Is there a Library connect MicroSDHC via SPI
i want/need to connect & access a microSD Card (32GB) on an breakout board via SPI (technical reasons) and want to use the suggested PINS (28-31) as in the intermediate lesson 5 exercise 1.
Is there a separate library (except the described spi, gios, devicetree) available/required, like an SD.h?
Thanks for hints/suggestions
    ''Is there a separate library (except the described spi, gios, devicetree) available/required, like an SD.h?''
    There is no separate Arduino-style SD.h-like library for NCS.
    As you are on dev academy intermediate course (lesson 5 exercise 1), so you know how to enable SPI and GPIO over the driver. You have to enable the follwoing config in prj.conf file
    CONFIG_GPIO=y
    CONFIG_SPI=y
    You can add sd card following way (https://docs.nordicsemi.com/bundle/ncs-latest/page/zephyr/services/storage/disk/access.html#sd_card_support_via_spi)
    &spi1 {
        status = "okay";
        cs-gpios = <&gpio0 27 GPIO_ACTIVE_LOW>;  /* example CS pin */
        sdhc0: sdhc@0 {
            compatible = "zephyr,sdhc-spi-slot";
            reg = <0>;
            status = "okay";
            mmc {
                compatible = "zephyr,sdmmc-disk";
                disk-name = "SD";
                status = "okay";
            spi-max-frequency = <24000000>;
    For the nRF5SDK. there is SD card library that communicates SD over SPI (nRF5 SD card lib) but not on NCS.
    Thanks.
    BR
    Kazi
    ok, i assumed it, but thanks for the suggestion. Compiling works, initialization of the microSD not yet.
    But what means NCS?
    NCS means nRF Connect for SDK.
    ''Compiling works, initialization of the microSD not yet.''
    Can you show me the board files?
  • // nrf52dk_nrf52832.overlay:
    &spi0 { status = "disabled";};
    &i2c1 { status = "disabled";};
    &spi1 {
    /* What about this property?? */
    //compatible = "nordic,nrf-spi";//using SPI as per ERRATA 58
    status = "okay";
    pinctrl-0 = <&spi1_default>;
    pinctrl-1 = <&spi1_sleep>;
    pinctrl-names="default", "sleep";
    cs-gpios = <&gpio0 31 GPIO_ACTIVE_LOW>;
    sdhc0: sdhc@0 {
    status = "okay";
    reg = <0>;
    mmc {
    status = "okay";
    disk-name = "MMC SD";
    spi-max-frequency = <24000000>; //max frequency up to 25MHZ
    /* Change the pin configuration */
    &pinctrl{
    spi1_default: spi1_default{
    group1{
    psels=<NRF_PSEL(SPIM_SCK, 0, 28)>,
    <NRF_PSEL(SPIM_MOSI, 0, 29)>,
    <NRF_PSEL(SPIM_MISO, 0, 30)>;
    spi1_sleep: spi1_sleep{
    group1{
    low-power-enable;
    Try to set SPI max frequency 400 kHz
    spi-max-frequency = <400000>;
    The overlay file based on your overlay be like this:
    &spi1 {
        compatible = "nordic,nrf-spim";   /* enable SPIM driver */
        status = "okay";
        sdhc0: sdhc@0 {
            reg = <0>;
            status = "okay";
            spi-max-frequency = <400000>; /* start low */
            mmc {
                status = "okay";
