Multiple partitions SDK 3.2.0 and toolchain 3.2.1
I am trying to access to two partitions of 2gb each on a micro SD card of 32gb.
I can access to one partition of 32gb in my micro sd card but as it is formatted in FAT32, if I have only one partition, I will not access to the entirety of the micro SD card.
Do you know which parameter I have to change to access to two partitions on the same micro SD card, please ?
Below there are the different files of code I use.
Thank you !
Jade
main.c
 * Copyright (c) 2019 Tavish Naruka <[email protected]>
 * Copyright (c) 2023 Nordic Semiconductor ASA
 * Copyright (c) 2023 Antmicro <www.antmicro.com>
/* Sample which uses the filesystem API and SDHC driver */
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/storage/disk_access.h>
#include <zephyr/fs/fs.h>
/* Définition des pins SPI basées sur votre pinctrl */
#define SPI_SCK_PIN  13 // P1.13
#define SPI_MOSI_PIN 12 // P1.12
#define SPI_MISO_PIN 14 // P1.14
#define SPI_CS_PIN   15 // P1.15 (Celui que vous soupçonnez)
#define SPI_PORT     DEVICE_DT_GET(DT_NODELABEL(gpio1))
#if defined(CONFIG_FAT_FILESYSTEM_ELM)
#include <ff.h>
PARTITION VolToPart[] = {
    {0, 1},  /* SD1 -> partition 1 */
    {0, 2},  /* SD2 -> partition 2 */
 *  Note the fatfs library is able to mount only strings inside _VOLUME_STRS
 *  in ffconf.h
#if defined(CONFIG_DISK_DRIVER_MMC)
#define DISK_DRIVE_NAME "SDHC0"
#else
#define DISK_MOUNT_PT "/"DISK_DRIVE_NAME":"
#define DISK_MOUNT_PTSD1 "/SD1:"
#define DISK_MOUNT_PTSD2 "/SD2:"
#define MAX_PARTS  2  /* jusqu’à 4 partitions possibles */
#define CD_NODE DT_NODELABEL(sd_cd0)
/* Un FATFS par partition */
//static FATFS fat_fs[MAX_PARTS];
//static struct fs_mount_t mp[MAX_PARTS];
static const char *disk_names[MAX_PARTS] = {
    "SD1", "SD2"
static const char *mount_points[MAX_PARTS] = {
    "/SD1:", "/SD2:"
// static FATFS fat_fs;
// /* mounting info */
// static struct fs_mount_t mp = {
// 	.type = FS_FATFS,
// 	.fs_data = &fat_fs,
#elif defined(CONFIG_FILE_SYSTEM_EXT2)
#include <zephyr/fs/ext2.h>
#define DISK_MOUNT_PT "/ext"
// 	.type = FS_EXT2,
// 	.flags = FS_MOUNT_FLAG_NO_FORMAT,
// 	.storage_dev = (void *)DISK_DRIVE_NAME,
// 	.mnt_point = "/ext",
#define FS_RET_OK FR_OK
#else
#define FS_RET_OK 0
LOG_MODULE_REGISTER(main);
// #define MAX_PATH 128
// #define SOME_FILE_NAME "some.dat"
// #define SOME_DIR_NAME "some"
// #define SOME_REQUIRED_LEN MAX(sizeof(SOME_FILE_NAME), sizeof(SOME_DIR_NAME))
static int lsdir(const char *path);
// #ifdef CONFIG_FS_SAMPLE_CREATE_SOME_ENTRIES
// static bool create_some_entries(const char *base_path)
// 	char path[MAX_PATH];
// 	struct fs_file_t file;
// 	int base = strlen(base_path);
// 	fs_file_t_init(&file);
// 	if (base >= (sizeof(path) - SOME_REQUIRED_LEN)) {
// 		LOG_ERR("Not enough concatenation buffer to create file paths");
// 		return false;
// 	LOG_INF("Creating some dir entries in %s", base_path);
// 	strncpy(path, base_path, sizeof(path));
// 	path[base++] = '/';
// 	path[base] = 0;
// 	strcat(&path[base], SOME_FILE_NAME);
// 	if (fs_open(&file, path, FS_O_CREATE) != 0) {
// 		LOG_ERR("Failed to create file %s", path);
// 		return false;
// 	fs_close(&file);
// 	path[base] = 0;
// 	strcat(&path[base], SOME_DIR_NAME);
// 	if (fs_mkdir(path) != 0) {
// 		LOG_ERR("Failed to create dir %s", path);
// 		/* If code gets here, it has at least successes to create the
// 		 * file so allow function to return true.
// 	return true;
// #endif
static const char *disk_mount_pt = DISK_MOUNT_PT;
static const char *disk_mount_ptSD1 = DISK_MOUNT_PTSD1;
static const char *disk_mount_ptSD2 = DISK_MOUNT_PTSD2;
static FATFS fat_fs; // Instance de l'objet FatFs
    .type = FS_FATFS,           // Le type de FS
    .mnt_point = "/SD:",        // Le point de montage (doit commencer par / et finir par :)
    .fs_data = &fat_fs,         // Pointeur vers l'objet fat_fs
    .storage_dev = "1:",        // DOIT correspondre au disk-name de l'overlay
    .flags = FS_MOUNT_FLAG_AUTOMOUNT, // Optionnel : aide à l'initialisation
static FATFS fat_fs_p1;
static FATFS fat_fs_p2;
// /* Partition 1 */
// static struct fs_mount_t mp_p1 = {
//     .mnt_point = "/SD0:",
//     .fs_data = &fat_fs_p1,
//     .storage_dev = "0:", // Le nom du disque dans l'overlay
// /* Partition 2 */
// static struct fs_mount_t mp_p2 = {
//     .mnt_point = "/SD1:",
//     .fs_data = &fat_fs_p2,
//     .storage_dev = "1:",
    .type = FS_FATFS,
    .mnt_point = "/P1:",
    .storage_dev = "0:", // On utilise le LABEL de l'overlay
    .type = FS_FATFS,
    .mnt_point = "/P2:",
    .storage_dev = "1:", // On utilise le LABEL de l'overlay
void mount_simple(void) {
    int res = fs_mount(&mp);
    if (res == 0) {
        printk("Succès ! Carte SD montée sur /SD:\n");
    } else {
        printk("Erreur de montage : %d (Vérifie le format FAT32)\n", res);
void mount_dual_partitions(void) {
    int res;
    // Initialiser le disque physique une seule fois
    disk_access_init("SD");
    // Monter Partition 1
    res = fs_mount(&mp_p1);
    if (res == 0) printk("Partition 1 montee sur /SD1:\n");
    // Monter Partition 2
    res = fs_mount(&mp_p2);
    if (res == 0) printk("Partition 2 montee sur /SD2:\n");
static FATFS fat_fs_d;
static FATFS fat_fs_e;
static struct fs_mount_t mp_d = {
    .type = FS_FATFS,
    .mnt_point = "/D:",
    .fs_data = &fat_fs_d,
    .storage_dev = "SD:0", // ":0" force la 1ère partition de la table MBR
static struct fs_mount_t mp_e = {
    .type = FS_FATFS,
    .mnt_point = "/E:",
    .fs_data = &fat_fs_e,
    .storage_dev = "SD:1", // ":1" force la 2ème partition de la table MBR
void mount_all(void) {
    // Initialise le hardware une seule fois
    // Monte les deux volumes
    if (fs_mount(&mp_d) == 0) printk("Partition D montee !\n");
    if (fs_mount(&mp_e) == 0) printk("Partition E montee !\n");
void test_write_file(void)
    int ret;
    const char *path = "/SD:/hello.txt";
    const char *data = "Test reussi sur nRF54L15 !\n";
    /* 1. Ouvrir le fichier (le creer s'il n'existe pas) */
    ret = fs_open(&file, path, FS_O_CREATE | FS_O_WRITE);
    if (ret < 0) {
        printk("Erreur ouverture fichier : %d\n", ret);
        return;
    /* 2. Ecrire les donnees */
    ret = fs_write(&file, data, strlen(data));
    if (ret < 0) {
        printk("Erreur ecriture : %d\n", ret);
    } else {
        printk("Ecrit %d octets dans %s\n", ret, path);
    /* 3. Fermer le fichier (Tres important pour vider le cache !) */
    fs_close(&file);
void safely_unmount(void)
    int res;
    res = fs_unmount(&mp); // On utilise la structure static mp
    if (res == 0) {
        printk("Carte SD demontee avec succes. Vous pouvez la retirer.\n");
    } else {
        printk("Erreur lors du demontage : %d\n", res);
// void mount_all_partitions(void)
//     for (int i = 0; i < MAX_PARTS; i++) {
// 		mp[i].type = FS_FATFS;
// 		mp[i].fs_data = &fat_fs[i];
// // 	.fs_data = &fat_fs
// 		if (i == 0) {
// 			mp[i].mnt_point = disk_mount_ptSD1;
// 		if (i == 1) {
// 			mp[i].mnt_point = disk_mount_ptSD2;
//         if (i == 0) {
// 			mp[i].storage_dev = (void *)"SD1";
// 		if (i == 1) {
// 			mp[i].storage_dev = (void *)"SD2";
//         int res = fs_mount(&mp[i]);
//         if (res == FR_OK) {
//             printk("Partition %s montée sur %s\n", disk_names[i], mount_points[i]);
//         } else {
//             printk("Partition %s non montée (code %d)\n", disk_names[i], res);
// void UNmount_all_partitions(void)
//         mp[i].mnt_point = mount_points[i];
//         mp[i].storage_dev = (void *)disk_names[i];
//         int res = fs_unmount(&mp[i]);
//             printk("Partition %s demontée sur %s\n", disk_names[i], mount_points[i]);
//         } else {
//             printk("Partition %s non demontée (code %d)\n", disk_names[i], res);
// static void write_to_sd(const char *mount_point)
//     char file_path[64];
//     int ret;
//     /* Construire le chemin du fichier */
//     printk("OK");
//     snprintf(file_path, sizeof(file_path), "/SD1:/test.txt", mount_point);
// printk("OK");
//     printk("OK");
//     /* Ouvrir (ou créer) le fichier en écriture */
//     ret = fs_open(&file, file_path, FS_O_CREATE | FS_O_RDWR);
//     printk("OK");
//     if (ret) {
//         LOG_ERR("Erreur d'ouverture du fichier (%d)", ret);
//         return;
//     /* Données à écrire */
//     const char msg[] = "Hello SD card from nRF54L15!\n";
//     /* Écriture */
//     ret = fs_write(&file, msg, sizeof(msg) - 1);
//     if (ret < 0) {
//         LOG_ERR("Erreur d'écriture (%d)", ret);
//         fs_close(&file);
//         return;
//     LOG_INF("Écrit %d octets dans %s", ret, file_path);
//     /* Fermer le fichier */
//     fs_close(&file);
//     /* Lire pour vérifier */
//     ret = fs_open(&file, file_path, FS_O_READ);
//     if (ret) {
//         LOG_ERR("Erreur de réouverture du fichier (%d)", ret);
//         return;
//     char buf[64];
//     int n = fs_read(&file, buf, sizeof(buf) - 1);
//     if (n >= 0) {
//         buf[n] = '\0';
//         LOG_INF("Contenu lu : %s", buf);
//     } else {
//         LOG_ERR("Erreur de lecture (%d)", n);
//     fs_close(&file);
// strcpy(file_path, "SD2:/test.txt");
//     if (ret) {
//         return;
//     const char msg2[] = "Hello SD card from nRF54L15!\n";
//     /* Écriture */
//     ret = fs_write(&file, msg2, sizeof(msg2) - 1);
//     if (ret < 0) {
//         fs_close(&file);
//         return;
//     fs_close(&file);
//     if (ret) {
//         return;
//     n = fs_read(&file, buf, sizeof(buf) - 1);
//     if (n >= 0) {
//         buf[n] = '\0';
//     } else {
//     fs_close(&file);
// /* Petit utilitaire pour inspecter le MBR et afficher les partitions trouvées */
// static void print_mbr_info(void)
//     uint8_t mbr[512];
//     if (disk_access_read("SD", mbr, 0, 1) != 0) {
//         printk("Impossible de lire le MBR (disk_access_read)\n");
//         return;
//     printk("MBR signature: 0x%02x%02x\n", mbr[510], mbr[511]);
//     for (int i = 0; i < 4; i++) {
//         uint8_t part_type = mbr[446 + i*16 + 4];
//         uint32_t start_lba = mbr[446 + i*16 + 8] |
//                              (mbr[446 + i*16 + 9] << 8) |
//                              (mbr[446 + i*16 + 10] << 16) |
//                              (mbr[446 + i*16 + 11] << 24);
//         uint32_t num_sectors = mbr[446 + i*16 + 12] |
//                                (mbr[446 + i*16 + 13] << 8) |
//                                (mbr[446 + i*16 + 14] << 16) |
//                                (mbr[446 + i*16 + 15] << 24);
//         if (part_type != 0) {
//             printk("Partition %d: type=0x%02x start=%u sectors=%u\n",
//                    i+1, part_type, start_lba, num_sectors);
// void init_sd_card(void)
//     const char *disk_pdrv = "SD";
//     int ret;
//     ret = disk_access_init(disk_pdrv);
//     if (ret != 0) {
//         printk("Erreur init SD card (%d)\n", ret);
//     } else {
//         printk("SD card initialisée\n");
void main(void) {
    // 1. INITIALISATION PHYSIQUE (Une seule fois)
    if (disk_access_init(disk_pdrv) != 0) {
        LOG_ERR("Erreur d'initialisation physique !");
        return;
    uint64_t sector_count;
if (disk_access_ioctl("SD", DISK_IOCTL_GET_SECTOR_COUNT, &sector_count) != 0) {
    printk("Erreur : Le driver 'SD' n'est pas reconnu par disk_access\n");
    // NE PAS FAIRE DE DEINIT ICI !
    // 2. MONTAGE DU SYSTÈME DE FICHIERS
    // Assure-toi que mp.storage_dev = "SD"
    mount_dual_partitions();
    // if (res == 0) {
    //     printk("Succès : Carte montée !\n");
    // } else {
    //     printk("Erreur montage : %d\n", res);
    //test_write_file();
    //safely_unmount();
/* List dir entry by path
 * @param path Absolute path to list
 * @return Negative errno code on error, number of listed entries on
 *         success.
	int res;
	struct fs_dir_t dirp;
	static struct fs_dirent entry;
	int count = 0;
	fs_dir_t_init(&dirp);
	/* Verify fs_opendir() */
	res = fs_opendir(&dirp, path);
	if (res) {
		printk("Error opening dir %s [%d]\n", path, res);
		return res;
	printk("\nListing dir %s ...\n", path);
	for (;;) {
		/* Verify fs_readdir() */
		res = fs_readdir(&dirp, &entry);
		/* entry.name[0] == 0 means end-of-dir */
		if (res || entry.name[0] == 0) {
		if (entry.type == FS_DIR_ENTRY_DIR) {
			printk("[DIR ] %s\n", entry.name);
		} else {
			printk("[FILE] %s (size = %zu)\n",
				entry.name, entry.size);
		count++;
	/* Verify fs_closedir() */
	fs_closedir(&dirp);
	if (res == 0) {
		res = count;
	return res;
prf.conf
CONFIG_DISK_ACCESS=y
CONFIG_LOG=y
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_PRINTK=y
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_GPIO=y
CONFIG_SPI=y
CONFIG_NRFX_POWER=y
CONFIG_CBPRINTF_FP_SUPPORT=y
nrf54l15dk_nrf54l15_cpuapp.overlay
&spi21 {
    status = "okay";
    pinctrl-0 = <&spi21_default>;
    pinctrl-1 = <&spi21_sleep>;
    cs-gpios = <&gpio1 15 GPIO_ACTIVE_LOW>; // P1.06 - SD_nCS
	sdhc0: sdhc@0 {
		compatible = "zephyr,sdhc-spi-slot";
		reg = <0>;
		status = "okay";
		mmc {
			compatible = "zephyr,sdmmc-disk";
			disk-name = "SD";
			status = "okay";
		spi-max-frequency = <4000000>; //8000000 max
//     sd_cd: sd_card_detect {
//         compatible = "gpio-keys";
//         sd_cd0: sd_cd0 {
//             gpios = <&gpio1 15 GPIO_ACTIVE_LOW>;
//             label = "SD_CARD_DETECT";
&uart20 {
	status = "disabled";
&pinctrl {
    spi21_default: spi21_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 1, 13)>,
                    <NRF_PSEL(SPIM_MOSI, 1, 12)>,
                    <NRF_PSEL(SPIM_MISO, 1, 14)>;
    spi21_sleep: spi21_sleep {
        group1 {
            low-power-enable;
ffconf.h
/  Configurations of FatFs Module
#define FFCONF_DEF	80386	/* Revision ID */
/ Function Configurations
#define FF_FS_READONLY	0
/* This option switches read-only configuration. (0:Read/Write or 1:Read-only)
/  Read-only configuration removes writing API functions, f_write(), f_sync(),
/  f_unlink(), f_mkdir(), f_chmod(), f_rename(), f_truncate(), f_getfree()
/  and optional writing functions as well. */
#define FF_FS_MINIMIZE	0
/* This option defines minimization level to remove some basic API functions.
/   0: Basic functions are fully enabled.
/   1: f_stat(), f_getfree(), f_unlink(), f_mkdir(), f_truncate() and f_rename()
/      are removed.
/   2: f_opendir(), f_readdir() and f_closedir() are removed in addition to 1.
/   3: f_lseek() function is removed in addition to 2. */
#define FF_USE_FIND		0
/* This option switches filtered directory read functions, f_findfirst() and
/  f_findnext(). (0:Disable, 1:Enable 2:Enable with matching altname[] too) */
#define FF_USE_MKFS		0
/* This option switches f_mkfs(). (0:Disable or 1:Enable) */
#define FF_USE_FASTSEEK	0
/* This option switches fast seek feature. (0:Disable or 1:Enable) */
#define FF_USE_EXPAND	0
/* This option switches f_expand(). (0:Disable or 1:Enable) */
#define FF_USE_CHMOD	0
/* This option switches attribute control API functions, f_chmod() and f_utime().
/  (0:Disable or 1:Enable) Also FF_FS_READONLY needs to be 0 to enable this option. */
#define FF_USE_LABEL	0
/* This option switches volume label API functions, f_getlabel() and f_setlabel().
/  (0:Disable or 1:Enable) */
#define FF_USE_FORWARD	0
/* This option switches f_forward(). (0:Disable or 1:Enable) */
#define FF_USE_STRFUNC	0
#define FF_PRINT_LLI	0
#define FF_PRINT_FLOAT	0
#define FF_STRF_ENCODE	0
/* FF_USE_STRFUNC switches string API functions, f_gets(), f_putc(), f_puts() and
/  f_printf().
/   0: Disable. FF_PRINT_LLI, FF_PRINT_FLOAT and FF_STRF_ENCODE have no effect.
/   1: Enable without LF-CRLF conversion.
/   2: Enable with LF-CRLF conversion.
/  FF_PRINT_LLI = 1 makes f_printf() support long long argument and FF_PRINT_FLOAT = 1/2
/  makes f_printf() support floating point argument. These features want C99 or later.
/  When FF_LFN_UNICODE >= 1 with LFN enabled, string API functions convert the character
/  encoding in it. FF_STRF_ENCODE selects assumption of character encoding ON THE FILE
/  to be read/written via those functions.
/   0: ANSI/OEM in current CP
/   1: Unicode in UTF-16LE
/   2: Unicode in UTF-16BE
/   3: Unicode in UTF-8
/ Locale and Namespace Configurations
#define FF_CODE_PAGE	932
/* This option specifies the OEM code page to be used on the target system.
/  Incorrect code page setting can cause a file open failure.
/   437 - U.S.
/   720 - Arabic
/   737 - Greek
/   771 - KBL
/   775 - Baltic
/   850 - Latin 1
/   852 - Latin 2
/   855 - Cyrillic
/   857 - Turkish
/   860 - Portuguese
/   861 - Icelandic
/   862 - Hebrew
/   863 - Canadian French
/   864 - Arabic
/   865 - Nordic
/   866 - Russian
/   869 - Greek 2
/   932 - Japanese (DBCS)
/   936 - Simplified Chinese (DBCS)
/   949 - Korean (DBCS)
/   950 - Traditional Chinese (DBCS)
/     0 - Include all code pages above and configured by f_setcp()
#define FF_USE_LFN		0
#define FF_MAX_LFN		255
/* The FF_USE_LFN switches the support for LFN (long file name).
/   0: Disable LFN. FF_MAX_LFN has no effect.
/   1: Enable LFN with static working buffer on the BSS. Always NOT thread-safe.
/   2: Enable LFN with dynamic working buffer on the STACK.
/   3: Enable LFN with dynamic working buffer on the HEAP.
/  To enable the LFN, ffunicode.c needs to be added to the project. The LFN feature
/  requiers certain internal working buffer occupies (FF_MAX_LFN + 1) * 2 bytes and
/  additional (FF_MAX_LFN + 44) / 15 * 32 bytes when exFAT is enabled.
/  The FF_MAX_LFN defines size of the working buffer in UTF-16 code unit and it can
/  be in range of 12 to 255. It is recommended to be set 255 to fully support the LFN
/  specification.
/  When use stack for the working buffer, take care on stack overflow. When use heap
/  memory for the working buffer, memory management functions, ff_memalloc() and
/  ff_memfree() exemplified in ffsystem.c, need to be added to the project. */
#define FF_LFN_UNICODE	0
/* This option switches the character encoding on the API when LFN is enabled.
/   0: ANSI/OEM in current CP (TCHAR = char)
/   1: Unicode in UTF-16 (TCHAR = WCHAR)
/   2: Unicode in UTF-8 (TCHAR = char)
/   3: Unicode in UTF-32 (TCHAR = DWORD)
/  Also behavior of string I/O functions will be affected by this option.
/  When LFN is not enabled, this option has no effect. */
#define FF_LFN_BUF		255
#define FF_SFN_BUF		12
/* This set of options defines size of file name members in the FILINFO structure
/  which is used to read out directory items. These values should be suffcient for
/  the file names to read. The maximum possible length of the read file name depends
/  on character encoding. When LFN is not enabled, these options have no effect. */
#define FF_FS_RPATH		0
/* This option configures support for relative path feature.
/   0: Disable relative path and remove related API functions.
/   1: Enable relative path and dot names. f_chdir() and f_chdrive() are available.
/   2: f_getcwd() is available in addition to 1.
#define FF_PATH_DEPTH	10
/*  This option defines maximum depth of directory in the exFAT volume. It is NOT
/   relevant to FAT/FAT32 volume.
/   For example, FF_PATH_DEPTH = 3 will able to follow a path "/dir1/dir2/dir3/file"
/   but a sub-directory in the dir3 will not able to be followed and set current
/   directory.
/   The size of filesystem object (FATFS) increases FF_PATH_DEPTH * 24 bytes.
/   When FF_FS_EXFAT == 0 or FF_FS_RPATH == 0, this option has no effect.
/ Drive/Volume Configurations
#define FF_VOLUMES		2
/* Number of volumes (logical drives) to be used. (1-10) */
#define FF_STR_VOLUME_ID	0
#define FF_VOLUME_STRS		"SD","SD1","SD2"
/* FF_STR_VOLUME_ID switches support for volume ID in arbitrary strings.
/  When FF_STR_VOLUME_ID is set to 1 or 2, arbitrary strings can be used as drive
/  number in the path name. FF_VOLUME_STRS defines the volume ID strings for each
/  logical drive. Number of items must not be less than FF_VOLUMES. Valid
/  characters for the volume ID strings are A-Z, a-z and 0-9, however, they are
/  compared in case-insensitive. If FF_STR_VOLUME_ID >= 1 and FF_VOLUME_STRS is
/  not defined, a user defined volume string table is needed as:
/  const char* VolumeStr[FF_VOLUMES] = {"ram","flash","sd","usb",...
#define FF_MULTI_PARTITION	1
/* This option switches support for multiple volumes on the physical drive.
/  By default (0), each logical drive number is bound to the same physical drive
/  number and only an FAT volume found on the physical drive will be mounted.
/  When this feature is enabled (1), each logical drive number can be bound to
/  arbitrary physical drive and partition listed in the VolToPart[]. Also f_fdisk()
/  will be available. */
#define FF_MIN_SS		512
#define FF_MAX_SS		512
/* This set of options configures the range of sector size to be supported. (512,
/  1024, 2048 or 4096) Always set both 512 for most systems, generic memory card and
/  harddisk, but a larger value may be required for on-board flash memory and some
/  type of optical media. When FF_MAX_SS is larger than FF_MIN_SS, FatFs is
/  configured for variable sector size mode and disk_ioctl() needs to implement
/  GET_SECTOR_SIZE command. */
#define FF_LBA64		0
/* This option switches support for 64-bit LBA. (0:Disable or 1:Enable)
/  To enable the 64-bit LBA, also exFAT needs to be enabled. (FF_FS_EXFAT == 1) */
#define FF_MIN_GPT		0x10000000
/* Minimum number of sectors to switch GPT as partitioning format in f_mkfs() and
/  f_fdisk(). 2^32 sectors maximum. This option has no effect when FF_LBA64 == 0. */
#define FF_USE_TRIM		0
/* This option switches support for ATA-TRIM. (0:Disable or 1:Enable)
/  To enable this feature, also CTRL_TRIM command should be implemented to
/  the disk_ioctl(). */
/ System Configurations
#define FF_FS_TINY		0
/* This option switches tiny buffer configuration. (0:Normal or 1:Tiny)
/  At the tiny configuration, size of file object (FIL) is reduced FF_MAX_SS bytes.
/  Instead of private sector buffer eliminated from the file object, common sector
/  buffer in the filesystem object (FATFS) is used for the file data transfer. */
#define FF_FS_EXFAT		0
/* This option switches support for exFAT filesystem. (0:Disable or 1:Enable)
/  To enable exFAT, also LFN needs to be enabled. (FF_USE_LFN >= 1)
/  Note that enabling exFAT discards ANSI C (C89) compatibility. */
#define FF_FS_NORTC		0
#define FF_NORTC_MON	1
#define FF_NORTC_MDAY	1
#define FF_NORTC_YEAR	2025
/* The option FF_FS_NORTC switches timestamp feature. If the system does not have
/  an RTC or valid timestamp is not needed, set FF_FS_NORTC = 1 to disable the
/  timestamp feature. Every object modified by FatFs will have a fixed timestamp
/  defined by FF_NORTC_MON, FF_NORTC_MDAY and FF_NORTC_YEAR in local time.
/  To enable timestamp function (FF_FS_NORTC = 0), get_fattime() need to be added
/  to the project to read current time form real-time clock. FF_NORTC_MON,
/  FF_NORTC_MDAY and FF_NORTC_YEAR have no effect.
/  These options have no effect in read-only configuration (FF_FS_READONLY = 1). */
#define FF_FS_CRTIME	0
/* This option enables(1)/disables(0) the timestamp of the file created. When
/  set 1, the file created time is available in FILINFO structure. */
#define FF_FS_NOFSINFO	0
/* If you need to know the correct free space on the FAT32 volume, set bit 0 of
/  this option, and f_getfree() on the first time after volume mount will force
/  a full FAT scan. Bit 1 controls the use of last allocated cluster number.
/  bit0=0: Use free cluster count in the FSINFO if available.
/  bit0=1: Do not trust free cluster count in the FSINFO.
/  bit1=0: Use last allocated cluster number in the FSINFO if available.
/  bit1=1: Do not trust last allocated cluster number in the FSINFO.
#define FF_FS_LOCK		0
/* The option FF_FS_LOCK switches file lock function to control duplicated file open
/  and illegal operation to open objects. This option must be 0 when FF_FS_READONLY
/  is 1.
/  0:  Disable file lock function. To avoid volume corruption, application program
/      should avoid illegal open, remove and rename to the open objects.
/  >0: Enable file lock function. The value defines how many files/sub-directories
/      can be opened simultaneously under file lock control. Note that the file
/      lock control is independent of re-entrancy. */
#define FF_FS_REENTRANT	0
#define FF_FS_TIMEOUT	1000
/* The option FF_FS_REENTRANT switches the re-entrancy (thread safe) of the FatFs
/  module itself. Note that regardless of this option, file access to different
/  volume is always re-entrant and volume control functions, f_mount(), f_mkfs()
/  and f_fdisk(), are always not re-entrant. Only file/directory access to
/  the same volume is under control of this featuer.
/   0: Disable re-entrancy. FF_FS_TIMEOUT have no effect.
/   1: Enable re-entrancy. Also user provided synchronization handlers,
/      ff_mutex_create(), ff_mutex_delete(), ff_mutex_take() and ff_mutex_give(),
/      must be added to the project. Samples are available in ffsystem.c.
/  The FF_FS_TIMEOUT defines timeout period in unit of O/S time tick.
/* Zephyr specific configuration override */
/* The ZEPHYR_CONFIG_OVERRIDE should be given header file name that will contain
/  series of undefs and redefinitions of the FF_ identifiers from the ffconf.h
/  it needs to override
#ifdef ZEPHYR_CONFIG_OVERRIDE
#define FFCONF_STRINGIZE_AGAIN(x) #x
#define FFCONF_STRINGIZE(x) FFCONF_STRINGIZE_AGAIN(x)
#include FFCONF_STRINGIZE(ZEPHYR_CONFIG_OVERRIDE)
#undef FFCONF_STRINGIZE
#undef FFCONF_STRINGIZE_AGAIN
/* End of Zephyr specific configuration override */
/*--- End of configuration options ---*/
Thank you !
