How to correctly minimise Ram usage and enable Wifi Scan, WPA2 PSK connection, ping on nRF7002
We are using the nRF7002-DK board. I am using Zephyr samples/net/wifi/shell with no other external connection other than the j2 micro-usb connection to PC and with the following in the prj.conf:
CONFIG_EARLY_CONSOLE=y
CONFIG_NETWORKING=y
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_MAIN_STACK_SIZE=5200
CONFIG_SHELL_STACK_SIZE=5200
CONFIG_NET_TX_STACK_SIZE=2048
CONFIG_NET_RX_STACK_SIZE=2048
CONFIG_NET_PKT_RX_COUNT=10
CONFIG_NET_PKT_TX_COUNT=10
CONFIG_NET_BUF_RX_COUNT=20
CONFIG_NET_BUF_TX_COUNT=20
CONFIG_NET_MAX_CONTEXTS=10
CONFIG_NET_DHCPV4=y
CONFIG_NET_IPV4=y
CONFIG_NET_IPV6=n
CONFIG_NET_TCP=y
CONFIG_NET_LOG=y
CONFIG_INIT_STACKS=y
CONFIG_NET_SHELL=y
CONFIG_NET_STATISTICS=y
CONFIG_NET_STATISTICS_PERIODIC_OUTPUT=n
CONFIG_WIFI=y
CONFIG_WIFI_LOG_LEVEL_ERR=y
CONFIG_NET_L2_WIFI_SHELL=y
# printing of scan results puts pressure on queues in new locking
# design in net_mgmt. So, use a higher timeout for a crowded
# environment.
CONFIG_NET_MGMT_EVENT_QUEUE_TIMEOUT=5000
CONFIG_NET_MGMT_EVENT_QUEUE_SIZE=16
CONFIG_NET_SHELL_IP_SUPPORTED=y
      I was able to run the following:
            wifi scan
            wifi connect      
            net iface
             net ping
Then, it compiled using : west build -p always -b nrf7002dk/nrf5340/cpuapp/nrf7001 samples/net/wifi/shell
Steps:
cd /Users/seb/ncs
rm -rf build/wifi_shell
west build -p always \
  -b nrf7002dk/nrf5340/cpuapp \
  -d build/wifi_shell \
  nrf/samples/wifi/shell
[12/597] Generating include/generated/zephyr/version.h
-- Zephyr version: 4.2.99 (/Users/seb/ncs/zephyr), build: ncs-v3.2.1
[597/597] Linking C executable zephyr/zephyr.elf
Memory region         Used Size  Region Size  %age Used
           FLASH:      769656 B      1008 KB     74.57%
             RAM:      352560 B       448 KB     76.85%
        IDT_LIST:          0 GB        32 KB      0.00%
west flash -d build/wifi_shell
By reducing the stack sizes for Wifi and constantly checking the scan, connect, ping functions, I was able to reduce the RAM used to about 253000 B will some acceptable weird behaviours.
I have also disabled debug
Please advise how can I safely reduce the RAM usage further and yet still be able to perform the 4 mentioned acttivities without issues.
Thank you
