nRF9151 TF-M Boot Hang When Enabling NVS for Onomondo SoftSIM
Hardware:
nRF9151 DK
Board: nrf9151dk/nrf9151/ns
  • nRF Connect SDK version: 3.2.1
  • Zephyr version: 0.17
Issue Description:
I have a working LWM2M application with TF-M enabled. When I integrate Onomondo SoftSIM library, it requires CONFIG_NVS=y to be enabled. However, as soon as I enable NVS, the device hangs during boot and never reaches main().
Broken Configuration (with NVS):
CONFIG_BUILD_WITH_TFM=y
CONFIG_LWM2M_CLIENT_UTILS=y
CONFIG_NVS=y
CONFIG_PM_PARTITION_SIZE_NVS_STORAGE=0x8000
CONFIG_SOFTSIM=y
Partition Layout:
The partition layout appears correct with no overlaps. NVS is in non-secure region:
nvs_storage:
  address: 0xe8000
  end_address: 0xf0000
  region: flash_primary
tfm_its:
  address: 0xf8000
tfm_otp_nv_counters:
  address: 0xfa000
tfm_nonsecure:
  address: 0x18000
  end_address: 0x78000
Questions:
  1. Is this a known SPU (System Protection Unit) permissions issue where NVS tries to access flash before TF-M configures the regions as non-secure?
  2. How can I configure TF-M to allow the NVS flash region (0xe8000-0xf0000) to be accessible from non-secure code during early boot?
  3. Is there a recommended initialization order or additional TF-M configuration needed when combining TF-M + NVS on nRF9151?
Any guidance would be greatly appreciated.
    can you provide .config file, and partitions.yml found in the build directory?
    Thank you for the response.
    Here is partitions.yml.
    EMPTY_0:
      address: 0xc000
      end_address: 0x10000
      placement:
        before:
        - mcuboot_pad
    EMPTY_1:
      address: 0xfa000
      end_address: 0x100000
      placement:
        after:
        - settings_storage
    app:
      address: 0x18000
      end_address: 0x80000
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        align:
          end: 0x1000
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0x10000
      end_address: 0x10200
      placement:
        align:
          start: 0x8000
        before:
        - mcuboot_primary_app
    mcuboot_primary:
      address: 0x10000
      orig_span: &id001
      - app
      - tfm
      - mcuboot_pad
      sharers: 0x1
      span: *id001
    mcuboot_primary_app:
      address: 0x10200
      orig_span: &id002
      - app
      - tfm
      span: *id002
    mcuboot_secondary:
      address: 0x80000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x8000
      share_size:
      - mcuboot_primary
    mcuboot_sram:
      address: 0x20000000
      end_address: 0x20008000
      orig_span: &id003
      - tfm_sram
      region: sram_primary
      span: *id003
    nonsecure_storage:
      address: 0xf0000
      end_address: 0xfa000
      orig_span: &id004
      - settings_storage
      - nvs_storage
      span: *id004
    nrf_modem_lib_ctrl:
      address: 0x20008000
      end_address: 0x200084e8
      inside:
      - sram_nonsecure
      placement:
        after:
        - tfm_sram
        - start
    nrf_modem_lib_rx:
      address: 0x2000a568
      end_address: 0x2000c568
      inside:
      - sram_nonsecure
      placement:
        after:
        - nrf_modem_lib_tx
    nrf_modem_lib_sram:
      address: 0x20008000
      orig_span: &id005
      - nrf_modem_lib_ctrl
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id005
    nrf_modem_lib_tx:
      address: 0x200084e8
      end_address: 0x2000a568
      inside:
      - sram_nonsecure
      placement:
        after:
    nvs_storage:
      address: 0xf0000
      end_address: 0xf8000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x8000
        before:
        - settings_storage
    otp:
      address: 0xff8108
      end_address: 0xff83fc
      region: otp
    settings_storage:
      address: 0xf8000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x8000
        before:
        - end
    sram_nonsecure:
      address: 0x20008000
      end_address: 0x20040000
      orig_span: &id006
      - sram_primary
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id006
    sram_primary:
      address: 0x2000c568
    sram_secure:
      address: 0x20000000
      orig_span: &id007
      - tfm_sram
      span: *id007
    tfm:
      address: 0x10200
      end_address: 0x18000
      inside:
      placement:
        before:
        - app
    tfm_nonsecure:
      address: 0x18000
      orig_span: &id008
      - app
      span: *id008
    tfm_secure:
      address: 0x10000
      orig_span: &id009
      - mcuboot_pad
      - tfm
      span: *id009
    tfm_sram:
      address: 0x20000000
      inside:
      - sram_secure
      placement:
        after:
        - start
    The .config
    SB_CONFIG_BOARD="nrf9151dk"
    SB_CONFIG_BOARD_REVISION=""
    SB_CONFIG_BOARD_NRF9151DK=y
    SB_CONFIG_BOARD_NRF9151DK_NRF9151_NS=y
    SB_CONFIG_BOARD_QUALIFIERS="nrf9151/ns"
    SB_CONFIG_SOC="nrf9151"
    SB_CONFIG_SOC_SERIES="nrf91"
    SB_CONFIG_SOC_FAMILY="nordic_nrf"
    SB_CONFIG_SOC_FAMILY_NORDIC_NRF=y
    SB_CONFIG_SOC_SERIES_NRF91X=y
    SB_CONFIG_SOC_NRF9120=y
    SB_CONFIG_SOC_NRF9151_LACA=y
    # Sysbuild image configuration
    # Modules
    # Available modules.
    SB_CONFIG_ZEPHYR_PROXICURE_FIRMWARE_MODULE=y
    # nrf (D:/ProxiCure/Firmware/nrf)
    SB_CONFIG_PARTITION_MANAGER=y
    SB_CONFIG_PM_MCUBOOT_PAD=0x200
    # SB_CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY is not set
    # SB_CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    SB_CONFIG_BUILD_OUTPUT_BIN=y
    SB_CONFIG_BUILD_OUTPUT_HEX=y
    SB_CONFIG_BOARD_IS_NON_SECURE=y
    SB_CONFIG_APPCORE_REMOTE_BOARD_TARGET_CPUCLUSTER="cpuapp"
    SB_CONFIG_APPCORE_REMOTE_DOMAIN="CPUAPP"
    # Secure Bootloader
    # SB_CONFIG_SECURE_BOOT_APPCORE is not set
    # end of Secure Bootloader
    # MCUboot configuration
    # SB_CONFIG_MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION is not set
    SB_CONFIG_MCUBOOT_EXTRA_IMAGES=0
    SB_CONFIG_MCUBOOT_MAX_UPDATEABLE_IMAGES=4
    SB_CONFIG_MCUBOOT_MIN_UPDATEABLE_IMAGES=1
    SB_CONFIG_MCUBOOT_MIN_ADDITIONAL_UPDATEABLE_IMAGES=0
    SB_CONFIG_MCUBOOT_UPDATEABLE_IMAGES=1
    SB_CONFIG_MCUBOOT_ADDITIONAL_UPDATEABLE_IMAGES=0
    SB_CONFIG_MCUBOOT_APP_SYNC_UPDATEABLE_IMAGES=y
    # SB_CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
    # end of MCUboot configuration
    # SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD is not set
    SB_CONFIG_SUPPORT_QSPI_XIP=y
    # Bluetooth Fair Pair
    SB_CONFIG_BT_FAST_PAIR_MODEL_ID=0x1000000
    SB_CONFIG_BT_FAST_PAIR_ANTI_SPOOFING_PRIVATE_KEY=""
    # end of Bluetooth Fair Pair
    SB_CONFIG_DFU_ZIP=y
    SB_CONFIG_DFU_ZIP_APP=y
    # SB_CONFIG_DFU_ZIP_BLUETOOTH_MESH_METADATA is not set
    # SB_CONFIG_MATTER is not set
    # Wi-Fi
    # SB_CONFIG_WIFI_NRF70 is not set
    # end of Wi-Fi
    # SB_CONFIG_APPROTECT_USE_UICR is not set
    # SB_CONFIG_APPROTECT_LOCK is not set
    # SB_CONFIG_APPROTECT_USER_HANDLING is not set
    SB_CONFIG_APPROTECT_NO_SYSBUILD=y
    # SB_CONFIG_SECURE_APPROTECT_USE_UICR is not set
    # SB_CONFIG_SECURE_APPROTECT_LOCK is not set
    # SB_CONFIG_SECURE_APPROTECT_USER_HANDLING is not set
    SB_CONFIG_SECURE_APPROTECT_NO_SYSBUILD=y
    # SB_CONFIG_LWM2M_CARRIER_DIVIDED_DFU is not set
    # TF-M
    # SB_CONFIG_TFM_OTP_PSA_CERTIFICATE_REFERENCE is not set
    # end of TF-M
    SB_CONFIG_SUPPORT_FIRMWARE_LOADER_BLE_MCUMGR=y
    SB_CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (D:/ProxiCure/Firmware/nrf)
    SB_CONFIG_ZEPHYR_HOSTAP_MODULE=y
    SB_CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    SB_CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    SB_CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
    SB_CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    SB_CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    SB_CONFIG_ZEPHYR_CJSON_MODULE=y
    SB_CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    SB_CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    SB_CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    SB_CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    SB_CONFIG_ZEPHYR_COREMARK_MODULE=y
    SB_CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    SB_CONFIG_ZEPHYR_CHRE_MODULE=y
    SB_CONFIG_ZEPHYR_LZ4_MODULE=y
    SB_CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    SB_CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    SB_CONFIG_ZEPHYR_CMSIS_MODULE=y
    SB_CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    SB_CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    SB_CONFIG_ZEPHYR_CMSIS_6_MODULE=y
    SB_CONFIG_ZEPHYR_FATFS_MODULE=y
    SB_CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    SB_CONFIG_ZEPHYR_HAL_ST_MODULE=y
    SB_CONFIG_ZEPHYR_HAL_TDK_MODULE=y
    SB_CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    SB_CONFIG_ZEPHYR_LIBLC3_MODULE=y
    SB_CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    SB_CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    SB_CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    SB_CONFIG_ZEPHYR_LVGL_MODULE=y
    SB_CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    SB_CONFIG_ZEPHYR_NANOPB_MODULE=y
    SB_CONFIG_ZEPHYR_NRF_WIFI_MODULE=y
    SB_CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    SB_CONFIG_ZEPHYR_PERCEPIO_MODULE=y
    SB_CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    SB_CONFIG_ZEPHYR_SEGGER_MODULE=y
    SB_CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    SB_CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # softsim (D:/ProxiCure/Firmware/modules/lib/onomondo-softsim)
    # Onomondo SoftSIM Options
    # SB_CONFIG_SOFTSIM_BUNDLE_TEMPLATE_HEX is not set
    # end of Onomondo SoftSIM Options
    SB_CONFIG_ZEPHYR_SOFTSIM_MODULE=y
    # end of softsim (D:/ProxiCure/Firmware/modules/lib/onomondo-softsim)
    SB_CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    SB_CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    SB_CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # Unavailable modules, please install those via the project manifest.
    # end of Modules
    # SB_CONFIG_WARN_EXPERIMENTAL is not set
    SB_CONFIG_WARN_DEPRECATED=y
    SB_CONFIG_SUPPORT_BOOTLOADER=y
    SB_CONFIG_SUPPORT_BOOTLOADER_MCUBOOT_ZEPHYR=y
    # SB_CONFIG_BOOTLOADER_NONE is not set
    SB_CONFIG_BOOTLOADER_MCUBOOT=y
    # SB_CONFIG_MCUBOOT_MODE_SINGLE_APP is not set
    # SB_CONFIG_MCUBOOT_MODE_SWAP_USING_OFFSET is not set
    SB_CONFIG_MCUBOOT_MODE_SWAP_USING_MOVE=y
    # SB_CONFIG_MCUBOOT_MODE_SWAP_WITHOUT_SCRATCH is not set
    # SB_CONFIG_MCUBOOT_MODE_SWAP_SCRATCH is not set
    # SB_CONFIG_MCUBOOT_MODE_OVERWRITE_ONLY is not set
    # SB_CONFIG_MCUBOOT_MODE_DIRECT_XIP is not set
    # SB_CONFIG_MCUBOOT_MODE_DIRECT_XIP_WITH_REVERT is not set
    # SB_CONFIG_MCUBOOT_MODE_RAM_LOAD is not set
    # SB_CONFIG_MCUBOOT_MODE_RAM_LOAD_WITH_REVERT is not set
    # SB_CONFIG_MCUBOOT_MODE_FIRMWARE_UPDATER is not set
    # SB_CONFIG_MCUBOOT_MODE_SINGLE_APP_RAM_LOAD is not set
    SB_CONFIG_SIGNATURE_TYPE="ECDSA_P256"
    # SB_CONFIG_BOOT_SIGNATURE_TYPE_NONE is not set
    # SB_CONFIG_BOOT_SIGNATURE_TYPE_RSA is not set
    SB_CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
    # SB_CONFIG_BOOT_SIGNATURE_TYPE_ED25519 is not set
    SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="D:/ProxiCure/Firmware/bootloader/mcuboot/root-ec-p256.pem"
    SB_CONFIG_SUPPORT_BOOT_ENCRYPTION=y
    # SB_CONFIG_BOOT_ENCRYPTION is not set
    SB_CONFIG_SUPPORT_FIRMWARE_LOADER_SMP_SVR=y
    # Build options
    # SB_CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # end of Build options
  • luqman said:
    The .config
    This is the sysbuild configs. Can you post the file located here?
    I tried running with your configs
    CONFIG_NVS=y
    and the sample ran just fine.
    (I left out #CONFIG_SOFTSIM=y but I can try with that also)
    Firmware\nrf9151-firmware\build\zephyr\.config
    Also i used the west. yaml file for adding the soft_sim library.
    manifest:
      version: "1.0"
      remotes:
        - name: ncs
          url-base: https://github.com/nrfconnect
        - name: onomondo
          url-base: https://github.com/onomondo
      projects:
        - name: nrf
          repo-path: sdk-nrf
          remote: ncs
          revision: v3.2.1
          import: true
        - name: nrf-softsim
          remote: onomondo
          path: modules/lib/onomondo-softsim
          revision: master
      self:
        path: proxiCure-firmware
        west-commands: scripts/west-commands.yml
    Also, I confirm that when I add NVS without the soft_sim library, it works fine, but when I add the soft_sim, it has a dependency on using the NVS. Now, what I imagine happening is that the soft_sim tries to use the nvs on early boot state, where the TFM is restricted to read/write the nvs for the private key of the sim.
    Because it still fails for me. i'm waiting for your tests
    Thank you
  • "Firmware\nrf9151-firmware\build\zephyr\.config" is the wrong file. I told you which file to upload. The one you provided is for sysbuild, which is why all of the configs start with "SB". Most like the path should be something like this "Firmware\nrf9151-firmware\build\nrf9151-firmware\zephyr\.config".
