We are updating an older platform with the nRF9151 on an add-on PCB.The platform has very limited processing power and buffer space.
The nRF9151 module with the at firmware is connected via UART without CTS/RTS connected. Our previous modules had the option to limit the amount of data received in the command used to get TCP/IP socket data, hence the lack of hardware flow control. We have one line of hardware communication we might be able to convert to a CTS connection, but it's sub optimal.
The question is if there's a command based way to limit the amount of data received through the UART from a TCP/IP socket via AT#XRECV or similar while using the at-firmware, or do we need to make either custom firmware for the nRF9151 module or hardware changes?
Daniel.
