Current version of AssetTracker
Hi
There is a github repo https://github.com/nrfconnect/Asset-Tracker-Template/tree/main that receives updates as of yesterday.
However on the documentation website https://docs.nordicsemi.com/bundle/ncs-2.9.2/page/nrf/applications/asset_tracker_v2/README.html , I read:
Important
The Asset Tracker v2 application is in maintenance mode. For new projects, it is recommended to use the Cellular: nRF Cloud multi-service sample instead..
Could explain what that means ? Why should I use the multi-service sample ? Is the AssetTracker as implemented in the github repo obsolete or is there a difference in functionality ?
Kind regards
Peter
    Hmmmm, it is strange. You should see something like this:
    Can you please retry from scratch and let me know the exact steps you went through ?
    Simon D-M
  • Hi
    I followed the steps in https://github.com/nrfconnect/Asset-Tracker-Template/blob/main/docs/common/getting_started.md
    # Initialize asset-tracker-template workspace
    west init -m github.com/.../Asset-Tracker-Template.git --mr main asset-tracker-template
    cd asset-tracker-template
    # Update nRF Connect SDK modules. This may take a while.
    west update
    Navigate to the application folder:
    1. # Assuming you are in the asset-tracker-template folder
      cd project/app
      west build -p -b nrf9151dk/nrf9151/ns # Pristine build
      west flash --erase # The --erase option is optional and will erase the entire flash memory before programming
      when I press Button 1, I get:
  • I forgot: I use the nRF9151 SMA DK, I also have a ThingyX91 flashed with AssetTracker using nrf Connect for Desktop which shows the expected UI elements (Terminal, ...) . The same is true for the nRF9161 DK flashed also with the nRF Connect for Desktop App. When I try to compile the Asset Tracker Template from Github for the nRF9161 Dk, I get a compile time error.
    The Asset tracker template does not natively support the nRF9161 DK. As for now, it only natively supports the nRF9151 DK / SMA DK and the Thingy:91 X. When using the Thingy, it also collects some more information from the on-board sensors.
    It says that your monthly quota of 1500 location service has already been used. It fails because the Asset Tracker Template uses by default nRF Cloud A-GNSS, which uses "location service tokens". (If you don't know what A-GNSS is, you can learn a more here.)
    Now, you have 3 options in front of you:
    1. You can wait until you have new "location service tokens".
    2. You can upgrade your nRF Cloud plan to one that gives more "location service tokens"
    3. You can use normal GNSS instead of A-GNSS.
    I would recommend you to try the latest one, as you don't have to wait and it is free.
    To do that, you can go in the prj.conf and disable the A-GNSS config "CONFIG_NRF_CLOUD_AGNSS=n". Rebuild the application and flash it and now your device should be using normal GNSS.
    Please tell me if that worked, I wasn't able to test it myself as I don't have access to a limited nRF Cloud account right now.
    If you still don't have the right interface in nRF Cloud, you can try to delete the device and unclaim it. Then reclaim it and run the application again.
    Simon D-M
  • Hi, thank you, unfortunately, it doesn't help. I flashed 3 different nRF9151 SMA DKs in addition to the Thingy91X and the nRF9161 DK.
    The Thingy91x has been flashed with the Asset Tracker from nRf Connect for Desktop, all others with the github version.
    Two of the three nRF9151 SMA DKs show this:
    I have reflashed one with the suggestion you made (disable CONFIG_NRF_CLOUD_AGNSS) but this doesnt help:
    Finally the third nRF9151 SMA DK show this:
    so no terminal , no data but a location !. This was the first one I claimed in nRFCloud. I have unclaimed it then reflashed it ( with the github version) and then reclaimed it.
    No idea why it is rendered differently in nRFCloud.
    Kind regards
    Peter
