MODEM_LIB_IPC_IRQ_PRIO=1
    # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_INF is not set
    # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DBG is not set
    CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_MODEM_LIB_LOG_LEVEL=3
    # CONFIG_NRF_MODEM_LIB_LOG_FW_VERSION_UUID is not set
    CONFIG_AT_MONITOR=y
    CONFIG_AT_MONITOR_HEAP_SIZE=512
    # CONFIG_AT_MONITOR_LOG_LEVEL_OFF is not set
    # CONFIG_AT_MONITOR_LOG_LEVEL_ERR is not set
    # CONFIG_AT_MONITOR_LOG_LEVEL_WRN is not set
    # CONFIG_AT_MONITOR_LOG_LEVEL_INF is not set
    # CONFIG_AT_MONITOR_LOG_LEVEL_DBG is not set
    CONFIG_AT_MONITOR_LOG_LEVEL_DEFAULT=y
    CONFIG_AT_MONITOR_LOG_LEVEL=3
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_LTE_LINK_CONTROL=32
    CONFIG_LTE_LC_FUNCTIONAL_MODE_MODULE=y
    CONFIG_LTE_LC_NETWORK_REGISTRATION_MODULE=y
    CONFIG_LTE_LC_CONNECTION_STATUS_MODULE=y
    CONFIG_LTE_LC_MODEM_EVENTS_MODULE=y
    CONFIG_LTE_LC_SYSTEM_MODE_MODULE=y
    # CONFIG_LTE_LC_CONN_EVAL_MODULE is not set
    CONFIG_LTE_LC_EDRX_MODULE=y
    CONFIG_LTE_LC_NEIGHBOR_CELL_MEAS_MODULE=y
    # CONFIG_LTE_LC_PERIODIC_SEARCH_MODULE is not set
    CONFIG_LTE_LC_PSM_MODULE=y
    # CONFIG_LTE_LC_RAI_MODULE is not set
    # CONFIG_LTE_LC_MODEM_SLEEP_MODULE is not set
    CONFIG_LTE_LC_TAU_PRE_WARNING_MODULE=y
    # CONFIG_LTE_LC_ENV_EVAL_MODULE is not set
    # CONFIG_LTE_LC_PDN_MODULE is not set
    # CONFIG_LTE_LC_CELLULAR_PROFILE_MODULE is not set
    CONFIG_LTE_LC_DNS_FALLBACK_MODULE=y
    CONFIG_LTE_LC_DNS_FALLBACK_ADDRESS="1.1.1.1"
    CONFIG_LTE_SHELL=y
    # CONFIG_LTE_LOCK_BANDS is not set
    CONFIG_LTE_PLMN_SELECTION_OPTIMIZATION=y
    # CONFIG_LTE_LOCK_PLMN is not set
    # CONFIG_LTE_UNLOCK_PLMN is not set
    CONFIG_LTE_PSM_REQ=y
    CONFIG_LTE_PSM_REQ_FORMAT_STRING=y
    # CONFIG_LTE_PSM_REQ_FORMAT_SECONDS is not set
    CONFIG_LTE_PSM_REQ_RPTAU="00101100"
    CONFIG_LTE_PSM_REQ_RAT="00001111"
    CONFIG_LTE_PSM_REQ_RPTAU_SECONDS=1800
    CONFIG_LTE_PSM_REQ_RAT_SECONDS=60
    # CONFIG_LTE_PROPRIETARY_PSM_REQ is not set
    CONFIG_LTE_EDRX_REQ=y
    CONFIG_LTE_EDRX_REQ_VALUE_LTE_M="0000"
    CONFIG_LTE_EDRX_REQ_VALUE_NBIOT="0000"
    CONFIG_LTE_EDRX_REQ_VALUE_NTN_NBIOT="1001"
    CONFIG_LTE_PTW_VALUE_LTE_M="0000"
    CONFIG_LTE_PTW_VALUE_NBIOT="0000"
    CONFIG_LTE_PTW_VALUE_NTN_NBIOT=""
    # CONFIG_LTE_NETWORK_MODE_DEFAULT is not set
    # CONFIG_LTE_NETWORK_MODE_LTE_M is not set
    CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y
    # CONFIG_LTE_NETWORK_MODE_NBIOT is not set
    # CONFIG_LTE_NETWORK_MODE_NBIOT_GPS is not set
    # CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT is not set
    # CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT_GPS is not set
    # CONFIG_LTE_NETWORK_MODE_NTN_NBIOT is not set
    CONFIG_LTE_MODE_PREFERENCE_AUTO=y
    CONFIG_LTE_MODE_PREFERENCE_VALUE=0
    CONFIG_LTE_NETWORK_TIMEOUT=600
    CONFIG_LTE_LC_TAU_PRE_WARNING_NOTIFICATIONS=y
    CONFIG_LTE_LC_TAU_PRE_WARNING_TIME_MS=5000
    CONFIG_LTE_LC_TAU_PRE_WARNING_THRESHOLD_MS=1200000
    CONFIG_LTE_NEIGHBOR_CELLS_MAX=10
    CONFIG_LTE_LC_ENV_EVAL_MAX_PLMN_COUNT=3
    # CONFIG_LTE_LC_TRACE is not set
    CONFIG_LTE_LC_WORKQUEUE_STACK_SIZE=1024
    # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_LTE_LINK_CONTROL_LOG_LEVEL=3
    # CONFIG_NTN is not set
    CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x8000
    CONFIG_FPROTECT_BLOCK_SIZE=0x8000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_AT_HOST_LIBRARY is not set
    # CONFIG_DK_LIBRARY is not set
    CONFIG_AT_PARSER=y
    # CONFIG_MODEM_BATTERY is not set
    CONFIG_MODEM_INFO=y
    CONFIG_MODEM_INFO_MAX_AT_PARAMS_RSP=10
    CONFIG_MODEM_INFO_BUFFER_SIZE=128
    CONFIG_MODEM_INFO_ADD_NETWORK=y
    # CONFIG_MODEM_INFO_ADD_DATE_TIME is not set
    CONFIG_MODEM_INFO_ADD_SIM=y
    CONFIG_MODEM_INFO_ADD_SIM_ICCID=y
    CONFIG_MODEM_INFO_ADD_SIM_IMSI=y
    CONFIG_MODEM_INFO_ADD_DEVICE=y
    # CONFIG_PDN is not set
    # CONFIG_RESET_ON_FATAL_ERROR is not set
    # CONFIG_SMS is not set
    # CONFIG_GCF_SMS is not set
    CONFIG_MODEM_KEY_MGMT=y
    # CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_OFF is not set
    # CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_ERR is not set
    # CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_WRN is not set
    # CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_INF is not set
    # CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_DBG is not set
    CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_DEFAULT=y
    CONFIG_MODEM_KEY_MGMT_LOG_LEVEL=3
    # CONFIG_SUPL_CLIENT_LIB is not set
    CONFIG_DATE_TIME=y
    CONFIG_DATE_TIME_AUTO_UPDATE=y
    CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=86400
    CONFIG_DATE_TIME_TOO_OLD_SECONDS=3600
    CONFIG_DATE_TIME_RETRY_COUNT=0
    CONFIG_DATE_TIME_RETRY_INTERVAL_SECONDS=60
    CONFIG_DATE_TIME_MODEM=y
    CONFIG_DATE_TIME_NTP=y
    CONFIG_DATE_TIME_THREAD_STACK_SIZE=1280
    CONFIG_DATE_TIME_NTP_QUERY_TIME_SECONDS=5
    # CONFIG_DATE_TIME_LOG_LEVEL_OFF is not set
    # CONFIG_DATE_TIME_LOG_LEVEL_ERR is not set
    # CONFIG_DATE_TIME_LOG_LEVEL_WRN is not set
    # CONFIG_DATE_TIME_LOG_LEVEL_INF is not set
    # CONFIG_DATE_TIME_LOG_LEVEL_DBG is not set
    CONFIG_DATE_TIME_LOG_LEVEL_DEFAULT=y
    CONFIG_DATE_TIME_LOG_LEVEL=3
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
    # CONFIG_MODEM_JWT is not set
    # CONFIG_MODEM_ATTEST_TOKEN is not set
    # CONFIG_LOCATION is not set
    # CONFIG_AT_SHELL is not set
    CONFIG_MODEM_ANTENNA=y
    CONFIG_MODEM_ANTENNA_GNSS_ONBOARD=y
    # CONFIG_MODEM_ANTENNA_GNSS_EXTERNAL is not set
    CONFIG_MODEM_ANTENNA_AT_MAGPIO=""
    CONFIG_MODEM_ANTENNA_AT_COEX0="AT%XCOEX0=1,1,1565,1586"
    CONFIG_MODEM_ANTENNA_AT_MIPIRFFEDEV=""
    CONFIG_MODEM_ANTENNA_AT_MIPIRFFECTRL_INIT=""
    CONFIG_MODEM_ANTENNA_AT_MIPIRFFECTRL_ON=""
    CONFIG_MODEM_ANTENNA_AT_MIPIRFFECTRL_OFF=""
    CONFIG_MODEM_ANTENNA_AT_MIPIRFFECTRL_PWROFF=""
    # CONFIG_MODEM_ANTENNA_LOG_LEVEL_OFF is not set
    # CONFIG_MODEM_ANTENNA_LOG_LEVEL_ERR is not set
    # CONFIG_MODEM_ANTENNA_LOG_LEVEL_WRN is not set
    # CONFIG_MODEM_ANTENNA_LOG_LEVEL_INF is not set
    # CONFIG_MODEM_ANTENNA_LOG_LEVEL_DBG is not set
    CONFIG_MODEM_ANTENNA_LOG_LEVEL_DEFAULT=y
    CONFIG_MODEM_ANTENNA_LOG_LEVEL=3
    # CONFIG_QOS is not set
    # CONFIG_IDENTITY_KEY_TFM is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # CONFIG_SAMPLE_RATE_CONVERTER is not set
    CONFIG_NCS_BOOT_BANNER=y
    CONFIG_NCS_APPLICATION_BOOT_BANNER_STRING="My Application"
    CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
    CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
    # CONFIG_UICC_LWM2M is not set
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    # CONFIG_FLASH_RPC is not set
    # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_RPC is not set
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_ETH_RTT is not set
    CONFIG_SENSOR=y
    # CONFIG_SENSOR_SIM is not set
    # CONFIG_SENSOR_STUB is not set
    # CONFIG_PMW3360 is not set
    # CONFIG_PAW3212 is not set
    # CONFIG_BME68X_IAQ is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # CONFIG_MOCK_NRF_RPC is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (D:/ProxiCure/Firmware/nrf)
    # hostap (D:/ProxiCure/Firmware/modules/lib/hostap)
    # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
    CONFIG_ZEPHYR_HOSTAP_MODULE=y
    # end of hostap (D:/ProxiCure/Firmware/modules/lib/hostap)
    # mcuboot (D:/ProxiCure/Firmware/bootloader/mcuboot)
    # MCUboot
    # CONFIG_MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION is not set
    CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    # CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
    # CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (D:/ProxiCure/Firmware/bootloader/mcuboot)
    # mbedtls (D:/ProxiCure/Firmware/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    CONFIG_PSA_CRYPTO_CLIENT=y
    # CONFIG_PSA_CRYPTO_ENABLE_ALL is not set
    CONFIG_PSA_WANT_ALG_CBC_NO_PADDING=y
    # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
    # CONFIG_PSA_WANT_ALG_CCM is not set
    # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    CONFIG_PSA_WANT_ALG_CMAC=y
    # CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
    # CONFIG_PSA_WANT_ALG_CTR is not set
    # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_ECDH is not set
    # CONFIG_PSA_WANT_ALG_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_JPAKE is not set
    # CONFIG_PSA_WANT_ALG_GCM is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    # CONFIG_PSA_WANT_ALG_HMAC is not set
    # CONFIG_PSA_WANT_ALG_MD5 is not set
    # CONFIG_PSA_WANT_ALG_PBKDF2_AES_CMAC_PRF_128 is not set
    # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS is not set
    # CONFIG_PSA_WANT_ALG_SHA_1 is not set
    # CONFIG_PSA_WANT_ALG_SHA_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_512 is not set
    # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
    CONFIG_PSA_WANT_KEY_TYPE_AES=y
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_DERIVE is not set
    CONFIG_PSA_CRYPTO=y
    CONFIG_PSA_CRYPTO_PROVIDER_TFM=y
    # CONFIG_MBEDTLS_LIBRARY is not set
    CONFIG_DISABLE_MBEDTLS_BUILTIN=y
    # CONFIG_CUSTOM_MBEDTLS_CFG_FILE is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_OFF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_ERR is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_WRN is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_INF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_DBG is not set
    CONFIG_MBEDTLS_LOG_LEVEL_DEFAULT=y
    CONFIG_MBEDTLS_LOG_LEVEL=3
    # CONFIG_MBEDTLS_DEBUG is not set
    CONFIG_MBEDTLS_INIT=y
    # CONFIG_MBEDTLS_SHELL is not set
    # CONFIG_MBEDTLS_ZEROIZE_ALT is not set
    CONFIG_APP_LINK_WITH_MBEDTLS=y
    # end of mbedtls (D:/ProxiCure/Firmware/modules/crypto/mbedtls)
    # oberon-psa-crypto (D:/ProxiCure/Firmware/modules/crypto/oberon-psa-crypto)
    CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
    # end of oberon-psa-crypto (D:/ProxiCure/Firmware/modules/crypto/oberon-psa-crypto)
    # trusted-firmware-m (D:/ProxiCure/Firmware/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_TFM_BOARD="D:/ProxiCure/Firmware/nrf/modules/trusted-firmware-m/tfm_boards/nrf9120"
    # CONFIG_TFM_DUMMY_PROVISIONING is not set
    # CONFIG_TFM_REGRESSION_NS is not set
    # CONFIG_TFM_LOG_LEVEL_SILENCE is not set
    CONFIG_TFM_QCBOR_PATH="D:/ProxiCure/Firmware/modules/tee/tf-m/trusted-firmware-m/../qcbor"
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # CONFIG_TFM_PROFILE_TYPE_NOT_SET is not set
    # CONFIG_TFM_PROFILE_TYPE_SMALL is not set
    # CONFIG_TFM_PROFILE_TYPE_MEDIUM is not set
    # CONFIG_TFM_PROFILE_TYPE_AROTLESS is not set
    # CONFIG_TFM_PROFILE_TYPE_LARGE is not set
    # CONFIG_TFM_CMAKE_BUILD_TYPE_RELEASE is not set
    # CONFIG_TFM_CMAKE_BUILD_TYPE_RELWITHDEBINFO is not set
    CONFIG_TFM_CMAKE_BUILD_TYPE_MINSIZEREL=y
    # CONFIG_TFM_CMAKE_BUILD_TYPE_DEBUG is not set
    CONFIG_TFM_ISOLATION_LEVEL=1
    # CONFIG_TFM_ITS_NUM_ASSETS_OVERRIDE is not set
    # CONFIG_TFM_ITS_MAX_ASSET_SIZE_OVERRIDE is not set
    CONFIG_TFM_PARTITION_PLATFORM_CUSTOM_REBOOT=y
    CONFIG_TFM_BL2_NOT_SUPPORTED=y
    CONFIG_TFM_IMAGE_VERSION_S="1.0.0+0"
    CONFIG_TFM_IMAGE_VERSION_NS="0.0.0+0"
    # CONFIG_TFM_BL1 is not set
    # CONFIG_TFM_USE_NS_APP is not set
    # CONFIG_TFM_CONNECTION_BASED_SERVICE_API is not set
    # CONFIG_TFM_IPC is not set
    CONFIG_TFM_SFN=y
    # CONFIG_TFM_REGRESSION_S is not set
    # CONFIG_TFM_PSA_TEST_CRYPTO is not set
    # CONFIG_TFM_PSA_TEST_PROTECTED_STORAGE is not set
    # CONFIG_TFM_PSA_TEST_INTERNAL_TRUSTED_STORAGE is not set
    # CONFIG_TFM_PSA_TEST_STORAGE is not set
    # CONFIG_TFM_PSA_TEST_INITIAL_ATTESTATION is not set
    CONFIG_TFM_PSA_TEST_NONE=y
    CONFIG_TFM_FLASH_MERGED_BINARY=y
    # CONFIG_TFM_SPM_LOG_LEVEL_DEBUG is not set
    CONFIG_TFM_SPM_LOG_LEVEL_INFO=y
    # CONFIG_TFM_SPM_LOG_LEVEL_ERROR is not set
    # CONFIG_TFM_SPM_LOG_LEVEL_SILENCE is not set
    CONFIG_TFM_EXCEPTION_INFO_DUMP=y
    # Platform partition component configs
    CONFIG_TFM_PLATFORM_SERVICE_INPUT_BUFFER_SIZE=64
    CONFIG_TFM_PLATFORM_SERVICE_OUTPUT_BUFFER_SIZE=64
    CONFIG_TFM_PLATFORM_SP_STACK_SIZE=0x500
    CONFIG_TFM_PLATFORM_NV_COUNTER_MODULE_DISABLED=y
    # end of Platform partition component configs
    # Crypto component configs
    # CONFIG_TFM_CRYPTO_SINGLE_PART_FUNCS_DISABLED is not set
    CONFIG_TFM_CRYPTO_ENGINE_BUF_SIZE=1
    CONFIG_TFM_CRYPTO_CONC_OPER_NUM=1
    CONFIG_TFM_CRYPTO_IOVEC_BUFFER_SIZE=1024
    CONFIG_TFM_CRYPTO_PARTITION_STACK_SIZE=0x800
    # end of Crypto component configs
    # TF-M SPM component configs
    # end of TF-M SPM component configs
    # TF-M memory regions
    CONFIG_PM_PARTITION_SIZE_TFM_SRAM=0x8000
    CONFIG_PM_PARTITION_SIZE_TFM=0x7E00
    CONFIG_PM_PARTITION_SIZE_TFM_PROTECTED_STORAGE=0
    CONFIG_PM_PARTITION_SIZE_TFM_INTERNAL_TRUSTED_STORAGE=0
    CONFIG_PM_PARTITION_SIZE_TFM_OTP_NV_COUNTERS=0
    # end of TF-M memory regions
    # Peripheral Secure mapping
    # CONFIG_NRF_FPU_SECURE is not set
    # CONFIG_NRF_CLOCK_SECURE is not set
    # CONFIG_NRF_POWER_SECURE is not set
    # CONFIG_NRF_SPIM0_SECURE is not set
    # CONFIG_NRF_TWIM0_SECURE is not set
    # CONFIG_NRF_UARTE0_SECURE is not set
    # CONFIG_NRF_SPIM1_SECURE is not set
    # CONFIG_NRF_TWIM1_SECURE is not set
    CONFIG_NRF_UARTE1_SECURE=y
    # CONFIG_NRF_SPIM2_SECURE is not set
    # CONFIG_NRF_TWIM2_SECURE is not set
    # CONFIG_NRF_UARTE2_SECURE is not set
    # CONFIG_NRF_SPIM3_SECURE is not set
    # CONFIG_NRF_TWIM3_SECURE is not set
    # CONFIG_NRF_UARTE3_SECURE is not set
    # CONFIG_NRF_SAADC_SECURE is not set
    # CONFIG_NRF_TIMER0_SECURE is not set
    # CONFIG_NRF_TIMER1_SECURE is not set
    # CONFIG_NRF_TIMER2_SECURE is not set
    # CONFIG_NRF_RTC0_SECURE is not set
    # CONFIG_NRF_RTC1_SECURE is not set
    # CONFIG_NRF_DPPI_SECURE is not set
    # CONFIG_NRF_WDT0_SECURE is not set
    # CONFIG_NRF_EGU0_SECURE is not set
    # CONFIG_NRF_EGU1_SECURE is not set
    # CONFIG_NRF_EGU2_SECURE is not set
    # CONFIG_NRF_EGU3_SECURE is not set
    # CONFIG_NRF_EGU4_SECURE is not set
    # CONFIG_NRF_EGU5_SECURE is not set
    # CONFIG_NRF_PWM0_SECURE is not set
    # CONFIG_NRF_PWM1_SECURE is not set
    # CONFIG_NRF_PWM2_SECURE is not set
    # CONFIG_NRF_PWM3_SECURE is not set
    # CONFIG_NRF_PDM_SECURE is not set
    # CONFIG_NRF_I2S_SECURE is not set
    # CONFIG_NRF_IPC_SECURE is not set
    # CONFIG_NRF_NVMC_SECURE is not set
    # CONFIG_NRF_GPIO0_SECURE is not set
    # CONFIG_NRF_GPIOTE0_SECURE is not set
    CONFIG_NRF_GPIO0_PIN_MASK_SECURE=0x00000000
    CONFIG_NRF_DPPI_CHANNEL_MASK_SECURE=0x00000000
    CONFIG_NRF_VMC_SECURE=y
    # end of Peripheral Secure mapping
    CONFIG_TFM_PROFILE_TYPE_MINIMAL=y
    CONFIG_TFM_CPU_FREQ_MHZ=128
    CONFIG_TFM_SECURE_UART=y
    # CONFIG_TFM_SECURE_UART_SHARE_INSTANCE is not set
    # CONFIG_TFM_SECURE_UART0 is not set
    CONFIG_TFM_SECURE_UART1=y
    CONFIG_TFM_HW_INIT_RESET_ON_BOOT=y
    CONFIG_TFM_HW_INIT_NRF_PERIPHERALS=y
    CONFIG_TFM_HALT_ON_CORE_PANIC=y
    CONFIG_TFM_ALLOW_NON_SECURE_RESET=y
    CONFIG_TFM_ALLOW_NON_SECURE_FAULT_HANDLING=y
    CONFIG_TFM_S_CODE_VECTOR_TABLE_SIZE=0x144
    # CONFIG_TFM_PSA_FRAMEWORK_HAS_MM_IOVEC is not set
    # end of trusted-firmware-m (D:/ProxiCure/Firmware/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    # cjson (D:/ProxiCure/Firmware/modules/lib/cjson)
    # CONFIG_CJSON_LIB is not set
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (D:/ProxiCure/Firmware/modules/lib/cjson)
    # azure-sdk-for-c (D:/ProxiCure/Firmware/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (D:/ProxiCure/Firmware/modules/lib/azure-sdk-for-c)
    # cirrus-logic (D:/ProxiCure/Firmware/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (D:/ProxiCure/Firmware/modules/hal/cirrus-logic)
    # openthread (D:/ProxiCure/Firmware/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (D:/ProxiCure/Firmware/modules/lib/openthread)
    # memfault-firmware-sdk (D:/ProxiCure/Firmware/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (D:/ProxiCure/Firmware/modules/lib/memfault-firmware-sdk)
    # coremark (D:/ProxiCure/Firmware/modules/benchmark/coremark)
    # CONFIG_COREMARK is not set
    CONFIG_ZEPHYR_COREMARK_MODULE=y
    # end of coremark (D:/ProxiCure/Firmware/modules/benchmark/coremark)
    # canopennode (D:/ProxiCure/Firmware/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (D:/ProxiCure/Firmware/modules/lib/canopennode)
    # chre (D:/ProxiCure/Firmware/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (D:/ProxiCure/Firmware/modules/lib/chre)
    # lz4 (D:/ProxiCure/Firmware/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (D:/ProxiCure/Firmware/modules/lib/lz4)
    CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    # zscilib (D:/ProxiCure/Firmware/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (D:/ProxiCure/Firmware/modules/lib/zscilib)
    # cmsis (D:/ProxiCure/Firmware/modules/hal/cmsis)
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    CONFIG_HAS_CMSIS_CORE=y
    # end of cmsis (D:/ProxiCure/Firmware/modules/hal/cmsis)
    # cmsis-dsp (D:/ProxiCure/Firmware/modules/lib/cmsis-dsp)
    CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    # CONFIG_CMSIS_DSP is not set
    # end of cmsis-dsp (D:/ProxiCure/Firmware/modules/lib/cmsis-dsp)
    # cmsis-nn (D:/ProxiCure/Firmware/modules/lib/cmsis-nn)
    CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    # CONFIG_CMSIS_NN is not set
    # end of cmsis-nn (D:/ProxiCure/Firmware/modules/lib/cmsis-nn)
    # cmsis_6 (D:/ProxiCure/Firmware/modules/hal/cmsis_6)
    CONFIG_ZEPHYR_CMSIS_6_MODULE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    # end of cmsis_6 (D:/ProxiCure/Firmware/modules/hal/cmsis_6)
    # fatfs (D:/ProxiCure/Firmware/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (D:/ProxiCure/Firmware/modules/fs/fatfs)
    # hal_nordic (D:/ProxiCure/Firmware/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_CLOCK_LOG is not set
    # CONFIG_NRFX_GPIOTE_LOG is not set
    # CONFIG_NRFX_IPC_LOG is not set
    # CONFIG_NRFX_NVMC_LOG is not set
    # CONFIG_NRFX_SPIM_LOG is not set
    # end of nrfx drivers logging
    CONFIG_NRFX_CLOCK=y
    # CONFIG_NRFX_CLOCK_USE_LFRC_CALIBRATION is not set
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    # CONFIG_NRFX_CLOCK_LF_CAL_ENABLED is not set
    # CONFIG_NRFX_CLOCK_LF_SRC_RC is not set
    CONFIG_NRFX_CLOCK_LF_SRC_XTAL=y
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_GPIOTE1=y
    CONFIG_NRFX_GPPI=y
    # CONFIG_NRFX_GPPI_V1 is not set
    # CONFIG_NRFX_I2S is not set
    CONFIG_NRFX_IPC=y
    CONFIG_NRFX_NVMC=y
    # CONFIG_NRFX_PDM is not set
    # CONFIG_NRFX_POWER is not set
    # CONFIG_NRFX_PWM is not set
    # CONFIG_NRFX_QDEC is not set
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_SAADC is not set
    CONFIG_NRFX_SPIM=y
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TIMER is not set
    # CONFIG_NRFX_TWIM is not set
    # CONFIG_NRFX_TWIS is not set
    # CONFIG_NRFX_UARTE is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    CONFIG_NRFX_RESERVED_RESOURCES_HEADER="nrfx_reserved_resources_ncs.h"
    # end of hal_nordic (D:/ProxiCure/Firmware/modules/hal/nordic)
    # hal_st (D:/ProxiCure/Firmware/modules/hal/st)
    CONFIG_ZEPHYR_HAL_ST_MODULE=y
    # end of hal_st (D:/ProxiCure/Firmware/modules/hal/st)
    # hal_tdk (D:/ProxiCure/Firmware/modules/hal/tdk)
    CONFIG_ZEPHYR_HAL_TDK_MODULE=y
    # TDK drivers
    # CONFIG_TDK_HAL is not set
    # end of TDK drivers
    # end of hal_tdk (D:/ProxiCure/Firmware/modules/hal/tdk)
    CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    # liblc3 (D:/ProxiCure/Firmware/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # end of liblc3 (D:/ProxiCure/Firmware/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    # littlefs (D:/ProxiCure/Firmware/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (D:/ProxiCure/Firmware/modules/fs/littlefs)
    # loramac-node (D:/ProxiCure/Firmware/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (D:/ProxiCure/Firmware/modules/lib/loramac-node)
    # lvgl (D:/ProxiCure/Firmware/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (D:/ProxiCure/Firmware/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    # nanopb (D:/ProxiCure/Firmware/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (D:/ProxiCure/Firmware/modules/lib/nanopb)
    # nrf_wifi (D:/ProxiCure/Firmware/modules/lib/nrf_wifi)
    CONFIG_ZEPHYR_NRF_WIFI_MODULE=y
    # CONFIG_NRF70_BUSLIB is not set
    # end of nrf_wifi (D:/ProxiCure/Firmware/modules/lib/nrf_wifi)
    CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    # percepio (D:/ProxiCure/Firmware/modules/debug/percepio)
    # Percepio Tracealyzer support can be enabled from the tracing subsystem
    # CONFIG_PERCEPIO_DFM is not set
    CONFIG_ZEPHYR_PERCEPIO_MODULE=y
    # end of percepio (D:/ProxiCure/Firmware/modules/debug/percepio)
    # picolibc (D:/ProxiCure/Firmware/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (D:/ProxiCure/Firmware/modules/lib/picolibc)
    # segger (D:/ProxiCure/Firmware/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    # CONFIG_USE_SEGGER_RTT is not set
    # end of segger (D:/ProxiCure/Firmware/modules/debug/segger)
    # uoscore-uedhoc (D:/ProxiCure/Firmware/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (D:/ProxiCure/Firmware/modules/lib/uoscore-uedhoc)
    # zcbor (D:/ProxiCure/Firmware/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # CONFIG_ZCBOR is not set
    # end of zcbor (D:/ProxiCure/Firmware/modules/lib/zcbor)
    # softsim (D:/ProxiCure/Firmware/proxiCure-firmware/app/../../modules/lib/onomondo-softsim)
    # Onomondo SoftSIM Options
    CONFIG_SOFTSIM=y
    # CONFIG_SOFTSIM_AUTO_INIT is not set
    # CONFIG_SOFTSIM_DEBUG is not set
    # CONFIG_SOFTSIM_STATIC_PROFILE_ENABLE is not set
    # end of Onomondo SoftSIM Options
    # CONFIG_SOFTSIM_LOG_LEVEL_OFF is not set
    CONFIG_SOFTSIM_LOG_LEVEL_ERR=y
    # CONFIG_SOFTSIM_LOG_LEVEL_WRN is not set
    # CONFIG_SOFTSIM_LOG_LEVEL_INF is not set
    # CONFIG_SOFTSIM_LOG_LEVEL_DBG is not set
    # CONFIG_SOFTSIM_LOG_LEVEL_DEFAULT is not set
    CONFIG_SOFTSIM_LOG_LEVEL=1
    CONFIG_ZEPHYR_SOFTSIM_MODULE=y
    # end of softsim (D:/ProxiCure/Firmware/proxiCure-firmware/app/../../modules/lib/onomondo-softsim)
    # nrfxlib (D:/ProxiCure/Firmware/nrfxlib)
    # Nordic nrfxlib
    # nrf_modem (Modem library)
    CONFIG_NRF_MODEM=y
    CONFIG_NRF_MODEM_LINK_BINARY=y
    CONFIG_NRF_MODEM_LINK_BINARY_CELLULAR=y
    # CONFIG_NRF_MODEM_LINK_BINARY_DECT_PHY is not set
    # CONFIG_NRF_MODEM_LOG is not set
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # end of nrf_modem (Modem library)
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    # Crypto libraries for nRF5x SOCs.
    CONFIG_HAS_HW_NRF_CC3XX=y
    # CONFIG_NRF_OBERON is not set
    # CONFIG_NRF_CC310_BL is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_NRF_DM is not set
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (D:/ProxiCure/Firmware/nrfxlib)
    CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    # connectedhomeip (D:/ProxiCure/Firmware/modules/lib/matter)
    # CONFIG_CHIP is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (D:/ProxiCure/Firmware/modules/lib/matter)
    # CONFIG_LIBMETAL is not set
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_HAS_MEC5_HAL is not set
    # CONFIG_OPENAMP is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="D:/ProxiCure/Firmware/bootloader/mcuboot/root-ec-p256.pem"
    CONFIG_MCUBOOT_ENCRYPTION_KEY_FILE=""
    CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="1.0.0"
    # CONFIG_MCUBOOT_IMGTOOL_OVERWRITE_ONLY is not set
    # CONFIG_MCUBOOT_IMGTOOL_UUID_VID is not set
    # CONFIG_MCUBOOT_IMGTOOL_UUID_CID is not set
    CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS=""
    # CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set
    # On board MCUboot operation mode
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_USING_OFFSET is not set
    CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_USING_MOVE=y
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_SCRATCH is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_OVERWRITE_ONLY is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_RAM_LOAD is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_RAM_LOAD_WITH_REVERT is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP_WITH_REVERT is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_FIRMWARE_UPDATER is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP_RAM_LOAD is not set
    CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE=y
    # CONFIG_MCUBOOT_BOOTLOADER_NO_DOWNGRADE is not set
    # CONFIG_MCUBOOT_BOOTLOADER_USES_SHA512 is not set
    # end of On board MCUboot operation mode
    CONFIG_MCUBOOT_BOOTUTIL_LIB=y
    CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3
    # CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set
    # Unavailable modules, please install those via the project manifest.
    # hal_bouffalolab module not available.
    # hal_gigadevice module not available.
    # hal_nxp module not available.
    # libsbc module not available.
    # Trusted-firmware-a module not available.
    # LoRa Basics Modem module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD="nrf9151dk"
    CONFIG_BOARD_REVISION=""
    CONFIG_BOARD_TARGET="nrf9151dk/nrf9151/ns"
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_NRF9151DK_NRF9151_NS=y
    CONFIG_BOARD_QUALIFIERS="nrf9151/ns"
    # Board Options
    # end of Board Options
    # Hardware Configuration
    CONFIG_SOC="nrf9151"
    CONFIG_SOC_SERIES="nrf91"
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_SOC_FAMILY_NORDIC_NRF=y
    CONFIG_SOC_SERIES_NRF91X=y
    CONFIG_SOC_NRF9120=y
    CONFIG_SOC_NRF9151_LACA=y
    CONFIG_HWINFO=y
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_NORDIC_BSP_NAME="stable"
    CONFIG_HAS_HW_NRF_CC310=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIOTE1=y
    CONFIG_HAS_HW_NRF_KMU=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_SAADC=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    CONFIG_HAS_HW_NRF_VMC=y
    # CONFIG_NRF_SYS_EVENT is not set
    # CONFIG_NRF_PERIPHCONF_SECTION is not set
    # CONFIG_IS_IRONSIDE_SE_SECONDARY_IMAGE is not set
    # CONFIG_IS_GEN_UICR_IMAGE is not set
    CONFIG_NRF_ENABLE_ICACHE=y
    CONFIG_NRF_TRUSTZONE_FLASH_REGION_SIZE=0x8000
    CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
    CONFIG_NRF_TRUSTZONE_RAM_REGION_SIZE=0x2000
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    # CONFIG_SOC_NRF54H20_PM_S2RAM_OVERRIDE is not set
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    CONFIG_TFM_NRF_NS_STORAGE=y
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_APPROTECT_USER_HANDLING is not set
    CONFIG_NRF_SECURE_APPROTECT_USE_UICR=y
    # CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
    # CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
    # CONFIG_NRF_TRACE_PORT is not set
    CONFIG_GPIO_INIT_PRIORITY=40
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=3
    # end of Hardware Configuration
    CONFIG_ARCH="arm"
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_CPU_CORTEX=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # ARM Options
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    # CONFIG_PLATFORM_SPECIFIC_INIT is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_ARM_NONSECURE_FIRMWARE=y
    CONFIG_ARM_NONSECURE_PREEMPTIBLE_SECURE_CALLS=y
    CONFIG_ARM_STORE_EXC_RETURN=y
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    CONFIG_ARM_TRUSTZONE_M=y
    # ARM TrustZone-M Options
    # Non-secure firmware
    # CONFIG_ARM_FIRMWARE_USES_SECURE_ENTRY_FUNCS is not set
    # end of ARM TrustZone-M Options
    # CONFIG_MPU_STACK_GUARD is not set
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    CONFIG_CPU_HAS_NRF_IDAU=y
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    # CONFIG_ISR_TABLE_SHELL is not set
    CONFIG_ARCH_SUPPORTS_ROM_OFFSET=y
    CONFIG_ARM_MPU=y
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=3
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_TRUSTED_EXECUTION_SECURE is not set
    CONFIG_TRUSTED_EXECUTION_NONSECURE=y
    # CONFIG_USERSPACE is not set
    # CONFIG_NOINIT_SNIPPET_FIRST is not set
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # CONFIG_FRAME_POINTER is not set
    # Interrupt Configuration
    # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    CONFIG_ARCH_DEVICE_STATE_ALIGN=4
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    # CONFIG_SRAM_SW_ISR_TABLE is not set
    CONFIG_EXCEPTION_DEBUG=y
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_VECTOR_TABLE_RELOCATION=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
    CONFIG_ARCH_SUPPORTS_COREDUMP_STACK_PTR=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_SUPPORTS_ROM_START=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    # CONFIG_MPU_LOG_LEVEL_INF is not set
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL_DEFAULT=y
    CONFIG_MPU_LOG_LEVEL=3
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # DSP Options
    # end of DSP Options
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    # CONFIG_SCHED_DUMB is not set
    CONFIG_SCHED_SIMPLE=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_DUMB is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_SIMPLE=y
    # Misc Kernel related options
    CONFIG_LIBC_ERRNO=y
    CONFIG_ERRNO=y
    CONFIG_CURRENT_THREAD_USE_TLS=y
    # end of Misc Kernel related options
    # Kernel Debugging and Metrics
    CONFIG_BOOT_DELAY=0
    # CONFIG_BOOT_CLEAR_SCREEN is not set
    CONFIG_THREAD_MONITOR=y
    CONFIG_THREAD_NAME=y
    CONFIG_THREAD_MAX_NAME_LEN=32
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # CONFIG_OBJ_CORE is not set
    # CONFIG_WORKQUEUE_WORK_TIMEOUT is not set
    # System Work Queue Options
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    CONFIG_SYSTEM_WORKQUEUE_WORK_TIMEOUT_MS=5000
    # end of System Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    # end of Timer API Options
    # Other Kernel Object Options
    CONFIG_POLL=y
    CONFIG_MEM_SLAB_POINTER_VALIDATE=y
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    CONFIG_EVENTS=y
    # CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
    # end of Other Kernel Object Options
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    # Security Options
    CONFIG_STACK_POINTER_RANDOM=0
    # end of Security Options
    # Memory Domains
    CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
    CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
    # end of Memory Domains
    # SMP Options
    # CONFIG_TICKET_SPINLOCKS is not set
    # end of SMP Options
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
    # CONFIG_STATIC_INIT_GNU is not set
    # CONFIG_BOOTARGS is not set
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_MUTABLE is not set
    CONFIG_DEVICE_DT_METADATA=y
    CONFIG_DEVICE_DEINIT_SUPPORT=y
    # end of Device Options
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Virtual Memory Support
    # MMU Features
    # end of MMU Features
    # end of Virtual Memory Support
    # SoC and Board Hooks
    # CONFIG_SOC_EARLY_RESET_HOOK is not set
    # CONFIG_SOC_PREP_HOOK is not set
    # CONFIG_SOC_EARLY_INIT_HOOK is not set
    # CONFIG_SOC_LATE_INIT_HOOK is not set
    # CONFIG_SOC_PER_CORE_INIT_HOOK is not set
    # CONFIG_BOARD_EARLY_INIT_HOOK is not set
    # CONFIG_BOARD_LATE_INIT_HOOK is not set
    # end of SoC and Board Hooks
    # Device Drivers
    # CONFIG_ADC is not set
    # CONFIG_AUDIO is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_BBRAM is not set
    # CONFIG_CAN is not set
    # CONFIG_CHARGER is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    CONFIG_CLOCK_CONTROL_NRF=y
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_FREQUENCY=32768
    # CONFIG_CLOCK_CONTROL_NRF_SHELL is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    # CONFIG_COMPARATOR is not set
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    # CONFIG_CONSOLE_HANDLER is not set
    CONFIG_CONSOLE_INIT_PRIORITY=60
    CONFIG_UART_CONSOLE=y
    # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
    # CONFIG_UART_CONSOLE_MCUMGR is not set
    # CONFIG_RAM_CONSOLE is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_EFI_CONSOLE is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_CRC_DRIVER is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DEBUG_DRIVER is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_DP_DRIVER is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    CONFIG_ENTROPY_GENERATOR=y
    # CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
    # CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
    # CONFIG_ENTROPY_LOG_LEVEL_INF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
    CONFIG_ENTROPY_LOG_LEVEL_DEFAULT=y
    CONFIG_ENTROPY_LOG_LEVEL=3
    CONFIG_ENTROPY_INIT_PRIORITY=50
    # CONFIG_FAKE_ENTROPY_NATIVE_POSIX is not set
    CONFIG_ENTROPY_PSA_CRYPTO_RNG=y
    CONFIG_ENTROPY_HAS_DRIVER=y
    # CONFIG_ESPI is not set
    # CONFIG_ETH_DRIVER is not set
    # Firmware drivers
    # CONFIG_ARM_SCMI is not set
    # end of Firmware drivers
    CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    CONFIG_FLASH_HAS_EXPLICIT_ERASE=y
    CONFIG_FLASH_HAS_PAGE_LAYOUT=y
    # CONFIG_FLASH_SHELL is not set
    CONFIG_FLASH_PAGE_LAYOUT=y
    # MSPI flash device driver
    # end of MSPI flash device driver
    # CONFIG_SOC_FLASH_NRF_CUSTOM_CONTEXT is not set
    CONFIG_SOC_FLASH_NRF=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
    # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
    # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
    # CONFIG_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_FLASH_LOG_LEVEL_INF is not set
    # CONFIG_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_FLASH_LOG_LEVEL_DEFAULT=y
    CONFIG_FLASH_LOG_LEVEL=3
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GNSS is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_GPIO_SHELL is not set
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_HOGS is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_HAPTICS is not set
    # CONFIG_HWINFO_LOG_LEVEL_OFF is not set
    # CONFIG_HWINFO_LOG_LEVEL_ERR is not set
    # CONFIG_HWINFO_LOG_LEVEL_WRN is not set
    # CONFIG_HWINFO_LOG_LEVEL_INF is not set
    # CONFIG_HWINFO_LOG_LEVEL_DBG is not set
    CONFIG_HWINFO_LOG_LEVEL_DEFAULT=y
    CONFIG_HWINFO_LOG_LEVEL=3
    CONFIG_HWINFO_HAS_DRIVER=y
    # CONFIG_HWINFO_SHELL is not set
    CONFIG_HWINFO_NRF=y
    # CONFIG_HWSPINLOCK is not set
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # CONFIG_IEEE802154 is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=3
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    # CONFIG_MBOX is not set
    # CONFIG_MDIO is not set
    # CONFIG_MIPI_DBI is not set
    # Miscellaneous Drivers
    # CONFIG_TIMEAWARE_GPIO is not set
    # Interconn Drivers
    # end of Interconn Drivers
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_MSPI is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    CONFIG_PINCTRL=y
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_PINCTRL_LOG_LEVEL=3
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_KEEP_SLEEP_STATE=y
    # CONFIG_PINCTRL_NPCX_EX is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_PS2 is not set
    # CONFIG_PSI5 is not set
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_PWM is not set
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # CONFIG_SENSOR_LOG_LEVEL_OFF is not set
    # CONFIG_SENSOR_LOG_LEVEL_ERR is not set
    # CONFIG_SENSOR_LOG_LEVEL_WRN is not set
    # CONFIG_SENSOR_LOG_LEVEL_INF is not set
    # CONFIG_SENSOR_LOG_LEVEL_DBG is not set
    CONFIG_SENSOR_LOG_LEVEL_DEFAULT=y
    CONFIG_SENSOR_LOG_LEVEL=3
    CONFIG_SENSOR_INIT_PRIORITY=90
    # CONFIG_SENSOR_ASYNC_API is not set
    # CONFIG_SENSOR_SHELL is not set
    # CONFIG_SENSOR_SHELL_BATTERY is not set
    # CONFIG_SENSOR_INFO is not set
    # Device Drivers
    # CONFIG_SENT is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    CONFIG_SERIAL_INIT_PRIORITY=50
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    # CONFIG_UART_LOG_LEVEL_INF is not set
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_LOG_LEVEL=3
    # CONFIG_UART_ASYNC_API is not set
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_ASYNC_RX_HELPER is not set
    # CONFIG_UART_SHELL is not set
    # Serial Drivers
    # CONFIG_UART_NATIVE_POSIX is not set
    # CONFIG_UART_NPCX_FIFO_EX is not set
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
    # CONFIG_UART_NRFX_UARTE_DIRECT_ISR is not set
    CONFIG_UART_0_INTERRUPT_DRIVEN=y
    CONFIG_UART_0_ENHANCED_POLL_OUT=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
    # CONFIG_SMBUS is not set
    # CONFIG_SPI_SHELL is not set
    # CONFIG_SPI_ASYNC is not set
    # CONFIG_SPI_RTIO is not set
    # CONFIG_SPI_SLAVE is not set
    # CONFIG_SPI_EXTENDED_MODES is not set
    CONFIG_SPI_INIT_PRIORITY=50
    CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
    # CONFIG_SPI_LOG_LEVEL_OFF is not set
    # CONFIG_SPI_LOG_LEVEL_ERR is not set
    # CONFIG_SPI_LOG_LEVEL_WRN is not set
    # CONFIG_SPI_LOG_LEVEL_INF is not set
    # CONFIG_SPI_LOG_LEVEL_DBG is not set
    CONFIG_SPI_LOG_LEVEL_DEFAULT=y
    CONFIG_SPI_LOG_LEVEL=3
    CONFIG_SPI_NRFX=y
    CONFIG_SPI_NRFX_SPIM=y
    CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
    CONFIG_SPI_NRFX_WAKE_TIMEOUT_US=200
    # CONFIG_STEPPER is not set
    # Timer drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    CONFIG_NRF_RTC_TIMER=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    CONFIG_NRF_RTC_COUNTER_BIT_WIDTH=24
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # USB common
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
    # end of USB common
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=3
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_USBC_PPC_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTIO is not set
    # CONFIG_VIRTIO_LOG_LEVEL_OFF is not set
    # CONFIG_VIRTIO_LOG_LEVEL_ERR is not set
    # CONFIG_VIRTIO_LOG_LEVEL_WRN is not set
    # CONFIG_VIRTIO_LOG_LEVEL_INF is not set
    # CONFIG_VIRTIO_LOG_LEVEL_DBG is not set
    CONFIG_VIRTIO_LOG_LEVEL_DEFAULT=y
    CONFIG_VIRTIO_LOG_LEVEL=3
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    CONFIG_NET_TCP_WORKQ_STACK_SIZE=1024
    CONFIG_NET_TC_TX_COUNT=0
    CONFIG_NET_INTERFACE_NAME_LEN=8
    # CONFIG_TEE is not set
    CONFIG_REQUIRES_FULL_LIBC=y
    # CONFIG_REQUIRES_FLOAT_PRINTF is not set
    # CONFIG_LIBC_ALLOW_LESS_THAN_64BIT_TIME is not set
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    # C Library
    CONFIG_PICOLIBC=y
    # CONFIG_NEWLIB_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    # CONFIG_COMMON_LIBC_ASCTIME_R is not set
    # CONFIG_COMMON_LIBC_CTIME_R is not set
    CONFIG_COMMON_LIBC_TIME=y
    CONFIG_COMMON_LIBC_MALLOC=y
    CONFIG_COMMON_LIBC_CALLOC=y
    CONFIG_COMMON_LIBC_REALLOCARRAY=y
    # CONFIG_COMMON_LIBC_REMOVE is not set
    # CONFIG_PICOLIBC_USE_MODULE is not set
    CONFIG_PICOLIBC_USE_TOOLCHAIN=y
    # CONFIG_PICOLIBC_IO_FLOAT is not set
    CONFIG_PICOLIBC_IO_LONG_LONG=y
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # end of C++ Language Support
    # Additional libraries
    # Hash Function Support
    CONFIG_SYS_HASH_FUNC32=y
    # CONFIG_SYS_HASH_FUNC32_DJB2 is not set
    CONFIG_SYS_HASH_FUNC32_MURMUR3=y
    # CONFIG_SYS_HASH_FUNC32_CHOICE_DJB2 is not set
    CONFIG_SYS_HASH_FUNC32_CHOICE_MURMUR3=y
    # CONFIG_SYS_HASH_FUNC32_CHOICE_IDENTITY is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_VALIDATE is not set
    # CONFIG_SYS_HEAP_STRESS is not set
    # CONFIG_SYS_HEAP_INFO is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    CONFIG_SYS_HEAP_ARRAY_SIZE=0
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_MULTI_HEAP is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # end of Heap and Memory Allocation
    # Memory Blocks
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Memory Blocks
    CONFIG_NET_BUF=y
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
    # CONFIG_NET_BUF_LOG_LEVEL_INF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
    CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_BUF_LOG_LEVEL=3
    # CONFIG_NET_BUF_POOL_USAGE is not set
    CONFIG_NET_BUF_ALIGNMENT=0
    # OS Support Library
    CONFIG_FDTABLE=y
    CONFIG_ZVFS_OPEN_MAX=4
    # CONFIG_PRINTK_SYNC is not set
    CONFIG_MPSC_PBUF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_MPSC_CLEAR_ALLOCATED is not set
    CONFIG_HAS_POWEROFF=y
    # CONFIG_POWEROFF is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    # CONFIG_CBPRINTF_FP_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
    CONFIG_ZVFS=y
    CONFIG_ZVFS_EVENTFD=y
    CONFIG_ZVFS_EVENTFD_MAX=2
    CONFIG_ZVFS_POLL=y
    CONFIG_ZVFS_POLL_MAX=3
    CONFIG_ZVFS_SELECT=y
    # end of OS Support Library
    # POSIX API Support
    # POSIX Options
    # CONFIG_POSIX_API is not set
    CONFIG_POSIX_AEP_CHOICE_NONE=y
    # CONFIG_POSIX_AEP_CHOICE_BASE is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
    # CONFIG_POSIX_ASYNCHRONOUS_IO is not set
    # CONFIG_POSIX_BARRIERS is not set
    # CONFIG_POSIX_C_LANG_SUPPORT_R is not set
    CONFIG_POSIX_C_LIB_EXT=y
    # CONFIG_GETOPT_LONG is not set
    # POSIX device I/O
    # CONFIG_POSIX_DEVICE_IO is not set
    CONFIG_POSIX_OPEN_MAX=4
    # end of POSIX device I/O
    # CONFIG_POSIX_FD_MGMT is not set
    # CONFIG_POSIX_FILE_SYSTEM_R is not set
    # CONFIG_POSIX_FILE_SYSTEM is not set
    # POSIX memory
    CONFIG_POSIX_PAGE_SIZE=0x40
    # CONFIG_POSIX_SHARED_MEMORY_OBJECTS is not set
    # CONFIG_POSIX_MAPPED_FILES is not set
    # CONFIG_POSIX_MEMORY_PROTECTION is not set
    # end of POSIX memory
    # CONFIG_POSIX_MESSAGE_PASSING is not set
    # CONFIG_POSIX_NETWORKING is not set
    # CONFIG_POSIX_SINGLE_PROCESS is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_OFF is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_ERR is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_WRN is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_INF is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_DBG is not set
    CONFIG_POSIX_ENV_LOG_LEVEL_DEFAULT=y
    CONFIG_POSIX_ENV_LOG_LEVEL=3
    # CONFIG_POSIX_MULTI_PROCESS is not set
    # CONFIG_POSIX_THREADS is not set
    # CONFIG_POSIX_READER_WRITER_LOCKS is not set
    # POSIX scheduler options
    # CONFIG_POSIX_PRIORITY_SCHEDULING is not set
    # end of POSIX scheduler options
    # CONFIG_POSIX_SEMAPHORES is not set
    # POSIX signals
    # CONFIG_POSIX_REALTIME_SIGNALS is not set
    # CONFIG_POSIX_SIGNALS is not set
    # end of POSIX signals
    # CONFIG_POSIX_SPIN_LOCKS is not set
    # POSIX synchronized I/O
    # CONFIG_POSIX_FSYNC is not set
    # CONFIG_POSIX_SYNCHRONIZED_IO is not set
    # end of POSIX synchronized I/O
    # CONFIG_POSIX_TIMERS is not set
    # X/Open system interfaces
    # CONFIG_XSI_REALTIME is not set
    CONFIG_XSI_SINGLE_PROCESS=y
    # CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_OFF is not set
    # CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_ERR is not set
    # CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_WRN is not set
    # CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_INF is not set
    # CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_DBG is not set
    CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_DEFAULT=y
    CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL=3
    # CONFIG_XOPEN_STREAMS is not set
    # CONFIG_XSI_SYSTEM_LOGGING is not set
    # CONFIG_XSI_THREADS_EXT is not set
    # end of X/Open system interfaces
    # Miscellaneous POSIX-related options
    # CONFIG_EVENTFD is not set
    # end of Miscellaneous POSIX-related options
    CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y
    # end of POSIX Options
    # POSIX Shell Utilities
    # CONFIG_POSIX_ENV_SHELL is not set
    # end of POSIX Shell Utilities
    # end of POSIX API Support
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_LIBGCC_RTLIB=y
    # Utility Library
    # CONFIG_JSON_LIBRARY is not set
    CONFIG_RING_BUFFER=y
    # CONFIG_RING_BUFFER_LARGE is not set
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    CONFIG_ONOFF=y
    # CONFIG_UTF8 is not set
    # CONFIG_COBS is not set
    # end of Utility Library
    # Universally Unique Identifier (UUID)
    # CONFIG_UUID is not set
    # end of Universally Unique Identifier (UUID)
    # CONFIG_MIN_HEAP is not set
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BINDESC is not set
    # CONFIG_BT is not set
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # CONFIG_CPU_LOAD_METRIC is not set
    # CONFIG_CPU_LOAD_LOG_LEVEL_OFF is not set
    # CONFIG_CPU_LOAD_LOG_LEVEL_ERR is not set
    # CONFIG_CPU_LOAD_LOG_LEVEL_WRN is not set
    # CONFIG_CPU_LOAD_LOG_LEVEL_INF is not set
    # CONFIG_CPU_LOAD_LOG_LEVEL_DBG is not set
    CONFIG_CPU_LOAD_LOG_LEVEL_DEFAULT=y
    CONFIG_CPU_LOAD_LOG_LEVEL=3
    CONFIG_CRC=y
    # CONFIG_CRC_LOG_LEVEL_OFF is not set
    # CONFIG_CRC_LOG_LEVEL_ERR is not set
    # CONFIG_CRC_LOG_LEVEL_WRN is not set
    # CONFIG_CRC_LOG_LEVEL_INF is not set
    # CONFIG_CRC_LOG_LEVEL_DBG is not set
    CONFIG_CRC_LOG_LEVEL_DEFAULT=y
    CONFIG_CRC_LOG_LEVEL=3
    # CONFIG_CRC_HW_HANDLER is not set
    # CONFIG_CRC32_K_4_2_TABLE_256 is not set
    # CONFIG_CRC_SHELL is not set
    # CONFIG_DAP is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_UBSAN is not set
    # CONFIG_STACK_USAGE is not set
    # CONFIG_STACK_SENTINEL is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    CONFIG_ASSERT_LEVEL=2
    CONFIG_SPIN_VALIDATE=y
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_THREAD_INFO is not set
    # CONFIG_DEBUG_COREDUMP is not set
    # CONFIG_SYMTAB is not set
    # end of Debugging Options
    # CONFIG_MIPI_STP_DECODER is not set
    # CONFIG_CS_TRACE_DEFMT is not set
    # CONFIG_CPU_LOAD is not set
    CONFIG_CPU_LOAD_LOG_PERIODICALLY=0
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    # CONFIG_MCUBOOT_SHELL is not set
    CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y
    CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE=0x2000
    CONFIG_IMG_BLOCK_BUF_SIZE=512
    # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_INF is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set
    CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT=y
    CONFIG_IMG_MANAGER_LOG_LEVEL=3
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM_LIB_LINK is not set
    # CONFIG_FILE_SYSTEM is not set
    CONFIG_FCB=y
    # CONFIG_FCB_ALLOW_FIXED_ENDMARKER is not set
    # CONFIG_NVS_DATA_CRC is not set
    # CONFIG_NVS_INIT_BAD_MEMORY_REGION is not set
    # CONFIG_NVS_LOG_LEVEL_OFF is not set
    # CONFIG_NVS_LOG_LEVEL_ERR is not set
    # CONFIG_NVS_LOG_LEVEL_WRN is not set
    # CONFIG_NVS_LOG_LEVEL_INF is not set
    # CONFIG_NVS_LOG_LEVEL_DBG is not set
    CONFIG_NVS_LOG_LEVEL_DEFAULT=y
    CONFIG_NVS_LOG_LEVEL=3
    # end of File Systems
    # CONFIG_GNSS_RTK is not set
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # CONFIG_LLEXT is not set
    # CONFIG_LLEXT_EDK is not set
    # Logging
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    CONFIG_LOG_MODE_DEFERRED=y
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    # CONFIG_LOG_MODE_MINIMAL is not set
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_FRONTEND_OPT_API is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    # CONFIG_LOG_MULTIDOMAIN is not set
    CONFIG_LOG_FLUSH_SLEEP_US=10000
    # Logging levels filtering
    CONFIG_LOG_RUNTIME_FILTERING=y
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_MODE_OVERFLOW=y
    # CONFIG_LOG_BLOCK_IN_THREAD is not set
    CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
    CONFIG_LOG_PROCESS_THREAD=y
    CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
    CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
    # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
    CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
    # CONFIG_LOG_TIMESTAMP_64BIT is not set
    # CONFIG_LOG_TIMESTAMP_USE_REALTIME is not set
    # CONFIG_LOG_SPEED is not set
    # end of Processing
    # Output Formatting
    # Prepend non-hexdump log message with function name
    # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
    CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
    # end of Prepend non-hexdump log message with function name
    # CONFIG_LOG_MIPI_SYST_ENABLE is not set
    # CONFIG_LOG_THREAD_ID_PREFIX is not set
    # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    # CONFIG_LOG_INFO_COLOR_GREEN is not set
    # CONFIG_LOG_DBG_COLOR_BLUE is not set
    CONFIG_LOG_TAG_MAX_LEN=0
    CONFIG_LOG_OUTPUT_FORMAT_TIME_TIMESTAMP=y
    # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
    # end of Output Formatting
    # Backends
    # CONFIG_LOG_BACKEND_UART is not set
    # CONFIG_LOG_BACKEND_IPC_SERVICE is not set
    # end of Backends
    # Misc
    # CONFIG_LOG_CMDS is not set
    CONFIG_LOG_USE_VLA=y
    CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_FMT_STRING_VALIDATE is not set
    # CONFIG_LOG_MEM_UTILIZATION is not set
    CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
    # end of Misc
    CONFIG_LOG_RATELIMIT=y
    CONFIG_LOG_RATELIMIT_INTERVAL_MS=5000
    CONFIG_LOG_OUTPUT=y
    # end of Logging
    CONFIG_MEM_ATTR=y
    # CONFIG_MEM_ATTR_HEAP is not set
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    CONFIG_NETWORKING=y
    # CONFIG_NET_HOSTNAME_ENABLE is not set
    # Link layer options
    # CONFIG_NET_L2_DUMMY is not set
    # CONFIG_NET_L2_VIRTUAL is not set
    # CONFIG_NET_L2_PPP is not set
    # CONFIG_NET_L2_OPENTHREAD is not set
    # CONFIG_NET_L2_CUSTOM_IEEE802154 is not set
    # CONFIG_NET_L2_CANBUS_RAW is not set
    # CONFIG_NET_L2_WIFI_MGMT is not set
    # CONFIG_NET_L2_WIFI_SHELL is not set
    # CONFIG_NET_L2_PTP is not set
    # end of Link layer options
    # IP stack
    CONFIG_NET_IP=y
    # CONFIG_NET_NATIVE is not set
    # CONFIG_NET_OFFLOAD is not set
    CONFIG_NET_OFFLOADING_SUPPORT=y
    CONFIG_NET_INIT_PRIO=90
    CONFIG_NET_IP_DSCP_ECN=y
    CONFIG_NET_IPV4=y
    CONFIG_NET_IF_MAX_IPV4_COUNT=1
    CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=1
    CONFIG_NET_IF_MCAST_IPV4_ADDR_COUNT=1
    CONFIG_NET_IPV4_DEFAULT_NETMASK=24
    CONFIG_NET_TC_RX_COUNT=1
    # CONFIG_NET_TC_SKIP_FOR_HIGH_PRIO is not set
    # CONFIG_NET_TC_TX_SKIP_FOR_HIGH_PRIO is not set
    # CONFIG_NET_TC_RX_SKIP_FOR_HIGH_PRIO is not set
    CONFIG_NET_TC_THREAD_COOPERATIVE=y
    # CONFIG_NET_TC_THREAD_PREEMPTIVE is not set
    CONFIG_NET_TC_NUM_PRIORITIES=16
    # CONFIG_NET_TC_THREAD_PRIO_CUSTOM is not set
    CONFIG_NET_TC_MAPPING_STRICT=y
    CONFIG_NET_TX_DEFAULT_PRIORITY=1
    CONFIG_NET_RX_DEFAULT_PRIORITY=0
    # CONFIG_NET_ALLOW_ANY_PRIORITY is not set
    CONFIG_NET_IP_ADDR_CHECK=y
    CONFIG_NET_MAX_ROUTERS=1
    CONFIG_NET_TCP=y
    CONFIG_NET_TCP_LOG_LEVEL=0
    CONFIG_NET_TCP_WORKER_PRIO=2
    CONFIG_NET_TCP_TIME_WAIT_DELAY=1500
    CONFIG_NET_TCP_INIT_RETRANSMISSION_TIMEOUT=200
    CONFIG_NET_TCP_RANDOMIZED_RTO=y
    CONFIG_NET_TCP_RETRY_COUNT=9
    CONFIG_NET_TCP_MAX_SEND_WINDOW_SIZE=0
    CONFIG_NET_TCP_MAX_RECV_WINDOW_SIZE=0
    CONFIG_NET_TCP_RECV_QUEUE_TIMEOUT=2000
    CONFIG_NET_TCP_PKT_ALLOC_TIMEOUT=100
    CONFIG_NET_TCP_FAST_RETRANSMIT=y
    CONFIG_NET_TCP_CONGESTION_AVOIDANCE=y
    # CONFIG_NET_TCP_KEEPALIVE is not set
    CONFIG_NET_TCP_REJECT_CONN_WITH_RST=y
    # CONFIG_NET_TEST_PROTOCOL is not set
    CONFIG_NET_UDP=y
    CONFIG_NET_UDP_MISSING_CHECKSUM=y
    CONFIG_NET_UDP_LOG_LEVEL=0
    CONFIG_NET_MAX_CONN=4
    CONFIG_NET_CONN_PACKET_CLONE_TIMEOUT=100
    CONFIG_NET_MAX_CONTEXTS=6
    # CONFIG_NET_CONTEXT_NET_PKT_POOL is not set
    CONFIG_NET_CONTEXT_SYNC_RECV=y
    CONFIG_NET_CONTEXT_CHECK=y
    # CONFIG_NET_CONTEXT_PRIORITY is not set
    # CONFIG_NET_CONTEXT_TXTIME is not set
    # CONFIG_NET_CONTEXT_RCVTIMEO is not set
    # CONFIG_NET_CONTEXT_SNDTIMEO is not set
    # CONFIG_NET_CONTEXT_RCVBUF is not set
    # CONFIG_NET_CONTEXT_SNDBUF is not set
    CONFIG_NET_CONTEXT_DSCP_ECN=y
    CONFIG_NET_CONTEXT_REUSEADDR=y
    CONFIG_NET_CONTEXT_REUSEPORT=y
    # CONFIG_NET_CONTEXT_RECV_PKTINFO is not set
    # CONFIG_NET_CONTEXT_RECV_HOPLIMIT is not set
    # CONFIG_NET_CONTEXT_TIMESTAMPING is not set
    # CONFIG_NET_CONTEXT_CLAMP_PORT_RANGE is not set
    # CONFIG_NET_TEST is not set
    CONFIG_NET_BUF_RX_COUNT=16
    CONFIG_NET_BUF_TX_COUNT=16
    CONFIG_NET_BUF_FIXED_DATA_SIZE=y
    # CONFIG_NET_BUF_VARIABLE_DATA_SIZE is not set
    CONFIG_NET_BUF_DATA_SIZE=128
    CONFIG_NET_PKT_BUF_USER_DATA_SIZE=4
    CONFIG_NET_DEFAULT_IF_FIRST=y
    # CONFIG_NET_DEFAULT_IF_UP is not set
    # CONFIG_NET_DEFAULT_IF_OFFLOADED_NETDEV is not set
    CONFIG_NET_INTERFACE_NAME=y
    # CONFIG_NET_PKT_ALLOC_STATS is not set
    # CONFIG_NET_PROMISCUOUS_MODE is not set
    # CONFIG_NET_DISABLE_ICMP_DESTINATION_UNREACHABLE is not set
    # Stack usage
    # end of Stack usage
    # CONFIG_NET_MGMT is not set
    # CONFIG_NET_STATISTICS is not set
    # CONFIG_NET_LOG is not set
    CONFIG_NET_PKT_LOG_LEVEL=0
    # CONFIG_NET_DEBUG_NET_PKT_ALLOC is not set
    CONFIG_NET_DEBUG_NET_PKT_EXTERNALS=0
    # CONFIG_NET_DEBUG_NET_PKT_NON_FRAGILE_ACCESS is not set
    CONFIG_NET_CORE_LOG_LEVEL=0
    CONFIG_NET_IF_LOG_LEVEL=0
    CONFIG_NET_TC_LOG_LEVEL=0
    CONFIG_NET_UTILS_LOG_LEVEL=0
    CONFIG_NET_CONTEXT_LOG_LEVEL=0
    CONFIG_NET_CONN_LOG_LEVEL=0
    CONFIG_NET_ROUTE_LOG_LEVEL=0
    # end of IP stack
    # Network Packet Filtering
    # CONFIG_NET_PKT_FILTER is not set
    # end of Network Packet Filtering
    # Network Protocols
    CONFIG_COAP=y
    # CONFIG_COAP_TEST_API_ENABLE is not set
    # CONFIG_COAP_WELL_KNOWN_BLOCK_WISE is not set
    CONFIG_COAP_EXTENDED_OPTIONS_LEN=y
    CONFIG_COAP_EXTENDED_OPTIONS_LEN_VALUE=40
    CONFIG_COAP_RANDOMIZE_ACK_TIMEOUT=y
    CONFIG_COAP_ACK_RANDOM_PERCENT=150
    CONFIG_COAP_MAX_RETRANSMIT=4
    CONFIG_COAP_BACKOFF_PERCENT=200
    CONFIG_COAP_URI_WILDCARD=y
    # CONFIG_COAP_KEEP_USER_DATA is not set
    # CONFIG_COAP_CLIENT is not set
    # CONFIG_COAP_SERVER is not set
    CONFIG_COAP_LOG_LEVEL=0
    # CONFIG_DNS_SD is not set
    # CONFIG_NET_LATMON is not set
    # CONFIG_MQTT_LIB is not set
    # CONFIG_MQTT_SN_LIB is not set
    # CONFIG_TFTP_LIB is not set
    CONFIG_HTTP_PARSER=y
    CONFIG_HTTP_PARSER_URL=y
    # CONFIG_HTTP_PARSER_STRICT is not set
    CONFIG_HTTP_CLIENT=y
    # CONFIG_HTTP_SERVER is not set
    CONFIG_HTTP=y
    CONFIG_NET_HTTP_LOG_LEVEL=0
    CONFIG_NET_HTTP_SERVER_LOG_LEVEL=0
    # CONFIG_WEBSOCKET_CLIENT is not set
    CONFIG_LWM2M=y
    # CONFIG_LWM2M_LOG_LEVEL_OFF is not set
    # CONFIG_LWM2M_LOG_LEVEL_ERR is not set
    # CONFIG_LWM2M_LOG_LEVEL_WRN is not set
    # CONFIG_LWM2M_LOG_LEVEL_INF is not set
    CONFIG_LWM2M_LOG_LEVEL_DBG=y
    # CONFIG_LWM2M_LOG_LEVEL_DEFAULT is not set
    CONFIG_LWM2M_LOG_LEVEL=4
    # Protocol versions
    CONFIG_LWM2M_VERSION_1_0=y
    # CONFIG_LWM2M_VERSION_1_1 is not set
    CONFIG_LWM2M_SECURITY_OBJECT_VERSION_1_0=y
    # CONFIG_LWM2M_SECURITY_OBJECT_VERSION_1_1 is not set
    CONFIG_LWM2M_SERVER_OBJECT_VERSION_1_0=y
    # CONFIG_LWM2M_SERVER_OBJECT_VERSION_1_1 is not set
    # end of Protocol versions
    # Engine features
    CONFIG_LWM2M_DTLS_SUPPORT=y
    CONFIG_LWM2M_DNS_SUPPORT=y
    CONFIG_LWM2M_COAP_BLOCK_TRANSFER=y
    # CONFIG_LWM2M_CANCEL_OBSERVE_BY_PATH is not set
    # CONFIG_LWM2M_QUEUE_MODE_ENABLED is not set
    CONFIG_LWM2M_QUEUE_MODE_UPTIME=93
    # CONFIG_LWM2M_QUEUE_MODE_NO_MSG_BUFFERING is not set
    CONFIG_LWM2M_TLS_SESSION_CACHING=y
    CONFIG_LWM2M_DTLS_CID=y
    # CONFIG_LWM2M_RD_CLIENT_SUPPORT_BOOTSTRAP is not set
    # CONFIG_LWM2M_ENGINE_ALWAYS_REPORT_OBJ_VERSION is not set
    # CONFIG_LWM2M_RD_CLIENT_CLOSE_SOCKET_AT_IDLE is not set
    # CONFIG_LWM2M_RD_CLIENT_SUSPEND_SOCKET_AT_IDLE is not set
    # CONFIG_LWM2M_RD_CLIENT_STOP_POLLING_AT_IDLE is not set
    CONFIG_LWM2M_RD_CLIENT_LISTEN_AT_IDLE=y
    CONFIG_LWM2M_TICKLESS=y
    # CONFIG_LWM2M_INTERVAL is not set
    CONFIG_LWM2M_SERVER_DEFAULT_SSID=101
    CONFIG_LWM2M_PEER_PORT=5683
    CONFIG_LWM2M_FIRMWARE_PORT_NONSECURE=5683
    CONFIG_LWM2M_FIRMWARE_PORT_SECURE=5684
    CONFIG_LWM2M_SERVER_DEFAULT_PMIN=1
    CONFIG_LWM2M_SERVER_DEFAULT_PMAX=300
    CONFIG_LWM2M_RD_CLIENT_MAX_RETRIES=5
    # end of Engine features
    # Memory and buffer size configuration
    CONFIG_LWM2M_ENGINE_STACK_SIZE=3072
    CONFIG_LWM2M_ENGINE_MAX_MESSAGES=15
    CONFIG_LWM2M_COAP_BLOCK_SIZE=1024
    CONFIG_LWM2M_COAP_MAX_MSG_SIZE=1280
    CONFIG_LWM2M_ENGINE_VALIDATION_BUFFER_SIZE=64
    CONFIG_LWM2M_ENGINE_MAX_PENDING=15
    CONFIG_LWM2M_ENGINE_MAX_REPLIES=15
    CONFIG_LWM2M_ENGINE_MAX_OBSERVER=15
    CONFIG_LWM2M_RD_CLIENT_ENDPOINT_NAME_MAX_LENGTH=33
    CONFIG_LWM2M_SECURITY_KEY_SIZE=2048
    CONFIG_LWM2M_SECURITY_INSTANCE_COUNT=1
    CONFIG_LWM2M_SERVER_INSTANCE_COUNT=1
    CONFIG_LWM2M_COAP_ENCODE_BUFFER_SIZE=1024
    CONFIG_LWM2M_NUM_OUTPUT_BLOCK_CONTEXT=3
    # CONFIG_LWM2M_LOG_ENCODE_BUFFER_ALLOCATIONS is not set
    CONFIG_LWM2M_NUM_BLOCK1_CONTEXT=3
    CONFIG_LWM2M_SWMGMT_PACKAGE_URI_LEN=128
    CONFIG_LWM2M_COMPOSITE_PATH_LIST_SIZE=6
    # CONFIG_LWM2M_DEVICE_ERROR_CODE_SETTINGS is not set
    CONFIG_LWM2M_DEVICE_PWRSRC_MAX=5
    CONFIG_LWM2M_DEVICE_ERROR_CODE_MAX=10
    CONFIG_LWM2M_DEVICE_EXT_DEV_INFO_MAX=5
    CONFIG_LWM2M_NUM_ATTR=20
    CONFIG_LWM2M_MAX_NOTIFIED_NUMERICAL_RES_TRACKED=4
    # end of Memory and buffer size configuration
    # Content format supports
    CONFIG_LWM2M_RW_OMA_TLV_SUPPORT=y
    # end of Content format supports
    CONFIG_LWM2M_ENGINE_DEFAULT_LIFETIME=300
    CONFIG_LWM2M_UPDATE_PERIOD=60
    CONFIG_LWM2M_SECONDS_TO_UPDATE_EARLY=60
    CONFIG_LWM2M_SERVER_BOOTSTRAP_ON_FAIL=y
    CONFIG_LWM2M_SHELL=y
    # CONFIG_LWM2M_ACCESS_CONTROL_ENABLE is not set
    CONFIG_LWM2M_ACCESS_CONTROL_INSTANCE_COUNT=50
    CONFIG_LWM2M_CONN_MON_OBJ_SUPPORT=y
    CONFIG_LWM2M_CONNMON_OBJECT_VERSION_1_0=y
    # CONFIG_LWM2M_CONNMON_OBJECT_VERSION_1_2 is not set
    # CONFIG_LWM2M_CONNMON_OBJECT_VERSION_1_3 is not set
    CONFIG_LWM2M_CONN_MON_APN_MAX=1
    CONFIG_LWM2M_FIRMWARE_UPDATE_OBJ_SUPPORT=y
    # CONFIG_LWM2M_FIRMWARE_UPDATE_OBJ_SUPPORT_MULTIPLE is not set
    CONFIG_LWM2M_FIRMWARE_UPDATE_OBJ_INSTANCE_COUNT=1
    CONFIG_LWM2M_FIRMWARE_UPDATE_PULL_SUPPORT=y
    CONFIG_LWM2M_FIRMWARE_UPDATE_PULL_COAP_PROXY_SUPPORT=y
    CONFIG_LWM2M_FIRMWARE_UPDATE_PULL_COAP_PROXY_ADDR=""
    # CONFIG_LWM2M_LOCATION_OBJ_SUPPORT is not set
    # CONFIG_LWM2M_SWMGMT_OBJ_SUPPORT is not set
    # CONFIG_LWM2M_PORTFOLIO_OBJ_SUPPORT is not set
    # CONFIG_LWM2M_BINARYAPPDATA_OBJ_SUPPORT is not set
    # CONFIG_LWM2M_EVENT_LOG_OBJ_SUPPORT is not set
    # CONFIG_LWM2M_GATEWAY_OBJ_SUPPORT is not set
    CONFIG_LWM2M_IPSO_SUPPORT=y
    # CONFIG_LWM2M_IPSO_TEMP_SENSOR is not set
    # CONFIG_LWM2M_IPSO_GENERIC_SENSOR is not set
    # CONFIG_LWM2M_IPSO_HUMIDITY_SENSOR is not set
    # CONFIG_LWM2M_IPSO_PRESSURE_SENSOR is not set
    # CONFIG_LWM2M_IPSO_LIGHT_CONTROL is not set
    # CONFIG_LWM2M_IPSO_ACCELEROMETER is not set
    # CONFIG_LWM2M_IPSO_BUZZER is not set
    # CONFIG_LWM2M_IPSO_TIMER is not set
    # CONFIG_LWM2M_IPSO_ONOFF_SWITCH is not set
    # CONFIG_LWM2M_IPSO_PUSH_BUTTON is not set
    # CONFIG_LWM2M_IPSO_CURRENT_SENSOR is not set
    # CONFIG_LWM2M_IPSO_VOLTAGE_SENSOR is not set
    # CONFIG_LWM2M_IPSO_FILLING_SENSOR is not set
    # CONFIG_LWM2M_UCIFI_SUPPORT is not set
    # CONFIG_SOCKS is not set
    CONFIG_SNTP=y
    # CONFIG_SNTP_UNCERTAINTY is not set
    CONFIG_SNTP_LOG_LEVEL=0
    # end of Network Protocols
    # Network Libraries
    CONFIG_NET_CONFIG_LOG_LEVEL=0
    # CONFIG_NET_CONFIG_SETTINGS is not set
    # CONFIG_NET_CONFIG_CLOCK_SNTP_INIT is not set
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_PRIORITY_DEFAULT=50
    CONFIG_NET_SOCKETS_POLL_MAX=0
    CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=3000
    CONFIG_NET_SOCKET_MAX_SEND_WAIT=10000
    # CONFIG_NET_SOCKETS_SERVICE is not set
    # CONFIG_NET_SOCKETS_SOCKOPT_TLS is not set
    CONFIG_NET_SOCKETS_TLS_PRIORITY=45
    CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH=y
    CONFIG_NET_SOCKETS_OFFLOAD=y
    CONFIG_NET_SOCKETS_OFFLOAD_PRIORITY=40
    # CONFIG_NET_SOCKETS_OFFLOAD_DISPATCHER is not set
    # CONFIG_NET_SOCKETS_PACKET is not set
    # CONFIG_NET_SOCKETS_CAN is not set
    CONFIG_NET_SOCKETPAIR=y
    CONFIG_NET_SOCKETPAIR_BUFFER_SIZE=64
    # CONFIG_NET_SOCKETPAIR_STATIC is not set
    CONFIG_NET_SOCKETPAIR_HEAP=y
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_SOCKETPAIR=296
    CONFIG_NET_SOCKETS_LOG_LEVEL=0
    # CONFIG_TLS_CREDENTIALS is not set
    # CONFIG_NET_SHELL is not set
    # end of Network Libraries
    # Network additional services
    # CONFIG_NET_CAPTURE is not set
    # CONFIG_NET_DHCPV4 is not set
    # CONFIG_NET_DHCPV4_SERVER is not set
    CONFIG_NET_DHCPV6_DUID_MAX_LEN=22
    # CONFIG_NET_TRICKLE is not set
    # CONFIG_NET_ZPERF is not set
    # CONFIG_WIFI_CREDENTIALS is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC is not set
    # end of Network additional services
    # CONFIG_NET_CONNECTION_MANAGER is not set
    # end of Networking
    # Power Management
    # CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
    # end of Power Management
    # Platform Management Communications Infrastructure (PMCI)
    # CONFIG_MCTP is not set
    # end of Platform Management Communications Infrastructure (PMCI)
    # Portability
    # end of Portability
    # CONFIG_PROFILING is not set
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
    # CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
    CONFIG_CSPRNG_AVAILABLE=y
    CONFIG_CSPRNG_ENABLED=y
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    # CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    CONFIG_SETTINGS=y
    # CONFIG_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_SETTINGS_LOG_LEVEL_WRN is not set
    # CONFIG_SETTINGS_LOG_LEVEL_INF is not set
    # CONFIG_SETTINGS_LOG_LEVEL_DBG is not set
    CONFIG_SETTINGS_LOG_LEVEL_DEFAULT=y
    CONFIG_SETTINGS_LOG_LEVEL=3
    # CONFIG_SETTINGS_RUNTIME is not set
    CONFIG_SETTINGS_DYNAMIC_HANDLERS=y
    CONFIG_SETTINGS_FCB=y
    # CONFIG_SETTINGS_NVS is not set
    # CONFIG_SETTINGS_CUSTOM is not set
    # CONFIG_SETTINGS_NONE is not set
    CONFIG_SETTINGS_FCB_NUM_AREAS=8
    CONFIG_SETTINGS_FCB_MAGIC=0xc0ffeeee
    # CONFIG_SETTINGS_ZMS_NO_LL_DELETE is not set
    # CONFIG_SETTINGS_ZMS_LOAD_SUBTREE_PATH is not set
    # CONFIG_SETTINGS_SHELL is not set
    CONFIG_SHELL=y
    # CONFIG_SHELL_LOG_LEVEL_OFF is not set
    # CONFIG_SHELL_LOG_LEVEL_ERR is not set
    # CONFIG_SHELL_LOG_LEVEL_WRN is not set
    # CONFIG_SHELL_LOG_LEVEL_INF is not set
    # CONFIG_SHELL_LOG_LEVEL_DBG is not set
    CONFIG_SHELL_LOG_LEVEL_DEFAULT=y
    CONFIG_SHELL_LOG_LEVEL=3
    CONFIG_SHELL_BACKENDS=y
    CONFIG_SHELL_BACKEND_SERIAL_INIT_PRIORITY=90
    CONFIG_SHELL_PROMPT_UART="uart:~$ "
    CONFIG_SHELL_BACKEND_SERIAL_INTERRUPT_DRIVEN=y
    # CONFIG_SHELL_BACKEND_SERIAL_API_POLLING is not set
    CONFIG_SHELL_BACKEND_SERIAL_API_INTERRUPT_DRIVEN=y
    # CONFIG_SHELL_BACKEND_SERIAL_API_ASYNC is not set
    # CONFIG_SHELL_BACKEND_SERIAL_FORCE_TX_BLOCKING_MODE is not set
    CONFIG_SHELL_BACKEND_SERIAL_TX_RING_BUFFER_SIZE=8
    CONFIG_SHELL_BACKEND_SERIAL_RX_RING_BUFFER_SIZE=64
    CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_TIMEOUT=100
    CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_SIZE=512
    CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_DEFAULT=y
    # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_DBG is not set
    # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_INF is not set
    # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_WRN is not set
    # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_ERR is not set
    # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_NONE is not set
    CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL=5
    # CONFIG_SHELL_BACKEND_MQTT is not set
    # CONFIG_SHELL_BACKEND_TELNET is not set
    # CONFIG_SHELL_BACKEND_DUMMY is not set
    # CONFIG_SHELL_MINIMAL is not set
    CONFIG_SHELL_DEVICE_HELPERS=y
    # CONFIG_SHELL_THREAD_PRIORITY_OVERRIDE is not set
    CONFIG_SHELL_BACKSPACE_MODE_DELETE=y
    CONFIG_SHELL_PROMPT_CHANGE=y
    CONFIG_SHELL_PROMPT_BUFF_SIZE=20
    CONFIG_SHELL_CMD_BUFF_SIZE=256
    CONFIG_SHELL_PRINTF_BUFF_SIZE=30
    CONFIG_SHELL_PRINTF_AUTOFLUSH=y
    CONFIG_SHELL_DEFAULT_TERMINAL_WIDTH=80
    CONFIG_SHELL_DEFAULT_TERMINAL_HEIGHT=24
    CONFIG_SHELL_ARGC_MAX=20
    CONFIG_SHELL_TAB=y
    CONFIG_SHELL_TAB_AUTOCOMPLETION=y
    CONFIG_SHELL_ASCII_FILTER=y
    CONFIG_SHELL_WILDCARD=y
    CONFIG_SHELL_MSG_CMD_NOT_FOUND=y
    CONFIG_SHELL_MSG_SPECIFY_SUBCOMMAND=y
    CONFIG_SHELL_ECHO_STATUS=y
    # CONFIG_SHELL_START_OBSCURED is not set
    CONFIG_SHELL_VT100_COMMANDS=y
    CONFIG_SHELL_VT100_COLORS=y
    # CONFIG_SHELL_GETOPT is not set
    CONFIG_SHELL_METAKEYS=y
    CONFIG_SHELL_HELP=y
    CONFIG_SHELL_HELP_OPT_PARSE=y
    CONFIG_SHELL_HELP_ON_WRONG_ARGUMENT_COUNT=y
    CONFIG_SHELL_HISTORY=y
    CONFIG_SHELL_HISTORY_BUFFER=512
    CONFIG_SHELL_STATS=y
    CONFIG_SHELL_CMDS=y
    CONFIG_SHELL_CMDS_RESIZE=y
    # CONFIG_SHELL_CMDS_SELECT is not set
    CONFIG_SHELL_CMD_ROOT=""
    CONFIG_SHELL_LOG_BACKEND=y
    # CONFIG_SHELL_LOG_BACKEND_CUSTOM is not set
    CONFIG_SHELL_LOG_FORMAT_TIMESTAMP=y
    CONFIG_SHELL_AUTOSTART=y
    CONFIG_SHELL_CMDS_RETURN_VALUE=y
    # CONFIG_SHELL_CUSTOM_HEADER is not set
    CONFIG_SHELL_TX_TIMEOUT_MS=500
    CONFIG_DEVICE_SHELL=y
    CONFIG_DEVICE_SHELL_INIT_CMD=y
    CONFIG_DATE_SHELL=y
    CONFIG_DEVMEM_SHELL=y
    CONFIG_APP_VERSION_SHELL=y
    CONFIG_KERNEL_SHELL=y
    CONFIG_KERNEL_SHELL_REBOOT_DELAY=0
    CONFIG_KERNEL_THREAD_SHELL=y
    CONFIG_KERNEL_THREAD_SHELL_LIST=y
    CONFIG_KERNEL_THREAD_SHELL_STACKS=y
    CONFIG_KERNEL_THREAD_SHELL_SUSPEND=y
    CONFIG_KERNEL_THREAD_SHELL_RESUME=y
    CONFIG_KERNEL_THREAD_SHELL_KILL=y
    # CONFIG_KERNEL_SHELL_PANIC_CMD is not set
    # CONFIG_STATS is not set
    # Storage
    CONFIG_FLASH_MAP=y
    # CONFIG_FLASH_MAP_SHELL is not set
    # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
    # CONFIG_FLASH_MAP_LABELS is not set
    CONFIG_STREAM_FLASH=y
    CONFIG_STREAM_FLASH_INSPECT=y
    CONFIG_STREAM_FLASH_POST_WRITE_CALLBACK=y
    CONFIG_STREAM_FLASH_ERASE=y
    # CONFIG_STREAM_FLASH_PROGRESS is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT=y
    CONFIG_STREAM_FLASH_LOG_LEVEL=3
    # end of Storage
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    # CONFIG_FORCE_COVERAGE is not set
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # CONFIG_MODULES is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_17=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_FLASH_LOAD_SIZE=0x30000
    CONFIG_ROM_END_OFFSET=0x2096
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    CONFIG_LINKER_ITERABLE_SUBALIGN=4
    CONFIG_LINKER_DEVNULL_SUPPORT=y
    # CONFIG_LINKER_DEVNULL_MEMORY is not set
    # end of Linker Options
    # Compiler Options
    # CONFIG_STD_C90 is not set
    CONFIG_STD_C99=y
    # CONFIG_STD_C11 is not set
    # CONFIG_STD_C17 is not set
    # CONFIG_STD_C23 is not set
    CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
    # CONFIG_GNU_C_EXTENSIONS is not set
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_DEPRECATION_TEST is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    CONFIG_TOOLCHAIN_SUPPORTS_VLA_IN_STATEMENTS=y
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    CONFIG_BUILD_GAP_FILL_PATTERN=0xFF
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_HEX_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_MOT is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_EXPERIMENTAL=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Compatibility
    CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y
    # end of Compatibility
    # Custom libraries
    # Custom libraries
    # Modules
    # CONFIG_SENSOR_MODULE is not set
    # end of Modules
    # CONFIG_UI_SENSE_LED is not set
    # LwM2M objects
    # CONFIG_APP_PUSH_BUTTON is not set
    # CONFIG_APP_LIGHT_CONTROL is not set
    # CONFIG_APP_LIGHT_SENSOR is not set
    # CONFIG_APP_ENV_SENSOR is not set
    # CONFIG_APP_ACCELEROMETER is not set
    # CONFIG_APP_GNSS is not set
    # end of LwM2M objects
    CONFIG_APP_LWM2M_PSK="000102030405060708090a0b0c0d0e0f"
    CONFIG_APP_ENDPOINT_PREFIX="urn:imei:"
    # Device info
    CONFIG_APP_MANUFACTURER="Nordic Semiconductor ASA"
    CONFIG_APP_DEVICE_TYPE="OMA-LWM2M Client"
    # end of Device info
    CONFIG_APP_CUSTOM_VERSION=""
    # CONFIG_APP_LWM2M_CONFORMANCE_TESTING is not set
    # end of Custom libraries
    # end of Zephyr
    # CONFIG_APP_LOG_LEVEL_OFF is not set
    # CONFIG_APP_LOG_LEVEL_ERR is not set
    # CONFIG_APP_LOG_LEVEL_WRN is not set
    # CONFIG_APP_LOG_LEVEL_INF is not set
    CONFIG_APP_LOG_LEVEL_DBG=y
    # CONFIG_APP_LOG_LEVEL_DEFAULT is not set
    CONFIG_APP_LOG_LEVEL=4
    Hope this is the right file.
    Thanks
    Is there any test done on your side I'm looking for your test
  • Yes, I have tested this now and reproduced the issue. I will give this priority now and will notify you if I figure something out.
  • I have done some more testing, and it very much looks like there is a bug going on. Unfortunately I don't have a workaround for this at the moment, but I will report the bug internally and come back with more information later on.
  • Thank you,
    Looking forward to some progress on this issue
