I am using the hardware nrf5340-dk/7002-ek
I compiled the sample project http_server with CONFIG_SHELL option enabled
I connected my board to my wifi network with the wifi command
I used wireshark and I was expecting to see mdns from my board but there is no mdns from my hardware
I even executed the following commands from my PC but I did not get any responsedns-sd -B _services._dns-sd._udp local
dns-sd -B _http._tcp local
and I can ping my device from my PC
I can see in the source code main.cDNS_SD_REGISTER_TCP_SERVICE(http_server_sd, CONFIG_NET_HOSTNAME, "_http", "local",
DNS_SD_EMPTY_TXT, SERVER_PORT);
and here after my prj.conf#
# Copyright (c) 2024 Nordic Semiconductor ASA
# General
CONFIG_LOG=y
CONFIG_ASSERT=y
#CONFIG_MAIN_STACK_SIZE=4096
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_RESET_ON_FATAL_ERROR=n
# LED Control
CONFIG_DK_LIBRARY=y
# Networking config
CONFIG_NETWORKING=y
CONFIG_NET_CONNECTION_MANAGER=y
CONFIG_NET_IPV4=y
CONFIG_NET_IPV6=y
CONFIG_NET_TCP=y
CONFIG_NET_UDP=y
CONFIG_NET_SOCKETS=y
CONFIG_POSIX_API=y
CONFIG_NET_MAX_CONN=10
CONFIG_NET_MAX_CONTEXTS=20
# Network buffers
CONFIG_NET_PKT_RX_COUNT=64
CONFIG_NET_PKT_TX_COUNT=48
CONFIG_NET_BUF_RX_COUNT=96
CONFIG_NET_BUF_TX_COUNT=72
# HTTP
CONFIG_HTTP_PARSER=y
CONFIG_HTTP_PARSER_URL=y
CONFIG_SHELL=y
CONFIG_SHELL_GETOPT=y
CONFIG_DEVICE_SHELL=y
CONFIG_POSIX_TIMERS=y
CONFIG_DATE_SHELL=y
CONFIG_NET_L2_ETHERNET=y
CONFIG_NET_SHELL=y
CONFIG_WIFI=y
CONFIG_WIFI_NRF70=y
# WPA supplicant
CONFIG_WIFI_NM_WPA_SUPPLICANT=y
CONFIG_NET_L2_WIFI_SHELL=y
CONFIG_NET_DHCPV4=y
CONFIG_DNS_RESOLVER=y
CONFIG_NET_STATISTICS=y
CONFIG_NET_STATISTICS_WIFI=y
CONFIG_NET_STATISTICS_USER_API=y
CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=4
CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=5
CONFIG_NET_CONTEXT_SYNC_RECV=y
CONFIG_INIT_STACKS=y
CONFIG_L2_WIFI_CONNECTIVITY=y
CONFIG_L2_WIFI_CONNECTIVITY_AUTO_CONNECT=y
CONFIG_L2_WIFI_CONNECTIVITY_AUTO_DOWN=n
CONFIG_WIFI_CREDENTIALS=y
CONFIG_FLASH=y
#CONFIG_FLASH_PAGE_LAYOUT=y
#CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_NVS=y
# Memories
CONFIG_MAIN_STACK_SIZE=5200
CONFIG_SHELL_STACK_SIZE=5400
CONFIG_NET_TX_STACK_SIZE=4096
CONFIG_NET_RX_STACK_SIZE=4096
CONFIG_NET_CONNECTION_MANAGER_MONITOR_STACK_SIZE=5000
CONFIG_LOG=y
CONFIG_PRINTK=y
CONFIG_STACK_SENTINEL=y
CONFIG_DEBUG_COREDUMP=y
CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN=y
##CONFIG_SHELL_CMDS_RESIZE=n
#CONFIG_DEBUG=y
CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_INF=y
CONFIG_WIFI_LOG_LEVEL_DBG=y
CONFIG_NET_MGMT=y
CONFIG_NET_MGMT_EVENT=y
CONFIG_NET_MGMT_EVENT_INFO=y
CONFIG_NET_MGMT_EVENT_LOG_LEVEL_DBG=y
CONFIG_DATE_TIME=y
CONFIG_DATE_TIME_NTP=y
CONFIG_JSON_LIBRARY=y
# Increase the stack for the HTTP service threads
CONFIG_HTTP_SERVER_SAMPLE_STACK_SIZE=8092
#CONFIG_HTTP_SERVER_SAMPLE_RECEIVE_BUFFER_SIZE=2048
#CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8092
CONFIG_JSON_LIBRARY_FP_SUPPORT=y
CONFIG_LOG_BUFFER_SIZE=4096
CONFIG_MDNS_RESPONDER=y
CONFIG_DNS_SD=y
# Ensure the hostname is actually set
CONFIG_NET_HOSTNAME_ENABLE=y
CONFIG_NET_HOSTNAME="nrf-webserver"
CONFIG_NET_CONFIG_NEED_IPV4=y
CONFIG_NET_IPV4_IGMP=y
CONFIG_NET_L2_WIFI_MGMT=y
# Specifically for mDNS Responder CONFIG_MDNS_RESPONDER_LOG_LEVEL_DBG=y # Specifically for DNS Service Discovery (SD) CONFIG_DNS_SD_LOG_LEVEL_DBG=y
but I did not get any log related to mdns in the serial
