Obtaining UUID of a primary service
I'm trying to write a generic tool that lists the attribute table of a connected BLE Peripheral. For each discovered attribute I want to log to the console the attribute number, attribute type and its UUID.
I have a problem with primary service declarations. I can get the declaration UUID (2800) but I don't seem to be able to get the UUID of the service being declared. My understanding is that the service's own UUID is in the user_data field of the bt_gatt_attr.
My code in this area looks like this:
   if (bt_uuid_cmp(attr->uuid, BT_UUID_GATT_PRIMARY) == 0) {
        printk("Discovered Primary Service\n");
        // The service's own UUID is in the user_data field of the bt_gatt_attr
        // https://docs.zephyrproject.org/latest/doxygen/html/group__bt__gatt__client.html#:~:text=bt_gatt_discover_func_t,-typedef%20uint8_t(*&text=Discover%20attribute%20callback%20function.,-conn&text=Connection%20object.&text=Attribute%20found%2C%20or%20NULL%20if%20not%20found.&text=Discovery%20parameters%20given.,order%20to%20cache%20its%20information.&text=bt_gatt_attr%20is%20given%20as%20an,See%20below.
        struct bt_gatt_service_val *svc = (struct bt_gatt_service_val *)attr->user_data;
        uint16_t uuid_val = BT_UUID_16(svc->uuid)->val;
        printk("Service UUID = %d\n",uuid_val);
But I'm always getting the same value from the user_data  UUID field which as a uint16_t is 57926. Like this:
Creating connection with Coded PHY support
Connected: D1:00:2D:79:94:DD (random)
Service UUID = 57926
Discovered attribute, handle: 01 uuid: 2800 Primary Service
Discovered attribute, handle: 02 uuid: 2803   Characteristic
Discovered attribute, handle: 03 uuid: 2a05     Service Changed
Discovered attribute, handle: 04 uuid: 2902      Client Characteristic Configuration
Discovered attribute, handle: 05 uuid: 2803   Characteristic
Discovered attribute, handle: 06 uuid: 2b29     Client Supported Features
Discovered attribute, handle: 07 uuid: 2803   Characteristic
Discovered attribute, handle: 08 uuid: 2b2a     Database Hash
Discovered attribute, handle: 09 uuid: 2800 Primary Service
Discovered attribute, handle: 10 uuid: 2803   Characteristic
Discovered attribute, handle: 11 uuid: 2a00     Device Name
Discovered attribute, handle: 12 uuid: 2803   Characteristic
Discovered attribute, handle: 13 uuid: 2a01     Appearance
Discovered attribute, handle: 14 uuid: 2803   Characteristic
Discovered attribute, handle: 15 uuid: 2a04     Peripheral Preferred Connection Parameters
Discovered attribute, handle: 16 uuid: 2800 Primary Service
Discovered attribute, handle: 17 uuid: 2803   Characteristic
Discovered attribute, handle: 18 uuid: 2a19     Battery Level
Discovered attribute, handle: 19 uuid: 2902      Client Characteristic Configuration
Discovered attribute, handle: 20 uuid: 2904    Characteristic Presentation Format
Discovered attribute, handle: 21 uuid: 2800 Primary Service
Discovered attribute, handle: 22 uuid: 2803   Characteristic
Discovered attribute, handle: 23 uuid: 2a24     Model Number String
Discovered attribute, handle: 24 uuid: 2803   Characteristic
Discovered attribute, handle: 25 uuid: 2a29     Manufacturer Name String
Discovered attribute, handle: 26 uuid: 2800 Primary Service
Discovered attribute, handle: 27 uuid: 2803   Characteristic
Discovered attribute, handle: 28 uuid: 2a37     Heart Rate Measurement
Discovered attribute, handle: 29 uuid: 2902      Client Characteristic Configuration
Discovered attribute, handle: 30 uuid: 2803   Characteristic
Discovered attribute, handle: 31 uuid: 2a38     Body Sensor Location
Discovered attribute, handle: 32 uuid: 2803   Characteristic
Discovered attribute, handle: 33 uuid: 2a39     Heart Rate Control Point
Discovery complete
What am I doing wrong?
Thanks in anticipation
