NCS 3.2.1 LPCOMP init failed (NCS 3.2.1, nrfx 4.0.1)
Hi everyone,
For mthe prject I'm working I must use the LPCOMP module to detect a cross. but anytime a init the LPCOMP module my code seems to freeze and nothing else happen. So it put a check inside and my code just loop since the init is never true.
prj.conf
CONFIG_NRFX_LPCOMP=y
CHIP_ERROR AppTask::InitLPCOMP()
	nrfx_lpcomp_config_t cfg = NRFX_LPCOMP_DEFAULT_CONFIG(NRFX_ANALOG_EXTERNAL_AIN3);
    cfg.reference = NRF_LPCOMP_REF_SUPPLY_9_16;    //
    cfg.hyst = NRF_LPCOMP_HYST_ENABLED,// NRF_LPCOMP_HYST_50mV;
    cfg.interrupt_priority = NRFX_DEFAULT_IRQ_PRIORITY;
    cfg.detection = NRF_LPCOMP_DETECT_CROSS;       // permet UP et DOWN
    int err = nrfx_lpcomp_init(&cfg, (nrfx_lpcomp_event_handler_t)LPCOMP_Handler);
	while( nrfx_lpcomp_init_check() != true)
		nrf_gpio_pin_toggle(SbgGpio2);
		k_usleep(10);
	nrfx_lpcomp_start( NRF_LPCOMP_INT_READY_MASK | NRF_LPCOMP_INT_CROSS_MASK, 0 );
    return CHIP_NO_ERROR;
If anyone can provide some help.
Thanks.
Parents Reply
  • HI  ,
    I implement the zephyr comparator but the callback is never called. here is my code
    &comp {
    	status = "okay";
    	psel = <3>;
    	refsel = "VDD_9_16";
    	compatible = "nordic,nrf-lpcomp";
    	enable-hyst;
    static void lpcomp_callback(const struct device *dev, void *user_data)
    	int val = comparator_get_output(lpcomp);
    	gpio_pin_set_dt(&ledds5, val);
    	printk("Comparator output value %d\n", val);
    //Init comp
    comparator_set_trigger(lpcomp, COMPARATOR_TRIGGER_BOTH_EDGES);
    comparator_set_trigger_callback(lpcomp, lpcomp_callback, NULL);
